SM8102HABC
SM8102HABC
    SILERGY(矽力杰)
    SOT23-6
    高效、快速响应、2.0A、18V输入同步降压调节器
SM8102HABC 数据手册
Application Note: SM8102H High Efficiency, Fast Response, 2.0A, 18V Input Synchronous Step Down Regulator Advanced Design Specification General Description Features  The SM8102H is a high efficiency, synchronous stepdown DC/DC converter capable of delivering 2A load current. The SM8102H operates over a wide input voltage range from 4.2V to 18V and integrates main switch and synchronous switch with very low RDS(ON) to minimize the conduction loss.      The SM8102H adopts the instant PWM architecture to achieve fast transient responses for high step down applications and high efficiency at light loads. In addition, it operates at pseudo-constant frequency of 500kHz to minimize the size of inductor and capacitor.      Ordering Information SM8102 □(□□)□ Applications Temperature Code Package Code Optional Spec Code Ordering Number SM8102HABC Package type SOT23-6 Low RDS(ON) for Internal Switches (Top/Bottom): 130mΩ/105mΩ 4.2-18V Input Voltage Range 2A Output Current Capability 500kHz Switching Frequency Minimize the External Components Stable with 10µF COUT and 2.2µH Inductor Instant PWM Architecture to Achieve Fast Transient Responses Internal Soft-start Limits the Inrush Current Cycle-by-cycle Peak/Valley Current Limitation Hic-cup Mode Output Short Circuit Protection Thermal Shutdown with Auto Recovery Compact Package SOT23-6       Note ---- Set Top Box Portable TV DSL Modem LCD TV IP CAM Networking Typical Application CBS 100nF L 4.7µH BS VIN :4.2~18V IN Efficiency vs. Load Current 100 VOUT: 3.3V LX 95 SM8102H EN CFF 47pF RH 100k FB GND RL 22.1k Figure1. Schematic Diagram 90 COUT 10µF Efficiency (%) CIN 10µF (IOUT=0~2A, L=4.7µH/VLS6045EX-4R7M) 85 80 75 70 65 Inductor and COUT Selection Table VOUT [V] L [µH] 2.2 3.3 2.2 4.7 3.3 6.8 4.7 COUT [µF] 10 VIN=12V,VOUT=3.3V 22 √ 1.2 √ ☆ √ √ 3.3 √ ☆ √ √ 5 √ ☆ Note: ‘☆ ’ means recommended for most applications. AN_SM8102H Rev0.0 © 2020 Silergy Corp. VIN=5V,VOUT=3.3V 60 55 50 0.01 VIN=18V,VOUT=3.3V 0.1 1 10 Load Current (A) Figure2. Efficiency vs. Load Current Silergy Corp. Confidential- Prepared for Customer Use Only 1 All Rights Reserved. SM8102H Pin-out (top view) BS 1 6 LX GND 2 5 IN 4 EN FB 3 (SOT23-6) Top mark: R6xyz (Device code: R6, x=year code, y=week code, z= lot number code) Pin Name Pin Number BS 1 GND 2 FB 3 EN 4 IN 5 LX 6 Pin Description Boot-strap pin. Supply high side gate driver. Connect a 0.1µF ceramic capacitor between the BS and the LX pin. Power ground pin. Output feedback pin. Connect this pin to the center point of the output resistor divider (as shown in Figure 1) to program the output voltage: VOUT=0.6×(1+RH/RL). Enable control. Pull high to turn on. Do not leave this pin floating. Input pin. Decouple this pin to the GND pin with at least a 10µF ceramic capacitor. Inductor pin. Connect this pin to the switching node of inductor. Block Diagram IN Current Sense Internal Power PWM Control & Protect Logic EN 1.2V FB Internal SST Thermal Protection © 2020 Silergy Corp. LX Current Sense 0.6V AN_SM8102H Rev0.0 BS Input UVLO 4.15V GND Silergy Corp. Confidential- Prepared for Customer Use Only 2 All Rights Reserved. SM8102H Absolute Maximum Ratings (Note 1) Supply Input Voltage ------------------------------------------------------------------------------------------------- -0.3V to 19V LX, EN Voltage--------------------------------------------------------------------------------------------- -0.3V to VIN + 0.3V FB, BS-LX Voltage----------------------------------------------------------------------------------------------------- -0.3V to 4V Power Dissipation, PD @ TA = 25°C SOT23-6, ------------------------------------------------------------------------------ 1W Package Thermal Resistance (Note 2) θ JA ---------------------------------------------------------------------------------- ----------------------- 100°C/W θ JC ------------------------------------------------------------------------ ----------------------------------- 25°C/W Junction Temperature Range ------------------------------------------------------------------------------------- -40°C to 150°C Lead Temperature (Soldering, 10 sec.) ----------------------------------------------------------------------------- 260°C Storage Temperature Range ------------------------------------------------------------------------------- -65°C to 150°C Dynamic LX voltage in 10ns duration (Note3) ---------------------------------------------------- IN+3V to GND-5V Recommended Operating Conditions (Note 3) Supply Input Voltage ---------------------------------------------------------------- --------------------------- 4.2V to 18V Junction Temperature Range ------------------------------------------------------------------------------- -40°C to 125°C Ambient Temperature Range ------------------------------------------------------------------------------- -40°C to 85°C AN_SM8102H Rev0.0 © 2020 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 3 All Rights Reserved. SM8102H Electrical Characteristics (VIN = 12V, VOUT = 3.3V, L = 4.7µH, COUT = 10µF, TA = 25°C, IOUT = 1A unless otherwise specified) Parameter Input Voltage Range Input UVLO Threshold Input UVLO Hysteresis Quiescent Current Shutdown Current Feedback Reference Voltage FB Input Current Top FET RON Bottom FET RON EN Rising Threshold EN Falling Threshold Min ON Time Min OFF Time Turn On Delay Soft-start Time Switching Frequency Symbol VIN VUVLO VHYS IQ ISHDN Test Conditions Min 4.2 Top FET Current Limit Bottom FET Current Limit Output Under Voltage Protection Threshold Output UVP Delay UVP Hiccup On Time UVP Hiccup Off Time Thermal Shutdown Temperature Thermal Shutdown Hysteresis ILMT,TOP 3 A ILMT,BOT 2 A IOUT=0, VFB=VREF×105% EN=0 VREF 591 IFB RDS(ON)1 RDS(ON)2 VEN, R VEN, F tON,MIN tOFF,MIN tON,DLY tSS fSW VFB=3.3V Typ 0.6 200 5 10 Unit V V V µA µA 600 609 mV 50 nA mΩ mΩ V V ns ns µs ms kHz -50 1.08 0.9 from EN high to LX start switching VOUT from 0 to 100% IOUT=1A 130 105 1.2 1.0 50 100 300 1 500 Max 18 4.15 1.32 1.1 VUVP 0.33 VREF tUVP,DLY tUVP,ON tUVP,OFF 200 1.4 5.2 µs ms ms TSD 150 ˚C THYS 15 ˚C Note 1: Stresses beyond the “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Note 2: θ JA is measured in the natural convection at T A = 25°C on a 2OZ two-layer Silergy evaluation board. Paddle of SOT23-6 package is the case position for SM8102H θ JC measurement. Note 3: The device is not guaranteed to function outside its operating conditions. AN_SM8102H Rev0.0 © 2020 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 4 All Rights Reserved. SM8102H Efficiency vs. Load Current Efficiency vs. Load Current (IOUT=0~2A, L=3.3µH/VLS6045EX-3R3N) (IOUT=0~2A, L=3.3µH/VLS6045EX-3R3N) 100 100 90 90 80 80 Efficiency (%) Efficiency (%) Typical Performance Characteristics 70 60 50 60 50 VIN=5V, VOUT=1.2V VIN=12V, VOUT=1.2V VIN=18V, VOUT=1.2V 40 70 VIN=5V, VOUT=1.8V VIN=12V, VOUT=1.8V VIN=18V, VOUT=1.8V 40 30 30 0.01 0.1 1 0.01 10 0.1 Efficiency vs. Load Current (IOUT=0~2A, L=6.8µH/VLS6045EX-6R8M) 100 100 95 95 90 90 Efficiency (%) Efficiency (%) Efficiency vs. Load Current (IOUT=0~2A, L=4.7µH/VLS6045EX-4R7M) 85 80 75 70 85 80 75 70 VIN=5V,VOUT=3.3V VIN=12V,VOUT=3.3V 65 VIN=7.4V,VOUT=5V VIN=12V,VOUT=5V 65 VIN=18V,VOUT=3.3V 0.1 1 VIN=18V,VOUT=5V 10 60 0.01 0.1 Load Current (A) ∆VOUT VLX IL 1 10 Load Current (A) Output Ripple Output Ripple (VIN=12V, VOUT=3.3V, ILOAD=0A) (VIN=12V, VOUT=3.3V, ILOAD=2A) 100mV/div 10 Load Current (A) Load Current (A) 60 0.01 1 ∆VOUT 100mV/div VLX 5V/div IL 2A/div 5V/div 1A/div Time (2μs/div) AN_SM8102H Rev0.0 © 2020 Silergy Corp. Time (2μs/div) Silergy Corp. Confidential- Prepared for Customer Use Only 5 All Rights Reserved. SM8102H Load Transient Load Transient (VIN=12V, VOUT=3.3V, ILOAD=0-1A) (VIN=12V, VOUT=3.3V, ILOAD=0.2-2A) ∆VOUT 200mV/div IL 0.5A/div ∆VOUT IL 200mV/div 1A/div Time (100µs/div) Time (100µs/div) Startup from Enable Shutdown from Enable (VIN=12V, VOUT=3.3V, ILOAD=2A) (VIN=12V, VOUT=3.3V, ILOAD=2A) EN 5V/div VOUT 2V/div VLX 10V/div VLX 10V/div IL 2A/div IL 2A/div Time (2ms/div) EN 5V/div VOUT 2V/div Time (2ms/div) Startup from VIN Shutdown from VIN (VIN=12V, VOUT=3.3V, ILOAD=2A) (VIN=12V, VOUT=3.3V, ILOAD=2A) VIN 10V/div VOUT 2V/div VIN VLX IL Time (2ms/div) AN_SM8102H Rev0.0 © 2020 Silergy Corp. 10V/div 10V/div VOUT 2V/div VLX 10V/div IL 2A/div 2A/div Time (2ms/div) Silergy Corp. Confidential- Prepared for Customer Use Only 6 All Rights Reserved. SM8102H Short Circuit Protection Short Circuit Protection (VIN=12V, VOUT=3.3V, Open to Short) (VIN=12V, VOUT=3.3V, 2A to Short) VOUT 2V/div VOUT 2V/div IL 2A/div IL 2A/div Time (10ms/div) AN_SM8102H Rev0.0 © 2020 Silergy Corp. Time (10ms/div) Silergy Corp. Confidential- Prepared for Customer Use Only 7 All Rights Reserved. SM8102H Operation The SM8102H is a high efficiency, 500kHz synchronous step-down DC/DC regulator capable of delivering up to 2A load current. It can operate over a wide input voltage range from 4.2V to 18V and integrate main switch and synchronous switch with very low RDS(ON) to minimize the conduction loss. The SM8102H adopts the instant PWM architecture to achieve fast transient responses for high step down applications and high efficiency at light loads. The SM8102H provides protection functions such as cycle by cycle current limiting and thermal shutdown protection. The SM8102H will sense the output voltage conditions for the fault protection. Applications Information Because of the high integration in the SM8102H, the application circuit based on this regulator is rather simple. Only input capacitor CIN, output capacitor COUT, output inductor L and feedback resistors (RH and RL) need to be selected for the targeted applications specifications. Feedback Resistor Dividers RH and RL Choose RH and RL to program the proper output voltage. To minimize the power consumption under light loads, it is desirable to choose large resistance values for both RH and RL. A value of between 10kΩ and 1MΩ is highly recommended for both resistors. If VOUT is 3.3V, RH=100k is chosen, then using following equation, RL can be calculated to be 22.1k: 0.6V RL  RH VOUT  0.6V Output Capacitor COUT The output capacitor is selected to handle the output ripple noise requirements. Both steady state ripple and transient requirements must be taken into consideration when selecting this capacitor. For the best performance, it is recommended to use X5R or a better grade ceramic capacitor with 16V rating and more than 10µF capacitance. Output Inductor L There are several considerations in choosing this inductor. 1) Choose the inductance to provide the desired ripple current. It is suggested to choose the ripple current to be about 40% of the maximum output current. The inductance is calculated as: VOUT(1  VOUT/VIN,MAX) L fSW  IOUT,MAX  40% Where fsw is the switching frequency and IOUT,MAX is the maximum load current. The SM8102H is quite tolerant of different ripple current amplitude. Consequently, the final choice of inductance can be slightly off the calculation value without significantly impacting the performance. 2) The saturation current rating of the inductor must be selected to be greater than the peak inductor current under full load conditions. ISAT, MIN  IOUT, MAX  3) VOUT RH FB RL VOUT(1-VOUT/VIN,MAX) 2  fSW  L The DCR of the inductor and the core loss at the switching frequency must be low enough to achieve the desired efficiency requirement. It is desirable to choose an inductor with DCR
SM8102HABC
物料型号:SM8102H
器件简介:SM8102H是一款高效率、快速响应的同步降压DC/DC转换器,能够提供2A的负载电流。它在4.2V至18V的宽输入电压范围内工作,集成了主开关和同步开关,具有非常低的RDS(ON)以最小化导通损耗。
引脚分配:SM8102H采用SOT23-6封装,引脚功能如下: - BS:自举引脚,为高端门驱动供电。 - GND:电源地引脚。 - FB:输出反馈引脚,用于设置输出电压。 - EN:使能控制引脚。 - IN:输入引脚,需要与地之间至少使用10μF陶瓷电容进行解耦。 - LX:电感引脚,连接至电感的开关节点。
参数特性:包括低RDS(ON)内部开关、4.2-18V输入电压范围、2A输出电流能力、500kHz开关频率、10μF COUT和2.2μH电感的稳定工作、瞬时PWM架构实现快速瞬态响应、内部软启动限制开机电流、周期性峰值/谷值电流限制、hic-cup模式、输出短路保护、热关断自动恢复等。
功能详解:SM8102H采用瞬时PWM架构,实现高降压应用的快速瞬态响应和轻负载时的高效率。它在500kHz的伪恒定频率下工作,以最小化电感和电容的尺寸。
应用信息:适用于机顶盒、便携式电视、DSL调制解调器、液晶电视、IPCAM和网络设备。
封装信息:SM8102H采用SOT23-6封装,具有紧凑的尺寸和良好的散热性能。
SM8102HABC 价格&库存
很抱歉,暂时无法提供与“SM8102HABC”相匹配的价格&库存,您可以联系我们找货
