7287-1990-30
7287-1990-30
    YAZAKI(矢崎)
    插件
    汽车连接器
7287-1990-30 数据手册
1 2 (2/1) (2/1) 3 (14.20) 3 (11.30) 4 3 SUB-ASSEMBLY PART NUMBER 4 (14.20) 3 (11.30) 3 6 5 SEE TABLE 2 NO. PART NUMBER PART NAME MATERIAL COLOR QUANTITY 1 SEE TABLE 2 2P 9.5mm SEALED FEMALE CONNECTOR HOUSING PBT-GF15 SEE TABLE 2 1 2 7172-0241 2P 9.5mm SEALED FEMALE CONNECTOR TPA PBT-GF15 NATURAL 1 3 7137-2297-50 2P 9.5mm SEALED CONNECTOR INTERFACE SEAL SILICONE RED 1 1 SEE TABLE 2 2P 9.5mm SEALED FEMALE CONNECTOR HOUSING PBT-GF15 SEE TABLE 2 1 2 7172-0241 2P 9.5mm SEALED FEMALE CONNECTOR TPA PBT-GF15 NATURAL 1 3 7137-2297-50 2P 9.5mm SEALED CONNECTOR INTERFACE SEAL SILICONE RED 1 4 7158-7080-50 CONNECTOR SECONDARY LOCK (CPA) HPA RED 1 3 TABLE 1 1 7 E SEE TABLE 2 2 3 KEYWAY B 3 KEYWAY A TABLE 2 3 3 (12.75) (12.75) 3 TAPING RECOMMENDATION (1/1) 3 SUB-ASSEMBLY PART NUMBER HOUSING PART NUMBER KEYWAY CPA COLOR MASS (g) 7287-1991-30 7187-1990-30 A N BLACK (22.10) 7287-1990-30 7187-1990-30 A Y BLACK (22.85) 7287-1993-40 7187-1992-40 B N LIGHT GRAY (22.10) 7287-1992-40 7187-1992-40 B Y LIGHT GRAY (22.85) E EXPLODED VIEW (1/1) ( D 130.00 MIN D 42.10) 3 (35.80 - 37.50) (SEE NOTE 10) 1 3 4 C C 3 2 3 SECTION A-A WITH CPA 1 A B CAVITY 1 CAVITY 2 (32.00) 3 3 (27.75) 2 A 2 17.60±0.30 3 3 (32.00) - 11-01-2010 04-09-2009 02-22-2008 C10-A810 C09-A284 C08-A434 MMR MMR DCH LET DATE REVISION RECORD NO. CHKD 2 1 1 C19-A304 HAP 10MAX A ±0.15 ±0.20 B C ±0.30 SPECIFIED 2 B 3 A 03-27-2019 1. PARTS MUST BE PURCHASED FROM YAZAKI. 2. PARTS MUST BE FREE OF FLASH AND IMPERFECTIONS THAT AFFECT FUNCTION. 3. APPLICABLE TERMINAL: SEE 7116-5625-02:R DRAWING (YPT SEALED)(4mm² - 16mm²)(PREFERRED) MAX WIRE OD: 8.30mm MIN WIRE OD: 3.40mm SEE 7116-3285-02:R DRAWING (Y-TYPE SEALED)(10mm²) MAX WIRE OD: 6.50mm MIN WIRE OD: 5.50mm SEE 7116-3250:R DRAWING (Y-TYPE SEALED)(4mm² - 8mm²) MAX WIRE OD: 5.00mm MIN WIRE OD: 3.40mm 4. APPLICABLE WIRE SEAL: SEE 7158-3034-50:R DRAWING (Y-TYPE SEALED) SEE 7158-3672-50:R DRAWING (YPT SEALED) 5. APPLICABLE CAVITY PLUG: SEE 7157-3583:R DRAWING 6. MATING PART NUMBER: SEE 7287-1991-30:A 1 7. PARTS SATISFIES USCAR-2, REV. 4, NOVEMBER 2004, (T3/V2/S2/MF3), WITH THE FOLLOWING EXCEPTIONS: USCAR 5.4.1 TERMINAL INSERTION FORCE (6 AWG WIRE) = 36N MAX. 8. PARTS TO COMPLY WITH YPES-31-038 REQUIREMENTS. 9. THIS DIMENSION SHOWS THE PRE-SET POSITION OF THE TPA. 10. THIS DIMENSION SHOWS THE PRE-SET POSITION OF THE CPA. 11. THIS DRAWING IS TO BE USED FOR INTERNAL YAZAKI PSW SUBMISSION. 12. HANDLING MANUAL NUMBER: YPES-15-1204E 13. CONNECTOR IS CAPABLE OF ACCEPTING A DRESS COVER. (3.10 - 4.50) (SEE NOTE 9) SECTION A-A UPDATED TO LATEST STANDARDS, ADDED AND REMOVED DIMENSIONS, ADDED VIEWS REVISE SHAPE REVISE NOTE NEW NOTES: 3 (35.00) 3 REAR ISOMETRIC VIEW (1/1) 3 30.00 MIN 3 3 (56.00) 2 FRONT ISOMETRIC VIEW (1/1) RECOMMENDED PASS-THROUGH HOLE DIMENSION (1mm CLEARANCE ALL AROUND) (2/1) 3 50MAX ±0.20 ±0.30 ±0.50 100MAX ±0.30 ±0.55 ±0.80 250MAX ±0.50 ±0.95 ±1.40 4 CUSTOMER CUSTOMER PART NO. CUSTOMER DWG NO. MATL. SPEC. NAME OFFICE YNA TRIAL PART NO. VENDOR VENDOR NO. GENERAL TOLERANCE 250OVR R5 MAX R10 MAX R20 MAX R20 OVR ANGLE ECCENT DWG TYPE UNIT SCL ANGLE PART NO. DWG SOURCE DWG DATE mm CH. CODE ±3° 0.1 7287-1991-30:M 3 04-02-2008 ±0.75 R 3 2/1 ±2.50 ±3° 0.1 ±1.40 ±0.20 ±0.30 ±0.50 CHECKED APPROVED CHECKED DRAWN DESIGN DWG NO. jeremy. ±2.00 0.15 ±3° James 2019.04.24 DEREK HECTOR 14:28:19 gagnon@u Littek 04'00' HARRIS AVITIA MASS s.yazaki. SEE TABLE 2 com 04-10-2007 04-10-2019 Digitally signed by jeremy.gagnon@us. yazaki.com DN: cn=jeremy. gagnon@us.yazaki.com Date: 2019.04.26 08:31:37 -04'00' 5 Digitally signed by cant-gpclient DN: cn=cant-gp-client, c=US, o=Yazaki North America, Inc. Reason: I am approving this document Date: 2019.04.11 12:05:49 06'00' 6 SEE TABLE TREAT. & FIN. ISSUE MARK N/A 2P 9.5mm SEALED FEMALE CONNECTOR SUB-ASSEMBLY 7287-1991-30, ETC. 7287-1991-30:R YAZAKI CORPORATION 7 A Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Yazaki: 7287199030
7287-1990-30 价格&库存
很抱歉,暂时无法提供与“7287-1990-30”相匹配的价格&库存,您可以联系我们找货
    • 1+18.64500
    • 162+13.98430
    • 324+9.32250
    库存:1844
    7287-1990-30
      • 324+11.00000
      库存:2268
      7287-1990-30
        • 324+7.97863
        库存:28
        AVSS-0.50-粉/棕
          库存:2034
