TXC CORPORATION
www.txccorp.com
SPECIFICATION FOR APPROVAL
CN:
1707012433
CUSTOMER
PRODUCT TYPE
SMD SEAM SEALING X'TAL 3.2×2.5
NOMINAL FREQ.
16.000000MHz
TXC P/N
AM16000309
REVISION
S1
CUSTOMER P/N
PM / SALES
DATE
CUSTOMER
CONFIRMATION
(Singnature)
(Date)
(1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance
of the attached specifications.
(2) Orders received and accepted by TXC after return of signed copy of specification will be produced per
these specifications.
(3) Any changes to these specifications must be agreed upon by both parties and new revision of the
Product Specification Sheet will be issued.
(4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets"
from customers will be regarded as the agreement on the contents of these specifications.
MSL:Level 1
RoHS Compliant
(for glass crystal only:Pb used with sealing glass material is exempt from EU directive)
FMT-DOC015 VER.C
TXC confidential and proprietary document
TXC CORPORATION
www.txccorp.com
PRODUCT SPECIFICATION SHEET
CN:
1707012433
PRODUCT TYPE
NOMINAL FREQ.
16.000000MHz
TXC P/N
AM16000309
REVISION
S1
PE/RD
QA
MFG
Wen yuan Chang
20-Jul-17
NOTE:
(1) TXC green product standard is based on the international standards. Relevant
information is posted on the TXC website and updated regularly. The documentation is
subject to the latest green product quality system.
(2) Revision "Sx" is for engineering samples only. PE/RD's approval required.
(3) Revision "Ax" is production ready. PE, QA and MFG's approval required.
MSL:Level 1
RoHS Compliant
FMT-DOC015 VER.C
TXC CORPORATION
Rev
Revise page
S1
N/A
FMT-DOC015 VER.C
TXC P/N:
Revise contents
Initial released
AM16000309
REVISION: S1
PAGE: 1
Date
Ref.No.
Reviser
20-Jul-17
N/A
Xiaohua Zhang
TXC CORPORATION
TXC P/N:
AM16000309
REVISION: S1
PAGE: 2
Spec Sheet Contents
No.
Content
Page
1
ELECTRICAL SPECIFICATIONS
P.3
2
DIMENSIONS
P.4
3
MARKING
P.4
4
FACTORY LOCATION
P.4
5
SUGGESTED REFLOW PROFILE & MANUAL SOLDER CONDITION
P.4
6
STRUCTURE ILLUSTRATION
P.5
7
EMBOSS CARRIER TAPE & REEL
P.6
8
PACKING
P.7
9
RELIABILITY SPECIFICATIONS
P.8
FMT-DOC015 VER.C
TXC CORPORATION
AM16000309
TXC P/N:
REVISION: S1
PAGE: 3
■ ELECTRICAL SPECIFICATIONS
Standard conditions
Ambient temperature :
25±5℃
Relative humidity
40%~70%
In addition to special specifications, are measured in the standard environment.
25±3℃
Relative humidity
40%~70%
If there is any doubt about the result, it is necessary to make measurements in the standard environment.
Measure equipment
Electrical characteristics measured by S&A 250B or equivalent.
Crystal cutting type
The crystal is using AT CUT (thickness shear mode).
Unit Weight:
0.018±0.001 g/pcs
Electrical Spec.
Parameters
SYM.
Notes
MIN
TYPE
MAX
UNITS
FL
16.000000
MHz
Fundamental
CL
8
pF
4 Frequency Tolerance
±15
ppm
at 25 ℃ ± 3 ℃
5 Frequency Stability
±50
ppm
Over Operating Temp. Range (Reference 25℃)
6 Operating Temperature
7 Aging
1 Nominal Frequency
2 Oscillation Mode
3 Load Capacitance
-40
125
±3
ppm
1st Year at 25 ℃ ± 3 ℃
8 Drive Level
DL
10
200
μW
9 Effective Resistance Rr
Rr
60
Ω
10 Shunt Capacitance C0
C0
2
pF
11 Insulation Resistance
500
MΩ
12 Storage Temperature Range
-40
125
FMT-DOC015 VER.C
at DC 100V
TXC CORPORATION
AM16000309
TXC P/N:
■ DIMENSIONS
REVISION: S1
PAGE: 4
Unit:mm
(Unit:mm)
0.70 ± 0.10
3.20 ± 0.10
GND
3
3
4
2.50 ± 0.10
4
1
GND
2
1
2
0.90±0.10
Internal View Connection
1.20±0.10
1.00±0.10
2
4
3
0.80 1.40
0.70±0.10
1.20
0.50
1.20
1
1.40
Bottom View
Suggested Layout
■ MARKING
T□□□
TXC Logo
Frequency Code
ex: 16.000000 MHz = 160
Lot Code
Date Code
Production Control Code
Month Code:
MONTH
YEAR
JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC
2005
2009
2013
2017
2021
A
B
C
D
E
F
G
H
J
K
L
2006
2010
2014
2018
2022
N
P
Q
R
S
T
U
V
W
X
Y
Z
2007
2011
2015
2019
2023
a
b
c
d
e
f
g
h
j
k
l
m
2008
2012
2016
2020
2024
n
p
q
r
s
t
u
v
w
x
y
z
*This month code will be cycled every four years
Production location: Taiwan & China (NGB)
■ SUGGESTED REFLOW PROFILE
10 sec
260
Peak Temperature : 260±5℃, 10 sec. Max.
Solder melting point : 220±10 ℃, 60 sec. Min.
220
180
■ SUGGESTED MANUAL SOLDER CONDITION 150
Temperature: 350 ± 10 ℃
Time: 3 sec.
Re-solder times: twice
Time (sec)
120 sec
60 sec
NOTE: After manual welding, the product shall be measured down to room temperature.
FMT-DOC015 VER.C
M
TXC CORPORATION
TXC P/N:
AM16000309
REVISION: S1
PAGE: 5
■ STRUCTURE ILLUSTRATION
A-A' sectional drawing
B-B' sectional drawing
NO
COMPONENTS
C-C' sectional drawing
MATERIALS
FINISH/SPECIFICATIONS
1 Lid
Kovar (Fe/Co/Ni)
2 Base(Package)
Ceramic (AI2O3) + Kovar (Fe/Co/Ni)+ Ag/Cu
Color black
3 PAD
Au
Tungsten metalize
+ Ni plating
+ Au plating
4 Crystal blank
SiO2
5 Conductive adhesive Ag
Silicon resin
6 Electrode
FMT-DOC015 VER.C
Noble Metal
TXC CORPORATION
AM16000309
TXC P/N:
REVISION: S1
PAGE: 6
■ PACKING
F
G
B
E
H
INDEX MARK
A
DIMENSIONS
REMARK :
C
Feeding
D
A
B
C
D
E
F
G
H
1.65
3.40
2.70
4.00
8.00
4.00
1.50
1.75
160mm min
(UNIT : mm)
160mm min
T
T
T
T
Empty Sealed
3000pcs Products
Trailer
400mm min
Leader
User Direction of Feeding
W
W1
2.0
L1
DIMENSIONS
FMT-DOC015 VER.C
L
L
L1
W
W1
pcs / Reel (UNIT : mm)
178.0
13.0
11.5
8.0
Standard Reel Quantity is 3,000 pcs per reel
TXC CORPORATION
TXC P/N:
AM16000309
REVISION: S1
PAGE: 7
■PACKING
Box Item:
1. Reel X 6
2. Reel X 12
3. Reel X 25
4. Reel X 50
5. Reel X 100
(L200 X W200 X H140mm)
(L200 X W200 X H250mm)
(L400 X W400 X H280mm)
(L399 X W346 X H360mm)
Note:
1. For the maximum reel of loads for each type box.
2. The number of reels is slightly adjusted according to each factory.
Label
Tape
Tape
shipping mark
Customer Information
Label :
[STORAGE]
1.Do not get wet by the rain.
2.The storage environment shall be 5℃ ~40℃ and 30% ~ 75%RH humidity and avoid exposure to sunlight.
3.If customers have special requirements, we can coordinate.
FMT-DOC015 VER.C
TXC CORPORATION
TXC P/N:
AM16000309
REVISION: S1
PAGE: 8
■ RELIABILITY SPECIFICATIONS (AEC-Q200 Compliant)
1.Mechanical Endurance
No.
Test Item
1.1 Drop Test
Test Methods
120 cm height, 10 times on Stainless Plate .
1.2 Mechanical Shock
1.3 Vibration
Device are shocked to half sine wave ( 3000 G ) three mutually
perpendicular axes each 3 times. 0.3m sec. duration time
Frequency range
10 ~ 2000 Hz~10 Hz
Amplitude
1.52 mm/10G
Sweep time
20 minute
REF.DOC
JIS C 6701
MIL-STD-202
Method 213
MIL-STD-202
Method 204
Perpendicular axes each test time 4 Hrs
(Total test time 12 Hrs)
1.4 Solderability
Temperature
245 ℃ ± 5℃
Immersing depth
1.25 mm
Immersion time
5 ± 1 seconds
Flux
Rosin resin methyl alcohol
J-STD-002
solvent ( 1 : 4 )
1.5 Terminal Strength
Mount on PCB board and shear strength 1.8kg for 60 sec.
AEC-Q200-006
1.6 Board Flex
Duration Time: 60 sec, Deviation: 3mm
AEC-Q200-005
2.Environmental Endurance
No.
Test Item
2.1 Resistance To Soldering Heat
Test Methods
Pre-heat temperature
125 ℃
Pre-heat time
60 ~ 120 sec.
Test temperature
260 ± 5 ℃
Test time
10 ± 1 sec.
2.2 High Temp. Storage
+ 125 ℃ ± 3 ℃ for all 1000 Hrs.
2.3 Low Temp. Storage
- 40 ℃ ± 3 ℃ for all 1000 Hrs.
REF. DOC
MIL-STD 202
Method 210
MIL-STD-202
Method 108
JIS C 6701
Total 1000 cycles of the following Thermal Shock :
1 cycle
105 ± 3℃
2.4 Thermal Shock
-55 ± 3℃
2.5 Temperature Cycle
2.6 Biased Humidity
2.7 Moisture Resistance
2.8 Operational Life
FMT-DOC015 VER.C
MIL-STD-202
Method 107
25℃
5 min.
5 min.
20 sec. max.
Total 1000 cycles of the following temperature cycle :
- 40℃ ± 3 to 125℃ ± 3 , Dwell time:15min.
JESD 22
Method JA-104
+ 125℃ ± 3℃ , RH 85% , 1000 Hrs.
MIL-STD-202
Method 103
20 cycles ( +25℃~65℃ , 80%~100% RH) , 24hrs/cycle.
MIL-STD 202
Method 106
+ 125 ℃ ± 3 ℃ for 1000 Hrs.
MIL-STD-202
Method 108
很抱歉,暂时无法提供与“AM16000309”相匹配的价格&库存,您可以联系我们找货
