SK15U100AAPU
SK15U100AAPU
    SK(時科)
    TO-277
    肖特基二极管 100V 15A 570mV@15A TO-277
SK15U100AAPU 数据手册
SK15U100AAPU 100V Trench MOS Barrier Schottky 15 Amperes, 100 Volts o Ultra Low VF 0.57V@15A, 25 C 2 Features 1 l Trench MOS schottky technology 3 l Low stored charge Majority Carrier 1 Conduction l Ultra low forward voltage drop l Low leakage current 2 3 l Low power loss and high efficiency l High surge capacity l ESD rating:>20K volts Typical Application Schottky rectifier design for high frequency switched mode power supplies, such as adaptators and on board DC/DC converters. TO-277 Device Summary Mechanical Data Case: JEDEC TO-277 , molded plastic body Symbol Value IF(AV) 15 A VRRM 100V VF(Typical) 0.57V Tj(max) 150 C o Terminals: Plated leads, solderable per MIL-STD-750, Method 2026 Mounting Position: Any Note: Pins 2 & 3 must be electrically connected at the printed circuit board. REV.08 1 of 4 SK15U100AAPU Major Rating and Characteristics(per diode) Symbol Parameter Values Units V VRRM Repetitive peak reverse voltage 100 TJ Storage temperature range -55 to 150 IFSM IF(AV) Surge non repetitive forward current 10 ms sine or 6 ms rect. pulse O C 350 A Maximum average forward current 50 % duty cycle, rectangular waveform O Tc=25 C 15 Electrical Characteristics(TA=25 OC unless otherwise noted) Parameter Test condition Symbol IF =5A IF =10A O IF =15A VF(1) IF =5A IF =10A O TA=125 C O Reverse leakage current VR =100V O O VR=5VDC, 25 C(1MHz) - 0.57 0.65 0.41 - V 0.52 0.60 - 50 uA 15 70 mA IR(2) TA=125 C Junction capacitance 0.45 UNITS 0.56 IF =15A TA=25 C MAX 0.51 TA=25 C Forward Voltage drop TYP Cj 1000 pF Notes (1) Pulse test: 300us pulse width,2% duty cycle (2) Pulse test: 300us pulse width,2% duty cycle Thermal Characteristics(TA=25 OC unless otherwise noted) Parameter Symbol Typical thermal resistance RJA(1) RJM(2) SK15U100AAPU 75 34 UNIT O C /W Notes (1) Free air, mounted on recommended PCB, 2oz.pad area; thermal resistance RJA-junction to ambient (2) Cathode pad dimensions 18.8mm x 14.4mm. Anode pad dimensions 5.6mm x 14.4mm; RJM-junction to mount REV.08 2 of 4 SK15U100AAPU Characteristics Curves(TA=25 O C unless otherwise noted) Fig.1 Typical Forward Voltage Characteristics Fig.2 Typical Reverse Leakage Characteristics O 150 C O 125 C O 100 C O 75 C O O 150 C 25 C O 100 C O 125 C REV.08 O O 75 C 25 C 3 of 4 SK15U100AAPU Package Outline Dimensions in Millimeters REV.08 4 of 4
SK15U100AAPU 价格&库存
很抱歉,暂时无法提供与“SK15U100AAPU”相匹配的价格&库存,您可以联系我们找货
SK15U100AAPU
    • 5000+1.04874
    库存:48000
    SK15U100AAPU
      • 5000+1.01479
      库存:3000
      SK15U100AAPU
        • 5000+1.04874
