NJM78L05UA-TE1
NJM78L05UA-TE1
    NJR(新日本无线)
    SOT89-3
    线性稳压器/LDO SOT89-3 Vo=5V IQ=2mA PD=350mW
NJM78L05UA-TE1 数据手册
NJM78L00 3-TERMINAL POSITIVE VOLTAGE REGULATOR ■ GENERAL DESCRIPTION The NJM78L00 series of 3-Terminal Positive Voltage Regulators are constructed using the New JRC Planar epitaxial process. These regulators employ internal current limiting and thermal shut down, making them essentially indestructible. If adequate heat sinking is provided, they can deliver up to 100mA output current. They are intended as fixed voltage regulators in a wide range of applications including local or on-card regulation for elimination of noise and distribution problems associated with single-point regulation. In addition, they can be used with power pass elements to make high-current voltage regulators. The NJM78L00 series used as a Zener diode/resistor combination replacement, offers an effective output impedance improvement of typically two orders of magnitude, along with lower quiescent current and lower noise. ■ PACKAGE OUTLINE NJM78L00UA (SOT-89) NJM78L00EA ( SOP8 ) (5V, 9V, 12V Version Only) ■ FEATURES ● Internal Short Circuit Current Limit ● Internal Thermal Overload Protection ● Excellent Ripple Rejection ● Guaranteed 100mA Output Current ● Package Outline SOT-89, SOP8 JEDEC 150mil ● Bipolar Technology ■ PIN CONFIGURATION 2 PIN CONFIGURATION 1. OUT 2. GND 3. IN 1 2 3 NJM78L00UA PIN CONFIGURATION 1 8 2 7 3 6 4 5 NJM78L00EA 1. OUT 2. GND 3. GND 4. NC 5. NC 6. GND 7. GND 8. IN ■ EQUIVALENT CIRCUIT Ver.2017-01-25 -1- NJM78L00 ■ ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL (Ta=25°C) MAXIMUM RATINGS (78L02A to 78L09A) (78L12A to 78L15A) (78L18A to 78L24A) 30 35 40 UNIT Input Voltage VIN Power Dissipation PD Operating Temperature Range Topr -40 to +85 °C Storage Temperature Range Tstg -40 to +150 °C (SOT-89) (SOP8) 350 700(*1) V mW (*1) Mounted on glass epoxy board ■ ELECTRICAL CHARACTERISTICS (CIN=0.33μF, CO=0.1μF, Tj=25°C) Measurement is to be conducted is pulse testing. PARAMETER NJM78L02UA Output Voltage Line Regulation 1 Line Regulation 2 Load Regulation 1 Load Regulation 2 Quiescent Current Average Temperature Coefficient of Output Voltage Ripple Rejection Output Noise Voltage NJM78L03UA Output Voltage Line Regulation 1 Line Regulation 2 Load Regulation 1 Load Regulation 2 Quiescent Current Average Temperature Coefficient of Output Voltage Ripple Rejection Output Noise Voltage NJM78L05UA/EA Output Voltage Line Regulation 1 Line Regulation 2 Load Regulation 1 Load Regulation 2 Quiescent Current Average Temperature Coefficient of Output Voltage Ripple Rejection Output Noise Voltage -2- SYMBOL VO ΔVO-VIN1 ΔVO-VIN2 ΔVO-IO1 ΔVO-IO2 IQ ΔVO/ΔT RR VNO VO ΔVO-VIN1 ΔVO-VIN2 ΔVO-IO1 ΔVO-IO2 IQ ΔVO/ΔT RR VNO VO ΔVO-VIN1 ΔVO-VIN2 ΔVO-IO1 ΔVO-IO2 IQ ΔVO/ΔT RR VNO TEST CONDITION VIN=9V, IO=40mA VIN=4.75V to 20V, IO=40mA VIN=5V to 20V, IO=40mA VIN=9V, IO=1 to 40mA VIN=9V, IO=1 to 100mA VIN=9V, IO=0mA VIN=9V, IO=1mA 6V< VIN
NJM78L05UA-TE1 价格&库存
很抱歉,暂时无法提供与“NJM78L05UA-TE1”相匹配的价格&库存,您可以联系我们找货
