h
±8 Gauss, High Performance
3-axis Magnetic Sensor
MMC5983MA
FEATURES
• Fully integrated 3-axis magnetic sensor and
electronic circuits requiring fewer external
components
• Superior dynamic range and accuracy:
✓ ±8G FSR
✓ 18bits operation
✓ 0.4mG total RMS noise
✓ Enables heading accuracy of 0.5º
• Max output data rate of 1000Hz
• Industrial standard low profile package
3.0mm x 3.0mm x 1.0mm
• Degaussing with built-in SET/RESET function
✓ Eliminates thermal variation induced offset
error (Null field output)
✓ Clears the residual magnetization resulting
from strong external fields
• On-chip sensitivity compensation
• On-chip temperature sensor
• Data_Ready Interrupt
• Low power consumption
• 1µA power down current
• I2C Slave, FAST(≤400KHz) mode
• 3.0V single low power supply
• SPI interface available
• RoHS compliant
APPLICATIONS
• Electronic Compass & Navigation
• Position Sensing
• General Purpose Magnetic Field
Measurements
DESCRIPTION
The MMC5983MA is an AEC-Q100 qualified complete
3-axis magnetic sensor with on-chip signal processing
and integrated I2C/SPI bus suitable for use in
automotive applications. The device can be connected
directly to a microprocessor, eliminating the need for
A/D converters or timing resources.
Information furnished by MEMSIC is believed to be accurate and reliable.
However, no responsibility is assumed by MEMSIC for its use, or for any
infringements of patents or other rights of third parties which may result from
its use. No license is granted by implication or otherwise under any patent or
patent rights of MEMSIC.
MEMSIC MMC5983MA Rev. A
FUNCTIONAL BLOCK DIAGRAM
It can measure magnetic fields within the full scale
range of 8 Gauss (G), with 0.25mG/0.0625mG per
LSB resolution at 16bits/18bits operation mode and 0.4
mG total RMS noise level, enabling heading accuracy
of 0.5ºin electronic compass applications.
An integrated SET/RESET function provides for the
elimination of error due to Null Field output change with
temperature. Temperature information from the
integrated temperature sensor is available over the I2C
Interface. The SET/RESET function can be performed
for each measurement, periodically, or when the
temperature changes by a predetermined amount as
the specific application requires.
In addition, the SET/RESET function clears the sensors
of any residual magnetic polarization resulting from
exposure to strong external magnets.
The MMC5983MA is packaged in a low profile LGA
package and an operating temperature range from 40C to +105C.
The MMC5983MA provides an I2C digital output with
400 KHz, fast mode operation, and a 10MHz SPI digital
output.
©MEMSIC, Inc.
One Technology Drive, Suite 325, Andover, MA01810, USA
Tel: +1 978 738 0900
Fax: +1 978 738 0196
www.memsic.com
Page 1 of 20
2/25/2019
SPECIFICATIONS (Measurements @ 25C, unless otherwise noted; VDD=3.0V unless otherwise specified)
Parameter
Field Range (Each Axis)
Supply Voltage
Conditions
Min
Typ
8
Total applied field
Units
G
VDD
2.8
3.0
3.6
V
VDDIO(I2Cinterface and INT)
2.8
3.0
3.6
V
5.0
ms
µA
µA
µA
µA
µA
Supply Voltage Rise Time
Supply Current1,2
(7 measurements/second)
Max
BW=00
BW=01
BW=10
BW=11
450
225
112.5
32
1.0
Power Down Current2
Operating Temperature
-40
105
C
Storage Temperature
Linearity Error2
(Best fit straight line)
Hysteresis2
-55
125
C
FS=±8G
Happlied=±4G
3 sweeps across ±8G
0.1
%FS
0.01
%FS
Repeatability Error2
3 sweeps across ±8G
0.1
%FS
1.0
Alignment Error
8 G
mG
mG
mG
mG
Bits
Hz
Hz
Hz
Hz
Hz
Degrees
With16bits operation
4096
Counts/G
With18bits operation
-40~105 C
Delta from 25 C, 8 G
16384
Counts/G
5
0.5
G
32768
Counts
-40~105 C
Delta from 25 C
131072
Counts
3
mG
0.8
C/Count
10
G
BW=00
BW=01
BW=10
BW=11
Output Resolution
Max Output data rate2
BW=00
BW=01
BW=10
BW=11
BW=11(CM_Freq=111)
Heading Accuracy3
Sensitivity Accuracy4,5
Sensitivity Change Over
Temperature
Null Field
Output5
Null Field Output Change Over
Temperature using SET/RESET
Temperature Sensor Output
Disturbing
Field6
Maximum Exposed Field
10,000
1
SET/RESET Repeatability
1.
2.
3.
4.
5.
6.
Degrees
0.8
0.4
0.6
0.8
1.2
18
50
100
225
580
1000
1.0
5
Transverse Sensitivity
Total RMS Noise2
3.0
G
mG
Supply current is proportional to how many measurements performed per second.
Based on 3lots characterization result.
MEMSIC product enables users to utilize heading accuracy to be 1.0 degree typical when using MEMSIC’s proprietary software or algorithm.
Sensitivity of the orthogonal axes is analytically derived from raw data and is subsequently processed by MEMSIC software drivers.
Based on shipment test result.
This is the magnitude of external field that can be tolerated without changing the sensor characteristics. If the disturbing field is exceeded, a SET/RESET
operation is required to restore proper sensor operation.
Page 2 of 20
2/25/2019
DIGITAL INTERFACE (VIO=3.0V)
Symbol
VIH
VIL
VHYS
IIL
VOH
VOL
Parameter (Units)
High Level Input Voltage (Volts)
Low Level Input Voltage (Volts)
Hysteresis of Schmitt Trigger Input (Volts)
Input Leakage, All Inputs (uA)
High Level Output Voltage (Volts)
Low Level Output Voltage (Volts)
Minimum
0.7*VIO
Typical
Maximum
0.3*VIO
0.2
-10
0.8*VIO
10
0.2*VIO
I2C INTERFACE I/O CHARACTERISTICS (VIO=3.0V)
Parameter
Symbol
Test Condition
Min.
Typ.
Max.
Unit
Logic Input Low Level
VIL
-0.5
0.3* VIO
V
Logic Input High Level
VIH
0.7*VIO
VIO
V
Hysteresis of Schmitt Input
Vhys
0.2
Logic Output Low Level
VOL
Input Leakage Current
Ii
SCL Clock Frequency
fSCL
START Hold Time
tHD;STA
0.6
µS
START Setup Time
tSU;STA
0.6
µS
LOW period of SCL
tLOW
1.3
µS
HIGH period of SCL
tHIGH
0.6
µS
Data Hold Time
tHD;DAT
Data Setup Time
tSU;DAT
0.1
Rise Time
tr
From VIL toVIH
0.3
µS
Fall Time
Bus Free Time Between STOP and
START
STOP Setup Time
tf
From VIH toVIL
0.3
µS
0.1VIO
很抱歉,暂时无法提供与“MMC5983MA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+8.08060
- 400+7.34800
- 1000+6.68990
- 国内价格
- 1+15.02280
- 10+12.91680
- 30+11.59920
- 100+10.24920
- 500+9.49320
- 1000+9.22320
- 国内价格
- 1+14.63250
- 10+12.28630
- 30+11.02140
- 100+9.73810
- 500+9.01890
- 1000+8.76210
- 国内价格
- 1+13.63180
- 10+11.72080
- 30+10.52520
- 100+9.30020
