H6OSC-SUG-8M
H6OSC-SUG-8M
    YXC(扬兴科技)
    HC-49S/SMD
    无源晶振 8MHz ±20ppm 20pF -20℃~+70℃
H6OSC-SUG-8M 数据手册
Crystal Unit HC-49SMD Applications Features ‧Industrial Control Consumers. ‧Dimensions: 11.5 x 4.80 x3.8mm. ‧Standard Frequency: 3.2768~64MHz ‧Surface mount type crystal units. ‧A great number of standard frequencies. Specifications(规格参数) Item Nominal Frequency Range(额定频率范围) Vibration Mode(震动模式) Load Capacitance(负载电容) Frequency Tolerance(频率偏差) (at 25℃ ) Frequency Versus Temperature Characteristics(频率-温度特性) Operating Temperature(工作温度) Storage Temperature(储存温度) Shunt Capacitance(静态电容) Level of Drive(激励电平) Aging (老化)(at 25℃ ) Symbol Specifications f_nom 3.2768~64MHz - AT Fundamental CL 12pF, 20pF, or specify f_tol ±10ppm, ±20ppm, or specify f_tem ±20ppm, or specify T_use -20~+70℃, or specify T_stg -40~+85℃ C0 7pF Max. DL 1~500μW Max.(100μW typical) f_age ±3ppm/year Max. Equivalent Series Resistance(等效串联电阻(ESR)) HC-49SMD 3.2768 ~ 4MHz 180 Ω Max. 6 ~ 7MHz 80 Ω Max. 4 ~ 5MHz 120 Ω Max. 7 ~ 10MHz 60 Ω Max. 5 ~ 6 MHz 100 Ω Max. 10 ~ 30MHz 40 Ω Max. Dimensions and Recommended land pattern(外观尺寸及推荐焊盘) Dimensions (Unit: mm) Recommended land pattern(Unit: mm) www.yxc.hk 1
H6OSC-SUG-8M 价格&库存
很抱歉,暂时无法提供与“H6OSC-SUG-8M”相匹配的价格&库存,您可以联系我们找货
H6OSC-SUG-8M
  • 1+0.36000
  • 100+0.33600
  • 300+0.31200
  • 500+0.28800
  • 2000+0.27600
  • 5000+0.26880
库存:7280
H6OSC-SUG-8M
  • 1+0.36110
  • 10+0.34270
  • 100+0.33020
  • 500+0.31490
  • 1000+0.30090
库存:120
H6OSC-SUG-8M
  • 5+0.64887
  • 50+0.51668
  • 150+0.45058
  • 1000+0.40101
库存:1725
H6OSC-SUG-8M
  • 1+0.54899
  • 50+0.32342
  • 1000+0.29149
库存:4512
H6OSC-SUG-8M
  • 5+0.64070
  • 50+0.50710
  • 150+0.44220
  • 1000+0.39330
库存:2445
H6OSC-SUG-8M
  • 1+0.29300
库存:48
