211PC069S8049
211PC069S8049
    APTIV(安波福)
    胶壳端子 汽车连接器
211PC069S8049 数据手册
VERSION ANONYME A DATEUR ANONYMOUS VERSION DATE INDICATOR F1 INDICE ENSEMBLE MONTE OU INDICE CORPS REVISION LEVEL COUPE A-A REPERE EMPREINTE CAVITY MOLD NUMBER MATIERE CORPS PORTE-CLIPS GROMMET GROMMET FEMALE HOUSING'S MATERIAL PORTE-CLIPS / WIRE ACCORDING TO: GRILLE PORTE-CLIPS 6V MIXTE 3 Sn Pb Cu Mg1 211 CC 3 S 2120 15368841 2.8x0.8 2 Sn Pb Cu Mg1 LEVIER RAMENER DANS LA SECTION 211 CC 3 S 1120 10725666 2.8x0.8 1 Sn Pb Cu Mg1 LEVER TO BRING BACK IN THE SECTION 211 CC 2 S 2120 10726212 1.5x0.8 2 Sn Pb Cu Mg1 211 CC 2 S 1230 10738192 1.5x0.8 1 Au Cu Mg1 211 CC 2 S 1120 10738188 1.5x0.8 1 Sn Pb Cu Mg1 FEMALE CONNECTOR 6W HYBRID GROMMET GROMMET JOINT INTERFACIAL INTERFACE SEAL BOUCHON NO WAFER HINGE OR WAFER HINGE BROKEN ALLOWED 211 M 077 SILICON SILICONE 30 shores BLUE PBT 15% FV PBT 0% FV VERT PBT 0% GF GREEN GAMME REVETEMENT TYPE RANGE MATIERE PLATING MATERIAL 2.20 VUE F1 VIEW F1 5.00 3.33 3.33 PBT 0% FV BLEU PBT 0% GF BLUE 4.15 4.15 VUE F VIEW F VUE F VIEW F GREY 34.90 # 0.10 NOIR BLACK JAUNE 211 M 110 SILICONE SILICON 30 shores GREEN 211 M 077 SILICON SILICONE 30 shores 6 1 6 1 VERT PARTIALLY REPRESENTED SEAL BLUE PBT 0% FV VERT PBT 0% GF GREEN MATIERE COULEUR MATERIAL COLOUR JOINT PARTIELLEMENT REPRESENTE JOINT PARTIELLEMENT REPRESENTE BLEU PARTIALLY REPRESENTED SEAL PC 6 VOIES 1.5 x 0.8 6-WAY 1.5 FEMALE CONNECTOR - - PORTE-CLIPS 6V 1.5 6 WAY 1.5 FEMALE CONNECTOR TYPE VUE FI VIEW F1 GRIS YELLOW REF. MVL CONTACT REF. TERMINAL REF. BLEU PBT 15% GF MVL'S REFERENCE DELPHI VERT PBT 15% FV 210 A 01 5 019 DESCRIPTION VISUAL DEFECTS ON NO FUNCTIONNAL AREAS ALLOWED # 0.25 BROWN GREEN DESIGNATION DEFAUTS D'ASPECT SUR ZONES NON FONCTIONNELLES ADMIS # 0.05 MARRON SILICON SILICONE 30 shores 211 M 4 047 GRID CAP PORTE-CLIPS 6V MIXTE 6 WAY HYBRID FEMALE CONNECTOR 2.8x0.8 1.60 GREEN 211 I 0 031 CHARNIERE DE PLAQUETTE ARRIERE ABSENTE OU CASSEE ADMISE 11 PBT 0% GF 211 M 110 211 I 6 031 FEMALE HOUSING CONDITIONNEMENT SUIVANT NORME: 10 VERT 211 I 8 031 FEMALE CONNECTOR AND CAVITY'S POSITION ACCORDING TO INTERFACE DRAWING: 211FT0289 ET /AND STE 96 339 622 99 9 PBT 0% FV STE: 96 288 230 99 CONNECTEUR ET POSITION ALVEOLE CONFORMES AU PLAN D'INTERFACE: 8 10725665 JAUNE VIOLET PURPLE 210 A 01 5 019 CAP DIAMETRE DE L'ISOLANT DES FILS / WIRE INSULATION DIAMETER Ø1.5 MINI=1.40 MAXI=2.80 Ø2.8 MINI=1.60 MAXI=3.45 MASSE DU CONNECTEUR LIVRE / DELIVERY CONNECTOR WEIGHT: 12g 211 CC 3 S 3120 # 0.30 BOUCHON E73 03 150G Cu Fe 21.60 INTERFACE SEAL PACKAGING ACCORDING TO STANDARD: Sn Pb 16.70 JOINT INTERFACIAL ALVEOLE SUIVANT: 7 1 12.40 GROMMET CONDUCTEUR SUIVANT STE :96 418 794 99 1.5x0.8 + 0.25 - 0.15 4.45 16.50 22.00 LOCKING POSITION 33.50±0.50 POSITION MONTEE 37.50±0.50 4.80 GROMMET -CLASSE DE VIBRATION MOTEUR SELON B217050 REV A PRECONISATION D'UTILISATION: USER'S MANUAL: PU 001 6 10740374 8.60 PBT 15% GF 211 M 7 087 GRID -SEALING CLASS 2 ACCORDING TO B217050 REV A 5 211 CC 2 S 1160 6 GRILLE FEMALE CONNECTOR 6W 1.5 -TEMPERATURE CLASS T3 ACCORDING TO B217050 REV A CAVITY ACCORDING TO Cu Fe 5 PORTE-CLIPS 6V 1.5 -CLASSE ETANCHEITE 2 SELON B217050 REV A 4 Sn Pb YELLOW 211 I 1 067 -ENGINE VIBRATOR CLASS ACCORDING TO B217050 REV A 3 2 4 2 1.5x0.8 3 211 I 5 067 FEMALE CONNECTOR ACCORDING TO PSA SPECIFICATION: -CLASSE DE TEMPERATURE T3 SELON B217050 REV A 10756749 MVL CONNECTEUR DOIT ETRE CONFORME AU CDC: SUIVANT: 211 CC 2 S 2160 INTERFACE SEAL 13.30 FEMALE HOUSING FEMALE CONNECTOR ACCORDING TO: Cu Fe 2 SPECIFICATIONS CONNECTEUR Sn Pb GRID F A 0.05 96 238 404 99 1 1 9.70 # 0.05 PORTE-CLIPS 1 2.8x0.8 JOINT INTERFACIAL 211 I 4 067 NOTE 10726549 GRILLE # 0.25 NOTA 211 CC 3 S 2160 6 32.20 Cu Fe 5 1.10 # 1.20 Sn Pb 4 0.05 2 3 1.00 # # 0.05 2.8x0.8 2.70 1.50 # 0.05 27.63 10726549 2 > PBT < 211 CC 3 S 2 160 1 3 FEMALE HOUSING DELIVERY POSITION X XX POSITION VERROUILLEE PORTE-CLIPS PC 6 VOIES MIXTE 6-WAY HYBRID FEMALE CONNECTOR DELPHI P/N ADDED VUE F VIEW F 6 1 6 1 4.05 6.60 8.20 10.75 6 1 2.45 6 1 6 1 12.35 6.60 12.35 4.05 10.75 6 2.45 GRIS MARRON JAUNE VERT BLACK BLUE GREY BROWN YELLOW GREEN COULEUR 211 PC 06 9S 0 049 211 PC 06 9S 6 049 211 PC 06 9 S 8 211 049 PC 06 2 S 1 049 211 PC 06 2 S 4 049 211 PC 06 2 S 5 049 REF. 10768569 02 10779505 02 C 10768704 02 C 10769031 02 C 10812008 02 - #2° VOIR TABLEAU SEE TABLE 211PL069SX049 8.20 BLEU C #0.1 - NOIR C - #0.10 1 C 33500311 01 REV. REF. REV. REF. REV. REF. REV. DELPHI A2 - COLOUR MVL SEE TABLE 2002-07-23 AT 2013/07/15 F FAURIE 2013/07/15 S LACOTE 2013/07/15 L ETIFIER 211FT0447 6-WAY 1.5*0.8 or HYBRID 211FT0447 6-WAY 1.5*0.8 or HYBRID SERIAL RELEASED FRA-0102 D 1 - 1 See Table - 1:1 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Aptiv: 211PC062S1049 211PC062S4049 211PC069S0049 211PC069S8049 211PC062S1049-B 211PC062S4049-B 211PC069S0049-B 211PC069S6049-B 211PC069S6049 211PC069S8049-B 211CC2S4161 211PC022S6059
211PC069S8049 价格&库存
很抱歉,暂时无法提供与“211PC069S8049”相匹配的价格&库存,您可以联系我们找货
211PC069S8049
    • 1+5.01630
    • 10+4.59119
    • 30+4.50617
    库存:5
