XL2OI-111-16M
XL2OI-111-16M
    YXC(扬兴科技)
    SMD3225_4P
    无源晶振 16MHz ±10ppm 12pF -40℃~+85℃
XL2OI-111-16M 数据手册
Crystal Unit YSX321SL Applications Features ‧Smart Wearable ‧Dimensions: 3.20 x 2.50 x 0.70 mm.. ‧High precision and high frequency stability. IOT Communication ‧Standard Frequency: 8~54MHz ‧Extremely good for reducing EMI effect. Specifications(规格参数) Item Nominal Frequency Range(额定频率范围) Vibration Mode(震动模式) Load Capacitance(负载电容) Frequency Tolerance(频率偏差) (at 25℃ ) Frequency Versus Temperature Characteristics(频率-温度特性) Operating Temperature(工作温度) Storage Temperature(储存温度) Shunt Capacitance(静态电容) Level of Drive(激励电平) Aging (老化)(at 25℃ ) Symbol Specifications f_nom 8~64MHz - AT Fundamental CL 10pF, 20pF, or specify f_tol ±10ppm, ±20ppm, or specify f_tem ±20ppm, or specify T_use -40~+85℃ or specify T_stg -55~+125℃ C0 7pF Max. DL 1~200μW Max.(100μW typical) f_age ±3ppm/year Max. Equivalent Series Resistance(等效串联电阻(ESR)) YST321SL 8 ~ 11.2892MHz 150 Ω Max. 12 ~ 16MHz 80 Ω Max. 17 ~ 64MHz 50 Ω Max. Dimensions and Recommended land pattern(外观尺寸及推荐焊盘) Dimensions (Unit: mm) Recommended land pattern(Unit: mm) www.yxc.hk 1
XL2OI-111-16M
物料型号:YSX321SL 器件简介:YXO,RoHS,NPS NPS无铅 应用领域:智能穿戴设备、物联网通信 特点:尺寸为3.20 x 2.50 x 0.70 mm,标准频率为8~54MHz,具有高精度和高频率稳定性,极好地降低电磁干扰效果。
规格参数: - 额定频率范围:8-64MHz - 震动模式:AT Fundamental - 负载电容:10pF, 20pF, 或指定 - 频率偏差(25°C):±10ppm, +20ppm, 或指定 - 频率-温度特性:+20ppm, 或指定 - 工作温度:-40~+85°C 或指定 - 储存温度:-55~+125°C - 静态电容:最大7pF - 激励电平:最大1~200mW(典型100mW) - 老化(25°C):每年最大±3ppm
等效串联电阻(ESR): - 8~11.2892MHz:最大150 - 12~16MHz:最大80 - 17~64MHz:最大50
XL2OI-111-16M 价格&库存
很抱歉,暂时无法提供与“XL2OI-111-16M”相匹配的价格&库存,您可以联系我们找货
XL2OI-111-16M
  • 1+0.31500
  • 100+0.29400
  • 300+0.27300
  • 500+0.25200
  • 2000+0.24150
  • 5000+0.23520
库存:35037
XL2OI-111-16M
  • 5+0.55404
  • 50+0.44280
  • 150+0.38718
  • 500+0.34539
库存:952
XL2OI-111-16M
  • 20+0.84360
  • 100+0.50320
  • 800+0.35220
  • 3000+0.25160
  • 6000+0.23910
  • 30000+0.22140
XL2OI-111-16M
  • 1+0.49665
  • 200+0.32025
  • 1500+0.27930
  • 3000+0.24675
库存:1989
XL2OI-111-16M
  • 5+0.41160
  • 50+0.32980
  • 150+0.27500
  • 500+0.25220
  • 1000+0.23590
  • 3000+0.22150
  • 6000+0.21160
库存:95
