SQ29020VDC
SQ29020VDC
    SILERGY(矽力杰)
    QFN19_150MIL
    高效16V/20A同步降压调节器
SQ29020VDC 数据手册
SQ29020 High Efficiency, 16V/20A Synchronous Step-down Regulator Advanced Design Specification General Description Features  Wide Input Voltage Range: 2.9V/3.6V to 16V  Internal 7.5mΩ Power Switch and 2.4mΩ Synchronous Rectifier  Accurate Feedback Set Point: 0.6V ±1%  Differential Remote Sense  Fast Transient Response  600kHz, 800kHz and 1000kHz Operating Frequency  Selectable Automatic High-efficiency Discontinuous Operating Mode at Light Loads  Programmable Valley Current Limit  Reliable Built-in Protections:  Automatic Recovery for Input Under-voltage (UVLO), Output Under-voltage (UVP) and Overtemperature (OTP) Conditions  Cycle-by-cycle Valley and Peak Current Limit (OCP)  Cycle-by-cycle Reverse Current Limit  Internal and Adjustable Soft-start to Limits Inrush Current  Smooth Pre-biased Startup  Power Good Output Monitor for Under-voltage and Overvoltage 导 小 芯 The SQ29020 is a high-efficiency synchronous step-down DC-DC regulator featuring internal power and synchronous rectifier switches capable of delivering 20A of continuous output current over a wide input voltage range, from as low as 2.9V up to 16V. The output voltage is adjustable from 0.6V to 5.5V. dF or 半 Silergy’s proprietary Instant-PWM™ fast-response, constanton-time (COT) PWM control method supports high input/output voltage ratios (low duty cycles) and responds to load transients within ~100ns while maintaining a near constant operating frequency over line, load and output voltage ranges. This control method provides stable operation without complex compensation, even with low ESR ceramic output capacitors. lP Applications de nti a Internal 7.5mΩ power and 2.4mΩ synchronous rectifier switches provide excellent efficiency for a wide range of applications, especially for low output voltages and low duty cycles. Cycle-by-cycle current limit, input under-voltage lockout, internal soft-start, output under- and over-voltage protection, and thermal shutdown provide safe operation in all operating conditions. rep are The stable internal reference (VREF) provides ±1% accuracy over TJ= -40°C to 125°C, and the differential input sense configuration allows the feedback sensing at the most relevant load point.      VIN=2.9V~16V erg + 90 L=0.22μH BS IN CIN=100μF Efficiency vs. Load Current (fSW=600kHz, FCCM, L=0.22μH/VLBU1007090T-R22L) 100 CBS=0.1μF LX CIN=22μF×2 CIN=0.1μF×2 RPG=10kΩ External VCC Supply(opt.) Sil PG CVCC=1μF ON/ OFF RILMT=5.6kΩ GNDS EN MODE SS AGND VSENSE+ COUT=47μF×5 R1=100kΩ R2=100kΩ VCC ILMT GND VOUT=1.2V RFF=1kΩ CFF=220pF FBS 80 VSENSE- Load Efficiency (%) yC orp .C on fi The SQ29020 is available in a compact QFN3x4 package. Telecom and Networking Systems Servers High Power Access Points Storage Systems Cellular Base Stations 70 VIN=3.6V, VOUT=1.2V VIN=7.4V, VOUT=1.2V VIN=12V, VOUT=1.2V VIN=16V, VOUT=1.2V 60 50 40 30 20 10 RMODE=0Ω 0 0.001 CSS=0.22µF Figure 1. Typical Application Circuit DS_SQ29020 Rev.0.0A ©2020 Silergy Corp. 0.01 0.1 1 10 20 Load Current (A) Figure 2. Efficiency vs. Load Current Silergy Corp. Confidential- Prepared for Customer Use Only 1 All Rights Reserved. SQ29020 Ordering Information Ordering Part Number SQ29020VDC Pinout (top view) Package type Top mark QFN3×4-19 DDExyz RoHS Compliant and Halogen Free 3 MODE 4 SS 5 GNDS 6 FBS 7 EN 8 PG 9, 18 10, 11, 12, 13, 14, 15 IN GND 16 VCC 17 LX 19 BS or 半 ILMT dF 2 Pin Description Analog ground Synchronous rectifier current limit setting. Connect a resistor to AGND to set the inductor valley current limit Operation mode selection. Program MODE to select FCCM/PFM, and the operating switching frequency. See table 1 External soft-start setting. Optionally adjust the soft-start time by adding an appropriate external capacitor between this pin and AGND pin. See Detailed Description Remote ground sense. Connect this pin directly to the negative side of the preferred voltage sense point. Short to GND if remote sense is not used Remote feedback sense. Connect this pin to the center point of the output resistor divider to program the output voltage. See Design Procedure Enable input. Pull low to disable the device, high to enable. Do not leave this pin floating. May be used for increasing startup voltage or sequencing. See Detailed Description Power good indicator. Open drain output when the output voltage is within 92.5% to 120% of the regulation set point Power input. Decouple this pin to GND pin with at least a 30μF ceramic capacitor Power ground Internal 3.3V LDO output. Power supply for internal analog circuits and driving circuits. Decouple this pin to GND with at least a 1μF ceramic capacitor. Make one good Kelvin connection from AGND to VCC capacitor GND connection. Use short, direct connections and avoid the use of vias. May be driven by an external bias supply. See Detailed Description. Inductor pin. Connect this pin to the switching node of the inductor Boot-strap supply for the high side gate driver. Connect a 0.1µF ceramic capacitor between the BS and the LX pin rep are Pin Name AGND Sil erg yC orp .C on fi de nti a lP Pin No 1 导 小 芯 x=year code, y=week code, z= lot number code DS_SQ29020 Rev.0.0A ©2020 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 2 All Rights Reserved. lP rep are dF or 半 导 小 芯 SQ29020 de nti a Figure 3. Block Diagram Absolute Maximum Ratings (1) IN .C orp LX, 10ns duration BS FBS, GNDS, AGND, VCC, PG Junction Temperature, Operating Lead Temperature (Soldering, 10 sec.) Storage Temperature on fi ILMT, SS EN, MODE, LX Min Max -0.3 18 -0.3 4 -0.3 IN + 0.3 -5 IN + 5 LX - 0.3 LX + 4 -0.3 4 -40 150 260 -65 150 Min Recommended Operating Conditions (3) IN Output Voltage GNDS VCC external bias Output current Output current limit setting Peak inductor current Junction Temperature Min 2.9 0.6 -0.2 3.12 Sil erg yC Thermal Information (2) θ JA Junction-to-ambient thermal resistance θ JC Junction-to-case (bottom) thermal resistance PD Power dissipation TA = 25°C DS_SQ29020 Rev.0.0A ©2020 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only -40 Max 24 4.5 4.2 Max 16 5.5 0.2 3.6 20 24 28 125 Unit V °C Unit °C/W W Unit V A °C 3 All Rights Reserved. SQ29020 Electrical Characteristics VIN = 12V, TJ = -40°C to +125°C, typical values are at TJ = 25°C, unless otherwise specified (4) Power Switch Synchronous Rectifier Quiescent Current IQ UVLO, Rising UVLO, Hysteresis Output Load regulation External Bias input Reference Voltage Error Amp Offset Input Current On resistance Leakage Current Limit On resistance Leakage VVCC,UVLO VVCC,HYS VCC VCC,REG VCC,EXT VREF VOS IFBS RDS(ON)HS IHS, LKG ILMT,HS RDS(ON)LS ILS, LKG ILMT,RVS tRCL,BLK ILMT,BOT VILMT IILMT/ILMT,BOT RDIS VEN,R VEN,HYS IEN ISS1 ISS2 tSS,MIN VOVP VUVP tUVP,DLY tHICCUP,ON tHICCUP,OFF Reverse current Forward current ILMT Pin Output Voltage ILMT Ratio Discharge FET Resistance erg yC orp .C on fi Rising Threshold Enable (EN) Threshold Hysteresis Input Current Charging current Soft Start (SS) Discharge current Min soft-start time Overvoltage protection threshold threshold Undervoltage protection Delay UVP/OCP Hiccup ON Time UVP/OCP Hiccup OFF Time Sil Thresholds Power Good DS_SQ29020 Rev.0.0A ©2020 Silergy Corp. Delay VPG tPG,R tPG,F Output low voltage VPG,LOW Output low leakage IPG,LKG Min 2.9 2.6 VEN=0V, TJ=25°C VEN=2V, VFBS = 0.65V, PFM mode, No Switching 导 小 芯 VEN=2V, VFBS = 1V VBS-LX = 3.3V, TJ=25°C VEN=0V, VLX=0V 3.15 0.594 -3 -50 25.5 VCC = 3.3V, TJ=25°C VEN=0V, VLX=12V 9 40 RILMT = 5.6kΩ ILMT,BOT >5A 1.15 9 1.18 VEN=2V VSS=0V VSS=1V 110 45 CSS open VFBS falling, fault VFBS rising, good VFBS rising, fault VFBS falling, good VFBS falling, good VFBS rising, fault VIN=0V, 100kΩ from PG to 3.3V VIN=0V, 10kΩ from PG to 3.3V VEN = 2V, VFBS = 0V, IPG=10mA VPG = 3.3V Silergy Corp. Confidential- Prepared for Customer Use Only Typ 2.75 200 2 550 3.15 or 半 IVCC=0mA IVCC=25mA optional GNDS = 0V dF FBS Test Conditions lP VCC Symbol VIN VIN,UVLO VIN,HYS ISHDN de nti a Input Voltage UVLO, rising UVLO, Hysteresis Shutdown Current rep are Parameter 77 89.5 110 102 100 3.3 1.4 0.600 0 7.5 0.01 28 2.4 0.04 13 60 21.4 1.2 10 120 1.23 0.2 0 46 38 1 120 50 20 3 12 80 92.5 120 105 0.8 20 550 660 3 Max 16 2.9 5 Unit V V mV µA 850 µA 2.5 V mV V % V V mV nA mΩ µA A mΩ µA A ns A V µA/A Ω V V µA µA mA ms 3.45 3.6 0.606 3 50 11.3 8 33 3.6 32 16 1.25 11 1.28 130 55 %VFBS µs ms 84 96.5 130 108 %VFBS ms 750 850 0.4 5 V µA 4 All Rights Reserved. SQ29020 Electrical Characteristics (cont.) VIN = 12V, TJ = -40°C to +125°C, typical values are at TJ = 25°C, unless otherwise specified (4) Parameter Symbol Switching Frequency fSW Test Conditions RMODE=0Ω, IOUT=0A, FCCM, VOUT=1V, TJ=25°C RMODE=30.1kΩ, IOUT=0A, FCCM, VOUT=1V, TJ=25°C RMODE=60.4kΩ, IOUT=0A, FCCM, VOUT=1V, TJ=25°C IOUT=3A (Note 4) IOUT=3A (Note 4) Min Typ Max 510 600 690 690 800 910 900 1000 1100 Unit kHz dF or 半 导 小 芯 Min ON Time tON,MIN 60 ns Min OFF Time tOFF,MIN 180 Thermal Shutdown Temperature TSD 160 ˚C Thermal Shutdown Hysteresis THYS (Note 4) 30 Note 1: Stresses beyond the “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Note2: Package thermal resistance is measured in the natural convection at TA=25˚C on a 8.5cm×8.5cm size four-layer Silergy Evaluation Board. Note 3: The device is not guaranteed to function outside its operating conditions. Note 4: Production testing is performed at 25˚C; limits at -40°C to +125°C are guaranteed by design, test or statistical correlation. Typical Performance Characteristics rep are (TA=25℃, VIN=12V, VOUT=1.2V, L=0.22μH, COUT=235μF, fSW=600kHz, RILMT=5.6kΩ, CSS=0.22μF, unless otherwise noted) Efficiency vs. Load Current (fSW=600kHz, PFM, L=0.22μH/VLBU1007090T-R22L) 100 100 60 50 40 VIN=3.6V, VOUT=1.2V VIN=7.4V, VOUT=1.2V VIN=12V, VOUT=1.2V VIN=16V, VOUT=1.2V 20 0 0.001 0.01 0.1 1 50 40 10 0 0.001 10 20 0.01 0.1 1 10 20 Load Current (A) orp Load Current (A) 60 20 .C 10 70 30 on fi 30 de nti a 70 80 Efficiency (%) 80 Efficiency vs. Load Current Efficiency vs. Load Current (fSW=600kHz, PFM, L=0.22μH/VLBU1007090T-R22L) (fSW=600kHz, FCCM, L=0.22μH/VLBU1007090T-R22L) 100 yC 100 90 90 80 erg 80 70 Sil 60 50 40 VIN=5V, VOUT=1.8V VIN=12V, VOUT=1.8V VIN=16V, VOUT=1.8V 30 20 10 0 0.001 Efficiency (%) Efficiency (%) VIN=3.6V, VOUT=1.2V VIN=7.4V, VOUT=1.2V VIN=12V, VOUT=1.2V VIN=16V, VOUT=1.2V 90 lP 90 Efficiency (%) Efficiency vs. Load Current (fSW=600kHz, FCCM, L=0.22μH/VLBU1007090T-R22L) VIN=5V, VOUT=1.8V VIN=12V, VOUT=1.8V VIN=16V, VOUT=1.8V 70 60 50 40 30 20 10 0.01 0.1 1 10 20 0 0.001 0.01 Load Current (A) DS_SQ29020 Rev.0.0A ©2020 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 0.1 1 10 20 Load Current (A) 5 All Rights Reserved. SQ29020 Typical Performance Characteristics (cont.) Efficiency vs. Load Current Efficiency vs. Load Current (fSW=600kHz, PFM, L=0.56μH/FCUL1060-H-R56M=P3) (fSW=600kHz, FCCM, L=0.56μH/FCUL1060-H-R56M=P3) 100 100 90 90 80 80 70 70 60 50 40 30 0 0.001 0.01 0.1 20 10 0 0.001 10 20 1 40 or 半 10 50 30 VIN=6V, VOUT=3.3V VIN=12V, VOUT=3.3V VIN=16V, VOUT=3.3V 20 60 dF Load Current (A) Efficiency vs. Load Current 0.1 10 20 1 Load Current (A) Efficiency vs. Load Current (fSW=600kHz, FCCM, L=0.56μH/FCUL1060-H-R56M=P3) 100 100 90 90 80 70 lP 60 40 30 0.01 0.1 1 Load Current (A) orp Load Transient 10 20 70 60 50 40 30 VIN=7.4V, VOUT=5V VIN=12V, VOUT=5V VIN=16V, VOUT=5V 20 10 0 0.001 Sil erg yC 100mV/div IL 20A/div 10 20 1 Output Ripple (VIN=12V, VOUT=1.2V, IOUT=20A) ∆VOUT 50mV/div VLX 10V/div IL 20A/div Time (200µs/div) DS_SQ29020 Rev.0.0A ©2020 Silergy Corp. 0.1 Load Current (A) (VIN=12V, VOUT=1.2V, IOUT=2~20A, FCCM) ∆VOUT 0.01 .C 10 on fi VIN=7.4V, VOUT=5V VIN=12V, VOUT=5V VIN=16V, VOUT=5V 20 de nti a 50 Efficiency (%) 80 Efficiency (%) 0.01 VIN=6V, VOUT=3.3V VIN=12V, VOUT=3.3V VIN=16V, VOUT=3.3V rep are (fSW=600kHz, PFM, L=0.56μH/FCUL1060-H-R56M=P3) 0 0.001 导 小 芯 Efficiency (%) Efficiency (%) (TA=25℃, VIN=12V, VOUT=1.2V, L=0.22μH, COUT=235μF, fSW=600kHz, RILMT=5.6kΩ, CSS=0.22μF, unless otherwise noted) Silergy Corp. Confidential- Prepared for Customer Use Only Time (2μs/div) 6 All Rights Reserved. SQ29020 Typical Performance Characteristics (cont.) (TA=25℃, VIN=12V, VOUT=1.2V, L=0.22μH, COUT=235μF, fSW=600kHz, RILMT=5.6kΩ, CSS=0.22μF, unless otherwise noted) Shutdown from VIN (VIN=12V, VOUT=1.2V, IOUT=20A) VIN VOUT 1V/div VLX 10V/div IL 20A/div dF Time (4ms/div) Startup from EN 1V/div VLX 10V/div IL 20A/div 10V/div IL 20A/div Shutdown from EN lP VOUT VLX Time (4ms/div) de nti a 5V/div 1V/div (VIN=12V, VOUT=1.2V, IOUT=20A) EN 5V/div VOUT 1V/div VLX 10V/div IL 20A/div Time (4ms/div) orp .C Time (4ms/div) on fi EN rep are (VIN=12V, VOUT=1.2V, IOUT=20A) 10V/div VOUT 导 小 芯 10V/div or 半 VIN Startup from VIN (VIN=12V, VOUT=1.2V, IOUT=20A) Short Circuit Protection (VIN=12V, VOUT=1.2V, IOUT=20A~short, RILMT=5.6kΩ) 1V/div VOUT 1V/div IL 20A/div Sil erg VOUT yC Short Circuit Protection (VIN=12V, VOUT=1.2V, IOUT=0A~short, RILMT=5.6kΩ, FCCM) IL 20A/div Time (20ms/div) DS_SQ29020 Rev.0.0A ©2020 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only Time (20ms/div) 7 All Rights Reserved. SQ29020 Typical Performance Characteristics (cont.) (TA=25℃, VIN=12V, VOUT=1.2V, L=0.22μH, COUT=235μF, fSW=600kHz, RILMT=5.6kΩ, CSS=0.22μF, unless otherwise noted) Short Circuit Protection Short Circuit Protection (VIN=12V, VOUT=1.2V, IOUT=0A~short, RILMT=10kΩ, FCCM) (VIN=12V, VOUT=1.2V, IOUT=10A~short, RILMT=10kΩ) IL 20A/div VOUT IL dF Time (20ms/div) Output Ripple rep are (VIN=12V, VOUT=1.2V, IOUT=0A, PFM) 10V/div IL 10A/div de nti a VLX lP 50mV/div Time (20ms/div) Output Ripple ∆VOUT 50mV/div VLX 10V/div IL 10A/div Time (2μs/div) Sil erg yC orp .C Time (2μs/div) 20A/div (VIN=12V, VOUT=1.2V, IOUT=0A, FCCM) on fi ∆VOUT 1V/div 导 小 芯 1V/div or 半 VOUT DS_SQ29020 Rev.0.0A ©2020 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 8 All Rights Reserved. SQ29020 Detailed Description be reduced as needed to always ensure a proper operation. Constant-on-time Architecture Under TJ=-40℃ ~125℃ condition, the device can support up to 5.5V output even the input voltage is as low as 8V. L1 VOUT R1 Power switch COUT R2 Synchronous rectifier Ramp Generator DIFF VRAMP S R VREF orp On-time Generator .C VFB Q on fi CIN PWM signal Sil erg yC Silergy’s Instant-PWM control method adds several proprietary improvements to traditional COT architecture. Whereas most legacy COT implementations require a dedicated connection to the output voltage terminal to calculate the tON duration, Instant-PWM derives this signal internally. Another improvement optimizes operation when used with low ESR ceramic output capacitors. In many applications it is desirable to utilize very low ESR ceramic output capacitors, but legacy COT regulators may become unstable when used with these output capacitors. Minimum Duty Cycle and Maximum Duty Cycle In the COT architecture, there is no limitation for small duty cycle, since at very low duty cycle operation, once the on-time is close to the minimum on time, the switching frequency can DS_SQ29020 Rev.0.0A ©2020 Silergy Corp. or 半 导 小 芯 When operating conditions include changes in input voltage and/or output loads, the COT operating frequency will naturally vary from the ideal. Silergy’s FLL technology minimizes this variation by comparing the actual operating frequency with the desired frequency. The FLL block adjusts the calculated tON period to lock the operating frequency to the onboard reference oscillator. The FLL function is disabled during soft-start and discontinuous current mode (DCM) operating condition. Note that FLL does not impede the high frequency retriggering of the power switch during load transients. dF Operating Frequency/Light Load Settings rep are The MODE pin sets both the operating frequency and the light load behavior of the device. This pin is sampled when the device is enabled and the operating modes are set when the internal regulator (Vcc) rises above VVCC,UVLO. The mode is locked until the device is restarted. de nti a Instant-PWM Operation VIN Frequency Locked Loop (FLL) lP Fundamental to any constant-on-time (COT) architecture is the one-shot circuit or on-time generator, which determines how long to turn on the high-side power switch. Each on-time (tON) is a “fixed” period internally calculated to operate the regulator at the desired switching frequency over the input and output voltage range, where tON=(VOUT/VIN)×(1/fSW). For example, consider a hypothetical converter configured for 1.2V output from a 12V input operating at 600kHz. The target on-time is (1.2V/12V)×(1/600kHz)=167ns. Each tON pulse is triggered by the feedback comparator when the output voltage as measured at FB drops below the target value. As the input or output voltages change, an appropriate tON pulse is calculated, maintaining a fairly constant operating frequency while regulating the output voltage. In a COT architecture, there is no fixed clock, so the power switch can turn on almost immediately after a load transient and subsequent switching pulses can be quickly initiated, ramping the inductor current up to meet load requirements with minimal delays. COT has significant benefits over traditional current mode or voltage mode control methods that must simultaneously monitor the feedback voltage, inductor current and compensation signals to determine when to turn off the power switch and turn on the synchronous rectifier. MODE Pin connection VCC 240kΩ* to GND 120kΩ* to GND GND 30kΩ* to GND 60kΩ* to GND *±20% LightLoad operation PFM PFM PFM FCCM FCCM FCCM Operating Frequency 600kHz 800kHz 1000kHz 600kHz 800kHz 1000kHz Table 1 Under medium to heavy loads, the inductor current, even at the lowest point just before each tON pulse, is always positive. This is known as continuous conduction mode (CCM). At lower load currents, when IOUT ~ < 1/2×ΔIL, the current through the inductor will ramp to near zero before the next tON pulse. The behavior of the device in this condition may be set to pulse frequency modulation (PFM) to optimize efficiency, or to forced continuous conduction mode (FCCM) which maintains a fixed operating frequency. When operating in PFM under light load conditions, the synchronous rectifier will turn off, preventing recirculation current that can seriously reduce efficiency under these light load conditions. As load current is further reduced, and while the feedback is greater than the reference voltage, the control loop will not trigger another tON until needed, lowering the operating frequency, further enhancing efficiency. Fixed frequency CCM resumes smoothly as soon as the load current increases sufficiently for the inductor current to remain positive throughout the cycle. PFM operation should not be Silergy Corp. Confidential- Prepared for Customer Use Only 9 All Rights Reserved. SQ29020 selected if the application is sensitive to frequencies lower than the selected operating frequency, including audible frequencies. controlled starts. The accurate threshold is useful to inhibit operation until a specific IN voltage is reached. When EN is < 0.4V the internal linear regulator that drives VCC and most internal circuitry is turned off, disabling the device. Driving EN above VEN,R initiates a startup sequence as the device is enabled. In FCCM operation under light loads, the synchronous rectifier remains on even when the inductor current crosses zero. Current flow will continue until the next tON cycle. In this way, the device always operates in CCM and keeps a relatively constant switching frequency over the entire output current range. VIN IN 导 小 芯 RH EN RL AGND GND Linear Regulator (VCC) An internal linear regulator produces a 3.3V supply at VCC from IN. VCC powers the internal gate drivers, PWM logic, analog circuitry, and other blocks. Connect a 1µF (minimum) low ESR ceramic capacitor from VCC to GND. Note that an external bias supply may be used to drive VCC in the range specified by VCC,EXT. Care should be taken to ensure that the bias supply draws no current from the VCC linear regulator. dF or 半 For automatic start-up, connect EN to IN through resistor RH. If power supply sequencing is required, similarly connect EN to the output of the power rail that should start first. RH should be 1kΩ to 1MΩ. Note that when enabling the device via EN, two thresholds will be observed. First, at ~0.8V, the internal linear regulator that drives VCC will be enabled and, assuming sufficient voltage at IN, VCC will rise. Second, as EN is driven above VEN,R (1.23V nom) a startup sequence will be enabled. If EN falls VEN,HYS below VEN,R (1.03V nom) switching regulation will be disabled. CVCC 1µF GND Under Voltage Lock-out .C on fi de nti a To prevent operation before all internal circuitry is ready and to ensure that the power and synchronous rectifier switches can be sufficiently enhanced, this device includes undervoltage lockout protection at IN and VCC. The device remains in a low current state and all switching actions are inhibited until IN exceeds VIN,UVLO and VCC exceeds VIN,UVLO. At that time, if EN is enabled, the device will start-up by initiating a soft-start ramp. If IN or VCC fall below their respective UVLO falling thresholds, the device will be disabled. lP AGND rep are VCC Differential Remote Sense (FBS, GNDS) FBS and GNDS may be used as a differential feedback connection directly to the output capacitor or main load connection. This helps to compensate for DC losses in the PCB at high output currents. Keep these connections short and direct. If remote sense is not required, connect GNDS directly to AGND. GNDS must be within +/-0.2V of GND and AGND. Power Good (PG) This device integrates a floating power supply for the gate driver that operates the power switch. Proper operation requires a 0.1µF low ESR ceramic capacitor to be connected between BS and LX. This bootstrap capacitor provides the gate driver supply voltage for the high-side N-channel power MOSFET switch. The power good indicator is an open drain output controlled by a window comparator connected to the internal feedback signal VFB. PG will be high impedance during normal device operation when VFBS is within a range of VREF x 0.925 to VREF x 1.05 (nom) for at least tPG,R . Once within this range and to prevent a false fault indication, PG will remain high impedance unless VFB falls below VREF*0.80 or exceeds VREF x 1.20 (nom) for tPG,F. erg yC orp External Bootstrap Capacitor (BS) CBS 0.1µF Sil BS LX Enable Control (EN) PG is held low during start up, when the device is disabled and during an over-temperature protection (OTP) fault condition (see OTP). PG should be pulled up to a 3.3V (nom) or lower logic supply through a resistor in the range 10kΩ~100kΩ. PG will remain low even if VCC is 0V. EN is a high-voltage capable input with a stable, logiccompatible threshold that provides convenient control of device start-up behavior such as automatic, delayed or logicDS_SQ29020 Rev.0.0A ©2020 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 10 All Rights Reserved. SQ29020 Programmable Soft-start Time (SS) Pre-biased operation A soft-start circuit is incorporated to smoothly ramp the output to the desired voltage whenever the device is enabled. At startup, soft-start clamps the output at a low voltage and then ramps the output to the desired voltage over the soft-start time tSS, which avoids high current flow and transients during startup. The default tSS is ~1mS. Longer tSS may be achieved by connecting a capacitor CSS from SS to AGND. If the output is not at 0V at startup, it is considered pre-biased. In this case, the power switch and synchronous rectifiers will not begin switching until the soft-start ramp VSS,ACT exceeds the sensed output voltage VFBS. The output is actively discharged when the converter is shut down by EN, UVLO or OTP. Typically 120Ω, the discharge FET parallels the synchronous rectifier and pulls LX low to discharges the output through the inductor. CSS (nF)  VREF ISS (μA) 导 小 芯 t SS (ms)= Output Discharge (where ISS is ~46μA, VREF is 0.6V) Fault Protections Selecting CSS = 150nF would set tSS ~ 2ms. CSS is not required if the default tSS of ~ 1ms is adequate for the application. or 半 Output Under Voltage Protection (UVP) If a fault condition, such as a short circuit at the output, brings VFBS < ~50% of the set point for tUVP,DLY, UVP will be triggered and switching will be disabled for tHICCUP,OFF. Switching will resume for tHICCUP,ON and this cycle will repeat. If the output fault conditions are removed, the device will return to normal operation. VFB VCC Min{VSS,INT,VSS,VREF} ISS,INT dF VSS,ACT VCC ISS Output Short Circuit SS VREF VSS,INT VSS CSS GND de nti a Startup and Shutdown sequence .C orp VUVLO yC EN tDLY2 470µs erg tDLY1 80µs VCC VREF Sil VSS,ACT(internal signal) VPG VFB Bottom FET current limit IL VSS,ACT(internal signal) on fi If IN exceeds VIN,UVLO, normal startup can be initiated by bringing EN high, or by pulling EN high from V IN. After a short delay, tDLY1, the internal VCC LDO is turned on to power the internal control circuits. Once VCC is up and after another short delay, tDLY2, the soft-start signal Vss ramps and normal switching action begins. The output voltage VOUT ramps up and once the output voltage is 92.5% of the regulation point, PG becomes high-impedance after a delay time tPG,R. VIN ~50%VSET VOUT lP AGND rep are Set UVP delay time 0.6VREF Hic-up off Hic-up on time time Hic-up off time Soft start time Over Temperature Protection (OTP) OTP includes circuitry to prevent overheating due to excessive power dissipation. This will shut down the device when the junction temperature exceeds 160°C. Once the junction temperature cools down by approximately 30°C, the device will resume normal operation with a complete soft-start cycle. For continuous operation, provide adequate cooling so that the junction temperature does not exceed the OTP threshold. TSD TSD-THYS VPG-VPG,HYS VUVP tSS TJ VOUT tPG,R tPG,F VSS,ACT (internal signal) VREF PG VOUT DS_SQ29020 Rev.0.0A ©2020 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 11 All Rights Reserved. SQ29020 PFM / FCCM settings determine the behavior. In FCCM, the synchronous rectifier will be turned on and will remain on for most of the cycle, except for tON minimum pulses of tON,MIN. In PFM, the synchronous rectifier will remain on only until the inductor current reaches zero. Further switching is inhibited. If VFBS exceeds VOVP, OQDM is activated. Valley Current Limit Protection (OCP) Inductor current is measured in the synchronous rectifier on every cycle when it turns on and as the inductor current ramps down. If the current exceeds ILMT,BOT, the next tON is inhibited until the current returns back to safe levels. Bottom FET current limit See Inductor Design regarding proper inductor value selection. Under light loads false OVP triggering is possible if the inductor is too small. This may also cause the reverse current limiting. IL 导 小 芯 VFB VREF Output Quick Discharging Mode (OQDM) When operating in PFM under light load conditions, if FBS is driven above VOVP for more than ~20μs, OQDM will be activated. This changes the operating mode to FCCM. The synchronous rectifier is turned on at a very high duty factor to discharge the output as quickly as possible. This will continue until the inductor current becomes positive and VFBS is below VOVP. Note that OQDM may not prevent UVP or OTP from triggering a latch off protection of the device. VLX VFB 500µF and minimum load current is low, set feed-forward values as RFF = 1kΩ and CFF > 2.2nF to provide for sufficient ripple signal to VFBS for small output ripple and good transient behavior. Silergy Corp. Confidential- Prepared for Customer Use Only 14 All Rights Reserved. SQ29020 the input capacitor should be connected to the IN and GND by wide copper plane. Place one smaller package input MLCC capacitor at the reach out port of pin18. This capacitor can be connected with GND by vias. Thermal Design Considerations Maximum power dissipation depends on the thermal resistance of the IC package, the PCB layout, the surrounding airflow, and the difference between the junction and ambient temperatures. The maximum power dissipation may be calculated by: PD,MAX = (TJ,MAX− TA) / θJA where, TJ,MAX is the maximum junction temperature, T A is the ambient temperature, and θJA is the junction to ambient thermal resistance. 导 小 芯 or 半 AGND Layout: Make one Kelvin connection between AGND and GND at the CVCC negative sides. CSS, RMODE, RILMT should connect to AGND using short, direct copper trace. rep are dF Feedback Network: Place the feedback components (R1, R2, RFF and CFF) as close to FBS pin as possible. Avoid routing the remote output sense line and remote GND sense (GNDS) line near LX, BS or other high frequency signal as they are noise sensitive. Make the feedback sampling point Kelvin connect with COUT rather than the inductor output terminal. .C 5 4.2 orp 4 3 1 0 0 25 50 75 Layout Design Sil Ambient Temperature ( 100 LX Connection: The LX connection has large voltage swings and fast edges and can easily radiate noise to adjacent components. Keep its area small to prevent excessive EMI, while providing wide copper traces to minimize parasitic resistance and inductance. Keep sensitive components away from the switching node or provide ground traces between for shielding, to prevent stray capacitive noise pickup. BS Capacitor: Place the BS capacitor on the same layer as the device, keep the BS voltage path (BS, LX and CBS) as short as possible. Control Signals: It is not recommended to connect control signals and IN directly. A resistor in a range of 1kΩ to 1MΩ should be used if they are pulled high by IN. GND Vias: Place adequate number of vias on the GND layer around the device for better thermal performance. yC 2 erg Maximum Power Dissipation (W) Maximum Power Derating Curve on fi de nti a The maximum power dissipation at T A=25℃ may be calculated by the following formula: PD,MAX = (125℃ − 25℃) / (24℃/W) = 4.2W The maximum power dissipation depends on operating ambient temperature for fixed T J,MAX and thermal resistance θJA. Use the derating curve in figure below to calculate the effect of rising ambient temperature on the maximum power dissipation. VCC Capacitor: Place the VCC capacitor close to VCC using short, direct copper trace to one nearest device GND pin. lP The recommended operating conditions include a maximum junction temperature of 125℃. The junction to ambient thermal resistance θJA is layout dependent. For the QFN3×419 package the thermal resistance θJA is 24℃/W when measured on a standard Silergy four-layer thermal test board. These standard thermal test layouts have a very large area with long 2-oz. copper traces connected to each IC pin and very large, unbroken 1-oz. internal power and ground planes. Good thermal performance requires wide copper traces at all the pads leading to exposed copper areas on the component side of the board as well as good thermal via from the exposed pad connecting to a wide middle-layer ground plane and, perhaps, to an exposed copper area on the board's solder side. Output Capacitors: Guarantee the COUT negative sides are connected with GND pin by wide copper traces instead of vias, in order to achieve better accuracy and stability of output voltage. 125 ) Follow these PCB layout guidelines for optimal performance and good thermal dissipation. PCB Board: A four-layer layout with 2-oz copper is strongly recommended to achieve better thermal performance. The top layer and bottom layer should place power IN and GND copper plane as wide as possible. Middle1 layer should place all GND layer for conducting heat and shielding middle2 layer signal line from top layer crosstalk. Place signal lines on middle2 layer instead of the other layers, so that the other layers’ GND plane not be cut apart by these signal lines. Input Capacitors: Place the input capacitor very near IN and GND, minimizing the loop formed by these connections. And DS_SQ29020 Rev.0.0A ©2020 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 15 All Rights Reserved. SQ29020 CFF RILMT RFF R2 VIN RMODE IN Vias to EN R1 MODE 5 4 3 ILMT FBS 6 AGND EN 7 2 IN GND Vias 1 8 PG 19 18 9 BS CIN IN 17 LX 11 12 13 14 15 GND GND GND GND GND GND 16 10 VCC AGND Kelvin connection CVCC GND L or 半 COUT GND Vias 导 小 芯 CIN SS CBS GNDS CIN GND Vias CSS open drain CIN COUT remote GND sense COUT dF COUT remote output sense Top Layer Middle2 Layer VOUT Middle1 Layer (GND Layer, not shown) lP GND rep are COUT Bottom Layer Sil erg yC orp .C on fi de nti a Figure 4. PCB Layout Suggestion DS_SQ29020 Rev.0.0A ©2020 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 16 All Rights Reserved. SQ29020 rep are dF or 半 导 小 芯 QFN3×4-19 Package Outline Drawing Bottom view Sil erg yC orp .C on fi de nti a lP Top view Front view Recommended PCB layout (Reference only) Notes: All dimension in millimeter and exclude mold flash & metal burr. Center line refers chip body center. DS_SQ29020 Rev.0.0A ©2020 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 17 All Rights Reserved. SQ29020 Taping & Reel Specification Package orientation or 半 导 小 芯 1. Carrier Tape & Reel specification for packages QFN3×4 12 Pocket pitch(mm) yC Tape width (mm) 8 Reel size (Inch) Trailer length (mm) Leader length (mm) Qty per reel 13" 400 400 5000 Sil erg Package type orp .C on fi Reel Size de nti a lP rep are 2. dF Feeding direction DS_SQ29020 Rev.0.0A ©2020 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 18 All Rights Reserved. SQ29020 Revision History Revision Number Description Pages changed Initial draft 1. The max. input voltage changes from 18V to 16V; 2. Update the Absolute Maximum Ratings 3. Add efficiency curves for PFM Mode; 4. Update the Detailed Description. a) Add Minimum Duty Cycle and Maximum Duty Cycle (page9); b) Update the diagrammatic drawing in UVP description (page11); c) Update the Layout Design (page15) Revision history is for reference only and may not be comprehensive or complete. Page3 Page 5~6 Page9~15 Sil erg yC orp .C on fi de nti a lP rep are dF or 半 导 小 芯 0.0 0.0A Revision Date 04/17/2020 07/28/2020 DS_SQ29020 Rev.0.0A ©2020 Silergy Corp. Powered by TCPDF (www.tcpdf.org) Silergy Corp. Confidential- Prepared for Customer Use Only 19 All Rights Reserved.
SQ29020VDC 价格&库存
很抱歉,暂时无法提供与“SQ29020VDC”相匹配的价格&库存,您可以联系我们找货
SQ29020VDC
  • 1+9.03560
  • 10+7.46760
  • 30+6.61500
  • 100+5.64480
库存:200
