RWTF032FM1SC
RWTF032FM1SC
    METORAGE(星火半导体)
    存储卡 32GB 2.7V~3.6V microSDHC
RWTF032FM1SC 数据手册
Tentative Product Specification - RWTF032FM1SC (32GB microSDHC Memory Card) Document Number: M22012 (Version 1.2) 【Overview】 ⚫ ⚫ ⚫ Flash Type ■ YMTC Bus Speed Mode ■ UHS-I, SDR104 Speed Class ⚫ Class 10 ■ A2 ■ U1 ■ V10 Power Consumption ■ Power Up Current < 250uA ■ Standby Current < 1000uA ⚫ ■ ⚫ ■ ■ ⚫ ⚫ Advanced Flash Management ■ ECC Correction ■ Wear Leveling ■ Bad Block Management Supply Voltage 2.7 ~ 3.6V Temperature Range(Ta) ■ Operation: -40°C ~ 85°C ■ Storage: -40°C ~ 85°C RoHS compliant Read Current < 150mA Write Current < 150mA Metorage Semiconductor Technology Co.,Ltd. Confidential Tentative RWTF032FM1SC History of Specification Change Revision History Date Author 1.0 First release.(Tentative Specification) 2022/07/11 Fang 1.1 Update CID Register 2022/07/20 Fang 2022/09/16 Fang 1.2 1.Modify chapter 5.2 2.Modify chapter 6.10 Confidential Tentative RWTF032FM1SC Requirement and Notice This product is provided "as is", and Metorage does not make any other guarantees (whether express, implied, statutory or otherwise) with respect to this product or any part of it. Metorage expressly denies any implied warranties of marketability, suitability for specific uses, and non-infringement. 1) The products described in this specification refer to the electronic equipment used in vehicles (navigation, driving recorders, AV equipment, etc.) If you have special quality and reliability requirements, product failure or misuse may directly endanger life safety and human health for special uses (aviation, aerospace, transportation equipment, combustion equipment, life support devices, safety devices, etc.) requirements, or consider to use other than our standard use, please contact us to discuss in detail. 2) Please use within the product guarantee range (especially the working voltage range and temperature range). Metorage will not be responsible for all failures of the machine if it exceeds these specifications. In addition, even if it is used within these specifications, please pay attention to avoid infringement of various laws and regulations due to the operation of our products. 3) Please avoid tearing off the label attached to the product of this specification and / or changing the label, as doing so may damage the characteristics and / or quality of the product. 4) It is forbidden to copy, photocopy, translate or restore all or part of this document to anyone without Metorage written permission by using electronic media or machine-readable form. Confidential Tentative RWTF032FM1SC Table of Contents 1. Introduction .................................................................................................................................. 6 1.1. General Description ................................................................................................................. 6 1.2. Flash Management .................................................................................................................. 6 1.2.1. Error Correction Code ....................................................................................................... 6 1.2.2. Wear Leveling ................................................................................................................... 6 1.2.3. Bad Block Management ................................................................................................... 6 2. Product Specifications ................................................................................................................ 6 3. ELectrical Interface outlines ....................................................................................................... 7 3.1. microSD Card Pins ................................................................................................................... 7 3.2. microSD Card Bus Topology ................................................................................................... 8 3.3. microSD Bus Mode Protocol .................................................................................................. 8 3.4. SPI Bus Mode Protocol .......................................................................................................... 12 3.5. microSD card initialization.................................................................................................... 14 4. SD Card Comparison.................................................................................................................. 16 5. Electrical Specifications ............................................................................................................. 17 5.1. Power Consumption .............................................................................................................. 17 5.2. Working Rating ...................................................................................................................... 17 5.3. DC Characteristic.................................................................................................................... 17 5.3.1. Bus Operation Conditions for 3.3V Signaling .................................................................17 5.3.2. Bus Signal Line Load ...................................................................................................... 18 5.3.3. Power Up Time of Host ................................................................................................. 19 5.3.4. Power Up Time of Card ................................................................................................. 20 5.4. AC Characteristic................................................................................................................... 20 5.4.1. microSD Interface Timing (Default) ...............................................................................21 5.4.2. microSD Interface Timing (High-Speed Mode) ............................................................ 22 5.4.3. microSD Interface Timing (SDR12, SDR25, SDR50 and SDR104 Modes) .................... 23 5.4.4. microSD Interface Timing (DDR50 Mode) ................................................................... 25 6. Host System Design Guildelines ............................................................................................. 26 6.1. Efficient Data Writing to microSD Memory Card ................................................................ 26 6.1.1. Write_Single_Block and Write_Multiple_Block ............................................................ 26 6.2. Basic Process of Error Handling ........................................................................................... 27 6.2.1. Retry Process .................................................................................................................. 27 6.2.2. Recovery Process........................................................................................................... 27 6.2.3. Tuning Write Command Process ................................................................................... 27 6.2.4. Tuning Read Command Process ................................................................................... 27 6.2.5. Exception Handling Process ......................................................................................... 27 6.3. Common Error Handling in SPI and SD mode ..................................................................... 27 6.3.1. Time-out.......................................................................................................................... 27 6.3.2. Error Detect (CMD CRC Error) ...................................................................................... 27 6.3.3. Error Detect (Other Error) in SPI and SD mode ........................................................... 27 6.3.4. Others ............................................................................................................................ 27 6.4. Data Error Handling in SPI and SD mode ............................................................................ 27 Confidential Tentative RWTF032FM1SC 6.4.1. Time-out ......................................................................................................................... 27 6.4.2. Read CRC16 Error ........................................................................................................... 27 6.4.3. Write CRC Status Error .................................................................................................. 27 6.4.4. Others ............................................................................................................................ 27 6.5. Multiple Block Write (CMD25) Process ............................................................................... 28 6.6. Retry Error handling ............................................................................................................. 29 6.7. Recovery Error Handling ...................................................................................................... 30 6.8. Tuning Write Command Error Handling ............................................................................... 31 6.9. Exception Error Handling ..................................................................................................... 32 6.10. Multiple Blocks Read (CMD18) Error Handling Process ................................................... 33 6.11. Tuning Read Data Error Handling ....................................................................................... 34 7. Card Registers ............................................................................................................................ 35 7.1. Card Identification Register (CID) ........................................................................................ 35 7.2. Card Specific Data Register (CSD)........................................................................................ 35 8. Physical Dimension.................................................................................................................... 37 9. Appendix .................................................................................................................................... 39 9.1. Endurance characteristic ...................................................................................................... 39 Confidential Tentative RWTF032FM1SC 1. INTRODUCTION 1.1. General Description The microSD card is fully compliant with the standards released by the SD Card Association. The Command List supports [Part 1 Physical Layer Specification Ver6.10 Final] definitions. The microSD card comes with an 8-pin interface, designed to operate at a maximum frequency of 208MHz. It can alternate communication protocol between the SD mode and SPI mode. It performs data error detection and correction with very low power consumption. SD card are one of the most popular removable storage cards today due to its high performance and good reliability. 1.2. Flash Management 1.2.1. Error Correction Code Flash memory cells will deteriorate with use, which might generate random bit errors in the stored data. Thus, microSD card applies ECC Algorithm, which can detect and correct errors during Read processes, ensuring data is read correctly, as well as protecting data from corruption. 1.2.2. Wear Leveling NAND Flash devices can only undergo a limited number of program/erase cycles, and in most cases, the flash media are not used evenly. If some area gets updated more frequently than others, the lifetime of the device would be reduced significantly. Thus, Wear Leveling technique is applied to extend the lifespan of NAND Flash by evenly distributing write and erase cycles across the media. Metorage provides advanced Wear Leveling algorithm, which can efficiently spread out the flash usage through the whole flash media area. Moreover, by implementing both dynamic and static Wear Leveling algorithms, the life expectancy of the NAND Flash is greatly improved. 1.2.3. Bad Block Management Bad blocks are blocks that include one or more invalid bits, and their reliability is not guaranteed. Blocks that are identified and marked as bad by the manufacturer are referred to as “Initial Bad Blocks”. Bad blocks that are developed during the lifespan of the flash are named “Later Bad Blocks”. Metorage implements an efficient bad block management algorithm to detect the factory-produced bad blocks and manages any bad blocks that appear with use. This practice further prevents data being stored into bad blocks and improves the data reliability. 2. PRODUCT SPECIFICATIONS ⚫ Compliant Specifications - SD Memory Card Specifications: Compliant with Part 1 Physical Layer Specification Ver. 6.10 Compliant with Part 2 File System Specification Ver. 3.00 Support SD SPI mode Bus Speed Mode (use 4 parallel data lines) ■ Non-UHS Mode ➢ Default speed mode: 3.3V signaling, frequency up to 25MHz, up to 12.5 MB/sec ➢ High speed mode: 3.3V signaling, frequency up to 50MHz, up to 25 MB/sec ■ UHS Mode ➢ SDR12: 1.8V signaling, frequency up to 25MHz, up to 12.5 MB/sec ➢ SDR25: 1.8V signaling, frequency up to 50MHz, up to 25 MB/sec ➢ SDR50: 1.8V signaling, frequency up to 100MHz, up to 50 MB/sec ➢ SDR104: 1.8V signaling, frequency up to 208MHz, up to 104MB/sec ➢ DDR50: 1.8V signaling, frequency up to 50MHz, sampled on both clock edges, up to 50 MB/sec NOTES: 1. Timing in 1.8V signaling is different from that of 3.3V signaling. 2. To properly run the UHS mode, please ensure the device supports UHS-I mode. The command list supports [Part 1 Physical Layer Specification Ver. 6.10 ] definitions ■ Command list are described in “Table 3-2 SD mode Command Set ” and “Table 3-3 SPI mode Command Set” in this document. Support Hot Plug ■ Card removal during read operation will never harm the content. Password Protection of cards (Support) ■ ■ ⚫ ⚫ ⚫ ⚫ ⚫ 6 Confidential Tentative RWTF032FM1SC 3. ELECTRICAL INTERFACE OUTLINES 3.1. microSD Card Pins Figure 3-1 microSD Card Pin assignment (Back View of the card) Table 3-1 microSD Memory Card Pad Assignment Pin SD Mode SPI Mode Name Type1 Description Name Type Description 1 DAT2 I/O/PP Data Line [bit2] RSV - - 2 CD/DAT32 I/O/PP3 Card Detect/ Data Line [bit3] CS I3 Chip Select (neg. true) 3 CMD PP Command/Response DI I Data In 4 VDD S Supply voltage VDD S Supply voltage 5 CLK I Clock SCLK I Clock 6 VSS S Supply voltage ground VSS S Supply voltage ground 7 DAT0 I/O/PP Data Line [bit0] DO O/PP Data Out 8 DAT1 I/O/PP Data Line [bit1] RSV - - (1) S: power supply, I: input; O: output using push-pull drivers; PP: I/O using push-pull drivers. (2) The extended DAT lines (DAT1-DAT3) are input on power up. They start to operate as DAT lines after SET_BUS_WIDTH command. The Host shall keep its own DAT1-DAT3 lines in input mode as well while they are not used. It is defined so in order to keep compatibility to MultiMedia Cards. (3) At power up, this line has a 50KOhm pull up enabled in the card. This resistor serves two functions: Card detection and Mode Selection. For Mode Selection, the host can drive the line high or let it be pulled high to select SD mode. If the host wants to select SPI mode, it should drive the line low. For Card detection, the host detects that the line is pulled high. This pull-up should be disconnected by the user during regular data transfer with SET_CLR_CARD_DETECT (ACMD42) command. 7 Confidential Tentative RWTF032FM1SC 3.2. microSD Card Bus Topology The microSD Card supports 2 alternative communication protocols, SD and SPI BUS mode. Host can choose either one of both bus mode, same data can be read or written by both modes. SD mode allows 4-bits data transfer way, it provides high performance. SPI mode supports 1-bit data transfer and of course the performance is lower compared to SD mode. 3.3. microSD Bus Mode Protocol In default speed, the microSD Memory Card bus has a single master (application); multiple slaves (Cards), synchronous star topology (refer to Figure 3-2). In high speed and UHS-I, the microSD Memory Card bus has a single master (application) and single slave (card), synchronous point to point topology. Clock, power and ground signals are common to all cards. Command (CMD) and data (DAT0-DAT3) signals are dedicated to each card providing continues point to point connection to all the cards. During initialization process commands are sent to each card individually, allowing the application to detect the cards and assign logical addresses to the physical slots. Data is always sent (received) to (from) each card individually. However, in order to simply the handling of the card stack, after the initialization process, all commands may be sent concurrently to all cards. Addressing information is provided in the command packet. SD bus allows dynamic configuration of the number of data lines. After power up, by default, the microSD Memory Card will use only DAT0 for data transfer. After initialization the host can change the bus width (number of data active lines). This feature allows easy tradeoff between HW cost and system performance. Note that while DAT1 to DAT3 are not in use, the related Host’s DAT lines should be in tristate (input mode). For SDIO cards DAT1 and DAT2 are used for signaling. Figure 3-2 SD Memory Card System Bus Topology The microSD bus includes the following signals: CLK: Host to card clock signal CMD: Bidirectional Command/Response signal DAT0-DAT3: 4 Bidirectional data signals VDD, Vss1, Vss2: Power and ground signals 8 Confidential Tentative RWTF032FM1SC Table 3-2 SD Mode Command Set 0 Card Command Class (CCC) 1 Comma Basic nd Queue CMD0 + CMD2 + CMD3 + CMD4 + 2 3 4 Block Reserve Block read d write 5 6 Write Erase protecti on 7 Lock card CMD5 8 Applicat ion specific 9 I/O mode 10 Switch Extensi on + CMD6 + CMD7 + CMD8 + CMD9 + CMD10 + CMD11 + CMD12 + CMD13 + CMD15 + CMD16 + CMD17 + CMD18 + CMD19 + CMD20 + + + + CMD21 + CMD23 + + CMD24 + CMD25 + CMD27 + CMD28 + CMD29 + CMD30 + CMD32 + CMD33 + CMD34-37 + CMD38 + CMD40 + CMD42 + CMD43-47 11 + CMD48 + CMD49 + CMD50 + CMD52 + CMD53 + 9 Confidential Tentative 0 Card Command Class (CCC) Basic 1 2 RWTF032FM1SC 3 4 5 Comma Block Reserve Block nd read d write Queue 6 7 8 9 10 11 Write Applicat Lock I/O Extensi Erase protecti ion Switch card mode on on specific CMD55 + CMD56 + CMD57 + CMD58 + CMD59 + ACMD6 + ACMD13 + ACMD14 + ACMD15 + ACMD16 + ACMD22 + ACMD23 + ACMD28 + ACMD41 + ACMD42 + ACMD51 + Commands Support requirements CMD0 CMD2 CMD3 CMD4 CMD5 CMD6 CMD7 CMD8 CMD9 CMD10 Mandatory Mandatory Mandatory Mandatory Optional Mandatory for cards version 1.10 and after. Mandatory Mandatory for cards version 2.00 and after. Mandatory Mandatory CMD11 Mandatory for cards supporting UHS-I. Optional for cards that do not support UHS-I. CMD12 CMD13 CMD15 CMD16 CMD17 CMD18 Mandatory Mandatory Mandatory Mandatory Mandatory Mandatory CMD19 Mandatory for cards supporting UHS-I. Optional for cards that do not support UHS-I. 10 Confidential Tentative RWTF032FM1SC Support requirements Commands CMD20 Not support for SDSC cards. Mandatory for SDHC and SDXC cards that support Video Speed Class. Optional for SDHC cards that support: a) Speed Class; or b) UHS Speed Grade, and do not support Video Speed Class. Mandatory for SDXC cards that support Speed Class or UHS Speed Grade. CMD21 Optional CMD23 Not support for SDSC cards. Mandatory for SDHC and SDXC cards that support UHS104. Optional for SDHC cards and SDXC cards that do not support UHS104. CMD24 CMD25 CMD27 CMD28 CMD29 CMD30 CMD32 CMD33 CMD34-37 Mandatory for writable type of cards. Mandatory for writable type of cards. Mandatory for writable type of cards. Optional Optional Optional Mandatory for writable type of cards. Mandatory for writable type of cards. Optional for cards version 1.10 and after. CMD38 Mandatory for writable type of cards. Discard and FULE support is optional. CMD40 CMD43-47 Optional Optional for cards version 1.01 and 1.10. Mandatory for cards version 2.00 and after. COP support is optional for CMD42. Mandatory for cards supporting Command Queue. CMD48 Optional Mandatory for cards supporting Performance Enhancement functions. CMD42 CMD49 CMD50 CMD52 CMD53 CMD55 CMD56 CMD57 CMD58 CMD59 ACMD6 ACMD13 ACMD14 ACMD15 ACMD16 ACMD22 ACMD23 ACMD28 ACMD41 ACMD42 ACMD51 Optional Mandatory for cards supporting Performance Enhancement functions. Optional for cards version 1.10 and after. Optional Optional Mandatory Mandatory Optional for cards version 1.10 and after. Optional Optional Mandatory Mandatory Optional Optional Optional Mandatory for writable types of cards. Mandatory for writable types of cards. Optional Mandatory Mandatory Mandatory 11 Confidential Tentative RWTF032FM1SC 3.4. SPI Bus Mode Protocol While the SD Memory Card channel is based on command and data bit streams that are initiated by a start bit and terminated by a stop bit, the SPI channel by byte oriented. Every command or data block is built for 8-bit bytes and is byte aligned with the CS signal (i.e. the length is a multiple of 8 clock cycles). The card starts to count SPI bus clock cycle at the assertion of the CS signal. Every command or data token shall be aligned with 8-clock cycle boundary. Similar to the SD Memory Card Protocol, the SPI messages consist of command, response and datablock tokens. The advantage of SPI mode is reducing the host design effort, especially for MMC host side, it just be modified by little change. Note: please use SD card specification to implement SPI mode function, not use MMC specification. For example, SPI mode is initialized by ACMD41, and the registers are different from MMC card, especially CSD register. Figure 3-3 SD Memory Card State Diagram (SPI mode) Table 3-3 SPI Mode Command Set Card Command Class (CCC) Supported Class commands description 0 Basic CMD0 Mandatory + CMD1 Mandatory + 1 2 3 4 Reser Block Reser Block ved read ved write 12 5 6 Write Erase prote ction 7 8 9 10 11 Applic Lock ation I/O card specif mode ic Switc Reserv h ed Confidential Tentative RWTF032FM1SC CMD5 CMD6² Optional Mandatory + CMD8³ Mandatory + CMD9 Mandatory + CMD10 Mandatory + CMD12 Mandatory + CMD13 Mandatory + CMD16 Mandatory + CMD17 Mandatory + CMD18 Mandatory + CMD24 Mandatory1 + CMD25 Mandatory1 + CMD27 Mandatory1 + CMD28 Optional + CMD29 Optional + CMD30 Optional + CMD32 Mandatory1 + CMD33 Mandatory1 + + + CMD34-37² Optional CMD38 Mandatory1 4 + + + CMD42 (Note4) + CMD50² Optional CMD52 Optional + CMD53 Optional + CMD55 Mandatory1 + CMD56 Mandatory1 + CMD57² Optional CMD58 Mandatory + CMD59 Mandatory + ACMD13 Mandatory + ACMD22 Mandatory1 + ACMD23 Mandatory1 + ACMD41 Mandatory + ACMD42 Mandatory1 + ACMD51 Mandatory1 + + + Note(1):The commands related write and erase are mandatory for the Writable types of Cards. Note(2):This command was defined in spec version 1.10. Note(3):This command is newly defined in version 2.00. Note(4):This command is optional in Version 1.01 and 1.10 and mandatory from Version 2.00. COP support is optional for CMD42. 13 Confidential Tentative RWTF032FM1SC 3.5. microSD card initialization Figure 3-4 presents the initialization flow chart for UHS-I hosts and Figure 3-5 shows sequence of commands to perform voltage switch. Figure 3-4 UHS-I Host Initialization Flow Chart Figure 3-5 ACMD41 Timing Followed by Voltage Switch Sequence When signaling level is 3.3V, host repeats to issue ACMD41 with HCS=1 and S18R=1 until the response indicates ready. The argument (HCS and S18R) of the first ACMD41 is effective but the all following ACMD41 should be issued with the same argument. If Bit31 indicates ready, host needs to check CCS and S18A. The card indicates S18A=0, which means that voltage switch is not allowed and the host needs to use current signaling level. 14 Confidential Tentative RWTF032FM1SC Table 3-4 S18R and S18A Combinations Current Signaling Level 3.3V 1.8V S18R S18A Comment 0 0 1.8V signaling is not requested 1 0 The card does not support 1.8V signaling 1 1 Start signal voltage switch sequence X 0 Already switched to 1.8V To change signaling level at the same time between host and card, signal voltage switch sequence is invoked by CMD11 as shown in Figure 3-6. CMD11 is issued only when S18A=1 in the response of ACMD41. Figure 3-6 Signal Voltage Switch Sequence 15 Confidential Tentative RWTF032FM1SC 4. SD CARD COMPARISON Table 4-1 Comparing microSDHC, and microSDXC File System Addressing Mode HCS/CCS bits of ACMD41 CMD8 (SEND_IF_COND) CMD16 (SET_BLOCKLEN) Partial Read Lock/Unlock Function Write Protect Groups Supply Voltage 2.7v – 3.6v (for operation) Total Bus Capacitance for each signal line CSD Version (CSD_STRUCTURE Value) Speed Class microSDHC FAT32 Block (512 byte unit) Support Support Support (Only CMD42) Not Support Mandatory Not Support microSDXC exFAT Block (512 byte unit) Support Support Support (Only CMD42) Not Support Mandatory Not Support Support 2.7v-3.6v 40pF 40pF 2.0 (0x1) 2.0 (0x1) Mandatory (Class 2 / 4 / 6 / 10) Mandatory (Class 2 / 4 / 6 / 10) Table 4-2 Comparing UHS Speed Grade Symbols Operable Under SD Memory Card Mark U1 ( UHS Speed Grade 1) U3 ( UHS Speed Grade 3) *UHS-I Bus I/F, UHS-II Bus I/F microSDHC UHS-I and UHS-II, microSDXC UHS-I and UHS-II Performance 10 MB/s minimum write speed Under the UHS Class speed condition 30 MB/s minimum write speed Under the UHS Class speed condition Applications Full higher potential of recording realtime broadcasts and capturing large-size HD videos. Capable of recording 4K 2K video. *UHS (Ultra High Speed), the fastest performance category available today, defines bus-interface speeds up to 512 Megabytes per second for greater device performance. It is available on microSDXC and microSDHC memory cards and devices. 16 Confidential Tentative RWTF032FM1SC 5. ELECTRICAL SPECIFICATIONS 5.1. Power Consumption The table below is the power consumption of microSD card with different flash memory types. Table 5-1 Power Consumption of microSD card Flash Mode Max. Read Current (mA) Max. Write Current (mA) 150 150 150 150 150 150 150 150 Default Speed Mode High Speed Mode UHS50/DDR50 UHS-I Mode UHS104/ DDR50 Note: The test data is tentative, current numbers might be subject to changes without notice. 5.2. Working Rating Table 5-2 Working Rating of microSD card Item 1 2 3 Symbol Ta Tst VDD Parameter Operating Temperature Storage Temperature Voltage Min -40 -40 2.7 Max +85 +85 3.6 Unit ℃ ℃ V Note:The samples are engineering samples and the data is tentative. 5.3. DC Characteristic 5.3.1. Bus Operation Conditions for 3.3V Signaling Table 5-3 Threshold Level for High Voltage Range Parameter Supply Voltage Output High Voltage Symbol VDD VOH Min 2.7 0.75*VDD Max 3.6 - Unit V V Output Low Voltage VOL - 0.125*VDD V Input High Voltage Input Low Voltage VIH VIL 0.625*VDD VSS-0.3 VDD+0.3 0.25*VDD V V Power Up Time - - 250 ms Condition IOH=-2mA VDD Min IOL=2mA VDD Min From 0V to VDD min Table 5-4 Peak Voltage and Leakage Current Parameter Peak voltage on all lines Symbol - Input Leakage Current - Output Leakage Current - Min Max -0.3 VDD+0.3 All Inputs -10 10 All Outputs -10 10 17 Unit V Remarks - uA - uA - Confidential Tentative RWTF032FM1SC Table 5-5 Threshold Level for 1.8V Signaling Parameter Symbol Min Max Unit Remarks Supply Voltage VDD 2.7 3.6 V - Regulator Voltage VDDIO 1.7 1.95 V Generated by VDD Output High Voltage VOH 1.4 - V IOH=-2mA Output Low Voltage VOL - 0.45 V IOL=2mA Input High Voltage VIH 1.27 2.00 V - Input Low Voltage VIL Vss-0.3 0.58 V - Table 5-6 Input Leakage Current for 1.8V Signaling Parameter Symbol Min Max Unit Remarks Input Leakage Current - -2 2 uA DAT3 pull-up is disconnected. 5.3.2. Bus Signal Line Load Bus Operation Conditions – Signal Line’s Load Total Bus Capacitance = CHOST + CBUS + N CCARD Table 5-7 Bus Signal Line Load of microSD Card Symbol RCMD RDAT Min Max Unit Remark 10 100 kΩ to prevent bus floating Total bus capacitance for each signal line CL - 40 pF 1 card CHOST+CBUS shall not exceed 30 pF Card Capacitance for each signal pin CCARD - 101 pF - Maximum signal line inductance - - 16 nH - Pull-up resistance inside card (pin1) RDAT3 10 90 kΩ Capacity Connected to Power Line CC - 5 uF May be used for card detection To prevent inrush current Parameter Pull-up resistance 18 Confidential Tentative RWTF032FM1SC 5.3.3. Power Up Time of Host The host needs to keep power line level less than 0.5V and more than 1ms before power ramp up. Figure 5-1 Power Up Diagram of Host Power On or Power Cycle Followings are requirements for Power on and Power cycle to assure a reliable microSD Card hard reset. (1) Voltage level shall be below 0.5V. (2) Duration shall be at least 1ms. Power Supply Ramp Up The power ramp up time is defined from 0.5V threshold level up to the operating supply voltage which is stable between VDD (min.) and VDD (max.) and host can supply SDCLK. Followings are recommendations of Power ramp up: (1) The voltage of power ramp up should be monotonic as much as possible. (2) The minimum ramp up time should be 0.1ms. (3) The maximum ramp up time should be 35ms for 2.7-3.6V power supply. (4) Host shall wait until VDD is stable. (5) After 1ms VDD stable time, the host provides at least 74 clocks before issuing the first command. Power Down and Power Cycle (1) When the host shuts down the power, the card V DD shall be lowered to less than 0.5Volt for a minimum period of 1ms. During power down, DAT, CMD, and CLK should be disconnected or driven to logical 0 by the host to avoid a situation that the operating current is drawn through the signal lines. (2) If the host needs to change the operating voltage, a power cycle is required. Power cycle means the power is turned off and supplied again. A power cycle is also needed for accessing cards that are already in Inactive State. To create a power cycle the host shall follow the power down description before power up the card (i.e. the card VDD shall be once lowered to less than 0.5Volt for a minimum period of 1ms). 19 Confidential Tentative RWTF032FM1SC 5.3.4. Power Up Time of Card A device shall be ready to accept the first command within 1ms from detecting VDD min. The device may use up to 74 clocks for preparation before receiving the first command. Figure 5-2 Power Up Diagram of Card 5.4. AC Characteristic Figure 5-3 Bus Signal Level 20 Confidential Tentative RWTF032FM1SC 5.4.1. microSD Interface Timing (Default) Figure 5-4 Card Input/Output Timing (Default Speed Card) Table 5-8 Bus Timing – Parameters Values (Default Speed) Parameter Symbol Min Max Unit Clock CLK (All values are referred to min(VIH) and max(VIL) Clock frequency Data Transfer fPP 0 25 MHz Mode Clock frequency Identification fOD 0(1)/100 400 kHz Mode Clock low time tWL 10 - ns Clock high time tWH 10 - ns Clock rise time tTLH - 10 ns Clock fall time tTHL - 10 ns Remark Ccard≤ 10 pF (1 card) Ccard≤ 10 pF (1 card) Ccard≤ 10 pF (1 card) Ccard≤ 10 pF (1 card) Ccard≤ 10 pF (1 card) Ccard≤ 10 pF (1 card) Inputs CMD, DAT (referenced to CLK) Input set-up time tISU 5 - ns Input hold time tIH 5 - ns Ccard≤ 10 pF (1 card) Ccard≤ 10 pF (1 card) Outputs CMD, DAT (referenced to CLK) CL≤ 40 pF Output Delay time during Data tODLY 0 14 ns Transfer Mode (1 card) C L≤ 40 pF Output Delay time during tODLY 0 50 ns Identification Mode (1 card) (1) 0Hz means to stop the clock. The given minimum frequency range is for cases where continuous clock is required. 21 Confidential Tentative RWTF032FM1SC 5.4.2. microSD Interface Timing (High-Speed Mode) Figure 5-5 Card Input/Output Timing (High Speed Card) Table 5-9 Bus Timing – Parameters Values (High Speed) Symbol Parameter Min Max Unit Clock CLK (All values are referred to min(VIH) and max(VIL) Clock frequency Data Transfer fPP 0 50 MHz Mode Clock low time tWL 7 - ns Clock high time tWH 7 - ns Clock rise time tTLH - 3 ns Clock fall time tTHL - 3 ns Remark Ccard ≤ 10 pF (1 card) Ccard ≤ 10 pF (1 card) Ccard ≤ 10 pF (1 card) Ccard ≤ 10 pF (1 card) Ccard ≤ 10 pF (1 card) Inputs CMD, DAT (referenced to CLK) Input set-up time tISU 6 - ns Input hold time tIH 2 - ns Outputs CMD, DAT (referenced to CLK) Output Delay time during Data tODLY 14 Transfer Mode Ccard ≤ 10 pF (1 card) Ccard ≤ 10 pF (1 card) ns CL ≤ 40 pF (1 card) Output Hold time TOH 2.5 - ns CL ≤ 15 pF (1 card) Total System capacitance of each line¹ CL - 40 pF CL ≤ 15 pF (1 card) (1) In order to satisfy severe timing, the host shall drive only one card. 22 Confidential Tentative RWTF032FM1SC 5.4.3. microSD Interface Timing (SDR12, SDR25, SDR50 and SDR104 Modes) Input Figure 5-6 Clock Signal Timing Table 5-10 Clock Signal Timing Symbol tCLK tCR, tCF Clock Duty Min 4.80 30 Max - Unit ns 0.2* tCLK ns 70 % Remark 208MHz (Max.), Between rising edge, VCT= 0.975V tCR, tCF < 0.96ns (max.) at 208MHz, CCARD=10pF tCR, tCF < 2.00ns (max.) at 100MHz, CCARD=10pF The maximum value of tCR, tCF is 10ns regardless of clock frequency - SDR50 and SDR104 Input Timing Figure 5-7 Card Input Timing Table 5-11 SDR50 and SDR104 Input Timing Symbol tIS tIH Symbol tIS tIH Min 1.40 0.801 Min 3.00 0.801 Max Max - SDR104 Mode CCARD =10pF, VCT= 0.975V CCARD = 5pF, VCT= 0.975V SDR50 Mode CCARD =10pF, VCT= 0.975V CCARD = 5pF, VCT= 0.975V Unit ns ns Unit ns ns 23 Confidential Tentative RWTF032FM1SC Output(SDR12, SDR25, SDR50) Figure 5-8 Output Timing of Fixed Data Window Table 5-12 Output Timing of Fixed Data Window (SDR12, SDR25, SDR50) Symbol tODLY Min - Max 7.5 Unit ns tODLY - 14 ns TOH 1.5 - ns Remark tCLK>=10.0ns, CL=30pF, using driver Type B, for SDR50 tCLK>=20.0ns, CL=40pF, using driver Type B, for SDR25 and SDR12 Hold time at the tODLY (min.), CL=15pF Output(SDR104 Modes) Figure 5-9 Output Timing of Variable Data Window Table 5-13 Output Timing of Variable Window (SDR104) Symbol tOP △tOP tODW Min 0 -350 0.60 Max 2 +1550 - Unit Ul ps Ul Remark Card Output Phase Delay variable due to temperature change after tuning tODW = 2.88ns at 208MHz 24 Confidential Tentative RWTF032FM1SC 5.4.4. microSD Interface Timing (DDR50 Mode) Figure 5-10 Clock Signal Timing Table 5-14 Clock Signal Timing Symbol Min Max Unit Remark tCLK 20 - ns 50MHz (Max.), Between rising edge tCR, tCF - 0.2* tCLK ns tCR, tCF < 4.00ns (max.) at 50MHz, CCARD=10pF Clock Duty 45 55 % - Figure 5-11 Timing Diagram DAT Inputs/Outputs Referenced to CLK in DDR50 Mode 25 Confidential Tentative RWTF032FM1SC Table 5-15 Bus Timings – Parameters Values (DDR50 Mode) Parameter Symbol Min Max Input CMD (referenced to CLK rising edge) Unit Input set-up time tISU 3 - ns Input hold time tIH 0.8 - ns Output CMD (referenced to CLK rising edge) Output Delay time during Data tODLY 13.7 Transfer Mode Output Hold time 1.5 TOH - ns ns Remark Ccard≤ 10 pF (1 card) Ccard≤ 10 pF (1 card) CL≤ 30 pF (1 card) CL≥ 15 pF (1 card) Inputs DAT (referenced to CLK rising and falling edges) Input set-up time tISU2x 3 - ns Input hold time tIH2x 0.8 - ns Ccard≤ 10 pF (1 card) Ccard≤ 10 pF (1 card) Outputs DAT (referenced to CLK rising and falling edges) Output Delay time during Data Transfer Mode tODLY2x - 7.0 ns Output Hold time TOH2x 1.5 - ns CL≤ 25 pF (1 card) CL≥ 15 pF (1 card) 6. HOST SYSTEM DESIGN GUILDELINES 6.1. Efficient Data Writing to microSD Memory Card In order to optimize sequential writing performance and WAF (Write Amplification Factor), it is recommended to use allocation unit (AU) writing. It is recommended that Multiple_Block_Write shall be used as a command for writing data, and the size of data written by each command should be the FAT cluster x n (n: integer) 6.1.1. Write_Single_Block and Write_Multiple_Block Write single block (CMD24) was written by one sector (512Bytes), which is suitable to write small area such like updating file system area (FAT). Besides, write multiple blocks (CMD25) is a command for writing data to blocks that have sequential address per command, which is suitable to write large area such as user data. Write multiple blocks with a cluster unit (512Byte x 128 Sectors = 64KByte) in the file system is an efficient access to the flash memory, it is obviously to provide higher speed to compared to single write block. And it could be estimated that microSD card internal process would be reduced to save power consumption and flash write amplification factor, that is why the efficient data writing was recommended. To avoid the command issued by 512Bytes with single write block, software processes in the host device become faster. Figure 6-1 Matching between logical address and file system Note: Large Cluster unit is better for performance and WAF, for example, 128KB, 256KB or 512KB. Large cluster unit also can save write command numbers and few transfer time. 26 Confidential Tentative 6.2. 6.2.1. RWTF032FM1SC Basic Process of Error Handling Retry Process Execute the process by sending commands again, especially for signal issue between card and host. 6.2.2. Recovery Process Confirm card status is in Transfer State, if card status is not in Transfer State, please issue Stop command to recover it and execute or continue flow. If there was UECC during read/write status, we could use recovery process to recover it. 6.2.3. Tuning Write Command Process In order to adjust Host CMD and CLK timing, the way is issue tuning command to confirm what the device response and data was received by host. Based on the response, host was adjusting the timing step by step and recording the pass range. Through this flow host could adjust the appropriate timing settings to avoid unexpected handshaking issue. 6.2.4. Tuning Read Command Process In order to adjust Host CLK and DAT timing, the way is issue tuning command to confirm what the device response and data was received by host. Based on the response, host was adjusting the timing step by step and recording the pass range. Through this flow host could adjust the appropriate timing settings to avoid unexpected handshaking issue. 6.2.5. Exception Handling Process No doubt that sometimes we would face all error handling above could not recover it successfully, and we could react based on the situation. - If there was error in response, we could re-initialize the card. - If it was signal issue, we could set up signal status by reading data and tuning command. 6.3. Common Error Handling in SPI and SD mode 6.3.1. Time-out Run the Retry Process. No response from CMD, it might be signal or status got problem. To avoid the infinite loop, implement a retry counter in the host so that, if the retry counter expires, the exception handling starts in the host. 6.3.2. Error Detect (CMD CRC Error) Run the Recovery Process. If it got second time failure with CRC, the setting might be too margin to receive response stably. Suggestion is use tuning write command to fix timing and then retry it. 6.3.3. Error Detect (Other Error) in SPI and SD mode Run the Recovery Process. 6.3.4. Others Most errors could be recovered by running the Recovery Process, let card come into Transfer State and then executing the flow we planned. If it does not work, please use exception method to come back initial state. 6.4. Data Error Handling in SPI and SD mode 6.4.1. Time-out Run the Recovery Process. While the state was recovered, run the flow again. 6.4.2. Read CRC16 Error Run the Recovery Process. If it got second time failure with CRC, the setting might be too margin to receive data stably. Suggestion is use tuning read date to fix timing and then retry it. 6.4.3. Write CRC Status Error Run the Recovery Process. If it got second time failure with CRC, the setting might be too margin to receive CRC status stably. Suggestion is use tuning read date to fix timing and then retry it. 6.4.4. Others Most errors could be recovered by running the Recovery Process, let card come into Transfer State and then executing the flow we planned. 27 Confidential Tentative 6.5. RWTF032FM1SC Multiple Block Write (CMD25) Process - If Response is ADDRESS_OUT_OF_RANGE, please confirm writing address. - If Response is DEVICE_IS_LOCKED, please stop writing data. - If Response is COM_CRC_ERROR, run retry or tuning. CMD25 Command Response Response CRC7 Timeout Error Retry Not match Tunning Write Command Recovery Pass Send Data CRC status Fail Pass No Transfer End Yes CMD12 Recovery Error Timeout Command Response Pass CMD13 No Error Timeout Command Response Program state Over SPEC timeout Yes Pass Finish Figure 6-2 Multiple Write (CMD25) Error Handling 28 Recovery Confidential Tentative RWTF032FM1SC 6.6. Retry Error handling In order to avoid signal issue caused unexpected response from device, we could use Retry Process to fix it. - Please make sure card state is in transfer state before issuing following commands. - To avoid the infinite loop, implement a retry counter in the host. - If the device could not respond to CMD13 normally, please run exception handling to recover card status. CMD13 Timeout Error Command Response Exception handle Pass Decrease retry count Equal to 0 More than 0 Other state Check State Transfer state Re-send command before retry process Figure 6-3 Retry Error Handling Process 29 Confidential Tentative RWTF032FM1SC 6.7. Recovery Error Handling Sometimes the device failure could not be recovered by Retry Process, it suggests to execute STOP Command (CMD12) to stop whole commands and response and then run following flow. - Please confirm card status is in Transfer state - In order to avoid infinite loops, host has to set up a retry counter number. CMD13 Command Response Decrease recovery retry count Timeout Error Exception handle Equal to 0 Timeout Error More than 0 Check State Other state Command Response CMD12 Transfer state Finish Figure 6-4 Recovery Error Handling Process 30 Pass Confidential Tentative RWTF032FM1SC 6.8. Tuning Write Command Error Handling Reconfirm the card’s pass range, to make sure card could receive host commands. - If there was no any pass window, it might be connect issue or signal issue - Pass Range depends on frequency level, higher frequency makes fewer pass range Adjust delay to minimum Ex: Delay = 0 CMD13 Timeout Error Command Response Record the delay is Fail Record the delay is Pass Increase the delay No Is the maxinum delay Ex: Delay = 255 Yes Find the maximum pass range Use the half of maximum range Ex: Pass range (10-70) Ex: Set delay (40) Finish Figure 6-5 Tuning Write Command Error Handling Process 31 Confidential Tentative RWTF032FM1SC 6.9. Exception Error Handling - Error in Card’s response or data output time-out, it could re-initialize the card. - If there was CMD CRC7 issue, it could use tuning write command process to find out appropriate timing. - If there was DAT CRC16 issue, it could use tuning read command process to find out appropriate timing. Exception handle Fail on Error or Timeout Yes SD initial flow No Fail on Command CRC Yes Tuning write command No Fail on data CRC Yes Tuning read data No Yes User define error handle No Finish Figure 6-6 Exception Error Handling Process 32 Confidential Tentative RWTF032FM1SC 6.10. Multiple Blocks Read (CMD18) Error Handling Process - If card responded ADDRESS_OUT_OF_RANGE, please check reading address - If card responded DEVICE_IS_LOCKED, please stop reading data - If card responded COM_CRC_ERROR, run Retry or Tuning Process CMD18 Command Response Timeout Response CRC7 Not match Retry Recovery Tunning Write Command Recovery Tunning Read Command Pass Read Data Recovery Yes Timeout No Data CRC16 Not Match Pass No Received End Yes CMD12 Error Timeout Command Response Pass CMD13 No Error Timeout Command Response Other state Over SPEC timeout Yes Recovery Transfer Finish Figure 6-7 Multiple Blocks Read (CMD18) Error Handling Process 33 Confidential Tentative RWTF032FM1SC 6.11. Tuning Read Data Error Handling Reconfirm the card’s pass range, to make sure host could receive card’s Response and Data. - If there was no any pass window, it might be connect issue or signal issue - Pass Range depends on frequency level, higher frequency makes fewer pass range Adjust delay to minimum Ex: Delay = 0 CMD19 Timeout Error Command Response Record the delay is Fail Pass Read 1 sector data Yes Timeout CRC error No Record the delay is Pass Increase the delay No Is the maxinum delay + 1 Ex: Delay = 255 Yes Find the maximum pass range Use the half of maximum range Ex: Pass range (10-70) Ex: Set delay (40) Finish Figure 6-8 Tuning Read Data Error Handling Process 34 Confidential Tentative RWTF032FM1SC 7. CARD REGISTERS 7.1. Card Identification Register (CID) The Card Identification (CID) register is 128 bit wide. It contains the card identification information used during the card identification phase. Every individual flash card shall have a unique identification number. The structure of the CID register is defined in the following table. Table 7-1 Card Identification Register (CID) fields CID Bit Width Name Field Code [127:120] 8 Manufacture ID MID B5h [119:104] 16 OEM/Application ID OID 4D56h [103:64] 40 Product Name PNM 4D45544F52h [63:56] 8 Product Revision PRV --- [55:24] 32 Product Serial Number PSN --- [23:20] 4 Reserved --- --- [19:8] 12 Manufacturing Date MDT --- [7:1] 7 CRC7 check sum CRC --- [0] 1 Not used, always”1 --- 1h All contents in the CID table are programmable; Manufacturers can update the CID data through utility. Manufacturers should license MID and OID field form the SD Card Association(SDA). 7.2. Card Specific Data Register (CSD) The Card-Specific Data register provides information regarding access to the card contents. The CSD defines the data format, error correction type, maximum data access time, whether the DSR register can be used, etc. The programmable part of the register (entries marked by W or E, see below) can be changed by CMD27. The CSD Table Version 2.0(as shown below) is applied to SDHC and SDXC Cards. Note that bits [15:0] are programmable by the host side. Refer to the SD specification for detailed information. 35 Confidential Tentative RWTF032FM1SC Table 7-2 Card Specific Data Register (CSD) fields CSD Bit Width Name Field Code Note [127:126] 2 CSD structure CSD_STRUCTURE 01 b Ver2.0 [125:120] 6 Reserved --- --- --- [119:112] 8 Data read access-time 1 TAAC 0E h 1ms [111:104] 8 NSAC 00 h --- 32 h Default 5A h High speed 0B h SDR50/DDR50 2B h SDR104 [103:96] 8 Data read access-time2 in CLK cycles(NSA*100) TRAN_SPEED Max data transfer rate [95:84] 12 Card command classes CCC 5B5 h 0,2,4,5,7,8,10 [83:80] 4 Max. read data block length READ_BL_LEN 9 h 512 Byte [79] 1 Partial block read allowed READ_BL_PARTIAL 0 b No [78] 1 Write block misalignment WRITE_BLK_MISALIGN 0 b No [77] 1 Read block misalignment READ_BLK_MISALIGN 0 b No [76] 1 DSR implemented DSR_IMP 0 b No [75:70] 6 Reserve --- --- --- [69:48] 22 Device size C_SIZE E69Fh --- [47] 1 Reserved --- --- --- [46] 1 Erase single block enable ERASE_BLK_EN 1 b Yes [45:39] 7 Erase sector size SECTOR_SIZE 7F h 128 [38:32] 7 Write protect group size WP_GRP_SIZE 00 h Not supported [31] 1 Write protect group enable WP_GRP_ENABLE 0 b No [30:29] 2 Reserved --- 0 b --- [28:26] 3 Write speed factor R2W_FACTOR 010 b x4 [25:22] 4 Max. write data block length WRITE_BL_LEN 9 h 512 Byte [21] 1 Partial block write allowed WRITE_BL_PARTIAL 0 b No [20:16] 5 Reserved --- --- --- [15] 1 File format group FILE_FORMAT_GRP 0 b Not use [14] 1 Copy flag COPY 0 b Original [13] 1 Permanent write protection PERM_WRITE_PROTECT 0 b Not Protected [12] 1 Temporary write protection TMP_WRITE_PROTECT 0 b Not Protected [11:10] 2 File format FILE_FORMAT 00 b Not use [9:8] 2 Reserved --- --- --- [7:1] 7 CRC CRC CRC7 --- [0] 1 Not used,always’1’ --- 1 b --- 36 Confidential Tentative RWTF032FM1SC 8. PHYSICAL DIMENSION 37 Confidential Tentative SYMOL A A1 A2 A3 A4 A5 A6 A7 A8 B B1’ B2 B3 B4 B5 B7 MIN 10.90 9.60 7.60 0.75 0.90 0.60 14.90 6.13 1.64 1.30 0.42 2.80 0.20 RWTF032FM1SC COMMON DIMENSION NOM MAX 11.00 11.10 9.70 9.80 3.85 7.70 7.80 1.10 0.80 0.85 8.50 0.70 0.80 15.00 15.10 6.23 6.33 1.84 2.04 1.50 1.70 0.52 0.62 2.90 3.00 0.30 0.40 NOTE BASIC BASIC 38 Confidential Tentative B8 B10 B11 B14 B15 C C1 C2 C3 C4 C5 R1 R2 R3 R4 R5 R6 R7 R10 R11 R17 R18 R19 α aaa 1.00 7.80 1.10 8.20 0.90 0.60 0.20 0.00 0.80 0.15 0.20 0.20 0.70 0.70 0.60 0.60 29.50 0.10 0.20 0.05 133° - 1.10 7.90 1.20 1.00 0.70 0.30 0.40 0.40 0.80 0.80 0.80 0.80 30.00 0.20 0.20 0.20 0.40 135° - RWTF032FM1SC 1.20 8.00 1.30 6.20 1.10 0.80 0.40 0.15 1.10 0.60 0.60 0.90 0.90 0.90 0.90 30.50 0.30 0.60 0.20 137° 0.10 9. APPENDIX 9.1. Endurance characteristic 3,000cycles/block (nominal value:under specified conditions) *This value is not guaranteed 39
RWTF032FM1SC 价格&库存
很抱歉,暂时无法提供与“RWTF032FM1SC”相匹配的价格&库存,您可以联系我们找货
