XKZGI-112-32.768K
XKZGI-112-32.768K
    YXC(扬兴科技)
    MC-306
    无源晶振 32.768kHz ±20ppm 12.5pF -40℃~+85℃
XKZGI-112-32.768K 数据手册
Crystal Unit 32.768KHZ YSX306GA Applications ‧RTC. Glass Sealed Features ‧Dimensions: :8.00 x 3.80 x 2.54mm. ‧Reflow is possible. ‧Standard Frequency: 32.768KHz ‧Contains Pb in sealing glass exempted by ROHS directive. Specifications(规格参数) Item Symbol Specifications f_nom 32.768KHz Frequency Tolerance(频率偏差) (at 25℃ ) CL 7pF, 9pF, 12.5pF, or specify± f_tol 10ppm, ±20ppm, or specify Operating Temperature(工作温度) B ( - 0.036 ± 0.006 ) * 10 -6 / ℃2 T_use -40~+85℃ T_stg -55~+125℃ C0 2.0pF Max. C1 3.0fF DL 1.0μW Max f_age ±5ppm/year Max. Nominal Frequency(额定频率范围) Load Capacitance(负载电容) Parabolic Coefficient(频率温度系数) Storage Temperature(储存温度) Shunt Capacitance(静态电容) Motional Capacitance(动态电容) Level of Drive(激励电平) Aging (老化)(at 25℃ ) Equivalent Series Resistance(等效串联电阻(ESR)) YST306GA 50K Ω Max. Dimensions and Recommended land pattern(外观尺寸) Dimensions (Unit: mm) www.yxc.hk 1
XKZGI-112-32.768K 价格&库存
很抱歉,暂时无法提供与“XKZGI-112-32.768K”相匹配的价格&库存,您可以联系我们找货
XKZGI-112-32.768K
  • 5+1.70570
  • 50+1.35280
  • 150+1.20120
库存:241
XKZGI-112-32.768K
  • 1+1.42140
  • 100+1.09180
  • 750+0.91155
  • 1500+0.82709
  • 3000+0.76838
库存:5170
XKZGI-112-32.768K
  • 1+1.46970
  • 10+1.19450
  • 50+1.00600
  • 150+0.93890
  • 500+0.88000
  • 1000+0.82800
  • 3000+0.78840
库存:1464
XKZGI-112-32.768K
  • 1+0.91022
  • 30+0.87771
  • 100+0.84521
  • 500+0.78019
  • 1000+0.74768
  • 2000+0.72818
库存:2939
