DF40HC(2.5)-60DS-0.4V(51)
    HRS(广濑)
    CONN_14.6X2.94MM_SM
    板对板 间距0.40mm 60Pin(2x30) 母 立贴
DF40HC(2.5)-60DS-0.4V(51) 数据手册
DF40 Series May.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board/FPC-to-Board Connector Product Page https://www.hirose.com/en/product/series/DF40 Apr. 2023 DF40 Series/0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board/FPC-to-Board Connector Features 1. High Density Mounting Space-Saving Space-Saving This is a space- saving design that minimizes connector depth while ensuring an vacuum pick & place area that does not affect mountability. The smallest depth in it' s class : 3. 38mm 18.6mm 2. Wide Stacking Height Variations A wide variety of height variations, 1. 5, 2. 0, 2. 5, 3. 0, 3. 5, 4. 0mm with the space- saving design. 3. High Contact Reliability High Contact Reliability - Effective Mating Length 0.45mm 0. 45mm of world' s largest effective mating length for 1. 5mm mated height. It has a good click feeling which is effective for preventing incomplete mating, and lock design is installed for small No. of pos. with weak mating force to prevent disconnection. 1.5 to 4.0mm Shock Absorbing Ribs 0.45mm May.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF40 5.0mm 3.38mm 80pos, 0.4mm Pitch, 1.5mm Height Conventional Product Locking Design (10 to 50 pos.) 4. Robust Design with Shock Absorbing Ribs Ribs provided on both connectors fit in when mated to absorb stress at impact. 5. Wide Self Alignment Range Guide ribs utilizing dead space ensure 0. 33mm of self- alignment. 2 DF40 Series/0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board/FPC-to-Board Connector 6. Solder Wicking Prevention The receptacle has a nickel barrier and the plug has the insert molded design to prevent soldering. 7. Mated Design Protects Contacts May.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Both connectors contact parts are walled to prevent splashes such as flux from adhering to the contacts. 8. Compliant with RoHS In consideration of environmental issues, we do not use substances prohibited by RoHS Directive. 9. High- Speed Signal Support, Noise Prevention We also have a shielded type that can support high- speed signal and prevent noise. 3 DF40 Series/0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board/FPC-to-Board Connector Stacking Height Variation Standard Type Stacking Height 1.5mm 2.0mm 2.5mm 3.0mm 3.5mm 4.0mm 10 ○ - ○ - - - 12 ○ ○ - - - - 20 ○ ○ ○ - ○ - 24 ○ ○ - - - - 30 ○ ○ ○ ○ ○ - 34 ○ - - - - - 40 ○ ○ ○ ○ ○ - 44 - ○ - ○ - - 50 ○ ○ ○ ○ ○ ○ 60 ○ ○ ○ ○ ○ ○ 70 ○ ○ - ○ - - 80 ○ ○ - ○ ○ ○ 90 ○ - - ○ - ○ 100 ○ - - ○ - - 120 ○ - - - - - May.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. No. of Pos. Shielded Type Stacking Height 1.5mm 3.0mm 3.5mm 10 ○ - - 30 ○ - - 36 - - ○ 48 ○ ○ - 70 - ○ - No. of Pos. 4 DF40 Series/0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board/FPC-to-Board Connector Product Specifications Rated Current 0.3A Operating Temperature (Note 1) -35 to +85℃ Rated Voltage 30V AC, 30V DC Operating Humidity Range 20 to 80% Storage Temperature (Note 2) -10 to +60℃ Storage Humidity Range (Note 2) 40 to 70% May.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Item Specifications Conditions Insulation Resistance 50M Ω Min. Measured at 100V DC Withstanding Voltage No Flashover or Breakdown 100V AC for 1 min. Contact Resistance 90m Ω Max. Measured at 20 m V AC, 1kHz, 1mA Vibration Resistance No electrical discontinuity of 1μ s or more. Frequency 10 to 55Hz, single amplitude of 0.75mm, 2 hours each of 3-axis direction Moisture Resistance Contact Resistance : 90m Ω Max. Insulation Resistance : 25M Ω Min. Temperature : 40 ± 2℃ , Humidity : 90 to 95%, Left for 96 hours Temperature Cycles Contact Resistance : 90m Ω Max. Insulation Resistance : 50M Ω Min. (-55℃ : 30 min. → +5 to +35℃ : 10 min. → +85℃ : 30 min. → +5 to +35℃ : 10 min.) 5 cycles Mating Durability Contact Resistance : 90m Ω Max. 30 times Solder Heat Resistance No dissolution or resin melting that will affect performance. Reflow : According to the Recommended Temperature Profile Hand Soldering : 350℃ within 3 sec. Note 1 : Includes temperature rise caused by current flow. Note 2 : Storage refers to the long-term storage condition for unused products before the board mounting. Operating temperature and humidity range apply when the product is not powered after PCB mounting and when temporarily stored during transportation. Materials / Finish Standard, Non Shielded Type Product Receptacle Plug Component Material Color / Finish Housing LCP Black Contact Phosphorous Bronze Gold Plating Housing LCP Black Contact Phosphorous Bronze Gold Plating Remarks UL94V-0 UL94V-0 - Shielded Type Product Component Housing Receptacle Contact Shield Housing Plug Contact Retention Tab Material Color / Finish LCP Black Phosphorous Bronze Gold Plating LCP Black Phosphorous Bronze Gold Plating 5 Remarks UL94V-0 UL94V-0 - DF40 Series/0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board/FPC-to-Board Connector Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ■ Standard, Non Shielded Type ● Receptacle DF40 # - (##) - # DS - 0.4 V (##) May.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❶ ❷ ❸ ❶ Series Name ❷ Shape Symbol ❸ Stacking Height ❹ No. of Pos. ❹ ❺ ❻ ❼ ❽ ❺ Connector Type DS : Double Row Receptacle ❻ Contact Pitch 0.4mm None : 1.5mm 2.0 : 2.0mm 2.5 : 2.5mm 3.0 : 3.0mm 3.5 : 3.5mm 4.0 : 4.0mm ❼ Contact Type V : Straight SMT 10, 12, 20, 24, 30, 34, 36, 40, 44, 48, 50, 60, 70, 80, 90, 100, 120 ❽ Packaging Type (51) : Embossed Packaging (58) : Embossed Packaging DF40 B : Retention Tab HB : Retention Tab (Stacking Height 2.5mm Min.) C : No Retention Tab HC : No Retention Tab (Stacking Height 2.5mm Min.) ● Plug DF40 # - # DP - 0.4 V (##) ❶ ❷ ❸ ❹ ❺ ❻ ❼ ❶ Series Name DF40 ❺ Contact Pitch 0.4mm ❷ Shape Symbol C : No Retention Tab ❻ Contact Type V : Straight SMT ❸ No. of Pos. 10, 12, 20, 24, 30, 34, 36, 40, 44, 48, 50, 60, 70, 80, 90, 100, 120 ❼ Packaging Type (51) : Embossed Packaging (58) : Embossed Packaging ❹ Connector Type DP : Double Row Pin Plug 6 DF40 Series/0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board/FPC-to-Board Connector ■ Shielded Type ● Receptacle DF40 GB - (##) - # DS - 0.4 V (##) May.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❶ ❷ ❸ ❹ ❺ ❻ ❼ ❽ ❶ Series Name DF40 ❺ Connector Type DS : Double Row Receptacle ❷ Shape Symbol GB : With Shield ❻ Contact Pitch 0.4mm ❸ Stacking Height 1.5 : 1.5mm 3.0 : 3.0mm ❼ Contact Type V : Straight SMT ❹ No. of Pos. 10, 30, 36, 48, 70 ❽ Packaging Type (51) : Embossed Packaging (58) : Embossed Packaging ● Plug DF40 GB - # DP - 0.4 V (##) ❶ ❷ ❸ ❹ ❺ ❻ ❼ ❶ Series Name DF40 ❺ Contact Pitch 0.4mm ❷ Shape Symbol GB : Retention Tab (For Shielded Type) ❻ Contact Type V : Straight SMT ❸ No. of Pos. 10, 30, 36, 48, 70 ❼ Packaging Type (51) : Embossed Packaging (58) : Embossed Packaging ❹ Connector Type DP : Double Row Pin Plug 7 DF40 Series/0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board/FPC-to-Board Connector Receptacle Stacking Height 1.5mm A±0.2 B±0.08 3.38±0.2 2.88±0.2 P=0.4±0.05 0.12±0.02 Recommended PCB Pattern 1.2±0.02 B±0.02 B±0.02 P=0.4±0.02 0 0 2.38 -0.05 1.5 Max. 3.78 +0.05 0 2.38 -0.05 1.5 Max. P=0.4±0.02 3.78 +0.05 0 May.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. D±0.15 Vacuum Pick & Place Area : C±0.2 0.2±0.02 0.2±0.02 DF40C (No Retention Tab) DF40B (Retention Tab) Unit : mm Part No. HRS No. No. of Pos. A B C D Purchase Unit (##):(51) Purchase Unit (##):(58) ○ ○ ○ ○ ○ ○ ○ - ○ - ○ - DF40B-10DS-0.4V(##) CL0684-4038-8-## 10 4.6 1.6 DF40B-12DS-0.4V(##) CL0684-4152-3-## 12 5.0 2.0 DF40B-30DS-0.4V(##) CL0684-4090-8-## 30 8.6 5.6 DF40B-50DS-0.4V(##) CL0684-4018-0-## 50 12.6 9.6 DF40B-60DS-0.4V(##) CL0684-4049-4-## 60 14.6 11.6 DF40B-80DS-0.4V(##) CL0684-4052-9-## 80 18.6 15.6 DF40C-20DS-0.4V(##) CL0684-4005-9-## 20 6.6 3.6 1.2 ○ ○ DF40C-24DS-0.4V(##) CL0684-4006-1-## 24 7.4 4.4 1.5 ○ ○ DF40C-30DS-0.4V(##) CL0684-4007-4-## 30 8.6 5.6 2.3 ○ ○ DF40C-34DS-0.4V(##) CL0684-4023-0-## 34 9.4 6.4 ○ ○ DF40C-40DS-0.4V(##) CL0684-4008-7-## 40 10.6 7.6 ○ ○ DF40C-50DS-0.4V(##) CL0684-4009-0-## 50 12.6 9.6 ○ ○ DF40C-60DS-0.4V(##) CL0684-4004-6-## 60 14.6 11.6 ○ ○ DF40C-70DS-0.4V(##) CL0684-4016-5-## 70 16.6 13.6 ○ ○ DF40C-80DS-0.4V(##) CL0684-4002-0-## 80 18.6 15.6 ○ ○ DF40C-90DS-0.4V(##) CL0684-4124-8-## 90 20.6 17.6 ○ ○ DF40C-100DS-0.4V(##) CL0684-4033-4-## 100 22.6 19.6 ○ ○ DF40C-120DS-0.4V(##) CL0684-4108-1-## 120 26.6 23.6 ○ - 【Specification Number】 (51) : Embossed Packaging (5,000pcs per reel) (58) : Embossed Packaging (1,000pcs per reel) Note Note Note Note 1 2 3 4 : Please order embossed tape packaged items by the reel. : The 60 pos. or more have recesses on the suction surface that do not affect suction. : is insulation area. : This connector has no polarity. 8 1.0 1.5 3.2 3.2 1.45 DF40 Series/0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board/FPC-to-Board Connector Stacking Height 2.0mm A±0.2 B±0.08 3.38±0.2 2.94±0.2 P=0.4±0.05 0.12±0.02 D±0.15 Vacuum Pick & Place Area : C±0.2 1.2±0.02 B±0.02 B±0.02 P=0.4±0.02 0 2.38 -0.05 1.5 Max. 3.78 +0.05 0 0 2.38 -0.05 1.5 Max. P=0.4±0.02 3.78 +0.05 0 May.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Recommended PCB Pattern 0.2±0.02 0.2±0.02 DF40C (No Retention Tab) DF40B (Retention Tab) Unit : mm Part No. HRS No. No. of Pos. A B C D Purchase Unit (##):(51) Purchase Unit (##):(58) DF40B(2.0)-12DS-0.4V(##) CL0684-4150-8-## 12 5.0 2.0 1.0 ○ ○ DF40B(2.0)-80DS-0.4V(##) CL0684-4128-9-## 80 18.6 15.6 3.2 ○ - DF40C(2.0)-20DS-0.4V(##) CL0684-4040-0-## 20 6.6 3.6 1.0 ○ ○ DF40C(2.0)-24DS-0.4V(##) CL0684-4041-2-## 24 7.4 4.4 1.2 ○ ○ DF40C(2.0)-30DS-0.4V(##) CL0684-4058-5-## 30 8.6 5.6 1.5 ○ ○ DF40C(2.0)-40DS-0.4V(##) CL0684-4042-5-## 40 10.6 7.6 ○ ○ DF40C(2.0)-50DS-0.4V(##) CL0684-4091-0-## 50 12.6 9.6 ○ ○ DF40C(2.0)-60DS-0.4V(##) CL0684-4034-7-## 60 14.6 11.6 ○ ○ DF40C(2.0)-70DS-0.4V(##) CL0684-4147-3-## 70 16.6 13.6 ○ ○ DF40C(2.0)-80DS-0.4V(##) CL0684-4132-6-## 80 18.6 15.6 ○ ○ 【Specification Number】 (51) : Embossed Packaging (4,000pcs per reel) (58) : Embossed Packaging (1,000pcs per reel) Note Note Note Note 1 2 3 4 : Please order embossed tape packaged items by the reel. : The 60 pos. or more have recesses on the suction surface that do not affect suction. : is insulation area. : This connector has no polarity. 9 3.2 1.95 DF40 Series/0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board/FPC-to-Board Connector Stacking Height 2.5 to 4.0mm A±0.2 B±0.08 3.38±0.2 2.94±0.2 P=0.4±0.05 0.12±0.02 D±0.15 Vacuum Pick & Place Area : C±0.2 1.2±0.02 B±0.02 B±0.02 P=0.4±0.02 0 2.38 -0.05 1.5 Max. 3.78 +0.05 0 0 2.38 -0.05 0.92 Max. P=0.4±0.02 3.78 +0.05 0 May.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Recommended PCB Pattern 0.2±0.02 0.2±0.02 DF40HC (No Retention Tab) DF40HB (Retention Tab) Stacking Height 2.5mm Unit : mm Part No. HRS No. No. of Pos. A B DF40HB(2.5)-10DS-0.4V(##) CL0684-4189-3-## 10 4.6 1.6 DF40HC(2.5)-20DS-0.4V(##) CL0684-4126-3-## 20 6.6 3.6 DF40HC(2.5)-30DS-0.4V(##) CL0684-4127-6-## 30 8.6 5.6 DF40HC(2.5)-40DS-0.4V(##) CL0684-4112-9-## 40 10.6 7.6 DF40HC(2.5)-50DS-0.4V(##) CL0684-4101-2-## 50 12.6 9.6 DF40HC(2.5)-60DS-0.4V(##) CL0684-4085-8-## 60 14.6 11.6 C D 1.0 1.5 2.4 3.2 Purchase Unit (##):(51) Purchase Unit (##):(58) 〇 - 〇 〇 〇 - 〇 〇 〇 〇 〇 〇 Purchase Unit (##):(51) Purchase Unit (##):(58) 〇 〇 【Specification Nmber】 (51) : Embossed Packaging (3,000pcs per reel) (58) : Embossed Packaging (1,000pcs per reel) Stacking Height 3.0mm Unit : mm Part No. HRS No. No. of Pos. A B C 1.5 D DF40HC(3.0)-30DS-0.4V(##) CL0684-4098-0-## 30 8.6 5.6 DF40HC(3.0)-40DS-0.4V(##) CL0684-4169-6-## 40 10.6 7.6 〇 - DF40HC(3.0)-44DS-0.4V(##) CL0684-4076-7-## 44 11.4 8.4 〇 〇 DF40HC(3.0)-50DS-0.4V(##) CL0684-4099-2-## 50 12.6 9.6 〇 〇 DF40HC(3.0)-60DS-0.4V(##) CL0684-4100-0-## 60 14.6 11.6 〇 〇 DF40HC(3.0)-70DS-0.4V(##) CL0684-4138-2-## 70 16.6 13.6 〇 〇 DF40HC(3.0)-80DS-0.4V(##) CL0684-4180-9-## 80 18.6 15.6 〇 〇 DF40HC(3.0)-90DS-0.4V(##) CL0684-4161-4-## 90 20.6 17.6 〇 〇 DF40HC(3.0)-100DS-0.4V(##) CL0684-4151-0-## 100 22.6 19.6 〇 〇 【Specification Nmber】 (51) : Embossed Packaging (3,000pcs per reel) (58) : Embossed Packaging (1,000pcs per reel) 10 3.2 2.9 DF40 Series/0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board/FPC-to-Board Connector Stacking Height 3.5mm Unit : mm Part No. HRS No. No. of Pos. A B C D Purchase Unit (##):(51) Purchase Unit (##):(58) DF40HC(3.5)-20DS-0.4V(##) CL0684-4188-0-## 20 6.6 3.6 1.0 〇 - DF40HC(3.5)-30DS-0.4V(##) CL0684-4136-7-## 30 8.6 5.6 1.5 〇 〇 DF40HC(3.5)-40DS-0.4V(##) CL0684-4209-9-## 40 10.6 7.6 〇 - DF40HC(3.5)-50DS-0.4V(##) CL0684-4109-4-## 50 12.6 9.6 〇 〇 DF40HC(3.5)-60DS-0.4V(##) CL0684-4102-5-## 60 14.6 11.6 〇 〇 DF40HC(3.5)-80DS-0.4V(##) CL0684-4162-7-## 80 18.6 15.6 〇 〇 Purchase Unit (##):(51) Purchase Unit (##):(58) 3.4 3.2 May.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 【Specification Nmber】 (51) : Embossed Packaging (2,000pcs per reel) (58) : Embossed Packaging (1,000pcs per reel) Stacking Height 4.0mm Unit : mm Part No. HRS No. No. of Pos. A B C D DF40HB(4.0)-50DS-0.4V(##) CL0684-4104-0-## 50 12.6 9.6 〇 ー DF40HC(4.0)-40DS-0.4V(##) CL0684-4111-6-## 40 10.6 7.6 〇 ー DF40HC(4.0)-50DS-0.4V(##) CL0684-4215-1-## 50 12.6 9.6 〇 ー DF40HC(4.0)-60DS-0.4V(##) CL0684-4133-9-## 60 14.6 11.6 〇 〇 DF40HC(4.0)-80DS-0.4V(##) CL0684-4140-4-## 80 18.6 15.6 〇 〇 DF40HC(4.0)-90DS-0.4V(##) CL0684-4165-5-## 90 20.6 17.6 〇 〇 【Specification Nmber】 (51) : Embossed Packaging (2,000pcs per reel) (58) : Embossed Packaging (1,000pcs per reel) Note Note Note Note 1 2 3 4 : Please order embossed tape packaged items by the reel. : The 60 pos. or more have recesses on the suction surface that do not affect suction. : is insulation area. : This connector has no polarity. 11 3.2 3.9 DF40 Series/0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board/FPC-to-Board Connector Receptacle (With Shield) Stacking Height 1.5mm (With Shield) 3.38±0.3 8.64±0.3 6.48±0.1 5.6±0.08 P=0.4±0.05 Vacuum Pick & Place Area : 1.5±0.2 1.45±0.15 3.12±0.2 3.38±0.3 12.24±0.3 10.08±0.1 9.2±0.08 P=0.4±0.05 3.2±0.08 0.12±0.02 0.2±0.02 0.12±0.02 Vacuum Pick & Place Area : 3.2±0.2 1.45±0.15 3.12±0.2 Recommended PCB Pattern 0.6±0.02 4.08 0.2±0.02 +0.05 0 +0.05 0 0 2.38 -0.05 1.5 Max. +0.05 0 4.08 3.78 +0.05 0 0 -0.05 2.64 0 -0.05 3.78 +0.05 0 1.5 Max. 0.28±0.02 0.2±0.02 0.6±0.02 4.08 10.08 ±0.02 9.2±0.02 3.2±0.02 P=0.4±0.02 0.6±0.02 0 -0.05 6.48 ±0.02 5.6 ±0.02 P=0.4±0.02 2.64 2.38 May.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.2±0.02 0.12±0.02 0.28±0.02 Unit : mm Part No. HRS No. No. of Pos. Signal PIN Ground PIN Purchase Unit (##):(51) Purchase Unit (##):(58) DF40GB(1.5)-10DS-0.4V(##) CL0684-4224-2-## 10 10 4 〇 〇 DF40GB(1.5)-30DS-0.4V(##) CL0684-4198-4-## 30 30 4 〇 〇 DF40GB(1.5)-48DS-0.4V(##) CL0684-4194-3-## 48 40 12 〇 〇 【Specification Nmber】 (51) : Embossed Packaging (5,000pcs per reel) (58) : Embossed Packaging (1,000pcs per reel) Note 1 : Please order embossed tape packaged items by the reel. Note 2 : is insulation area. Note 3 : This connector has no polarity. 12 DF40 Series/0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board/FPC-to-Board Connector Stacking Height 3.0 to 3.5mm (With Shield) 3.38±0.3 12.24±0.3 10.08±0.1 9.2±0.08 P=0.4±0.05 3.2±0.08 0.12±0.02 0.2±0.02 Vacuum Pick & Place Area : 3.2±0.2 16.64±0.3 13.6±0.08 9.2±0.08 3.6±0.08 3.38±0.3 3.38±0.2 3.68±0.2 P=0.4±0.05 0.2±0.02 0.12±0.02 0.12±0.05 Vacuum Pick & Place Area : 3.2±0.2 2.9±0.15 3.12±0.2 Recommended PCB Pattern 0.2±0.02 0.6±0.02 0.2±0.02 0.6±0.02 0.6±0.02 0.6±0.02 Stacking Height 3.0mm +0.05 0 4.08 1.5 Max. +0.05 0 4.08 4.08 +0.05 0 3.78 +0.05 0 0 2.38 -0.05 0 -0.05 2.64 0.28±0.02 0 -0.05 14.48±0.02 13.6±0.02 9.2±0.02 3.6±0.02 P=0.4±0.02 0.6±0.02 1.5 Max. +0.05 0 0 -0.05 2.38 +0.05 0 3.78 10.08±0.02 9.2±0.02 3.2±0.02 P=0.4±0.02 0.6±0.02 2.64 4.08 May.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2.9±0.15 3.12±0.2 0.28±0.02 Unit : mm Part No. HRS No. No. of Pos. Signal PIN Ground PIN Purchase Unit (##):(51) Purchase Unit (##):(58) DF40GB(3.0)-48DS-0.4V(##) CL0684-4197-1-## 48 40 12 〇 〇 DF40GB(3.0)-70DS-0.4V(##) CL0684-4196-9-## 70 54 20 〇 〇 Purchase Unit (##):(58) ー Stacking Height 3.5mm Unit : mm Part No. DF40GB(3.5)-36DS-0.4V(##) HRS No. CL0684-4231-0-## No. of Pos. Signal PIN Ground PIN Purchase Unit (##):(51) 36 36 4 〇 【Specification Nmber】 (51) : Embossed Packaging (3,000pcs per reel) (58) : Embossed Packaging (1,000pcs per reel) Note Note Note Note 1 2 3 4 : Please order embossed tape packaged items by the reel. : The 70 pos. or more have recesses on the suction surface that do not affect suction. : is insulation area. : This connector has no polarity. 13 DF40 Series/0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board/FPC-to-Board Connector Plug A±0.2 B±0.08 1.85±0.2 2.97±0.2 P=0.4±0.05 1.14±0.15 0.15±0.02 Recommended PCB Pattern B±0.02 0.65±0.02 +0.05 0 0 -0.05 2.05 P=0.4±0.02 3.37 May.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Vacuum Pick & Place Area : C±0.2 0.3±0.02 0.35±0.02 0.23±0.02 Unit : mm Part No. HRS No. No. of Pos. A B C Purchase Unit (##):(51) Purchase Unit (##):(58) 〇 〇 〇 〇 〇 〇 DF40C-10DP-0.4V(##) CL0684-4035-0-## 10 3.52 1.6 DF40C-12DP-0.4V(##) CL0684-4149-9-## 12 3.92 2.0 DF40C-20DP-0.4V(##) CL0684-4010-9-## 20 5.52 3.6 DF40C-24DP-0.4V(##) CL0684-4011-1-## 24 6.32 4.4 1.2 〇 〇 DF40C-30DP-0.4V(##) CL0684-4012-4-## 30 7.52 5.6 1.5 〇 〇 DF40C-34DP-0.4V(##) CL0684-4024-3-## 34 8.32 6.4 2.3 〇 〇 DF40C-40DP-0.4V(##) CL0684-4013-7-## 40 9.52 7.6 〇 〇 DF40C-44DP-0.4V(##) CL0684-4077-0-## 44 10.32 8.4 〇 〇 DF40C-50DP-0.4V(##) CL0684-4014-0-## 50 11.52 9.6 〇 〇 DF40C-60DP-0.4V(##) CL0684-4003-3-## 60 13.52 11.6 〇 〇 DF40C-70DP-0.4V(##) CL0684-4015-2-## 70 15.52 13.6 〇 〇 DF40C-80DP-0.4V(##) CL0684-4001-8-## 80 17.52 15.6 〇 〇 DF40C-90DP-0.4V(##) CL0684-4125-0-## 90 19.52 17.6 〇 〇 DF40C-100DP-0.4V(##) CL0684-4032-1-## 100 21.52 19.6 〇 〇 DF40C-120DP-0.4V(##) CL0684-4107-9-## 120 25.52 23.6 〇 - 【Specification Nmber】 (51) : Embossed Packaging (5,000pcs per reel) (58) : Embossed Packaging (1,000pcs per reel) Note Note Note Note Note 1 2 3 4 5 : : : : : Please order embossed tape packaged items by the reel. There are no concave areas on plug side contact part to increase the mating strength for 60 pos. or more. Use the 4 corner contact as a retention tab. It will not be energized. The 90 pos. or more have recesses on the suction surface that do not affect suction. This connector has no polarity. 14 1.0 3.2 DF40 Series/0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board/FPC-to-Board Connector Plug (With Shield) A±0.3 B±0.1 C±0.08 2.97±0.2 2.02±0.2 1.85±0.2 P=0.4±0.05 0.15±0.02 1.52±0.2 Recommended PCB Pattern D + 00.05 0 E -0.05 B±0.02 0 F-0.05 C±0.02 0 1.88 -0.05 0 1.02 -0.05 0 2.05 -0.05 0.23±0.02 3.32 +0.05 0 0.35±0.02 2.42 +0.05 0 P=0.4±0.02 3.37 + 00.05 May.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.08±0.02 1.14±0.15 Vacuum Pick & Place Area : C±0.2 Unit : mm Purchase Purchase Unit Unit (##):(51) (##):(58) Part No. HRS No. No. of Pos. A B C D E F G DF40GB-10DP-0.4V(##) CL0684-4225-5-## 10 3.16 2.67 1.6 4.74 3.32 2.12 1.0 〇 〇 DF40GB-30DP-0.4V(##) CL0684-4200-4-## 30 7.16 6.67 5.6 8.74 7.32 6.12 1.5 〇 〇 DF40GB-36DP-0.4V(##) CL0684-4232-0-## 36 8.36 7.87 6.8 9.94 8.52 7.32 2.3 〇 ー DF40GB-48DP-0.4V(##) CL0684-4195-6-## 48 10.76 10.27 9.2 12.34 10.92 9.72 〇 〇 DF40GB-70DP-0.4V(##) CL0684-4199-7-## 70 15.16 14.67 13.6 16.74 15.32 14.12 〇 〇 【Specification Nmber】 (51) : Embossed Packaging (5,000pcs per reel) (58) : Embossed Packaging (1,000pcs per reel) Note Note Note Note 1 2 3 4 : Please order embossed tape packaged items by the reel. : There are no concave areas on plug side contact part to increase the mating strength for 60 pos. or more. : is insulation area. : This connector has no polarity. 15 3.2 DF40 Series/0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board/FPC-to-Board Connector Packaging Specifications Diagram (JIS C 0806 Compliant) Receptacle (Stacking Height 1.5mm)   ●Reel Dimensions ●Embossed Tape Dimensions Label ° φ1.5 Feed Hole Back May.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ° Unreeling Direction Stacking Height 1.5mm Part No. DF40B-10DS-0.4V(##) DF40B-12DS-0.4V(##) Unit : mm A 16 DF40B-30DS-0.4V(##) DF40B-50DS-0.4V(##) B C D E 7.5 21.5 17.5 11.5 29.5 25.5 14.2 37.5 33.5 7.5 21.5 17.5 11.5 29.5 25.5 24 DF40B-60DS-0.4V(##) DF40B-80DS-0.4V(##) DF40C-20DS-0.4V(##) DF40C-24DS-0.4V(##) 32 28.4 16 DF40C-30DS-0.4V(##) DF40C-34DS-0.4V(##) DF40C-40DS-0.4V(##) 24 DF40C-50DS-0.4V(##) DF40C-60DS-0.4V(##) DF40C-70DS-0.4V(##) DF40C-80DS-0.4V(##) 32 28.4 14.2 37.5 33.5 44 40.4 20.2 49.5 45.5 24 - 11.5 29.5 25.5 DF40C-90DS-0.4V(##) DF40C-100DS-0.4V(##) DF40C-120DS-0.4V(##) DF40GB(1.5)-30DS-0.4V(##) DF40GB(1.5)-48DS-0.4V(##) Note : The hole of the carrier tape for 10 to 60pos. is only one side. 16 DF40 Series/0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board/FPC-to-Board Connector Receptacle (Stacking Height 2.0 to 2.5mm)  ●Embossed Tape Dimensions   ●Reel Dimensions Label ° φ1.5 Feed Hole Back May.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ° Unreeling Direction Stacking Height 2.0mm Part No. Unit : mm A B C D E DF40B(2.0)-12DS-0.4V(##) 16 - 7.5 21.5 17.5 DF40B(2.0)-80DS-0.4V(##) 32 28.4 14.2 37.5 33.5 7.5 21.5 17.5 DF40C(2.0)-20DS-0.4V(##) DF40C(2.0)-24DS-0.4V(##) 16 DF40C(2.0)-30DS-0.4V(##) DF40C(2.0)-40DS-0.4V(##) DF40C(2.0)-50DS-0.4V(##) - F 2.2 24 11.5 29.5 25.5 28.4 14.2 37.5 33.5 B C D E 7.5 21.5 17.5 DF40C(2.0)-60DS-0.4V(##) DF40C(2.0)-70DS-0.4V(##) DF40C(2.0)-80DS-0.4V(##) 32 Stacking Height 2.5mm Part No. DF40HB(2.5)-10DS-0.4V(##) DF40HC(2.5)-20DS-0.4V(##) Unit : mm A 16 DF40HC(2.5)-30DS-0.4V(##) DF40HC(2.5)-40DS-0.4V(##) DF40HC(2.5)-50DS-0.4V(##) 24 2.72 11.5 DF40HC(2.5)-60DS-0.4V(##) Note : The hole of the carrier tape for 10 to 60pos. is only one side. 17 F 29.5 25.5 DF40 Series/0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board/FPC-to-Board Connector Receptacle (Stacking Height 3.0 to 4.0mm)  ●Embossed Tape Dimensions   ●Reel Dimensions Label ° φ1.5 Feed Hole Back May.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ° Unreeling Direction Stacking Height 3.0mm Part No. Unit : mm A B C D E 24 - 11.5 29.5 25.5 32 28.4 14.2 37.5 33.5 44 40.4 20.2 49.5 45.5 DF40GB(3.0)-48DS-0.4V(##) 24 - 11.5 29.5 25.5 DF40GB(3.0)-70DS-0.4V(##) 32 28.4 14.2 37.5 33.5 F DF40HC(3.0)-30DS-0.4V(##) DF40HC(3.0)-40DS-0.4V(##) DF40HC(3.0)-44DS-0.4V(##) DF40HC(3.0)-50DS-0.4V(##) DF40HC(3.0)-60DS-0.4V(##) DF40HC(3.0)-70DS-0.4V(##) DF40HC(3.0)-80DS-0.4V(##) DF40HC(3.0)-90DS-0.4V(##) DF40HC(3.0)-100DS-0.4V(##) Stacking Height 3.5mm Part No. DF40HC(3.5)-20DS-0.4V(##) 3.15 Unit : mm A B 16 C D E 7.5 21.5 17.5 11.5 29.5 25.5 14.2 37.5 33.5 F DF40HC(3.5)-30DS-0.4V(##) DF40HC(3.5)-40DS-0.4V(##) DF40HC(3.5)-50DS-0.4V(##) - 24 DF40HC(3.5)-60DS-0.4V(##) DF40HC(3.5)-80DS-0.4V(##) 32 28.4 18 3.72 DF40 Series/0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board/FPC-to-Board Connector Stacking Height 4.0mm Part No. Unit : mm A B C D E 24 - 11.5 29.5 25.5 F DF40HB(4.0)-50DS-0.4V(##) DF40HC(4.0)-40DS-0.4V(##) DF40HC(4.0)-50DS-0.4V(##) 4.15 DF40HC(4.0)-60DS-0.4V(##) 32 28.4 14.2 37.5 33.5 DF40HC(4.0)-90DS-0.4V(##) 44 40.4 20.2 49.5 45.5 May.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF40HC(4.0)-80DS-0.4V(##) 19 DF40 Series/0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board/FPC-to-Board Connector Plug   ●Embossed Tape Dimensions   ●Reel Dimensions Label ° φ1.5 Feed Hole Back May.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ° Unreeling Direction Unit : mm Part No. DF40C-10DP-0.4V(##) DF40C-12DP-0.4V(##) A B C D E 12 5.5 17.5 13.5 16 7.5 21.5 17.5 11.5 29.5 25.5 DF40C-20DP-0.4V(##) DF40C-24DP-0.4V(##) DF40C-30DP-0.4V(##) - DF40C-34DP-0.4V(##) DF40C-40DP-0.4V(##) DF40C-44DP-0.4V(##) 24 DF40C-50DP-0.4V(##) DF40C-60DP-0.4V(##) DF40C-70DP-0.4V(##) DF40C-80DP-0.4V(##) 32 28.4 14.2 37.5 33.5 44 40.4 20.2 49.5 45.5 DF40C-90DP-0.4V(##) DF40C-100DP-0.4V(##) DF40C-120DP-0.4V(##) DF40GB-10DP-0.4V(##) 12 5.5 17.5 13.5 DF40GB-30DP-0.4V(##) 16 7.5 21.5 17.5 11.5 29.5 25.5 DF40GB-36DP-0.4V(##) DF40GB-48DP-0.4V(##) 24 DF40GB-70DP-0.4V(##) Note : The hole of the carrier tape for 10 to 60pos. is only one side. 20 DF40 Series/0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board/FPC-to-Board Connector Precautions Temperature(℃) 250 250℃ 【Conditions】 220℃ 1. Peak Temperature : 250℃ 200 2. Heating : 220℃ Min. for 60 sec. Max. 60sec. Max. 3. Preheating : 150 to 180℃, 90 to 120 sec. 180℃ 4. Number of Reflow Cycles : 2 cycles Max. May.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Recommended Temperature Profile 150 150℃ * Temperature refers to the surface temperature of the board near the connector lead. We recommend reflow mounting in a nitrogen environment. 90 to 120sec. 100 50 Normal Temperature 0 50 100 150 200 250 300 Heating Time (sec.) Recommended Manual Soldering Conditions Soldering iron temperature : 340 ± 10℃ , Soldering Time : Within 3 sec. Recommended Metal Mask Thickness and Open Area to PCB Pattern (Area Ratio) Thickness : 0.12mm, Aperture Ratio : DS 80% DP 80% Board Warpage Max. of 0.02mm at the center in reference to both ends of the connector Cleaning Cleaning is not recommended. If you clean this product, please evaluate its performance before using it. (Cleaning may impair the mating/unmating properties and lower resistance to environmental factors.) Precautions ■ Be careful when mating/unmating the connector when it is not mounted on the PCB as it may cause damage/ deformation to contacts. ■ Avoid supporting the PCB only with the connectors. Support it by other means such as bolts, screws, posts, etc. ■ Excessive prying during unmating/mating may result in damage. ■ In the case of hand soldering, please do not apply any flux which could cause flux wicking. ■ This product may have slight color differences due to production lot variability, but this does not affect the performance. ■ Please refer to the following page for handling precautions when inserting and removing. ■ Because the product can disengage if dropped (or other impact), or by FPC routing, it is advised to secure the mated connectors to the board with housings and cushioning materials. 21 DF40 Series/0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board/FPC-to-Board Connector Handling Precautions for Connector Insertion DF40#-#DS-0.4V May.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF40#-#DS-0.4V When aligning, look for the entrances without applying excessive force. Please note that applying excessive force may cause broken and shaving of the mold, which may lead to malfunctions of contact resistance When aligned in, it should drop one step and become parallel, and should be mated parallel from the point where it no longer moves back and forth or side to side. 22 DF40 Series/0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board/FPC-to-Board Connector Handling Precautions for Connector Removal DF40#-#DS-0.4V May.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF40#-#DP-0.4V When removing the connector, it is better to pull it out in parallel. If parallel extraction is not possible due to handling, remove diagonally from the pitch direction as shown on the left. However, if the FPC is not rigid enough, it may be a defect that causes contact to come out or the connector to break, so please check it when making a prototype. Pitch Direction Corner Direction Also, do not pull out from the corner direction as it will put a heavy load on contact. As shown on the left, do not remove the connector from the width direction as it may damage the connector. Width Direction 23 DF40 Series/0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board/FPC-to-Board Connector If the rigidity of the FPC is low, the terminal may come out. Receptacle FPC If you use a less rigid FPC to mounting receptacle side to the FPC, there is a risk that contact will fall out. We recommend mounting the plug side on the FPC side. If you need to mounting the receptacle to the FPC side, please request an FPC stiffness evaluation. May.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Plug Plug FPC Receptacle Even when the plug side is mounted on the FPC, if the rigidity of the FPC is low, the connector may break as shown on the left. Please use the FPC after checking its repetitive operation. FPC stiffness and evaluation results of each item are available for your request. 24 May.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF40 Series/0.4mm Pitch, 1.5 to 4.0mm Height, Board-to-Board/FPC-to-Board Connector While Taking into Consideration Specifications mentioned in this catalog are reference values. When considering to order or use this product, please review the Drawing and Product Specifications sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose, the warranty of the product may be affected. If considering usage for below mentioned applications, please contact your sales representative. In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given. HIROSE 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN        https://www.hirose.com ※ The contents of this catalog are current as of date of 4/ 2023. Contents are subject to change without notice for the purpose of improvements. ※ The HRS logo and "HIROSE" are trademarks of HIROSE ELECTRIC CO., LTD. 25
DF40HC(2.5)-60DS-0.4V(51) 价格&库存
很抱歉,暂时无法提供与“DF40HC(2.5)-60DS-0.4V(51)”相匹配的价格&库存,您可以联系我们找货
    • 10+5.61200
    库存:500
