PPI0001494
PPI0001494
    APTIV(安波福)
    汽车连接器 48 路 F 混合 0.64 1.5 CMC 48 路密封连接器
PPI0001494 数据手册
A B C 8x 1.80 #0.05 0.20 0.20 1.00 #0.05 DETAIL ALVEOLES 1.5 DETAIL CAVITIES 1.5 8x INDICE DU PORTE-CLIPS ASSEMBLE REVISION LEVEL OF FEMALE CONNECTOR N° D'EMPREINTE DU LEVIER LEVER CAVITY NUMBER A B C SORTIE FAISCEAU A DROITE RIGHT WIRING OUT ECHELLE 5:1 / SCALE SORTIE FAISCEAU A GAUCHE LEFT WIRING OUT ZONE DE MARQUAGE MARKING AREA 5:1 MARQUAGES EN DESSOUS DU LEVIER (LEVIER ENLEVE POUR CETTE VUE) MARKING UNDER LEVER COMPONENT (LEVER REMOVED FOR THIS VIEW) 43.50 39.75 #0.11 0.10 N° D'EMPREINTE DU PORTE-CLIPS FEMALE HOUSING CAVITY NUMBER B 2.650 B INDICATION SORTIE FAISEAU (DROIT) WIRING OUT INDICATION (RIGHT) LOGO DELPHI DELPHI'S LOGO 3.50 22.50 C 0.20 C 0.10 #0.11 LE LEVIER CACHE LA MAUVAISE INDICATION DE SORTIE DE FAISCEAU LEVER HIDE BAD WIRING OUT INDICATION INDICATION SORTIE FAISCEAU (GAUCHE) WIRING OUT INDICATION (LEFT) A 38.20 #0.25 GRILLE PRE-VERROUILLEE (POSITION DE LIVRAISON) GRID PRE-LOCKED (DELIVERY POSITION) 20.70 3.70 #0.10 14.85 LE LEVIER CACHE LA MAUVAISE INDICATION DE SORTIE DE FAISCEAU LEVER HIDE BAD WIRING OUT INDICATION 18.40 6.30 12.60 34.40 #0.30 C SPECIFICATION DE CONDITIONNEMENT PACKAGING SPECIFICATION FE PA 06 013 DATEUR (MOIS/ANNEE) CLOCK DATE (MONTH/YEAR) MATIERE DU LEVIER LEVER RAW MATERIAL CAHIER DES CHARGES SPECIFICATION PRODUITS ASSOCIES ASSOCIATED PARTS DETAIL ALVEOLES 0.635 DETAIL CAVITIES 0.635 BOUCHON D'ALVEOLES CAVITY PLUG CAPOT COVER SORTIE DES FILS WIRES OUTPUT 0° 45° CAVITE 0.635 0.635 CAVITY MVL P/N DELPHI P/N F965000 13956254 PPI0001538 NF R 13-462 FE PS 07 023 CAVITE 1.5 1.5 VAVITY MVL P/N DELPHI P/N MVL P/N DELPHI P/N PPI0001045 13768626 PPI0001486 13826722 DOSSIER DE PRECONISATION : PU 087 USER'S MANUAL: PU 087 33517228 DE FILS MINI ET MAXI ADMISSIBLE POUR GARANTIR L'ETANCHEITE DU PRODUIT SUITABLE MIN. AND MAX. WIRES TO GUARANTEE THE WATER TIGHTNESS OF THE A B C 21.75 40x 0.90 0.20 2.60 #0.10 REFERENCE MVL MVL PART NUMBER ZONE DE MARQUAGE MARKING AREA #0.05 A B C GTS 1.5 13955989 - 1.30 1.50 13648598 - 1.40 1.70 PPI0001482 13712871 F418400 2.00 2.20 1.00mm² - 1.30mm² PPI0001483 13741954 F418400 2.10 2.40 1.40mm² - 2.00mm² PPI0001484 13749482 2.30 2.80 SEALED VERSION 5:1 7 5 1 4 - PRINCIPALES PROPRIETES MECANIQUES MAIN MECHANICAL PROPERTIES CT 0.635 FORCE D'INSERTION D'UN CONTACT TERMINAL INSERTION FORCE EFFORT DE POLARISATION D'UN CONTACT A 90° ET 180° TERMINAL POLARISATION FORCE AT 90° AND 180° EFFORT DE RETENTION AVEC DV RETENTION FORCE WITH SECONDARY LOCK EFFORT SUR LE LEVIER D'ACCOUPLEMENT PC/PL MATING FORCE ON THE SLIDER DEVICE 8.80 CODAGE GRIS GREY CODING 6.60 #0.10 #0.10 NOMENCLATURE 13.20 CODAGE MARRON BROWN CODING #0.10 8.80 #0.10 13.20 CODAGE VERT GREEN CODING #0.10 13.20 #0.10 6.60 #0.10 6.60 #0.10 PARTS LIST B7 B7 6 GAUCHE LEFT 5 MATE SEAL JOINT INTERFACIAL MATING SEAL LEVIER LEVER UNSEALED VERSION DROITE RIGHT GAUCHE LEFT REFERENCE DELPHI DELPHI PART NUMBER 13956021 DELPHI INDICE DELPHI REVISION 01 01 01 REFERENCE MVL MVL PART NUMBER PPI0001494 PPI0001495 F552100 MVL INDICE MVL REVISION D D C SILICONE SILICON SILICONE SILICON PA66 GF 30 GRIS GREY INCOLORE CRISTAL NOIR BLACK 13956255 PPI0000425 C 1 PPI0000428 A 1 PPI0000416 A 1 C188300 C 1 C288300 C NA 33500411 11.00 #0.10 8.80 SEALED VERSION #0.10 8.80 UNSEALED VERSION #0.10 11.00 SEALED VERSION #0.10 11.00 #0.10 UNSEALED VERSION 13.20 DROITE RIGHT GAUCHE LEFT DROITE RIGHT GAUCHE LEFT DROITE RIGHT GAUCHE LEFT DROITE RIGHT GAUCHE LEFT DROITE RIGHT 33500400 33500499 33500500 33500417 33500408 33500419 33500420 33500414 33500405 33505158 33505157 01 01 01 F252100 PPI0001496 PPI0001497 F752100 F452100 F765000 F865000 F652100 C D D C C D D C NA 1 NA 1 1 01 01 01 NA 1 NA 1 1 01 01 01 01 F352100 F413500 F513500 C D D NA 1 NA 1 4 PBT GF 15 GRIS CLAIR LIGHT GREY 3 GRILLE ARR. NON ETANCHE UNSEALED REAR GRID PBT GF 15 GRIS FONCE DARK GREY 2 GRILLE AVANT FRONT GRID PBT GF 15 NOIR BLACK PPI0000405 B 1 2 GRILLE AVANT FRONT GRID PBT GF 15 GRIS GREY PPI0000406 B NA 2 GRILLE AVANT FRONT GRID PBT GF 15 MARRON BROWN PPI0000407 B NA 2 GRILLE AVANT FRONT GRID PBT GF 15 VERT GREEN PPI0000408 B NA NA NA 1 PBT GF 15 NOIR BLACK C088300 D 1 1 1 1 COULEUR COLOUR REF MVL MVL P/N INDICE REVISION 1 REP. ISOLANT PORTE-CLIPS FEMALE HOUSING DESIGNATION MATIERE MATERIAL 1 1 NA NA 1 NA NA 1 1 NA NA NA 1 QTE QTY UNSEALED VERSION NA 1 1 NA - 3 NA NA NA 2 - 1 5 1 GRILLE ARRIERE ETANCHE SEALED REAR GRID NA 2 - GAUCHE LEFT 01 #0.10 SEALED VERSION DROITE RIGHT SEE D RAWIN G PCC08 43002 6 GROMMET #0.10 SEE D RAWIN G PCC08 43002 SEALED VERSION SORTIE FAISEAU WIRING OUT 7 6.60 SEE D RAWIN G PCC08 43002 TYPE D'ETANCHEITE SEALING SPECIFICATION #0.10 SEE D RAWIN G PCC08 43002 13.20 - - - - - 10N MAXI 12N MAXI 24 MINI 30 MINI 80N MINI 100N MINI 65N MAXI 200N MINI -40°C / +125°C 15 g #0.5 Bar IPX9K DELPHI P/N ADDED GREEN CODING DETAILS ADDED IN TABLE VIEW MOVED TO D5 CHANGE REVISION OF TPA (B WAS A) CHANGE REVISION OF SEALED VERSION CONNECTOR AND HOUSING (D WAS C) ADD DELPHI PART NUMBER ADD DELPHI LOGO REMOVE OF UNSEALED VERSIONS, WHICH ARE ONLY PRODUCED IN A VERSION REVIEW OF TOLERANCES TO BE ACCORDANCE WITH OTHER CUSTOMER DRAWINGS CHANGE TO IMPROVE TPA CLOSING FOR AUTOMATIC CONTROL #0.2 - CT 1.5 65N MAXI EFFORT SUR LE LEVIER DE DESACCOUPLEMENT PC/PL UNMATING FORCE ON THE SLIDER DEVICE EFFICACITE DE VERROUILLAGE FULL ENGAGED EFFICIENCY CLASSE DE TEMPERATURE OPERATING TEMPERATURE CLASSE DE VIBRATIONS VIBRATION CLASS CLASSE D'ETANCHEITE SEALING CLASS CODAGE : EN ACCORD AVEC LA SPECIFICATION NF R 13-462 CODING : IN ACCORDANCE WITH NF R 13-462 SPECIFICATION CODAGE NOIR BLACK CODING MAXI MAXIMUM PPI0000489 MARKING UNDER LEVER COMPONENT (LEVER REMOVED FOR THIS VIEW) 5:1 / SCALE MINI MINIMUM PPI0001619 MARQUAGES EN DESSOUS DU LEVIER (LEVIER ENLEVE POUR CETTE VUE) ECHELLE JOINT TUBE SUR FIL WIRE TUBE 0.50mm² 0.50mm² - 0.85mm² MATIERE DU CORPS DU PORTE CLIPS MATERIAL OF THE FEMALE HOUSING REFERENCE DELPHI DELPHI PART NUMBER PRODUCT 0.35mm² GTS 0.635 30.00 0.20 40x 0.80 #0.05 4x TYPE DE CONTACT TERMINAL SIZE MISE EN OEUVRE APPLICATION SPECIFICATION #2° - SEE TABLE SEE TABLE A1 - 2006/12/14 F CHAZOTTES 2014/03/14 S LACOTE 2014/03/18 F FAURIE 2014/03/18 Pascal MENARD PCC0420007 CMC 48W X VERSION L SERIAL RELEASED CMC PROJECT - PCC0420007 1 - 1 See Table - 1:1 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Aptiv: PPI0001494 PPI0001495-B PPI0001496 PPI0001497 PPI0001494-B PPI0001496-B PPI0001497-B
PPI0001494 价格&库存
很抱歉,暂时无法提供与“PPI0001494”相匹配的价格&库存,您可以联系我们找货
PPI0001494
  • 1+17.03231
  • 10+15.64757
  • 30+15.37062
  • 100+14.53977
库存:10
