MT857X
Omni-polar, High Voltage & Low Power
Consumption Hall-Effect Switch IC
1 Product Description
The MT857X family is produced by BCD technology
with both high performance and high reliability. The
Hall IC internally includes an on-chip Hall voltage
generator, a voltage regulator for operation with
supply voltage of 3.0V to 24V, temperature
compensation circuitry, small-signal amplifier, Hall IC
with dynamic offset cancellation system, Schmitt
trigger and 10K internal pull-up resistor. It also
includes an clamp diode at output and reversed
power supply protection enhances the robustness of
Hall IC.
The product responds to either North pole or South
pole magnetic fields. The output will be turned on
(Low) when the magnetic flux density (B) is larger
than the operating point (BOP), and be turned off
(High) when the magnetic flux density (B) is lower
than the releasing point (BRP).
The MT857X family provides a variety of packages to
customers: SOT-23 for surface mount and flat TO-92
for through-hole mount. All packages are RoHS
compliant.
2 Features
BCD Technology
Omni-polar Switch
3.0~24V Operating Vcc Range
-40℃~125℃ Operating Temperature
Package Option:
Flat TO-92
SOT-23
Magnetic Sensitivity Option:
MT8571 (BOP=±32Gs, BRP=±27Gs)
MT8572 (BOP=±80Gs, BRP=±60Gs)
MT8573 (BOP=±60Gs, BRP=±45Gs)
Internal 10K pull-up resistor
-16V Reversed Power Supply Protection
Output Limiting Current Protection
RoHS Compliant: (EU)2015/863
4 Applications
Home appliances, Industrial
Position Detection
Magnetic Encoder
Proximity Switch
5. Pin Configuration and Functions
VCC
Out
GND
SOT-23
1
2
3
Flat TO-92
1
3
2
Description
Power
Internal
Pull-up
Resistor
Ground
3 Product Overview of MT857X
Part No.
Description
MT857XA
Flat TO-92, bulk packaging
(1000pcs/bag)
MT857XAT
SOT-23, tape & reel
(3000pcs/bag)
Figure.1
magntek.com.cn | Magnetic Tech Makes Magic Change
1
Pin Configuration & Functions
Rev
1.6
MT857X
Omni-polar, High Voltage & Low Power Consumption Hall-Effect Switch IC
Table of Contents
1
Product Description………...…….……………….……...…………………………………….…….………1
2
Features……………………………….……..……………………………………………………………….…….1
3
Product Overview of MT857X ..…………………………………………………………………………1
4
Applications……………………………………………………………………………………………………….1
5
Pin Configuration and Functions…………………………………………………….………………….1
6
Definition of Switching Function……………………………………………………………………….3
7
Function Description……...…………………………………………………………………………………..3
8
Feature Description……………………………………………………………………………………………3
9
Functional Block Diagram…………………………………………………………………………………..4
10
Electrical and Magnetic Characteristics………………………………………………………………4
10.1 Absolute Maximum Ratings……………………………………………………………………………….4
10.2 Electrical Specifications……………………………………………………………………………………..5
10.3 Magnetic Characteristics……………………………………………………………………………………5
10.4 ESD Ratings………………………………………………………………………………………………………..5
10.5 Characteristic Performance………………………………………………………………….…………….6
10.6 Typical Output Waveform…………………………………………………………………………………..7
11
Typical Application Circuit………………………………………………………………………………….7
12
Package Material Information……………………………………………………………………………8
12.1 SOT-23 Package Information……………………………...………………………………………………8
12.2 Flat TO-92 Package Information………………………………………………………………………9
13
Copy Rights and Disclaimer……………………………………………………………………………..10
1
2
3
4
5
Originally Version
1.1 Version
1.2 Version
1.3 Version
1.4 Version
6
7
1.5 Version
1.6 Version
Reversion History
Update Pin Configuration and Functions for SOT-23
Update Copy Rights and Disclaimer
Update Electrical Specifications
Update MT8572 & MT8573 Series
Update the marking spec of SOT-23
Update the Magnetic Spec of MT8571
Update the Magnetic Spec of MT8573
2
Rev
1.6
MT857X
6 Definition of Switching Function
Figure.2 shows the device functionality and hysteresis
Vcc
North
Figure.2
BOP N BRP N
BRP S
BOP S
South
Omni-polar Switching Function
7 Function Description
BOP: Operating Point, Magnetic flux density applied on the branded side of the package which turns the
output driver ON (VOUT=Low)
BRP: Releasing Point, Magnetic flux density applied on the branded side of the package which turns the
output driver OFF (VOUT=High)
BHYST: Hysteresis Window, |BOP - BRP|
Devices that have a lower magnetic threshold (VOUT=High) detect magnets at a farther distance. Higher
thresholds (VOUT=Low) generally require a closer distance or larger magnet.
8 Feature Description
The MT857X device is sensitive to the magnetic field component that is perpendicular to the top of the
package
or
or
or
S
N
S
N
N
S
N
S
SOT-23
Figure.3
Motion
or
S
N
S
N
N
S
N
S
Flat TO-92
SOT-23
Flat TO-92
PCB
PCB
VOUT = Low
VOUT= High
Flux Direction Polarity
3
Rev
1.6
MT857X
9 Functional Block Diagram
Vcc
Dynamic
Offset
Cancelation
Regulator
Limiting
Current
Protection
10KΩ
Reference
ESD
Out
Hall Plate
ITA
COMP
Output Driver
ESD
GND
Figure.4
10 Electrical and Magnetic Characteristics
Absolute maximum ratings are limited values to be applied individually, and beyond which the
serviceability of the circuit may be impaired. Functional operability is not necessarily implied. Exposure to
absolute maximum rating conditions for an extended period of time may affect device reliability.
Symbol
Parameters
Min
Max
Units
VCC
Supply Voltage
30
V
VRCC
Reverse Battery Voltage
-16
V
VOUT
Output Voltage
30
V
IOUT
Continuous Output Current
55
mA
TA
Operating Ambient Temperature
-40
125
TS
Storage Temperature
-50
150
TJ
Junction Temperature
165
B
Magnetic Flux Density
No Limit
4
Gs
Rev
1.6
MT857X
At TA=-40~150 ℃, Vcc=3.0V~24V (unless otherwise specified)
Symbol
Parameters
Test Condition
Min
Typ
Max
Unit
VCC
Supply Voltage
Operating
3.0
24
V
ICC
Supply Current
∣B∣∣BOP∣,
VOUT=Vcc
50
mA
VDSON
Output Saturation Voltage
IOUT=20mA,
∣B∣>∣BOP∣
0.4
V
IOFF
Output Leakage Current
VOUT=24V,
∣B∣5V/uS
∣B∣>∣BOP∣ (MAX)
15
us
FC
Chopping Frequency
400
KHz
FS
Sampling Frequency
25
KHz
Thermal Resistance of SOT-23
301
℃/W
Thermal Resistance of TO-92
230
℃/W
RTH
At VCC=3.0V~24V (unless otherwise specified)
Part No.
Symbol
Min
Typ
Max
Unit
BOP, TA =25℃
23
±32
41
Gs
MT8571 Series BRP, TA =25℃
18
±27
36
Gs
5
Gs
BOP, TA =25℃
±55
±80
±105
Gs
MT8572 Series BRP, TA =25℃
±35
±60
±85
Gs
10
Gs
BOP, TA =25℃
±35
±60
±85
Gs
MT8573 Series BRP, TA =25℃
±20
±45
±70
Gs
5
15
25
Gs
BHYST, TA =25℃
BHYST, TA =25℃
BHYST, TA =25℃
10.4 ESD Ratings
Symbol
VESD
Reference
Level
Unit
Human-body model (HBM)
AEC-Q100-002
Class H2
Grade
Charged-device model (CDM)
AEC-Q100-011
Class C3
Grade
5
Rev
1.6
MT857X
MT8571 At VCC=5V
Supply Current (mA)
1.4
1.2
1
0.8
0.6
0.4
0.2
25
125
Temperature ℃
Supply Current vs. Temperature
Bop S
Brp S
5
Bop N
Brp N
-5
-15
-40
85
125
-25
-35
Temperature ℃
MT8571
Magnetic Field Intensity (Gs)
Figure.6
10
8
6
4
2
-4
-6
-8
-10
-40
MT8571
Figure.7
100
80
60
40
-40
-60
-80
-100
80
-40
Bop S
Brp S
Bop N
Brp N
85
125
15
25
60
40
-40
Bop S
Brp S
Bop N
Brp N
85
125
-40
-60
-80
Temperature ℃
Temperature ℃
MT8573
MT8572
Magnetic Characteristics vs. Temperature (BOP & BRP)
Bhyst S
25
85
125
Bhyst N
Temperature ℃
35
25
10
5
-10
-15
-20
-25
Bhyst S
-40
Bhyst N
25
85
Temperature ℃
125
Figure.5
15
10
5
Bhyst S
-40
Bhyst N
25
85
-10
-15
-20
Temperature ℃
MT8573
MT8572
Magnetic Characteristics vs. Temperature (BHYST)
6
Rev
1.6
125
MT857X
MT8571A as example
B
BOP S
BRP S
T
BRP N
BOP N
V
High
Low
Figure.8
T
Digital Output vs. Magnetic Flux Density
11 Typical Application Circuit
MT8571AT as example
C1=100nF
Vcc
1
按钮
Vcc
OUT
3
GND
GND
2
Out
C2=1nF
Figure.9
7
Rev
1.6
MT857X
12 Package Material Information (For Reference Only – Not for Tooling Use)
3
XXXX
按钮
Product ID
按钮
2
1
OUT
Vcc
Figure.10
DateCode:
Y: Year W: Week
YW
GND
XXXX YW
SOT-23 Chip Marking Spec
Sensing
Center
Figure.11
SOT-23 Package Drawing
Symbol
Dimensions in Millimeters
Dimensions in Inches
Min
Max
Min
Max
A
1.050
1.250
0.041
0.049
A1
0.000
0.100
0.000
0.004
A2
1.050
1.150
0.041
0.045
b
0.300
0.500
0.012
0.020
c
0.100
0.200
0.004
0.008
D
2.820
3.020
0.111
0.119
E
1.500
1.700
0.059
0.067
E1
2.650
2.950
0.104
0.116
e
0.950 TYP
0.037 TYP
e1
1.800
2.000
0.071
0.079
L
0.300
0.600
0.012
0.024
θ
0︒
8︒
0︒
8︒
x
1.460 TYP
0.057 TYP
y
0.800 TYP
0.032 TYP
z
0.600 TYP
0.024 TYP
8
Rev
1.6
MT857X
12.3 Flat TO-92 Package Information
XXXX
XXXX
YWW
Product ID
YWW
DateCode: week (01~55)
DateCode: year (0~9)
3 OUT
2 GND
1 Vcc
Figure.14
Flat TO-92 Chip Marking Spec
Sensing
Center
Figure.15
Flat TO-92 Package Drawing
Symbol
Min
Max
Min
Max
A
1.420
1.620
0.056
0.064
A1
0.660
0.860
0.026
0.034
b
0.350
0.480
0.013
0.019
b1
0.400
0.510
0.016
0.020
c
0.330
0.510
0.013
0.020
D
3.900
4.100
0.154
0.161
D1
2.280
2.680
0.090
0.106
E
3.050
3.250
0.120
0.128
e
1.270 TYP
0.050 TYP
e1
2.440
2.640
0.096
0.104
L
14.350
14.750
0.565
0.581
θ
45︒ TYP
45︒ TYP
x
2.025 TYP
0.080 TYP
y
1.545 TYP
0.061 TYP
z
0.500 TYP
0.020 TYP
9
Rev
1.6
MT857X
13 Copy Rights and Disclaimer
1. This document may not be reproduced or duplicated, in any form, in whole or in part without prior
written consent of MagnTek . Copyrights © 2019, MagnTek Incorporated.
2. MagnTek reserves the right to make changes to the information published in this document at
anytime without notice.
3. MagnTek’s products are limited for use in normal commercial applications. MagnTek’s products are
not to be used in any device or system, including but not limited to medical life support equipment and
system.
For the latest version of this document, please visit our website: www.magntek.com.cn
10
Rev
1..4
很抱歉,暂时无法提供与“MT8571AT”相匹配的价格&库存,您可以联系我们找货
