SCB12Q4G160AF-07Q
SCB12Q4G160AF-07Q
    UNIIC(紫光国芯)
    FBGA-96
    SDRAM存储器 4Gbit DDR4 SDRAM 1333MHz
SCB12Q4G160AF-07Q 数据手册
Jul. 2020 S C B 1 2 Q 4 G x x0 A F 4Gbit DDR4 SDRAM E U Ro H S Co m p lia n t Pr o d u c t s D a t a She e t Re v . D Data Sheet SCB12Q4Gxx0AF 4Gbit DDR4 SDRAM Revision History Date Revision Subjects (major changes since last revision) 2019-08 A 2019-10 B Initial Release Modify some type Update Product list: Add SCB12Q4G800AF-08T, SCB12Q4G160AF-08T 2020-05 C 2020-07 D Update package outline of x 16 Product:Modify some typo. Format review (2020-05-28) Add Table 2: 4Gbit DDR4 Addressing We Listen to Your Comments Any information within this document that you feel is wrong, unclear or missing at all? Your feedback will help us to continuously improve the quality of this document. Please send your proposal (including a reference to this document) to: info@unisemicon.com UniIC_Techdoc, Rev. D 2020-07 2 / 32 Data Sheet SCB12Q4Gxx0AF 4Gbit DDR4 SDRAM Contents Contents ........................................................................................................................................................................................ 3 1 Features .................................................................................................................................................................................. 4 2 Product List ............................................................................................................................................................................. 5 3 Ball configuration..................................................................................................................................................................... 6 4 Ball Description ....................................................................................................................................................................... 8 5 Electrical Specifications......................................................................................................................................................... 10 6 Speed Bin .............................................................................................................................................................................. 12 7 Electrical Characteristics & Timing ........................................................................................................................................ 15 7.1 Reference Load for AC Timing and Output Slew Rate ............................................................................................... 15 7.2 Timing Parameters by Speed Grade .......................................................................................................................... 16 8 Package Outlines .................................................................................................................................................................. 27 9 Product Type Nomenclature .................................................................................................................................................. 29 List of Figures .............................................................................................................................................................................. 30 List of Tables ............................................................................................................................................................................... 31 UniIC_Techdoc, Rev. D 2020-07 3 / 32 Data Sheet SCB12Q4Gxx0AF 4Gbit DDR4 SDRAM 1 Features The 4Gbit DDR4 SDRAM offers the following key features: • Operating case temperature range TC = 0℃ to +95℃ • Refresh cycles Average refresh period 7.8s at 0℃ TC +85℃ 3.9s at +85℃ < TC +95℃ • Fine granularity refresh is supported • Adjustable internal generation VREFDQ • Pseudo Open Drain (POD) interface for data input/output • Driver strength selected by MRS • The high-speed data transfer by the 8 bits pre-fetch • Temperature Controlled Refresh (TCR) mode is supported • Low Power Auto Self Refresh (LPASR) mode is supported • Self refresh abort is supported • Programmable preamble is supported • Write leveling is supported • Command/Address latency (CAL) is supported • Multipurpose register READ and WRITE capability • Command Address Parity (CA Parity) for command address signal error detect and inform it to controller • Write Cyclic Redundancy Code (CRC) for DQ error detect and inform it to controller during high-speed operation • Data Bus Inversion (DBI) for Improve the power consumption and signal integrity of the memory interface • Data mask (DM) for write data • Per DRAM Addressability (PDA) for each DRAM can be set a different mode register value individually and has individual adjustment • Gear down mode (1/2 and 1/4 rate) is supported • PPR and sPPR is supported • Connectivity test (x16 only) • Maximum power down mode for the lowest power consumption with no internal refresh activity • JEDEC JESD-79-4 compliant • Power supply 5% - VPP = 2.5V – 5% + 10% • Data rate - 2666Mbps (DDR4-2666) - 2400Mbps (DDR4-2400) • Package - 78-ball FBGA - 96-ball FBGA - Lead-free • 16 or 8 internal banks 4 groups of 4 banks each (x4 and x8) 2 groups of 4 banks each (x16) • Differential clock inputs operation (CK_t and CK_c) • Bi-directional differential data strobe (DQS_t and DQS_c) • Termination Data Strobe is supported (x8 only) (TDQS_t and TDQS_c) • Asynchronous reset is supported (RESET_n) • ZQ calibration for Output driver by compare to external reference resistance (RZQ 240 ohm • Nominal, park and dynamic On-die Termination (ODT) • DLL aligns DQ and DQS transitions with CK transitions • Commands entered on each positive CK edge • CAS Latency (CL): 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22 and 23 supported • Additive Latency (AL) 0, CL-1, and CL-2 supported • Burst Length (BL): 8 and 4 with on the fly supported • CAS Write Latency (CWL): 9, 10, 11, 12, 14, 16 and 18 supported UniIC_Techdoc, Rev. D 2020-07 4 / 32 Data Sheet SCB12Q4Gxx0AF 4Gbit DDR4 SDRAM 2 Product List Table 1 shows all possible products within the 4Gbit DDR4 SDRAM component generation. Table 1 - Ordering Information for 4Gbit DDR4 Component UniIC Part Number Max. Clock frequency CAS-RCD-RP latencies Speed Sort Name Package 4Gbit DDR4 SDRAM Components in × 8 Organization (512 M × 8) SCB12Q4G800AF-07Q 1333 MHz 19-19-19 DDR4–2666V PG-FBGA-78 SCB12Q4G800AF-08T 1200 MHz 17-17-17 DDR4–2400T PG-FBGA-78 4Gbit DDR4 SDRAM Components in × 16 Organization (256 M × 16) SCB12Q4G160AF-07Q 1333 MHz 19-19-19 DDR4–2666V PG-FBGA-96 SCB12Q4G160AF-08T 1200 MHz 17-17-17 DDR4–2400T PG-FBGA-96 Table 2 - 4Gbit DDR4 Addressing Parameter 512Mb × 8 256Mb × 16 Number of bank groups 4 2 Bank group address BG[1:0] BG0 Bank count per group 4 4 Bank address in bank group BA[1:0] BA[1:0] Row Address 32K (A[14:0]) 32K (A[14:0]) Column Address 1K(A[9:0]) 1K(A[9:0]) Page Size 1KB 2KB UniIC_Techdoc, Rev. D 2020-07 5 / 32 Note Data Sheet SCB12Q4Gxx0AF 4Gbit DDR4 SDRAM 3 Ball configuration Figure 1 - Ball out for 512Mb ×8 Components (78-ball FBGA) UniIC_Techdoc, Rev. D 2020-07 6 / 32 Data Sheet SCB12Q4Gxx0AF 4Gbit DDR4 SDRAM Figure 2 - Ball out for 256Mb ×16 Components (96-ball FBGA) VDDQ VSSQ UniIC_Techdoc, Rev. D 2020-07 7 / 32 Data Sheet SCB12Q4Gxx0AF 4Gbit DDR4 SDRAM 4 Ball Description Table 3 - Input / Output Signal Functional Description for 512Mb ×8 Components (78-ball FBGA) Ball Name Function Address inputs A10/AP: Auto precharge A12/BC_n: Burst chop Note BA0, BA1 Bank select 2 BG0, BG1 Bank group input 2 DQ0 to DQ7 Data input/output DQS_t, DQS_c Differential data strobe TDQS_t, TDQS_c Termination data strobe CS_n Chip select 2 RAS_n/A16 CAS_n/A15 WE_n/A14 Command input 2 ACT_n Activation command input 2 CKE Clock enable 2 CK_t, CK_c Differential clock input DM_n Write data mask DBI_n Data bus inversion ODT ODT control 2 RESET_n Active low asynchronous reset 2 PAR Command and address parity ALERT_n Alert VDD Supply voltage for internal circuit VSS Ground for internal circuit VDDQ Supply voltage for DQ circuit VSSQ Ground for DQ circuit VREFCA Reference voltage for CA ZQ Reference pin for ZQ calibration NC No connection A0 to A14 2 1 Note: 1. Not internally connected with die. 2. Input only pins (address, command, CKE, ODT and RESET_n) do not supply termination. UniIC_Techdoc, Rev. D 2020-07 8 / 32 Data Sheet SCB12Q4Gxx0AF 4Gbit DDR4 SDRAM Table 4 - Input / Output Signal Functional Description for 256Mb ×16 Components (96-ball FBGA) Ball Name Function Address inputs A10/AP: Auto precharge A12/BC_n: Burst chop Note BA0, BA1 Bank select 2 BG0 Bank group input 2 A0 to A14 DQU0 to DQU7 DQL0 to DQL7 DQSU, DQSU_n DQSL, DQSL_n 2 Data input/output Differential data strobe CS_n Chip select 2 RAS_n/A16 CAS_n/A15 WE_n/A14 Command input 2 ACT_n Activation command input 2 CKE Clock enable 2 CK_t, CK_c Differential clock input DMU_n, DML_n Write data mask DBIU_n, DBIL_n Data bus inversion ODT ODT control 2 RESET_n Active low asynchronous reset 2 PAR Command and address parity ALERT_n Alert TEN Connectivity test mode enable VDD Supply voltage for internal circuit VSS Ground for internal circuit VDDQ Supply voltage for DQ circuit VSSQ Ground for DQ circuit VREFCA Reference voltage for CA ZQ Reference pin for ZQ calibration NC No connection 1 Note: 1. Not internally connected with die. 2. Input only pins (address, command, CKE, ODT and RESET_n) do not supply termination. UniIC_Techdoc, Rev. D 2020-07 9 / 32 Data Sheet SCB12Q4Gxx0AF 4Gbit DDR4 SDRAM 5 Electrical Specifications Table 5 - IDD & IDDQ Specification DDR4-2400 DDR4-2666 Symbol Unit x8 x16 x8 x16 IDD0 79 86 85 92 mA IDD0A 80 87 86 93 mA IDD1 93 128 115 142 mA IDD1A 96 122 107 146 mA IDD2N 67 67 74 74 mA IDD2NA 68 68 75 75 mA IDD2NT 80 86 90 97 mA IDD2NL 59 59 63 63 mA IDD2NG 65 65 71 71 mA IDD2ND 49 49 52 52 mA IDD2N_par 82 82 94 94 mA IDD2P 40 40 44 44 mA IDD2Q 66 67 74 75 mA IDD3N 78 78 86 86 mA IDD3NA 79 79 85 85 mA IDD3P 64 64 67 67 mA IDD4R 150 188 165 205 mA IDD4RA 152 197 183 227 mA IDD4RB 149 190 166 206 mA IDD4W 162 211 180 230 mA IDD4WA 170 227 197 266 mA IDD4WB 155 199 172 215 mA IDD4WC 151 194 168 210 mA IDD4W_par 176 215 189 204 mA IDD5B 170 170 180 180 mA IDD5F2 179 179 189 189 mA IDD5F4 147 147 160 160 mA IDD7 187 234 196 235 mA IDD8 30 30 30 30 mA UniIC_Techdoc, Rev. D 2020-07 10 / 32 Data Sheet SCB12Q4Gxx0AF 4Gbit DDR4 SDRAM Table 6 - IPP Specification DDR4-2400 DDR4-2666 Symbol Unit X8 X16 X8 X16 IPP0 4 8 5 9 mA IPP1 4 8 5 9 mA IPP2N 3 6 4 7 mA IPP2P 3 6 4 7 mA IPP3N 3 6 4 7 mA IPP3P 3 6 4 7 mA IPP4R 3 6 4 7 mA IPP4W 3 6 4 7 mA IPP5B 22 24 25 27 mA IPP5F2 23 25 27 29 mA IPP5F4 17 18 20 20 mA IPP7 22 33 29 40 mA IPP8 2 2 3 3 mA Table 7 - IDD6 Specification Symbol Temperature Range IDD6N DDR4-2666 DDR4-2400 Unit Notes IDD(max) IPP(max) IDD(max) IPP(max) 0 - 85 oC 30 6 30 6 mA 1 IDD6E 0 - 95 oC 36 8 36 8 mA 2 IDD6R 0 - 45 oC 25 4 25 4 mA 3 IDD6A 0 - 85 oC 30 6 30 6 mA 4 Note: 1. Applicable for MR2 settings A6 = 0 and A7 = 0. 2. Applicable for MR2 settings A6 = 0 and A7 = 1. IDD6E is only specified for devices which support the extended temperature range feature. 3. Applicable for MR2 settings A6 = 1 and A7 = 0. IDD6R is only specified for devices which support the reduced temperature range feature. 4. Applicable for MR2 settings A6 = 1 and A7 = 1. IDD6A is only specified for devices which support the auto self-refresh feature. UniIC_Techdoc, Rev. D 2020-07 11 / 32 Data Sheet SCB12Q4Gxx0AF 4Gbit DDR4 SDRAM 6 Speed Bin Table 8 - DDR4-2400 Speed Bins Speed Bin DDR4-2400R CL-nRCD-nRP Parameter 16-16-16 Symbol Internal read command to first data tAA Internal read command to first data with read DBI enabled tAA_DBI ACT to internal read or write delay time PRE command period ACT to PRE command period ACT to ACT command period or CL = 9 max min max 13.32 18.00 14.1614 (13.75)5,12 18.00 tAA(min) + 3nCK 13.32 14.16 (13.75)5,12 - ns 12 9 x tREFI ns 12 - ns 12 ns 1,2,3,4,11 32 9 x tREFI CWL 32 46.16 (45.75)5,12 45.32 1.5 tCK(AVG) 1.6 (Optional) Reserved 5,12 CL = 10 CL = 12 tCK(AVG) Reserv ed 1.5 1.6 Reserved 1.25 CL = 11 CL = 13 tCK(AVG) CL = tCK(AVG) CL = 14 tCK(AVG) CL = 13 CL = 15 tCK(AVG) CL = tCK(AVG) 1.25
SCB12Q4G160AF-07Q 价格&库存
很抱歉,暂时无法提供与“SCB12Q4G160AF-07Q”相匹配的价格&库存,您可以联系我们找货
