Crystal Unit
YSX530GA
Applications
‧Industrial Control
Consumers.
Glass Sealed
Features
‧Dimensions: 5.00 x 3.20 x 1.2 mm
‧2 pads SMD glass sealed crystal units.
‧Standard Frequency: 8~54MHz
‧Contains Pb in sealing glass exempted by ROHS directive.
Specifications(规格参数)
Item
Nominal Frequency Range(额定频率范围)
Vibration Mode(震动模式)
Load Capacitance(负载电容)
Frequency Tolerance(频率偏差) (at 25℃ )
Frequency Versus Temperature Characteristics(频率-温度特性)
Operating Temperature(工作温度)
Storage Temperature(储存温度)
Shunt Capacitance(静态电容)
Level of Drive(激励电平)
Aging (老化)(at 25℃ )
Symbol
Specifications
f_nom
8~54MHz
AT Fundamental
CL
10pF, 20pF, or specify
f_tol
±10ppm, ±20ppm, or specify
f_tem
±20ppm, or specify
T_use
-20~+70℃, -40~+85℃, or specify
T_stg
-55~+125℃
C0
5pF Max
DL
1~300μW Max.(100μW typical)
f_age
±3ppm/year Max.
Equivalent Series Resistance(等效串联电阻(ESR))
YST530GA
8 ~ 16MHz
80 Ω Max.
16 ~ 25MHz
40~60 Ω Max.
25 ~ 54MHz
30~40 Ω Max.
Dimensions and Recommended land pattern(外观尺寸及推荐焊盘)
Dimensions (Unit: mm)
Recommended land pattern(Unit: mm)
www.yxc.hk
1
很抱歉,暂时无法提供与“XG1SI-111-8M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.88200
- 30+0.85050
- 100+0.81900
- 500+0.75600
- 1000+0.72450
- 2000+0.70560
- 国内价格
- 1+1.47970
- 10+1.19680
- 50+1.00480
- 150+0.93640
- 500+0.87670
- 1000+0.82430
- 3000+0.78680
- 国内价格
- 50+0.96228
- 500+0.89100
- 1000+0.85536
- 5000+0.81972
- 10000+0.79834
- 国内价格
- 1+1.12350
- 50+0.86310
- 1000+0.79485
- 国内价格
- 5+1.68000
- 50+1.30000
- 150+1.10000
- 1000+1.03000
- 5000+0.92000
- 10000+0.85000
