MPX684K7BA8A50R00
MPX684K7BA8A50R00
    HEL(鸿志)
    CAP_18X8.5MM_TM
    薄膜电容 X2 680nF ±10% 310VAC P=15
MPX684K7BA8A50R00 数据手册
REFFILENO:RF220624003 EDITION NO: A 规 格 承 认 书 SPECIFICATION FOR APPROVAL 客 户 CUSTOMER NAME : 项 目 DESCRIPTION TYPE:MPX ( X2 ) : METALLIZED POLYPROPYLENE FILM INTERFERENCE SUPPRESSION CAPACITOR 客 户 料 号 CUSTOMER’S P/N 鸿 志 料 金属化聚丙烯膜抗干扰电容器 : X2 684K310VAC P=15 号 HEL S P/N : MPX684K7BA8A50R00 ※Thisspecification will be invalidated assuming that it is notaccepted when it is notreturned with oneyear from thedate of issue CUSTOMER APPROVAL PREPARE HEL APPROVAL PREPARE HEL HONG ZHI ENTERPRISE CO ADD: No.6,Pujiang Road,Shantou,Guangdong TEL: 0754-88788046 FAX: 0754-88784178 http: www.hongzhi.net emquiry:hongzhi@hongzhi.net issed date:2021-5-17 Edit:A HEL HONGZHI ELECTRONIC Ltd PLASTIC FILM CAPACITORS TYPE: MPX T W L=2.8±0.3mm H x ma H A CUSTOMER P/N CAP (μF) B CAP TOL (±%) RATED VOLTAGE (VAC) DIMENSION(mm) 1KHZ DF% (MAX) W+0.4/0.7 0.68 http: www.hongzhi.net 10 310 D C 0.1 18.0 HongZhi P/N H±0.4 T±0.4 14.5 8.5 emquiry:hongzhi@hongzhi.net 1 P Ød 15.0 0.7 MPX684K7BA8A50R00 issed date:2021-5-17 Edit:A Fig A HONGZHI ELECTRONIC HEL Ltd PLASTIC FILM CAPACITORS 1. SAFETY APPROVAL STANDARDS Specification Subject File No CQC(GB/T 14472-1998) Interference suppression capacitor CQC07001018754 UL(UL1414) Across the line ,Antenna coupling and line by pass capacitor E192572 CSA (CSA C22.2 NO-104) Across the line,Audio and Video equipment 2273014 VDE(IEC60384-14-Ⅲ EN132400) Fixed capacitor for electromagnetic interference suppression and connection to the supply mains 40023936 ENEC(IEC60384-14-Ⅲ EN132400) Fixed capacitor for electromagnetic interference suppression and connection to the supply mains NO2154 2. NUMBER DECODE REGULATION MPX 684  SERIES PEI PES MPS MSB K 7B A8 A5     0R0 0    1. 2. PEN PST MPE PSC MES PPS MEM PSM RATED CAPACITANCE CODE 101 PF 100PF NF μF 3. TOLERANCE Tolerance Symbols 4. MEB PSH 102 1000PF 1 NF 0.001μF ±1% F RATED VOLTAGE A B MMB PSB ±2% G MET PHB MEF MPX 103 10000PF 10 NF 0.01μF PPL MX1 PPN MPY 104 100000PF 100 NF 0.1μF ±2.5% H ±3% I PPT SKC MPP PSA MPB PSR 105 1000000PF 1000 NF 1.0μF ±5% J I MPF PAC 106 10μF ±10% K ±20% M C D E F G H J K 0 1.0 1.25 1.6 2.0 2.5 3.15 4.0 5.0 6.3 8.0 1 10 12.5 16 20 25 31.5 40 50 63 80 2 100 125 160 200 250 315 400 500 630 800 3 1000 1250 1600 2000 2500 3150 4000 5000 6300 8000 4 10000 12500 16000 20000 25000 31500 40000 50000 63000 80000 7 175VAC 275VAC 305VAC 5. MPT PCC L WIDTH OR DIAMETED mm 0 A B C D E 10 20 30 40 50 1 1 11 21 31 41 51 A1=11mm, -1=1mm , -2=2.5mm, -7=7.5mm http: www.hongzhi.net 2 2.5 12.5 22.5 32.5 42.5 52.5 3 3 13 23 33 43 53 4 4 14 24 34 44 54 5 5 15 25 35 45 55 6 6 16 26 36 46 56 7 7.5 17.5 27.5 37.5 47.5 57.5 8 8 18 28 38 48 58 B3=23mm emquiry:hongzhi@hongzhi.net 2 issed date: 2021-5-17 Edit:A 9 9 19 29 39 49 59 HEL HONGZHI ELECTRONIC Ltd PLASTIC FILM CAPACITORS 6. PITCH OF LENGTH mm 0 10 1 1 11 2 2.5 12.5 3 3 13 4 4 14 5 5 15 6 6 16 7 7.5 17.5 8 8 18 9 9 19 20 30 40 50 60 21 31 41 51 61 22.5 32.5 42.5 52.5 62.5 23 33 43 53 63 24 34 44 54 64 25 35 45 55 65 26 36 46 56 66 27.5 37.5 47.5 57.5 67.5 28 38 48 58 68 29 39 49 59 69 G H 70 80 71 81 72.5 82.5 73 83 74 84 75 85 76 86 77.5 87.5 78 88 79 89 I 90 91 92.5 93 94 95 96 97.5 98 99 A B C D E F A1=11mm, -1=1mm , -2=2.5mm, -7=7.5mm 7. B3=23mm LEAD STYLE          0. no forming; 1. strait forming; 2. out kink & flat forming; 3. in kink & stand kink; 4. strait cut short lead; 5. inner forming and short lead ; 6. out forming short lead; 7. in kink short lead & stand form short lead; 8. double king short lead. 8. LEAD LENGTH mm Code T Meaning Tapping 0 1 2 3 4 5 6 7 8 9 3.5 3.8±0.3 4±0.5 4.5 5±0.5 5±1 6 7 8 Code 9 A B C D E F G H J K L Meaning 10 11 12 13 14 15 16 17 18 19 20 Code M N P Q R S U V W X Y Meaning 21 22 23 24 25 30 35 40 45 50 55 Code Z Meaning 60above 9.10. CONSTRUCTION CODE (internal use) http: www.hongzhi.net emquiry:hongzhi@hongzhi.net 3 issed date: 2021-5-17 Edit:A HONGZHI ELECTRONIC HEL PLASTIC FILM CAPACITORS 3. SPECIFICATIONS: 1. OPERATING TEMPERATURE: -40℃~+105℃ 2. CAPACITANCE RANGE: 0.01μF~2.2μF 3. CAPACITANCE TOLERANCE: ±5%(J), ±10%(K), ±20%(M) 4. RATED VOLTAGE: 275VAC~, 310VAC 5. DISSIPATION FACTOR: 0.1% MAX AT 1KHZ, 25℃ 6. INSULATION RESISTANCE: >35000 MΩ(C≦0.33μF); 1000 MΩ·μF (C>0.33μF) 7. 7. MAX. Pulse rise time (dv/dt) : 4. . PERFORMANCE VR (ac) 275VAC 10mm 500 15mm 400 Lead spacing 22.5mm 27.5mm 200 140 37.5mm 100 Test Characteristics GB/T 14472 (IEC 60384-14) Performance Withstand voltage: Between terminals (4.3Ur ) For1800VDC 2 sec. Shall be no abnormality Withstand voltage: Between terminals & enclosure For 2.0UR+1500VAC 2 sec Shall be no abnormality Insulation resistance: Between terminals Apply rated voltage ±15% for 60 sec. When rated voltage under 100V. Apply 100V ±15% when rated voltage from 100V to 500V at 20 ℃. ≧30,000MΩ Insulation resistance: Between terminals & enclosure Heat proof: Insulation resistance at 85℃ ≧30,000MΩ Heat proof: Rate of variation of capacitance at 85℃ Testing temperature: 85±2℃. +5% Within-2% of the value before test Impulse voltage According to fig.1, before endurance No permanent breakdown or flashover Endurance According to fig.2 with U2=1000VAC X: U1=1.25UR VAC Voltage proof C, DF and insulation Vibration 3 directions at 2 hours each 10-500Hz at 0.75mm or 98m/s2 No visible damage; No open or; Short circuit Bump 4000 bumps at 390m/s2 No visible damage ; No open or Short circuit Change or temperature Solderability Upper and lower rated temperature 5 cycles Solder globule method Passive flammability Flame exposure time depending on severity Active flammability Surge pulses +URVAC No visible damage Wetting time for d≦0.80.80.022 1000 PCS C≦0.022 1500 PCS EIA STANDARD RS-296-D C>0.047 1000 PCS C≦0.047 1500 PCS Optional design Hub recess I. D. “E” Arbor hole “C” B 6.35mm -2 260±2 330±2 +5 W1 W2 PACKING Q’TY PER REE/BOX 50 +5 A B C ≦1.2mm Label Dia “D” A Recess depth 9.5m m (0.374”) minimum ≦0.8mm 1. Reel label consists of: 2. Component type 3. Electrical values; 4. Manufacturer’s name 5. Date ; EIA Std. RF Spec Core diameter ”F” 6. Component quantity CAPACITOR BODY DIAMETER ≧5mm (≧ 0.197”) 5.01~10mm (0.197~0.394”) 10.01~15mm (0.394~0.591”) CAPACITOR PITCH”A”±0.5mm (0.020”) 5mm or 0.200” 10mm or 0.400” 15mm or 0.600” CAPACITOR BODY LENGTH INSIDE TAPE SPACING “B” ±1.5mm (0.059”) ≧16.50mm (≧0.65”) 16.51~28.45mm (0.651~1.12”) 28.46~37.00mm (1.121~1.45”) 52.44mm or 2.062” 63.5mm or 2.500” 76.0mm or 2.874” C 13.9~38.1mm (0.54~1.50”) 14.50mm (0.570”) CAPACITOR BODY DIA. ≧ 5.0mm 5.1~7.0mm 7.1~9.5mm http: www.hongzhi.net D 76.2~355.6mm (3.0~14.0”) 381.0mm (15”) E 28.6~78.0mm (1.126~3.071”) 54.2mm (2.130”) PITCH 6mm 10mm 10mm F 34.5~92.0mm(1.374’3.626”) 61.0mm (2.401”) QUANTITY PCS/REEL 4000 max 2000 max 1000 max emquiry:hongzhi@hongzhi.net 6 issed date: 2021-5-17 Edit:A HEL HONGZHI ELECTRONIC Ltd PLASTIC FILM CAPACITORS 10.METALLIZED POLYPROPYLENE FILM INTERFERENCE SUPPRESSION CAPACITOR- - -X2 Characteristics of voltage derating to frequency --- MPX 275VAC V(rms) Permissible Votage 1000 474 100 103 225 1K 10K 100K 1000K 683 Frequency NOTE: The graphs illustrated above are for reference only wave form of current and temperature rise of capacitor are key factors to determine permissible current. For actual applicant on. Consult our sales represent ative or sales office. 7
MPX684K7BA8A50R00 价格&库存
很抱歉,暂时无法提供与“MPX684K7BA8A50R00”相匹配的价格&库存,您可以联系我们找货
