C35-2418-41124
C35-2418-41124
    UVK(优为科)
    CONN_23.36X5.1MM_SM
    排母 间距2.54mm 18Pin(2x9) H3.5 SMT带柱 镀金
C35-2418-41124 数据手册
G F E D C B A 1 2 3 4 2 Ordering Information No. of Positions XX Positions 3 4 Insulator Material Option PBT PA6T PA9T LCP 1 4 5 6 5 Terminal plating 0 Tin plating over all 1 Gold plating over all C 3 5 - X X XX- X X 1 X High Option No. of row/tiers 1 H=2.0-2.1mm 1 Single row 2 H=3.4-3.5mm Single tier 3 H=4.0-4.3mm 4 Double row 4 H=4.6-5.0mm Single tier 5 H=5.7mm 6 H=6.35-6.8mm 7 H=7.0-7.1mm 8 H=8.5mm 1 ≥ Packing 0 Pe Box 1 Tube 2 Reel 6 REV A0 DESCRIPTION NEW DRAWING REVISION DATA Technical Data Material: Contact Material: Brass Contact plating:Au Over 50µ" Ni Insulator Material:Black Polyester UL94V-0 Standard:PA6T+30%G.F Electrical: Current rating:3.0Amps/contact max. Contact resistance: ≤20mΩ/contact Insulation resistance: ≥1000MΩ at V=100V Withstanding Voltage:550V AC/minute SIZE A4 APPROVED BY DATE DATE 9 A0 REV 1/1 SHEET DATE 2013/11/06 0 1:1 SCALE 1 PAGE 2.54mm Female Header Dual Row SMT Type H3.5 OE7.2 CHECKED BY 2013/11/06 DATE DOCUMENT NO PART NO 8 C35-24**-41124 康观长 DRAWN BY TITLE U-Wilcome Precision Electronic Technology Co., Ltd 东莞市优为科精密电子科技有限公司 Mechanical: Mechanical life cycle:min.200 Operaing temperatures: Gold Plated:-55°C to+105°C Tin plated:-40°C to+105°C Soldering temperature: +260°C max(PA6T) 7 UNLESS OTHERWISE SPECIFIED TOLERANCES ARE X.X ±0.30 ±0.20 X.XX ±0.10 X.XXX ANG. ±°5 UNIT mm
C35-2418-41124 价格&库存
很抱歉,暂时无法提供与“C35-2418-41124”相匹配的价格&库存,您可以联系我们找货
