YLR06-1-25F-W5
YLR06-1-25F-W5
    YEZHAN(业展)
    电流采样电阻 1206 25mΩ ±1% ±50ppm/℃ 1W
YLR06-1-25F-W5 数据手册
承 认 书 SPECIFICATION FOR PRODUCT 客户名称 Customer Name 客户料号 Customer P/N 产品名称 Product Name 制造商料号 Manufacturer P/N YLR06-W5 申请承认日期 Apply Date 注意: 禁止使用1级环境管理物质.遵守ACBEL"环境管理物质规范"中所要求之含量标准. Note: Banned use of hazardous substances of level 1; Comply with "Specification for Hazardous Substances and Materials Management" of ACBEL 供货商 拟定 Draft 审核 Checked 冷雪龙 胡紫阳 供货商印鉴 Vendor Stamp 客户 批准 Approved 拟定 Draft YZ-WP-EN-084 审核 Checked 批准 Approved 客户承认印鉴 Customer Accepted and Stamp 总部地址:深圳市龙华区清祥路1号宝能科技园3期1栋B座13层 Headquarters address: 13th floor, block B, building 1, Baoneng Science Park Phase 3, No. 1 Qingxiang Road, Longhua District, Shenzhen 电话: 0755-26517682 Tel:+86-0755-26517682 Confidential and Proprietary To Shenzhen Yezhan electronics all right reserved +86-0755-26517682 yezhan@yezhan.com.cn http://www.yezhan.com.cn 低阻值合金电流采样贴片电阻-YLR06-W5系列 Low Resistance Metal Strip Chip Resistors-YLR06-W5 series 特征 Features 阻值范围 Resistance value 0.5~50mΩ 精度 Tolerance ±1%、±2%、±5% 功率 Power 0.25~1.5W 温度系数 Temperature coefficient ±50ppm/℃ 合金材质 Alloy material M:Manganin 工作温度范围 Operating temperature range -55℃~170℃ 低电感 Low inductance <5nH (1MHz) 绝缘阻抗 Insulation resistance ≥220MΩ (DC 500V 1min ) 耐压值 Withstand voltage 500V 符合RoHS要求 RoHS compliant 应用范围 Applications 电流采样 Current Sensing 过流保护 Over current protection 伺服电机控制电路 Servo motor control circuits 变频电源 Inverter power 电子控制系统 Electric control system 锂电池控制板 Li-battery management system 订购信息 Ordering Information YLR 06 -1 -1 F -W5 类型 Type 尺寸 Size 功率 Power 阻值 Resistance 精度 Tolerance 其他 Other YLR 06:1206 Unit: W Unit: mΩ J:±5% W5:其他 1/4:0.25W 1: 1mΩ G:±2% 1/2:0.5W 30: 30 mΩ F:±1% 1:1W 1.5:1.5W +86-0755-26517682 yezhan@yezhan.com.cn http://www.yezhan.com.cn 低阻值合金电流采样贴片电阻-YLR06-W5系列 Low Resistance Metal Strip Chip Resistors-YLR06-W5 series 产品尺寸和推荐焊盘尺寸 Products & Recommend Pad Dimension Unit:mm Type Resistance W C 0.5~1 YLR06-W5 1~2 A 1.1±0.3 3.2±0.2 1.1±0.2 L a 1.0 2.3 0.75±0.2 1.6±0.2 2~50 D 0.5±0.3 0.6±0.2 c 1.8 1.6 1.7 产品结构图 Item Construction Electron-beam welded constructions Epoxy coating Ni plated & Sn plated Resistance alloy Cu terminal +86-0755-26517682 yezhan@yezhan.com.cn http://www.yezhan.com.cn 低阻值合金电流采样贴片电阻-YLR06-W5系列 Low Resistance Metal Strip Chip Resistors-YLR06-W5 series 标准电气规范 Standard Electrical Specifications 系列 Type 尺寸 Size YLR06-W5 材料 Material 阻值 Resistance /mΩ 温漂 TCR① (ppm/℃) 精度 Resistance Tolerance (%) 工作温度 Operating Temperature (℃) Manganin 0.5~50 ±50 ±1% ±2% ±5% -55℃~170℃ 功率 Rated Power(W) P70℃ 1/4 1/2 1 1.5 1206 ① TCR(ppm/℃):Test conditions at 20℃~120℃. 工作特性 Performance Characteristics Items Additional Requirements Reference Limits JESD22 Method JA-104 ±0.5% AEC-Q200 REV D June 1 ±0.5% Temperature Cycling 1000 Cycles (-55℃ to +150℃) ESD Test 1) Direct Contact (DC): ±6kV; 2) Air Discharge (AD): ±12kV, ±16kV, ±25kV; High Temperature Exposure 1000hrs.@T=170℃.Unpowered. MIL-STD-202 Method 108 ±0.5% Moisture Resistance t=24hrs/cycle.Note: Steps 7a & 7b not required. Unpowered. MIL-STD-202 Method 106 ±0.5% Biased Humidity 1000hrs 85℃/85%RH。Note: Specified conditions:10% of operating power. MIL-STD-202 Method 103 ±0.5% Operational Life Condition D Steady State TA=125℃ at rated power. MIL-STD-202 Method 108 ±0.5% Thermal Shock 1000X(-55°C to +150°C) MIL-STD202Method107G ±0.5% Solderability 235℃±5℃,2s±0.5s J-STD-202 95% Coverage Minimum Resistance to Soldering Heat 260℃±5℃,10s±1s MIL-STD-202 Method 210 ±0.5% Short Time Overload 5×Rated power for 5 s MIL-STD-202 Method 201 ±0.5% Shock 100g , 6ms , Orientation & Shock time: ±X, ±Y, ±Z; 3 times each orientation, total 18 times. MIL-STD-202 Method 213 ±0.5% Vibration 5 g's for 20 min, 12 cycles each of 3 orientations. Note: Use 8"X5" PCB .031" thick 7 secure points on one long side and 2 secure points at corners of opposite sides. Parts mounted within 2" from any secure point. Test from 10-2000 Hz. MIL-STD202Method204 ±0.5% +86-0755-26517682 yezhan@yezhan.com.cn http://www.yezhan.com.cn 低阻值合金电流采样贴片电阻-YLR06-W5系列 Low Resistance Metal Strip Chip Resistors-YLR06-W5 series 回流焊温度曲线 Solder Reflow Temperature Condition 降功率曲线 Power Derating Curve +86-0755-26517682 yezhan@yezhan.com.cn http://www.yezhan.com.cn 低阻值合金电流采样贴片电阻-YLR06-W5系列 Low Resistance Metal Strip Chip Resistors-YLR06-W5 series 印字标识 Marking 激光字码; Laser Marking All the products marking are 4 digits. ‘R’ designates the decimal location in ohms E.g., 3mΩ= R003; 100mΩ=R100;1.5mΩ=1m50 标准品为激光字码,如需白色丝印字码,请咨询业展销售团队。 Laser marking is default. If need white printed marking, pls contact Yezhan sales team. 包装 Packing 存储条件 Storage Conditions: Temperature:5℃~35℃, Humidity:40%~75% 编带盘装:Embossed Plastic Tape Unit/mm Type A±0.15 B±0.2 W±0.2 F±0.05 E±0.1 P1±0.1 P2±0.05 P0±0.1 D0±0.1 t±0.1 YLR06-W5 2.0 3.6 8.0 3.5 1.75 4.0 2.0 4.0 Φ1.5 0.84 3000 PCS/ reel (0.5mΩ≤R<1mΩ) 5000 PCS/ reel (1mΩ
YLR06-1-25F-W5 价格&库存
很抱歉,暂时无法提供与“YLR06-1-25F-W5”相匹配的价格&库存,您可以联系我们找货
