SQ33065WAQ
SQ33065WAQ
    SILERGY(矽力杰)
    QFN-20(4.5x3.5)
    具有宽占空比范围的6V至75V同步降压控制器
SQ33065WAQ 数据手册
Application Note: SQ33065 6V to 75V Synchronous Buck Controller With Wide Duty Cycle Range General Description Features The SQ33065 is 75V synchronous buck controller with type Ⅲ voltage mode control and feedforward. Minimum tens of nanosecond on-time facilitates large step-down ratios. The SQ33065 continues to operate when input voltage decreases to as low as 6V.    rep are Ordering Information SQ33065 □(□□ □)  Package Code Optional Spec Code R1 yC C3 C2 Telecom Power Application  RF Power Application  Commercial Drone Application REN1 EN/UVLO RT SS/TRK VIN RVIN CIN VIN CBST BST HO Q1 CSS COMP LX FB NC RBST LF VOUT Optional erg R2  CVIN REN2 RRT orp C1 .C VOUT RFB1 Note on fi Typical Application lP Package type QFN3.5x4.5-20 Applications de nti a Ordering Number SQ33065WAQ OO KO O dF VIN pin voltage determines whether SQ33065 enters DEM to prevent reverse charging. Cycle-by-cycle over current protection is accomplished by measuring the voltage across the low-side MOSFET or current sense resistor. Forced-PWM (FPWM) eliminates frequency variation and a selectable diode emulation lowers power consumption at light-load conditions. The switching frequency as high as 1 MHz can be set or synchronized to an external clock. or W         6V to 75V Input Voltage Range 0.8V to 60V Output Voltage Range Switching Frequency: 100kHz~1MHz – SYNC In/Out Capability Soft-Start or Voltage Tracking 0.8V±1% Reference Voltage Minimum On-Time: 60ns typical Minimum Off-Time: 240ns typical Type Ⅲ Voltage-Mode Control with Feedforward High Gain-Bandwidth Error Amplifier Open-Drain Power Good Indicator Protection Features – Cycle-by-cycle Over current Protection – Prevent Reverse Charging Protection – Input UVLO with Hysteresis – VCC and BST UVLO Protection – Thermal Shutdown Protection with Hysteresis Compact Package: QFN3.5x4.5-20 AGND SYNCOUT EP VCC RILIM Sil RFB2 SYNCIN RSYNCIN NC PGOOD COUT LO PGND ILIM Q2 CVCC CILIM VCC RPGOOD Figure 1. Typical Application AN_SQ33065 Rev. 0.9A © 2022 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 1 All Rights Reserved. AN_SQ33065 Pinout (Top View) EN/UVLO VIN 1 20 19 LX SS/TRK 3 18 HO COMP 4 17 BST 16 NC 15 EP SYNCOUT 7 14 VCC SYNCIN 8 13 LO NC 9 12 PGND Exposed Pad (EP) AGND 6 11 ILIM dF 10 PGOOD or W FB 5 OO KO O RT 2 Pin Number 1 RT 2 SS/TRK 3 COMP FB AGND 4 5 6 SYNCOUT 7 SYNCIN NC PGOOD ILIM PGND LO VCC EP NC BST HO 8 9 10 11 12 13 14 15 16 17 18 de nti a on fi .C orp yC erg Sil LX 19 VIN 20 EP - AN_SQ33065 Rev. 0.9A © 2022 Silergy Corp. Pin Description Enable and UVLO pin Switching frequency set pin. A resistor is connected to RT pin and set the operation frequency. Soft-start and voltage tracking pin. A capacitor is connected to set soft-start time. Output of the internal error amplifier. Output Feedback Pin. Analog ground. Synchronization output. Logic output that provides a clock signal that is 180°out-of phase with the high-side FET gate drive. Synchronization input pin. No electrical connection. Power Good indicator. Current limit set and protection pin. Power ground. Low side MOSFET gate driver pin. Power supply pin. Exposed pad of the package. No electrical connection. Bootstrap supply for the high-side gate driver. High side MOSFET gate driver pin. Inductor pin. Connect this pin to the switching node of inductor. Voltage supply for VCC LDO regulator and prevent reverse charging protection pin. Exposed pad of the package. Connect to the system ground to reduce thermal resistance. lP Pin Name EN/UVLO rep are Top mark: DXYxyz (Device code: DXY, x=year code, y=week code, z= lot number code) Silergy Corp. Confidential- Prepared for Customer Use Only 2 All Rights Reserved. AN_SQ33065 Block Diagram VIN 7.5V VCC OO KO O LDO VCC UVLO 10uA 1.2V Standby BST UVLO EN PGOOD Comparator FB 0.4V rep are Synchronization Function SYNCIN OCP ILIM PGND Fig 2. Simplified Block Diagram Sil erg yC orp .C AGND LO CLK on fi FPWM&Diode Emulation Mode Selection VCC lP Oscillation Generator de nti a RAMP Generator VIN/kFF SYNCOUT LX dF OTP VREF COMP RT HO PWM Control&Logic &Protection 10uA SS/TRK or W Shutdown PGOOD BST AN_SQ33065 Rev. 0.9A © 2022 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 3 All Rights Reserved. AN_SQ33065 Absolute Maximum Ratings dF Recommended Operating Conditions (Note 3) or W OO KO O Absolute Maximum Voltage (Note 1) VIN, EN/UVLO, PGOOD------------------------------------------------------------------------------------------------- -0.3V to 95V LX------------------------------------------------------------------------------------------------------------------------------- -1V to 95V ILIM-------------------------------------------------------------------------------------------------------------------------- -0.3V to 95V VCC, SYNCIN------------------------------------------------------------------------------------------------------------- -0.3V to 14V BST to LX------------------------------------------------------------------------------------------------------------------ -0.3V to 14V FB, COMP, SS/TRK, RT--------------------------------------------------------------------------------------------------- -0.3V to 6V BST ------------------------------------------------------------------------------------------------------------------------- -0.3V to 105V Package Thermal Resistance (Note 2) Power Dissipation max, @ TA=25°C QFN3.5x4.5-20 ------------------------------------------------------------------------- 3.3W ƟJA --------------------------------------------------------------------------------------- ------------------------------------------ 42°C/W ƟJC(top) ----------------------------------------------------------------------------------------------------------------------------- 14°C/W Junction Temperature Range ----------------------------------------------------------------------------------------------------- 150°C Lead Temperature (Soldering, 10 sec.) ------------------------------------------------------------------------------------------ 260°C Storage Temperature Range ------------------------------------------------------------------------------------------- -65°C to 150°C rep are VIN ----------------------------------------------------------------------------------------------------------------------------- 6V to 75V External VCC------------------------------------------------------------------------------------------------------------------ 8V to 13V Junction Temperature Range ------------------------------------------------------------------------------------------ -40°C to 125°C lP Electrical Characteristics de nti a (VIN=48V, VEN/UVLO=1.5V, RRT=25kΩ, Tj=25˚C, Minimum and maximum limits apply over the –40°C to 125°C junction temperature range, unless otherwise specified) Parameter Symbol Conditions orp yC VVCC-EXT VIN = 6 V, VSS/TRK = 0 V, IVCC = 20 mA VSS/TRK = 0V, VCC = 6V VCC rising Rising threshold – falling threshold Voltage required to disable VCC regulator IVCC VSS/TRK = 0V, VVCC = 13V VSDN VEN/UVLO rising VVCC-LDO VCC Short-circuit Current VCC UVLO Threshold ISC-LDO VUVLO_H VCC UVLO Hysteresis VUVLO_HYS Sil erg VIN to VCC Dropout Voltage Minimum External Bias Supply Voltage External VCC Input Current, not Switching Enable And Input UVLO Shutdown to Standby Threshold AN_SQ33065 Rev. 0.9A © 2022 Silergy Corp. Max Unit 75 V 1.05 1.3 mA 88 5 425 9.3 93 510 12.8 V V μA μA 7.5 7.7 V 285 650 mV 50 5.25 65 5.5 mA V Typ 6 83 .C on fi Vin Input Supply& Prevent Reverse Charging Protection (VIN DEM) VIN Voltage Range VIN Operating Input Current, not VEN/UVLO = 1.5V, VSS/TRK = IQ-RUN 0V Switching VIN DEM Threshold VIN_DEM VIN DEM HYS VIN_DEMHYS VEN/UVLO = 0.8V Standby Input Current IQ-STBY VEN/UVLO = 0V, VVCC< 1V Shutdown Input Current IQ-SDN VCC Regulator VEN/UVLO = 1.5V VCC Regulation Voltage VVCC Min 7.3 40 5 270 mV 8 V 1.3 0.41 mA V Silergy Corp. Confidential- Prepared for Customer Use Only 4 All Rights Reserved. AN_SQ33065 VSDN-HYS EN/UVLO rising – falling threshold VEN VEN/UVLO rising 1.164 1.2 1.236 V IEN-HYS VEN/UVLO = 1.5V 9 10 11 μA VREF IFB-BIAS FB connected to COMP VFB = 0.8V VFB = 0V, COMP sourcing 1mA FB=1V, COMP sinking 1mA 808 0.1 mV μA VSS/TRK = 0V .C orp yC erg Sil AN_SQ33065 Rev. 0.9A © 2022 Silergy Corp. OO KO O 8.5 VEN/UVLO = 0.8V, VSS/TRK = 0.1V % of VREF, VFB rising % of VREF, VFB falling 800 mV 4.2 V 0.44 V 100 6.6 dB MHz 10 11.5 -15 15 120 105% 108% 111% 89% 92% 95% % of VREF 3% % of VREF 3% FB to PGOOD rising edge FB to PGOOD falling edge 33 33 uA Ω 26 VSS/TRK–VFB, VFB = 0.8V on fi DC Gain AVOL Unity Gain Bandwidth GBW Soft Start and Voltage Tracking SS/TRK Capacitor Charging ISS Current SS/TRK Discharge FET RSS Resistance SS/TRK to FB Offset VSS-FB SS/TRK Clamp Voltage VSS-CLAMP POWER GOOD INDICATOR FB Upper Threshold for PGUTH PGOOD High to Low FB Lower Threshold for PGLTH PGOOD High to Low PGOOD Upper Threshold PGHYS_U Hysteresis PGOOD Lower Threshold PGHYS_L Hysteresis PGOOD Rising Filter TPG-RISE PGOOD Falling Filter TPG-FALL PGOOD Low State Output VPG-OL Voltage PGOOD High State Leakage IPG-OH Current Switching Frequency Oscillator Frequency – 1 FSW1 Oscillator Frequency – 2 FSW2 Oscillator Frequency – 3 FSW3 Synchronization Input and Output SYNCIN External Clock FSYNC Frequency Range Minimum SYNCIN Input VSYNC-IH Logic High Maximum SYNCIN Input VSYNC-IL Logic Low SYNCIN Input Resistance RSYNCIN SYNCIN Input Minimum TSYNCI-PW Pulse Width 792 -0.1 or W VCOMP-OL dF COMP Output Low Voltage rep are VCOMP-OH lP COMP Output High Voltage 33 de nti a Shutdown Threshold Hysteresis Standby to Operating Threshold Standby to Operating Hysteresis Current Error Amplifier FB Reference Voltage FB Input Bias Current mV mV μs μs VFB = 0.9 V, IPGOOD = 2 mA 300 mV VFB = 0.8V, VPGOOD = 13V 100 nA 420 kHz kHz kHz RRT = 100kΩ RRT = 25kΩ RRT = 12.5kΩ 380 % of nominal frequency set by RRT 80% 104 400 770 150% 2 V 1 VSYNCIN =0.3V Minimum high state or low state duration 23 50 V kΩ ns Silergy Corp. Confidential- Prepared for Customer Use Only 5 All Rights Reserved. AN_SQ33065 Minimum off-time ISYNCOUT = –1 mA (sourcing) 2.8 TOFF(MIN) DC100kHz Maximum Duty Cycle 0.9 VSYNCIN Floating, TS = 1/FSW,FSW set by RRT VBST – VLX falling dF VBST – VLX rising 0.77 or W VCC to BST, BST pin sourcing 20 mA VSS/TRK = 0V, VLX = 48V,VBST = 54V VBST – VLX = 7 V, HO 50% to 50% VBST – VLX = 7 V, HO 50% to 50% FSW = 100 kHz, 6 V ≤ VVIN≤ 60 V FSW = 400 kHz, 6 V ≤ VVIN≤ 60 V orp yC VZCD-DIS ZCD threshold measured at LX pin 1000 clock cycles after first HO pulse Diode Emulation Zero-cross Threshold VDEM-TH Measured at LX with VLX rising Sil erg Zero-cross Detect Disable Threshold Gate Driver HO High-state Resistance, HO to BST HO Low-state Resistance, HO to LX LO High-state Resistance, LO to VCC AN_SQ33065 Rev. 0.9A © 2022 Silergy Corp. RHO-UP RHO-DOWN RLO-UP VBST – VLX = 7 V, IHO = –100 mA VBST – VLX = 7 V, IHO = 100 mA VBST – VLX = 7 V, ILO = –100 mA ns 0.95 V 48 uA 3.5 V 0.34 V 60 90 ns 240 340 ns 97% 90% 300 mV 15 V/V 90 100 110 uA 180 200 220 uA .C on fi de nti a Ramp Valley Voltage (COMP VRAMP(min) at 0%duty cycle) PWM Feedforward Gain (VIN 6 V ≤ VVIN≤ 75 V kFF / VRAMP) OVERCURRENT PROTECT (OCP) – VALLEY CURRENT LIMITING ILIM Source Current, Low voltage detected at IRS ILIM RSENSE Mode ILIM Source Current, LX voltage detected at IRDSON ILIM, TJ = 25°C RDS(on) Mode RDS-ON mode ILIM Current Tempco IRSTC RSENSE mode ILIM Current Tempco IRDSONTC ILIM Comparator Threshold VILIM-TH at ILIM DIODE EMULATION V ns 260 OO KO O 50% to 50% TS/2 – 240 lP DC400kHz V ISYNCOUT = 1 mA (sinking) rep are SYNCOUT High State Output VSYNCO-OH Voltage SYNCOUT Low State Output VSYNCO-OL Voltage Delay from HO Rising to TSYNCOUT SYNCOUT Leading Edge Delay from SYNCIN Leading TSYNCIN Edge to HO Rising Bootstrap Diode and Under Voltage Threshold Diode Forward Voltage, VCC VBST-FWD to BST BST to LX Quiescent Current, IQ-BST not Switching BST to LX under Voltage VBST-UV Detection BST to LX under Voltage VBST-HYS Hysteresis PWM CONTROL Minimum Controllable onTON(MIN) time 2700 0 -6.5 0 ppm/°C ppm/°C 6.5 200 -6.5 0 mV mV 6.5 mV 1.7 Ω 0.73 Ω 1.7 Ω Silergy Corp. Confidential- Prepared for Customer Use Only 6 All Rights Reserved. AN_SQ33065 RLO-DOWN HO, LO Source Current IHOH, ILOH HO, LO Sink Current IHOL, ILOL THERMAL SHUTDOWN Thermal Shutdown Threshold Thermal Shutdown Hysteresis Switching Characteristics TSD TSD-HYS HO, LO Rise Times THO-TR _TLO-TR HO, LO Fall Times THO-TF _TLO-TF HO Turn on Dead Time THO-DT LO Turn on Dead Time TLO-DT TJ rising or W VBST – VLX = 7 V, CLOAD = 1 nF, 20% to 80% VBST – VLX = 7 V, CLOAD = 1 nF, 80% to 20% VBST – VLX = 7 V, LO off to HO on, 50% to 50% VBST – VLX = 7 V, HO off to LO on, 50% to 50% 0.73 Ω 2.3 A 3.5 A 160 18 ˚C ˚C 5 ns 4 ns 25 ns 10 ns OO KO O VBST – VLX = 7 V, ILO = 100 mA VBST – VLX = 7 V, HO = LX, LO = AGND VBST – VLX = 7 V, HO = BST, LO = VCC LO Low-state Resistance, LO to PGND Sil erg yC orp .C on fi de nti a lP rep are dF Note 1: Stresses beyond the listed “Absolute Maximum Ratings” may cause permanent damage to the device. These are for stress ratings. Functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions may remain possibility to affect device reliability. Note 2: θJA is measured in the natural convection at TA=25ºC on a high effective four-layer PCB with thermal via according with JESD 51-2, -5, -7, -8, -14 measurement standard. Note 3: The device is not guaranteed to function outside its operating conditions. AN_SQ33065 Rev. 0.9A © 2022 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 7 All Rights Reserved. AN_SQ33065 voltage increases to a high level, which may damage Vin pin. So, in SQ33065, if input voltage is larger than VIN DEM, the device will enter diode emulation mode to stop energy flowing back to input capacitor. Operation Principles 6V~75V SQ33065 VIN RVIN or W Vin CVIN PGND orp .C on fi rep are de nti a lP Power Supply VCC In SQ33065, a LDO is connected to Vin to generate VCC voltage, providing internal logic power and gate driver power. If Vin>7.5V, output of LDO (VCC) is 7.5V. If Vin
SQ33065WAQ 价格&库存
很抱歉,暂时无法提供与“SQ33065WAQ”相匹配的价格&库存,您可以联系我们找货
SQ33065WAQ
  • 1+7.70280
  • 10+7.01680
  • 30+6.59540
  • 100+6.15440
库存:200
