BS4200N-2C
BS4200N-2C
    BENCENT(槟城)
    SMB-T
    半导体放电管(TSS) VDRM=400V@5μA Vs=520V@800mA SMB-T
BS4200N-2C 数据手册
BS42 200N-2C C Ordder Code: BS4200N-2 2C Version: A0 2014-01--21 Thy yristor Surg ge Suppresseer Ex xterior Feaatures Excellent capaability of abso orbing transieent surge Quick Q response to surge volltage(nS Leevel) used by fast rissing transientts Eliminates oveervoltage cau Moisture M sensiitivity level: leevel 1 Weight W 88 mg Non N degenerattive Bi-directional SM MB-T Appplication innformation Package P (topp view) E Ethernet B422NC 1309 2 Aggency Approovals I Icon 1 3 Schematic Syymbol D Description Co ompliance with 2 2011/65/EU Co ompliance withIE EC61249-2-21:20 003 Partt Number annd Electricaal Parameterr VS①@ IS IDRM@VDRM D Part Number N μA V V MAX Piin1,3-2 Pin1 1,3-2 5 400 520 BS420 00N-2C   mA A V T @ IT V A MAX 800 0 4 2.2 IH CO② mA pF MAX MAX 50 35 % (unless otherwise noted)). H = 45%-75% Ab bsolute maxim mum ratings measured at TA= 25ºC RH ①Vs is measurred at 100KV V/S ② Off-state Caapacitance is m MS=1V,f=1MH Hz measured at VDC=2V,VRM 1/5 www.benncent.com.cn S Specifications aare subject to ch hange without notice. n Customers should verify actuaal device perforrmance in their specific applications BS42 200N-2C C Ordder Code: BS4200N-22C Version: A0 2014-01--21 Thyyristor Surgge Suppresseer Parrt Numberinng System Mark M BS 4200 0 N 2 C (1) (2) ( 3) (4) (5) B42 22NC 13 309 (1))Bencent Sem miconductor Surge S Arresteer (2))Off state Volltage,e.g:4200 0=420×100=420V. = (3)) Package : SM MB-T B422NC: P Part Number (4)) 2 Lines Pro otection 1309 :Septeempter,2013 (5)) Rating Surrge Voltage: 6KV(10/70 00μS) V-II Curve P Parameters Definition n VDRM Peaak Off-state Voltage V IDRM O Off-stateCurr rent VS S Switching Volltage IS S Switching Currrent IH H Holding Currrent VT O On-state Volttage IT O On-state Currrent CO Off ff-state Capaccitance +I IT IS IH IDRM -V +V VT VDRM VS -I Surgge Ratings Cu urrent Wavefform 2/10μs 8/20μs 10/160μs 5/32 20μs* 10/1000μs Vo oltage Wavefform 2/10μs 1.2/50 0μs 10/160μs 10/7 700μs* 10/1000μs Ipp 500A 400A A 200A 15 50A 100A -Peaak pulse curreent rating (IPPP)is repetitive and guaranteeed for the liffe of the prod duct; -Ben ncent only maakes the test for f 5/320μs@ @150A* (10/700μs@6KV),but for otheer IPP valued derived from experience e isjjust for referrence only. Bencent B will not take any obligation fo or these paraameters, so beefore applyin ngour parts, please p make sure s to verify theparameeters listed in the above tab ble. Therrmal Considderations Sym mbol TJ TS 2/5 Parameter Opeerating Junctiion Tem mperature Ran nge Storaage Temperatture Range www.benncent.com.cn Ph hysical Chaaracteristics Vaalue Un nit Lead Materrial -40 to o +150 ℃ Body Materrial -60 to o +150 ℃ Terminal Fin nish Copper Alloy L recognized epoxy e meetin ng UL flam mmability classification 94V V-0 100% Matte--Tin Plated S Specifications aare subject to ch hange without notice. n Customers should verify actuaal device perforrmance in their specific applications BS42 200N-2C C Ordder Code: BS4200N-22C Thyyristor Surgge Suppresseer Version: A0 2014-01--21 Typpical Characcteristics 3/5 www.benncent.com.cn S Specifications aare subject to ch hange without notice. n Customers should verify actuaal device perforrmance in their specific applications BS42 200N-2C C Ordder Code: BS4200N-22C Version: A0 2014-01--21 Thyyristor Surgge Suppresseer Ennvironmentaal Characterristics T Testing Itemss Techn nical Standard ds Hiigh Temperatture Reverse Bias B Test Temperaature: 150±3℃ ℃, Bias=80% %VDRM Time:16 68H Hiigh Temperatture Life Testt Temperaature: 150℃ Time:16 68H Hiigh-low Temp perature Cyclle Test Temperaature:From -4 40℃ to125℃ Dwell tiime: 30min, 10-100 1 cycles Hiigh Temperatture &High Humidity H Testt Temperaature: 85℃Hu umidity:85% Test tim me:168H Prressure Cookeer Test Temperaature: 121℃, 2atm. Humidity:100% Test tim me: 24H to 168 8H Reesistance of Soldering S Heaat Temperaature: 260±5℃ ℃ Time off dip solderingg: 10s, 3timess Note: The abovve testing item ms can be speecified by cusstomers by co ontacting Benncent service Prooduct Dimeensions Botto om view H I Side view REF mm inch A 5.4±0.3 0..213±0.012 B 3.3±0.3 0..130±0.012 C 0.7±0.03 3 0..028±0.001 D 2.0±0.2 0..079±0.008 E 0.9±0.2 0..035±0.008 F 1.32±0.3 3 0..052±0.012 G 1.13±0.3 3 0..045±0.012 H 2±0.3 0..079±0.012 I 0.25±0.05 5 0..010±0.002 REF mm inch A 3.4 0.134 B 2.5 0.098 C 1.6 0.059 D 1.8 0.059 E 0.9 0.035 F 0.7 0.032 Reecommended Solderingg Pad 4/5 www.benncent.com.cn S Specifications aare subject to ch hange without notice. n Customers should verify actuaal device perforrmance in their specific applications BS42 200N-2C C Ordder Code: BS4200N-22C Version: A0 2014-01--21 Thyyristor Surgge Suppresseer Refflow Profilee Reflow Condition perature Min. Temp +150 0°C Temp perature Max. +200 0°C Timee(Min to Max) 60 – 180 secs. Aveerage ramp up rate(Liquidus Tem mp(TL) to peak k) TS(m max) to TL - Ra amp-up Rate 3°C/ /sec. Max. (L Liquidus) - Temperature T (T TL) Peaak Temp (TP) 7°C +217 60 – 150 secs. (TP) TS TL 6°C/ /sec. Max. Tim me 25°C to peaak Temp (TP) 8 min n. Max. Do not exceed +260 0°C 5/5 Ramp-dow wn Preheat TS(min) 8 – 15 secs. Ram mp-down Ratee Pacckage Reeel TL TS(max) +(26 60+0/-5 )°C Tim me within 5°C of actual Peak k Temp Critical Zone TL to TP Ram mp-up TL 3°C/ /sec. Max. - Temperature T (T TL) Refflow TP TP Temperature Pre Heat Pb-F Free Assembly y 25 2 Time me to peak temperatu ure tim Informaation REF mm m inch A 3.65+/ /-0.3 0.144+/-0.01 12 B 5.69+/ /-0.3 0.244+/0-.01 12 d 1.5+/ /-0.1 0.059+/-0.00 04 D 330.0 13.0 D1 100+ +/-3 3.937+/-0.11 18 D2 13+/--0.3 0.512+/-0.01 12 E 1.5+/ /-0.2 0.059+/-0.00 08 F 5.65+/ /-0.2 0.222+/-0.00 08 P 8.0+/ /-0.2 0.315+/-0.00 08 P0 4.0+/ /-0.2 0.157+/-0.00 08 P1 2.0+/ /-0.2 0.079+/-0.00 08 W 12.0+/ /-0.2 0.472+/-0.00 08 W1 16.8+/ /-2.0 0.661+/-0.07 79 Outline Reel R ( (pcs) Per Carto on (pcs) Reel R Diameterrs (mm) Taping 3 3,000 24,000 0 330 www.benncent.com.cn Carton Size(mm) L W H 360 0 360 0 380 0 S Specifications aare subject to ch hange without notice. n Customers should verify actuaal device perforrmance in their specific applications
BS4200N-2C 价格&库存
很抱歉,暂时无法提供与“BS4200N-2C”相匹配的价格&库存,您可以联系我们找货
BS4200N-2C
    • 5+2.60290
    • 50+2.30220
    • 150+2.15170
    • 500+2.00140
    • 3000+1.82780
    • 6000+1.71220
    库存:7
    BS4200N-2C
      库存:7
      BS4200N-2C
      • 5+1.20780
      • 20+1.10880
      • 100+1.00980
      • 500+0.91080
      • 1000+0.86460
      • 2000+0.83160
