W5500-MK绿色迷你版
W5500-MK绿色迷你版
    WIZNET
    DEVB_28.5X23MM
    开发板/评估板/验证板 W5500以太网网络模块 SPI接口/Ethernet/TCP/IP协议 兼容WIZ820io
W5500-MK绿色迷你版 数据手册
WIZ820io User Manual (Version 1.0) © 2011 WIZnet Co., Ltd. All Rights Reserved. ☞ For more information, visit our website at http://www.wiznet.co.kr WIZ820io User Manual (WIZnet Co., Ltd.) 1 Document Revision History Date Revision 2011-09-15 V1.0 Changes Official Release WIZ820io User Manual (WIZnet Co., Ltd.) 2 1. Introduction WIZ820io is the internet offload network module that includes W5200 (TCP/IP hardwired chip, include PHY), MAG-JACK (RJ45 with X’FMR) with other glue logics. It can be used as a component and no effort is required to interface W5200 and Transformer. The WIZ820io is an ideal option for users who want to develop their Internet enabling systems rapidly. For the detailed information on implementation of Hardware TCP/IP, refer to the W5200 Datasheet. WIZ820io consists of W5200 and MAG-JACK.   TCP/IP, Ethernet MAC : W5200 Ethernet PHY : Included in W5200  Connector : MAG-JACK(RJ45 with Transformer) 1.1 Feature                Supports 10/100 Base TX Supports half/full duplex operation Supports auto-negotiation and auto cross-over detection IEEE 802.3/802.3u Compliance Supports high speed SPI Interface (SPI mode 0, 3) Operates 3.3V with 5V I/O signal tolerance Supports network status indicator LEDs Includes Hardware Internet protocols: TCP, IPv4, UDP, ICMP, ARP, PPPoE, IGMP Includes Hardware Ethernet protocols: DLC, MAC Supports 8 independent connections simultaneously Supports Power down mode Supports Wake On LAN Supports Socket API for easy application programming Interfaces with two 2.54mm pitch 1 x 6 header pin Very small form factor: 23mm x 25mm (PCB size) WIZ820io User Manual (WIZnet Co., Ltd.) 3 2. Pin assignment & description 2.1 Pin assignment < TOP side view > < Pin assignment > WIZ820io User Manual (WIZnet Co., Ltd.) 4 2.2 Pin description Pin No. I/O Pin Name Description 1 P GND Ground 2 P GND Ground 3 I MOSI 4 I SCLK SPI Master Out Slave In This pin is used to SPI MOSI signal pin. SPI Clock This pin is used to SPI Clock Signal pin. SPI Slave Select : Active Low 5 I nSS J1 This pin is used to SPI Slave Select signal Pin when using SPI interface. Interrupt : Active low This pin indicates that W5200 requires MCU attention after socket connecting, 6 O nINT disconnecting, data receiving timeout, and WOL (Wake on LAN). The interrupt is cleared by writing IR Register or Sn_IR (Socket n-th Interrupt Register). All interrupts are maskable. 1 P GND Ground 2 P 3V3D Power : 3.3 V power supply 3 P 3V3D Power : 3.3 V power supply Power Down : Active High 4 I PWDN This pin is used to power down pin. Low : Normal Mode Enable High : Power Down Mode Enable J2 Reset : This pin is active low input to initialize or re-initialize W5200. 5 I nRESET It should be held at least 2us after low assert, and wait for at least 150ms after high de-assert in order for PLL logic to be stable. 6 O MISO WIZ820io User Manual (WIZnet Co., Ltd.) SPI Master In Slave Out This pin is used to SPI MISO signal pin. 5 3. Device SPI operations WIZ820io is controlled by a set of instruction that is sent from a external host , commonly referred to as the SPI Master. The SPI Master communicates with W5200 via the SPI bus, which is composed of four signal lines: Slave Chip Select (nSS), Serial Clock (SCLK), MOSI (Master Out Slave In) and MISO (Master In Slave Out). The SPI protocol defines four modes for its operation (Mode 0-3). Each mode differs according to the SCLK polarity and phase - how the polarity and phase control the flow of data on the SPI bus. The W5200 operates as SPI Slave device and supports the most common modes - SPI Mode 0 and 3. The only difference between SPI Mode 0 and 3 is the polarity of the SCLK signal at the inactive state. With SPI Mode 0 and 3, data is always latched in on the rising edge of SCLK and always output on the falling edge of SCLK. 3.1 Process of using general SPI Master device 1. Configure Input/Output direction on SPI Master Device pins. 2. Configure nSCS as ‘High’ on inactive 3. Write target address for transmission on SPDR register (SPI Data Register). 4. Write OP code and data length for transmission on SPDR register. 5. Write desired data for transmission on SPDR register. 6. Configure nSCS as ‘Low’ (data transfer start) 7. Wait for reception complete 8. If all data transmission ends, configure nSCS as ‘High’ 0 1 2 Address OP Code (1bit) + data length n (16bit) data1 n data ... data n-1 Bit 0 1 2 3 4 5 Byte 6 7 Byte < W5200 SPI Frame Format > WIZ820io User Manual (WIZnet Co., Ltd.) 6 < Address and OP/DATA Length Sequence Diagram > 3.2 Read processing The READ processing is entered by driving nSS low, followed by the Address, the OP code, the Data Length and the Data byte on MOSI. The OP code (OP) is defined type of the READ OP and WIRTE OP. On OP = 0, the read operation is selected. Otherwise, On OP = 1, the write operation is selected. In W5200 SPI mode, the Byte READ processing and the burst READ processing are provided. The Byte READ processing takes 4 instructions which is consist of the 16-bit Address, the 1-bit OP code(0x0), the 15-bit Data length and 8-bit Data. Otherwise, The Burst READ processing only takes the Data instruction after the setting of the burst read processing. To distinguish between the Byte READ and the burst READ processing, the Data length is used. If the Data length is ‘1,’ the Byte READ processing is operated. Otherwise, the Burst READ Processing is operated when the Data length is more than two. The MISO pin should be selected by driving MISO low after the falling edge of the nSS. WIZ820io User Manual (WIZnet Co., Ltd.) 7 < Read Sequence > /* Pseudo Code for Read data of 8bit per packet */ #define data_read_command uint16 addr; 0x00 // Address : 16bits int16 data_len; // Data length :15bits uint8 data_buf[]; // Array for data SpiSendData(); // Send data from MCU to W5200 SpiRecvData(); // Receive data from W5200 to MCU { ISR_DISABLE(); CSoff(); // Interrupt Service Routine disable // CS=0, SPI start // SpiSendData SpiSendData(((addr+idx) & 0xFF00) >> 8); SpiSendData((addr+idx) & 0x00FF); // Address byte 1 // Address byte 2 // Data write command + Data length upper 7bits SpiSendData((data_read_command| ((data_len& 0x7F00) >> 8))); // Data length bottom 8bits SpiSendData((data_len& 0x00FF)); // Read data:On data_len> 1, Burst Read Processing Mode. for(int idx = 0; idx WIZ820io User Manual (WIZnet Co., Ltd.) 9 /* Pseudo Code for Write data of 8bit per packet */ #define data_write_command uint16 addr; 0x80 // Address : 16bits int16 data_len; // Data length :15bits uint8 data_buf[]; // Array for data { SpiSendData(); //Send data from MCU to W5200 ISR_DISABLE();// Interrupt Service Routine disable CSoff();// CS=0, SPI start SpiSendData(((addr+idx) & 0xFF00) >> 8); SpiSendData((addr+idx) & 0x00FF); // Address byte 1 // Address byte 2 // Data write command + Data length upper 7bits SpiSendData((data_write_command | ((data_len& 0x7F00) >> 8))); // Data length bottom 8bits SpiSendData((data_len& 0x00FF)); // Write data: On data_len> 1, Burst Write Processing Mode. for(int idx = 0; idx
W5500-MK绿色迷你版 价格&库存
很抱歉,暂时无法提供与“W5500-MK绿色迷你版”相匹配的价格&库存,您可以联系我们找货
