JD2D3-CDL-A
JD2D3-CDL-A
    DIGIINTERNATIONAL
    ADAPTERLOOPBACKMALE/FEMRED
JD2D3-CDL-A 数据手册
LOOP BACK Top View P1 P2 Poly Bag Label Serial Loopback Tester JD2D3-CDL-A www.maxstream.net Bottom View www. maxstream .net Arial font Specifications: Pinout Specification: P1: D-Subminature 9 Female Connector Molded Shell: Steel Tin Plated Insert: Thermoplastic, Black Pin Contacts: Gold flash on mating end P1 P2 2,3 ------ NC 7,8 ------ NC 1,4,6 --- NC P2: D-Subminature 9 Male Connector Molded Shell: Steel Tin Plated Insert: Thermoplastic, Black Pin Contacts: Gold flash on mating end NC ------ 2,3 NC ------ 7,8 NC --- 1,4,6 C1: Cable Specifications Conductors: 6 Conductor Gauge: 28 awg stranded (7x36) Conductor Insulation: PVC Outer Shield: Aluminum/Mylar Foil Adapter Color: Red Special Notes: 1. Refer to shielding specification STDSHLD.dwg. 2. All text inserts and labels must use Arial font 3. Each adapter must be indiviually packaged in a poly bag with label shown above. Poly bag must have "Made in China" printed on the bag DO NOT SCALE DRAWINGS FOR DIMENSIONS Property of: MaxStream, Inc. Orem, Utah, USA ALL DIMENSIONS ARE IN INCHES UNLESS OTHERWISE SPECIFIED Part Description: Date: Serial Loopback Tester, DB9 M-F, Red, JD2D3-CDL-A Drawn By: Scott Yergensen Approved By: Jan Finlinson Part Number: 28 JAN 03 Revision #: 1 JD2D3-CDL-A Drawing Number JD2D3-CDL-A.dwg
JD2D3-CDL-A 价格&库存
很抱歉,暂时无法提供与“JD2D3-CDL-A”相匹配的价格&库存,您可以联系我们找货
