MGM2JA51K0
MGM2JA51K0
    SEI
    插件电阻 - 51KΩ ±5% 2W ±100ppm/℃
MGM2JA51K0 数据手册
MG / MGM / MGE / MGME Series Stackpole Electronics, Inc. High Voltage Metal Glaze Resistor Resistive Product Solutions Features: • • • • • • • • • • High voltage capability from 1600V to 7000V Inexpensive high voltage leaded resistor solution High resistance values up to 500M Tolerances as low as 1%; TCRs as low as 50 ppm/ºC Flameproof coating (brown) standard Epoxy coating (blue) available up to 2W MGE and MGME denote alternate epoxy coating instead of silicone RoHS compliant and halogen free Halogen free REACH compliant Electrical Specifications Type/Code Power Rating (W) @ 70ºC Maximum Working Voltage (V) Maximum Overload Voltage (V) Dielectric Withstanding Voltage (V) Silicone Epoxy MG14 0.25 1600 2000 400 MG12 0.5 3500 4000 500 700 MG1 1 4500 5000 500 1000 MG2 2 7000 14000 700 1200 MGM12 0.5 1700 2500 400 500 MGM1 1 4000 4500 500 700 MGM2 2 5000 10000 500 1000 MGM3 3 7000 14000 700 1200 TCR (ppm/ºC) (1) Ohmic Range (Ω) and Tolerance 1%, 5%, 10% 500 ± 100 100K - 500M (1) ±50 ppm/ºC available for some values and sizes. Contact Stackpole. Mechanical Specifications Type/Code MG14 MG12 MG1 MG2 MGM12 MGM1 MGM2 MGM3 A Body Length 0.248 ± 0.020 6.30 ± 0.50 0.354 ± 0.020 9.00 ± 0.50 0.453 ± 0.039 11.50 ± 1.00 0.610 ± 0.039 15.50 ± 1.00 0.248 ± 0.020 6.30 ± 0.50 0.354 ± 0.020 9.00 ± 0.50 0.453 ± 0.039 11.50 ± 1.00 0.610 ± 0.039 15.50 ± 1.00 Rev Date: 12/14/2022 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. B Body Diameter 0.091 ± 0.012 2.30 ± 0.30 0.126 ± 0.020 3.20 ± 0.50 0.157 ± 0.020 4.00 ± 0.50 0.197 ± 0.020 5.00 ± 0.50 0.091 ± 0.012 2.30 ± 0.30 0.157 ± 0.020 4.00 ± 0.50 0.177 ± 0.020 4.50 ± 0.50 0.197 ± 0.020 5.00 ± 0.50 1 C Lead Length (Bulk) 1.102 ± 0.079 28.00 ± 2.00 1.024 ± 0.079 26.00 ± 2.00 0.945 ± 0.079 24.00 ± 2.00 1.260 ± 0.079 32.00 ± 2.00 1.102 ± 0.079 28.00 ± 2.00 1.024 ± 0.079 26.00 ± 2.00 1.378 ± 0.079 35.00 ± 2.00 1.260 ± 0.079 32.00 ± 2.00 D Lead Diameter 0.022 ± 0.001 0.55 ± 0.03 0.026 ± 0.001 0.65 ± 0.03 0.031 ± 0.001 0.78 ± 0.03 0.031 ± 0.001 0.78 ± 0.03 0.022 ± 0.001 0.55 ± 0.03 0.026 ± 0.001 0.65 ± 0.03 0.031 ± 0.001 0.78 ± 0.03 0.031 ± 0.001 0.78 ± 0.03 Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com MG / MGM / MGE / MGME Series Stackpole Electronics, Inc. High Voltage Metal Glaze Resistor Resistive Product Solutions Performance Characteristics Test Temperature Coefficient (TCR) Test Specification (see Electrical Specification Chart) Short Time Overload ±(1% + 0.05Ω) Moisture Resistance ±(5% + 0.05Ω) Load Life ±(3% + 0.05Ω) Insulation Resistance ±10,000 MΩ over by type Dielectric Withstanding Voltage Resistance to Soldering Heat Resistance to Solvent Terminal Strength Test Condition by type Resistance value at room temperature Rated Voltage x 2.5 or Max. Overload Voltage, whichever is lower, for 5 seconds 40ºC ± 2ºC, 90% ~ 95% R.H., 1000 hours (for epoxy resin) 90 minutes ON and 30 minutes OFF 1000 hours at rated voltage, 70ºC 90 minutes ON and 30 minutes OFF 500 ± 50V DC during 1 minute, V-Block method (see Electrical Specification Chart) ±(1% + 0.05Ω) No abnormality in coatings and markings Tensile: ≥ 2.5 Kg In V-Block for 60 seconds 260ºC ± 5ºC, 2 seconds ± 1 second IPA for 5 ± 0.5 minutes with ultrasonic Direct load for 10 seconds, in the direction of the terminal leads Discharge Test: 0.01uf capacitor discharge pulse 10 times (1 pulse / 5 seconds max.) 10KΩ Anti-surge Characteristics 2.5 sec ON 2.5 sec OFF ±(10% + 0.05Ω) DC Source Intermittent Overload SW C=0.01uF Rx 4 times RCWV for 10000 cycles (1 second ON, 25 seconds OFF) ±(1% + 0.05Ω) RCWV (Rated Continuous Working Voltage) = √ P*R Operating Temperature Range: -55ºC to +175ºC Power Derating Curve: Rev Date: 12/14/2022 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com MG / MGM / MGE / MGME Series Stackpole Electronics, Inc. High Voltage Metal Glaze Resistor Resistive Product Solutions Temperature Rise: Recommended Solder Profile This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board density, geometry, packages used, etc., especially those cells labeled with “*”. 100% Matte Tin / RoHS Compliant Terminations Soldering iron recommended temperatures: 330°C to 350°C with minimum duration. Maximum number of reflow cycles: 3. Wave Soldering Description Maximum Recommended Preheat Time 80 seconds 70 seconds Temperature Diff. 140°C 120°C Solder Temp. 260°C 250°C Dwell Time at Max. 10 seconds 5 seconds Ramp DN (°C/sec) N/A N/A Temperature Diff. = Defference between final preheat stage and soldering stage. Minimum 60 seconds 100°C 240°C * N/A Convection IR Reflow Description Maximum Recommended Minimum Ramp Up (°C/sec) Dwell Time > 217°C Solder Temp. Dwell Time at Max. Ramp DN (°C/sec) 3°C/sec 150 seconds 260°C 30 seconds 6°C/sec 2°C/sec 90 seconds 245°C 15 seconds 3°C/sec * 60 seconds * 10 seconds * Rev Date: 12/14/2022 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com MG / MGM / MGE / MGME Series Stackpole Electronics, Inc. High Voltage Metal Glaze Resistor Resistive Product Solutions Recommended Lead Free Resistor Reflow Profile Packaging Specifications Type/Code A B1/B2 2.047 +0.039 /-0.00 0.047 MG14 52.00 +1.00 /-0.00 1.20 2.047 +0.039 /-0.00 0.047 MG12 52.00 +1.00 /-0.00 1.20 2.874 +0.039 /-0.00 0.059 MG1 73.00 +1.00 /-0.00 1.50 2.874 +0.039 /-0.00 0.059 MG2 73.00 +1.00 /-0.00 1.50 2.047 +0.039 /-0.00 0.047 MGM12 52.00 +1.00 /-0.00 1.20 2.047 +0.039 /-0.00 0.047 MGM1 52.00 +1.00 /-0.00 1.20 2.874 +0.039 /-0.00 0.059 MGM2 73.00 +1.00 /-0.00 1.50 2.874 +0.039 /-0.00 0.059 MGM3 73.00 +1.00 /-0.00 1.50 Max. deviation of spacing: 1mm per 10 spacing. Rev Date: 12/14/2022 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. C 0.031 max. 0.80 max. 0.031 max. 0.80 max. 0.031 max. 0.80 max. 0.031 max. 0.80 max. 0.031 max. 0.80 max. 0.031 max. 0.80 max. 0.031 max. 0.80 max. 0.031 max. 0.80 max. 4 D 0.020 max. 0.50 max. 0.020 max. 0.50 max. 0.020 max. 0.50 max. 0.020 max. 0.50 max. 0.020 max. 0.50 max. 0.020 max. 0.50 max. 0.020 max. 0.50 max. 0.020 max. 0.50 max. E 0.047 max. 1.20 max. 0.047 max. 1.20 max. 0.047 max. 1.20 max. 0.047 max. 1.20 max. 0.047 max. 1.20 max. 0.047 max. 1.20 max. 0.047 max. 1.20 max. 0.047 max. 1.20 max. 0.236 6.00 0.236 6.00 0.236 6.00 0.236 6.00 0.236 6.00 0.236 6.00 0.236 6.00 0.236 6.00 F ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 S 0.197 5.00 0.197 5.00 0.197 5.00 0.394 10.00 0.197 5.00 0.197 5.00 0.197 5.00 0.394 10.00 Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com MG / MGM / MGE / MGME Series Stackpole Electronics, Inc. High Voltage Metal Glaze Resistor Resistive Product Solutions Tape on Reel/Tape on Box Specifications Type/Code Quantity per Reel Quantity per Box MG14 5000 5000 MG12 3000 1000 MG1 2000 1000 MG2 1000 1000 MGM12 5000 5000 MGM1 3000 1000 MGM2 2000 1000 MGM3 1000 1000 Tape on Reel Across Flange (A) 2.835 72.00 2.835 72.00 2.835 72.00 3.740 95.00 2.835 72.00 2.835 72.00 3.740 95.00 3.740 95.00 W (A) 3.150 80.00 3.150 80.00 3.150 80.00 4.055 103.00 3.150 80.00 3.150 80.00 4.055 103.00 4.055 103.00 Tape on Box H (B) 2.953 75.00 1.811 46.00 2.953 75.00 3.780 96.00 4.134 105.00 1.811 46.00 3.228 82.00 3.780 96.00 L (C) 10.394 264.00 10.394 264.00 10.394 264.00 10.433 265.00 10.394 264.00 10.394 264.00 10.433 265.00 10.433 265.00 Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series MG MGE MGM MGME Description High Voltage Metal Glaze Leaded Resistor High Voltage Metal Glaze Leaded Resistor (Epoxy Coating) High Voltage Mini Metal Glaze Leaded Resistor High Voltage Mini Metal Glaze Leaded Resistor (Epoxy Coating) Package / Termination Type Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) Axial YES (1) 100% Matte Sn Jan-06 04/01 Axial YES(1) 100% Matte Sn Jan-06 04/01 Axial YES (1) 100% Matte Sn Always Always Axial YES(1) 100% Matte Sn Always Always Rev Date: 12/14/2022 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 5 www.seielect.com marketing@seielect.com MG / MGM / MGE / MGME Series Stackpole Electronics, Inc. High Voltage Metal Glaze Resistor Resistive Product Solutions “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order M Product Series Description Standard Size MG Silicone Coating Mini Size MGM Silicone Coating Standard Size MGE Epoxy Coating Only up to 2W Mini Size MGME Epoxy Coating Code G Size Code W 14 0.25 12 0.5 1 1 2 2 3 3 1 Code F J K 2 Tolerance Tol Value 1% E24 5% 10% Rev Date: 12/14/2022 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. J T Code T A B 6 1 0 0 K Packaging Size Quantity MG14, MGM12 5000 MG12, MGM1 3000 Tape and Reel MG1, MGM2 2000 MG2, MGM3 1000 MG14, MGM12 5000 Ammo MG12, MG1, MG2 1000 MGM1, MGM2, MGM3 Bulk all sizes 1000 Description Resistance Value Four characters with the multiplier used as the decimal holder. 1 Kohm = 1K00 1 Mohm = 1M00 1 Gohm = 1G00 www.seielect.com marketing@seielect.com
MGM2JA51K0
物料型号: - MG14、MG12、MG1、MG2、MGM12、MGM1、MGM2、MGM3
器件简介: - 这些是高压金属釉电阻器,具有1600V至7000V的高电压能力,提供高达500M的高电阻值,并且有低至1%的容差和50ppm/°C的低温度系数。
引脚分配: - 文档中提供了不同型号的电阻器的尺寸信息,包括体长、体径、引脚长度(散装)和引脚直径。
参数特性: - 包括工作电压、欧姆范围(100K - 500M)、功率等级(@ 70ºC)、介电强度、最大过载电压、TCR等。
功能详解: - 电阻器具有阻燃涂层(标准为棕色)、环氧涂层(高达2W,蓝色可选)、符合RoHS和无卤素、REACH合规。
应用信息: - 适用于需要高压和高电阻值的应用场合。
封装信息: - 提供了详细的机械规格,包括尺寸公差和引脚规格,以及推荐的焊接曲线和包装规格。
MGM2JA51K0 价格&库存
很抱歉,暂时无法提供与“MGM2JA51K0”相匹配的价格&库存,您可以联系我们找货
MGM2JA51K0
