XL1SI-111-8M
XL1SI-111-8M
    YXC(扬兴科技)
    SMD5032_4P
    无源晶振 8MHz ±10ppm 20pF -40℃~+85℃
XL1SI-111-8M 数据手册
Crystal Unit YSX531SL Applications ‧Industrial Control Consumers. Features ‧Dimensions: 5.00 x 3.20 x 0.90mm. ‧High precision and high frequency stability. ‧Standard Frequency: 8~54MHz ‧Extremely good for reducing EMI effect. Specifications(规格参数) Item Nominal Frequency Range(额定频率范围) Vibration Mode(震动模式) Load Capacitance(负载电容) Frequency Tolerance(频率偏差) (at 25℃ ) Frequency Versus Temperature Characteristics(频率-温度特性) Operating Temperature(工作温度) Storage Temperature(储存温度) Shunt Capacitance(静态电容) Level of Drive(激励电平) Aging (老化)(at 25℃ ) Symbol Specifications f_nom 8~54MHz - AT Fundamental CL 10pF, 20pF, or specify f_tol ±10ppm, ±20ppm, or specify f_tem ±20ppm, or specify T_use -40~+85℃ or specify T_stg -55~+125℃ C0 5pF Max. DL 1~200μW Max.(100μW typical) f_age ±3ppm/year Max. Equivalent Series Resistance(等效串联电阻(ESR)) YSX531SL 8 ~ 12MHz 60~80 Ω Max. 13 ~ 25MHz 40~60 Ω Max. 26 ~ 54MHz 30~40 Ω Max. Dimensions and Recommended land pattern(外观尺寸及推荐焊盘) Dimensions (Unit: mm) Recommended land pattern(Unit: mm) www.yxc.hk 1
XL1SI-111-8M 价格&库存
很抱歉,暂时无法提供与“XL1SI-111-8M”相匹配的价格&库存,您可以联系我们找货
XL1SI-111-8M
  • 5+2.05352
  • 50+1.60283
  • 150+1.40973
  • 1000+1.16867
库存:1048
XL1SI-111-8M
  • 1+0.77760
库存:99
XL1SI-111-8M
  • 10+2.89180
  • 100+1.72500
  • 500+1.20750
  • 1000+0.86250
  • 2000+0.81940
  • 10000+0.75900
XL1SI-111-8M
  • 5+2.01630
  • 50+1.57280
  • 150+1.38300
  • 1000+1.14590
  • 2000+1.04070
库存:244
XL1SI-111-8M
  • 1+1.08150
  • 50+0.83327
  • 1000+0.76838
库存:938
XL1SI-111-8M
  • 1+0.98000
  • 30+0.94500
  • 100+0.91000
  • 500+0.84000
  • 1000+0.80500
  • 2000+0.78400
库存:1752
