S2012CHUBW-002
S2012CHUBW-002
    INHERE(银河光电)
    LED指示灯 白雾面蓝光 0805 455nm~465nm 130mcd 正贴
S2012CHUBW-002 数据手册
Technical Data Sheet Customer Part No.: Inhere Part No.: S2012CHUBW-002 Part Name: 2012 白雾面蓝光 LED Spec Issue Date: 2023-07-11 Revision No.: A ============================================================================================= To Customer: We submit herewith the following information for your approval: ■Sample □OQC Inspection Record ■LED Dimension ■Electrical Characteristics Curve ■Internal Circuit Diagram ■Soldering recommendation Prepared by : Lily Date : 2023-07-11 Checked by : Tom Date : 2023-07-11 Approved by : Evan Date : 2023-07-11 ============================================================================================= Customer Opinion Approve and no objection Reject with the following reason: _____________________________________________________________________________________________ 恒润科技(香港)有限公司 Hengrun Technology (HK) Ltd. Unit C, 2/F, Wah Lai Building, 2 Lo Lung Hang St.,Hung Hom, Kowloon, Hong Kong Tel: 852-26400182 Fax: 852-31862408 E-mail: bill@inhereopto.com 1 / 10 东莞市恒润光电有限公司 Dongguan Heron Opto Co., Ltd. Building D, Guancheng Science & Technology Park Dongguan, Guangdong, China Tel: 0769-23328389 Fax: 0769-23328390 E-mail: bill@inhereopto.com Features 2.0mm×1.25mm SMD LED, 0.8mm thickness Low power consumption Wide view angle Package: 3000pcs/reel RoHS Compliant Applications Ideal for back light and indicator Various colors and lens types available Package Outlines Recommend Pad Layout 1 2 1.25 [0.05"] Polarity m ark 2.00 [0.08"] 0.50 [0.02"] 0.80 [0.03"] 1.30 [0.05"] 3.00° ATTENTION 1.20 [0.05"] 1.20 [0.05"] 1 2 OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES 1 2 Part No. Emitted color Dice Lens color S2012CHUBW-002 Blue InGaN/GaN White Diffused Notes: 1. All dimensions are in millimeters (inches). 2. Tolerances are  0.1mm (0.004inch) unless otherwise noted. Part No.: S2012CHUBW-002 Prepared by: Lily Rev.: A Checked by: Tom 2 / 10 Date: 2023-07-11 Approved by: Evan Absolute Maximum Ratings (Ta=25℃) Parameter Symbol Value Unit Forward current If 30 mA Reverse voltage Vr 5 V Power dissipation Pd 108 mW Operating temperature Top -40 ~+100 ℃ Storage temperature Tstg -40 ~+100 ℃ Peak pulsing current (1/10 duty f=1kHz) Ifp 125 mA Electro-Optical Characteristics (Ta=25℃) Value Parameter Test Condition Symbol Unit Min Typ Max Wavelength at peak emission If=20mA λp -- 456 -- nm Spectral half bandwidth If=20mA △λ -- 23 -- nm Dominant wavelength If=20mA λd 455 -- 465 nm Forward voltage If=20mA Vf 2.8 -- 3.6 V Luminous intensity If=20mA Iv 80 130 -- mcd Viewing angle at 50% Iv If=20mA 2θ1/2 -- 120 -- Deg Vr=5V Ir -- -- 10 A Reverse current Part No.: S2012CHUBW-002 Prepared by: Lily Rev.: A Checked by: Tom 3 / 10 Date: 2023-07-11 Approved by: Evan Optical Characteristic Curves Ta =25℃ Relative Radiant Intensity 1.0 0.5 0 350 450 400 500 600 550 650 50 2.5 40 2.0 Luminous Intensity Relative Value of IF=20mA Forward Current (mA) Wavelength (nm) RELATIVE INTENSITY Vs.WAVELENGTH 30 20 10 0 2.7 2.9 3.1 3.3 3.5 3.7 1.5 1.0 0.5 0 0 Forward Voltage (V) FORWARD CURRENT Vs. FORWARD VOLTAGE 20 30 40 50 2.5 Relative Luminous Intensity Forward Current (mA) 50 40 30 20 10 0 0 20 40 60 80 100 120 2.0 1.5 1.0 0.5 0 -40 -20 Ambient Temperature TA (℃) FORWARD CURRENT DERATING CURVE Part No.: S2012CHUBW-002 Prepared by: Lily 10 IF-Forward Current (mA) LUMINOUS INTENSITY Vs. FORWARD CURRENT 0 20 40 60 80 100 Ambient Temperature TA (℃) LUMINOUS INTENSITY Vs. AMBIENT TEMPERATURE Rev.: A Checked by: Tom 4 / 10 Date: 2023-07-11 Approved by: Evan Reflow Profile  Reflow Temp/Time 300 (℃ ) 10 S Max. 260℃ Max. 250 230℃ 4℃ /S Max. 200 150~180℃ 4℃ /S Max. Temperature 150 60~120 S 100 30~50 S 50 25℃ 0 50 100 150 200 Time Notes: 250 300 (sec) 1. We recommend the reflow temperature 245℃ (±5℃).the maximum soldering temperature should be limited to 260℃. 2. Don’t cause stress to the epoxy resin while it is exposed to high temperature. 3. Number of reflow process shall be 2 times or less. Soldering iron Basic spec is  5sec when 320(±20℃). If temperature is higher, time should be shorter (+10℃ -1sec). Power dissipation of iron should be smaller than 20W, and temperatures should be controllable. Surface temperature of the device should be under 350℃. Rework 1. Customer must finish rework within 5 sec under 340℃. 2. The head of iron cannot touch copper foil. 3. Twin-head type is preferred. Correct( ) Mistake( )  Avoid rubbing or scraping the resin by any object, during high temperature, for example reflow solder etc. Part No.: S2012CHUBW-002 Prepared by: Lily Rev.: A Checked by: Tom 5 / 10 Date: 2023-07-11 Approved by: Evan Test Circuit and Handling Precautions  Test circuit R + V - LED  Handling precautions 1. Over-current-proof Customer must apply resistors for protection; otherwise slight voltage shift will cause big current change (Burn out will happen). 2. Storage 2.1 It is recommended to store the products in the following conditions: Humidity: 60% R.H. Max. Temperature: 5℃~30℃ 2.2 Shelf life in sealed bag: 12 month at <5℃~30℃ and <30% R.H. after the package is opened, the products should be used within 168hrs or they should be keeping to stored at≦20 R.H. with zip-lock sealed. 3. Baking It is recommended to baking before soldering when the pack is unsealed after 168hrs. The Conditions are as followings: 3.1 60±3℃ x (12~24hrs) and <5%RH, taped reel type 3.2 100±3℃ x (45min~1hr), bulk type 3.3 130±3℃ x (15~30min), bulk type Part No.: S2012CHUBW-002 Prepared by: Lily Rev.: A Checked by: Tom 6 / 10 Date: 2023-07-11 Approved by: Evan Test Items and Results of Reliability Test Item Standard Test Conditions Test Method Note Number of Test Reflow Soldering Ta=260±5℃,Time=10±2S JB/T 10845-2008 3times 0/22 Salt Atmosphere Ta=35±3℃,PH=6.5~7.2 GB/T 2423.17-2008 24hrs 0/22 Temperature Cycling -40±5℃ 30±1min ↑→(25℃/5±1min)↓ 100±5℃ 30±1min GB/T 2423.22-2012 100cycles 0/22 Thermal Shock Ta=-40±5℃~100±5℃, 15±1min dwell GB/T 2423.22-2012 100cycles 0/22 High Humidity High Temp. Cycling Ta=30±5℃~65±5℃, 90±5%RH,24hrs/1cycle GB/T 2423.4-2008 10cycles 0/22 High Humidity High Temp. Storage Life Ta=85±5℃,ψ(%)=85±5%RH GB/T 2423.3-2006 1000hrs 0/22 High Temperature Storage Life Ta=100±5℃,non-operating GB/T 2423.2-2008 1000hrs 0/22 Low Temperature Storage Life Ta=-40±5℃,non-operating GB/T 2423.1-2008 1000hrs 0/22 -- 1000hrs 0/22 Life Test Ta=26±5℃,@20mA, ψ(%)=25%RH~55%RH High Humidity High Temp. Operating Life Ta=85±5℃,@20mA, ψ(%)=85%RH GB/T 2423.3-2006 500hrs 0/22 Low Temperature Operating Life Ta=-20±5℃,@20mA GB/T 2423.1-2008 1000hrs 0/22 Part No.: S2012CHUBW-002 Prepared by: Lily Rev.: A Checked by: Tom 7 / 10 Date: 2023-07-11 Approved by: Evan Forward Voltage Rank Combination (IF=20mA) Rank Min. Max. H 2.8 2.9 I 2.9 3.0 J 3.0 3.1 K 3.1 3.2 L 3.2 3.3 M 3.3 3.4 N 3.4 3.5 O 3.5 3.6 Unit V Luminous Intensity Rank Combination (IF=20mA) Rank Min. Max. I 80 100 J 100 125 K 125 160 L 160 200 M 200 250 N 250 -- Unit mcd Dominant Wavelength Rank Combination (IF=20mA) Rank Min. Max. C 455 457.5 D 457.5 460 E 460 462.5 F 462.5 465 Unit nm Group Name on Label (Example DATA: K K D 20) DATA: K K D 20 Vf(V) Iv (mcd) λd (nm) Test Condition KKD20 3.1~3.2 125~160 457.5~460 IF=20mA Notes: 1. The tolerance of forward voltage is±0.05V. 2. The tolerance of luminous intensity (Iv) is±15﹪. 3. The tolerance of dominant wavelength is±1nm. 4. This specification is preliminary. 5. This specification is a standard specification of our factory, can make in accordance with customer's special requirement. Part No.: S2012CHUBW-002 Prepared by: Lily Rev.: A Checked by: Tom 8 / 10 Date: 2023-07-11 Approved by: Evan 2012 Series SMD Chip LED Lamps Packaging Specifications Dimensions of Reel (Unit: mm)  Feeding Direction  Feeding D irection R oH S 57.54 [2.27"] 13.30 [0.52"] 颜色标签 Lable 178.50 [7.03"] 9.40 [0.37"] Dimensions of Tape (Unit: mm) SEC .A -A 2.00 [0.08"] 1.75 [0.07"] 0.20 [0.01"] 8.00 [0.31"] A 5.25 [0.21"] 4.00 [0.16"] 1.10 [0.04"]  1.05 [0.04"] 4.00 [0.16"]  A Arrangement of Tape Em pty parts (M in.25pcs) Loaded parts (LED :3000pcs) Em pty parts (M in.75pcs) Feeding D irection C onclusion parts (M in.100m m ) Introduction parts (M in.300m m ) Notes: 1. Empty component pockets are sealed with top cover tape. 2. The maximum number of missing lamps is two. 3. The cathode is oriented towards the tape sprocket hole in accordance with ANSI/EIA RS-481 specifications. 4. 3,000pcs/Reel. Part No.: S2012CHUBW-002 Prepared by: Lily Rev.: A Checked by: Tom 9 / 10 Date: 2023-07-11 Approved by: Evan 2012 Series SMD Chip LED Lamps Packaging Specifications  Packaging specifications M oisture-proof bag 颜色标签 R eel(3,000PC S) R oH S R oH S L able L able HS Ro La ble e bl La Ro HS Inside box M axim um s ten reels O utside box M axim um s four inside boxes Notes: Reeled products (numbers of products are 3,000pcs) packed in a seal off moisture-proof bag along with a desiccant one by one, ten moisture-proof bag of maximums (total maximum number of products are 30,000pcs) packed in an inside box (about size: 240x 230x 130mm) and four inside boxes of maximums are put in the outside box (about size: 545mm x 260mm x 250mm) Together with buffer material, and it is packed. (Part No., Lot No., quantity should appear on the label on the moisture-proof bag, part No. And quantity should appear on the label on the cardboard box.) The number of the loading steps of outside box (cardboard box) has it to three steps. Part No.: S2012CHUBW-002 Prepared by: Lily Rev.: A Checked by: Tom 10 / 10 Date: 2023-07-11 Approved by: Evan
S2012CHUBW-002 价格&库存
很抱歉,暂时无法提供与“S2012CHUBW-002”相匹配的价格&库存,您可以联系我们找货
