LESD8D5.0CT5G
LESD8D5.0CT5G
    JEMETE(晶美特)
    SOD-882
    ESD抑制器/TVS二极管 VRWM=5V VBR(Min)=5.6V VC=10V@IPP=8A SOD882
LESD8D5.0CT5G 数据手册
LESD8D5.0CT5G 1-Line bidirectional ESD Protection Diode Transient Voltage Suppressors General Description The LESD8D5.0CT5G is designed to protect voltage sensitive components from ESD and transient voltage events. Excellent clamping capability, low leakage, and fast response time, make these parts ideal for ESD protection on designs where board space is at a premium. Because of its small size, it is suited for use in cellular phones, MP3 players, digital cameras and many other portable applications where board space is at a premium. Applications     SOD882 Cellular phones Portable devices Digital cameras Power supplies Features   Small Body Outline Dimensions Low Body Height  Peak Power up to 80 Watts @ 8 x 20 μs Pulse Low Leakage current Response Time is Typically < 1 ns   Ordering information Device LESD8D5.0CT5G Marking PB Shipping 10000/Tape&Reel Absolute Ratings (Tamb=25°C ) Symbol Parameter Value Units PPP Peak Pulse Power (tp = 8/20μs) 80 W TL Maximum lead temperature for soldering during 10s 260 °C Tstg Storage Temperature Range -55 to +150 °C Top Operating Temperature Range -40 to +125 °C Tj Maximum junction temperature 150 °C ±25 ±25 KV 8 A IEC61000-4-2 (ESD) IPPM air discharge contact discharge IEC61000-4-5 (8/20uS) 1 1/3 LESD8D5.0CT5G 1-Line bidirectional ESD Protection Diode Electrical Parameter Symbol Parameter Reverse Peak IPP Maximum Current VC Clamping Voltage @ IPP Pulse IR Working Peak Reverse Voltage Maximum Reverse Leakage Current @ VRWM IT Test Current VRWM VBR Breakdown Voltage @ IT Electrical Characteristics Ratings at 25°C ambient temperature unless otherwise specified. VRWM IR1(uA) (V) @ VRWM Device LESD8D5.0CT5G VBR (V)@ IT (Note 1) IT VC (V) VC (V) @ IPP=5 A* @ Max IPP* (A)* (W)* (pF) IPP PPK C Max Max Min mA Typ Max Max Max Typ 5.0 0.1 5.6 1.0 8.5 10.0 8.0 80 15 *Surge current waveform per Figure 1. 1. VBR is measured with a pulse test current IT at an ambient temperature of 25℃. Fig1. IEC61000-4-5 Waveform Fig2.IEC61000-4-2 Waveform 2 2/3 LESD8D5.0CT5G 1-Line bidirectional ESD Protection Diode OUTLINE AND DIMENSIONS SOD882 SOD882 Dim Min Typ. Max A 0.46 0.48 0.50 A1 0 0.02 0.05 b 0.45 0.5 0.55 c 0.1 0.12 0.14 D 0.95 1.00 1.05 E 0.55 0.60 0.65 L 0.20 0.25 0.30 L1 h 0.035 0.05 0.12 0.065 0.17 崩胶 0 0.07 0.06 All Dimensions in mm 0.06 WWW.JEMETE.COM.CN 3 3/3
LESD8D5.0CT5G 价格&库存
很抱歉,暂时无法提供与“LESD8D5.0CT5G”相匹配的价格&库存,您可以联系我们找货
