P2016-04P
P2016-04P
    XFCN(台湾兴飞)
    P=2mm
    胶壳及附件 P=2mm 4Pin(1x4)
P2016-04P 数据手册
No. of DIMENSIONS Contacts DIM A DIM B 4.70 2.00 4.00 6.70 6.00 8.70 10.70 8.00 12.70 10.00 14.70 12.00 16.70 14.00 18.70 16.00 20.70 18.00 22.70 20.00 24.70 22.00 26.70 24.00 28.70 26.00 30.70 28.00 32.70 30.00 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 NOTE: UNLESS OTHERWISE SPECIFIED 1. MATERIAL P/N: Nylon,UL94V-0 RATED COLOR White 2. DIM. MARKED ...TO BE CHECKED BY QC 3. THE CAV.NO AND MARK IS LOCATED APPROXIMATELY AS SHOWN WITH MAX. HEIGHT 0.03 mm ABOVE SURFACE AND THE TEXT HEIGHT IS ABOUT 1.5 mm. 2.9±0.1 4. THE FOLLOWING CONDITION SHALL BE MET: . FLASH: 0.03 mm THICK BY 0.05 mm MAX. . EJECTION MARK: 0.10 mm MAX. . MISMATCH IN PARTING LINE: 0.05 mm MAX. . GATE PROTRUSION OR DEPRESSION: 0.05 mm MAX. A B A 2.00mm Crimp Style Connectors P2016-XX-N0
P2016-04P 价格&库存
很抱歉,暂时无法提供与“P2016-04P”相匹配的价格&库存,您可以联系我们找货
P2016-04P
    • 50+0.06207
    • 500+0.06074
    • 2000+0.05428
    • 5000+0.05345
    库存:1249
    P2016-04P
    • 1+0.12062
    • 50+0.06059
    • 1000+0.04572
    库存:1000
