Crystal Unit
YSX531SL
Applications
‧Industrial Control
Consumers.
Features
‧Dimensions: 5.00 x 3.20 x 0.90mm.
‧High precision and high frequency stability.
‧Standard Frequency: 8~54MHz
‧Extremely good for reducing EMI effect.
Specifications(规格参数)
Item
Nominal Frequency Range(额定频率范围)
Vibration Mode(震动模式)
Load Capacitance(负载电容)
Frequency Tolerance(频率偏差) (at 25℃ )
Frequency Versus Temperature Characteristics(频率-温度特性)
Operating Temperature(工作温度)
Storage Temperature(储存温度)
Shunt Capacitance(静态电容)
Level of Drive(激励电平)
Aging (老化)(at 25℃ )
Symbol
Specifications
f_nom
8~54MHz
AT Fundamental
CL
10pF, 20pF, or specify
f_tol
±10ppm, ±20ppm, or specify
f_tem
±20ppm, or specify
T_use
-40~+85℃ or specify
T_stg
-55~+125℃
C0
5pF Max.
DL
1~200μW Max.(100μW typical)
f_age
±3ppm/year Max.
Equivalent Series Resistance(等效串联电阻(ESR))
YSX531SL
8 ~ 12MHz
60~80 Ω Max.
13 ~ 25MHz
40~60 Ω Max.
26 ~ 54MHz
30~40 Ω Max.
Dimensions and Recommended land pattern(外观尺寸及推荐焊盘)
Dimensions (Unit: mm)
Recommended land pattern(Unit: mm)
www.yxc.hk
1
很抱歉,暂时无法提供与“XL1SI-111-12M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+2.29080
- 100+1.71330
- 500+1.32830
- 1000+0.96250
- 2000+0.91450
- 10000+0.84700
- 国内价格
- 1+0.98000
- 30+0.94500
- 100+0.91000
- 500+0.84000
- 1000+0.80500
- 2000+0.78400
- 国内价格
- 1+1.49810
- 10+1.19290
- 50+0.99070
- 150+0.92010
- 500+0.85870
- 1000+0.80510
- 3000+0.76680
- 国内价格
- 1+0.99395
- 50+0.76426
- 1000+0.70452
- 国内价格
- 5+1.90091
- 50+1.50833
- 150+1.34007
- 1000+1.13012
- 2000+1.03670
- 5000+0.98054
