SY7072
1.8V Minimum Input and 5. 5V Maximum Output
High Efficiency 2A Valley Current Synchronous Boost
General Description
Features
SY7072 is a high efficient, synchronous, step-up Boost
converter designed for one-cell Li-Ion or Li-polymer,
or a two to three-cell alkaline Ni-Cd or Ni-MH battery
powered applications. It can convert down to 1.8V
input voltage. It adopts NMOS for the main switch and
PMOS for the synchronous switch.
SY7072 can disconnect the output from input during
the shutdown mode. When input voltage exceeds the
regulated output voltage, SY7072 enters bypass mode
automatically.
Ordering Information
Applications
SY7072 □(□□)□
Temperature Code
Package Code
Optional Spec Code
Ordering Number
SY7072ABC
1.8V Minimum Input Voltage
Adjustable Output Voltage from 1.8V to 5.5V
Min 2A Valley Current Limit
5µA Typical Quiescent Current
Load Disconnect During Shutdown
Low RDS(ON) (Main Switch/Synchronous Switch)
at 3.3V Output: 100/170mΩ
Output OVP
Auto Bypass Mode When VIN ≥VOUT
RoHS Compliant and Halogen Free
Compact Package SOT23-6
Package type
SOT23-6
Note
All Single Cell Li or Dual Cell Battery Operated
Products as MP-3 Player, PDAs, and Other
Portable Equipment.
Typical Applications
Efficiency vs. Output Current
100
95
L1
VOUT
LX
CIN
IN
RFB1
SY7072
FB
ON/OFF
90
OUT
EN
Cff
COUT
Efficiency (%)
VIN
85
80
75
70
65
GND
RFB2
VIN =1.8V,VOUT =3.3V
VIN =2.2V,VOUT =3.3V
VIN =3.0V,VOUT =3.3V
60
55
50
0.001
0.01
0.1
1
Output Current (A)
Figure 1. Schematic Diagram
SY7072 Rev. 0.9A
© 2020 Silergy Corp.
Figure 2. Efficiency vs. Load Current
Silergy Corp. Confidential- Prepared for Customer Use Only
1
All Rights Reserved.
SY7072
Pinout (top view)
LX
1
6
IN
GND
2
5
OUT
FB
3
4
EN
(SOT23-6)
Top mark: Uyxyz for SY7072ABC (Device code: Uy, x=year code, y=week code, z= lot number code)
Pin Name
LX
GND
Pin Number
1
2
FB
3
EN
4
OUT
5
IN
6
Pin Description
Inductor node. Connect an inductor between the IN pin and the LX pin.
Ground pin.
Feedback pin. Connect a resistor RFB1 between OUT and FB, and a resistor RFB2
between FB and GND to program the output voltage. VOUT=1.2V× (RFB1/RFB2+1).
Enable pin. Pull high to turn on. Do not leave it floating.
Output pin. Decouple this pin to the GND pin with a minimum of 22µF ceramic
capacitor.
Input pin.
Block Diagram
IN
OUT
OUT
IN
IN
VCC
Supply
1.75V
Linear charge
control
One Shot
Timer
FB
GM
1.2V
Ref
R
OUT
UVLO
Q
TG
PWM
Control
S
Q
WELL
SWITCH
LX
BG
Zc
Current
Sense
GND
EN
Enable
control
Mode
Control
Figure3. Block Diagram
SY7072 Rev. 0.9A
2
SY7072
Absolute Maximum Ratings (Note 1)
FB, IN, OUT, EN --------------------------------------------------------------------------------------------------- -0.3V to 6.0V
LX ----------------------------------------------------------------------------------------------------------- -0.3V *1 to 6.0V *2
Power Dissipation, P D @ TA =25°C SOT23-6----------------------------------------------------------------------- 1W
Package Thermal Resistance (Note 2)
θ JA ----------------------------------------------------------------------------------------------- ---------------- 100°C/W
θ JC ------------------------------------------------------------------------------------- ---------------------------- 30°C/W
Junction Temperature Range ----------------------------------------------------------------------------------- -40°C to 150°C
Lead Temperature (Soldering, 10 sec.) --------------------------------------------------------------------------------- 260°C
Storage Temperature Range ---------------------------------------------------------------------------------- -65°C to 150°C
(*1)
LX Voltage tested down to -3V< 20ns
(*2)
LX Voltage tested up to +7V< 20ns
Recommended Operating Conditions (Note 3)
IN -------------------------------------------------------------------------------------------- ---------------------------- 1.8V to 5.5V
OUT--------------------------------------------------------------------------------------------------------------------- 1.8V to 5.5V
EN ----------------------------------------------------------------------------------------------------------------- 0V to VOUT+0.3V
All Other Pins ----------------------------------------------------------------------------------------------------------------- 0-5.5V
Junction Temperature Range ------------------------------------------------------------------------------------ -40°C to 125°C
Ambient Temperature Range ------------------------------------------------------------------------------------- -40°C to 85°C
SY7072 Rev. 0.9A
3
SY7072
Electrical Characteristics
(VIN =2.4V, VOUT=3.3V, IOUT=500mA, TA = 25°C, unless otherwise specified)
Parameter
Symbol Test Conditions
Min
Input Voltage Range
VIN
1.8
Input UVLO Threshold
VUVLO
Typ
Max
5.5
Unit
V
1.65
1.75
V
Input UVLO Hysteresis
0.1
V
1
5
0.1
1
µA
µA
µA
Quiescent Current
VIN
VOUT
Shutdown Current
VHYS
IQ
VFB=1.3V,VEN=VIN=2V,
VOUT=3.4V
VEN=0V,VIN=2.4V
Linear Charge Current
ISHDN
ICHARGE
Feedback Reference Voltage
VREF
Low Side Main FET RON
RDS(ON)1
Synchronous FET RON
RDS(ON)2
EN Input Voltage High
VEN,H
EN Input Voltage Low
VEN,L
EN Leakage Current
IEN,LK
Min ON Time
tON,MIN
60
ns
Min OFF Time
tOFF,MIN
140
ns
Soft-Start Time
tSS
Switching Frequency
FSW
ILMT,VAL
Output Over Voltage
Threshold
Output Over Voltage
Hysteresis
Thermal Shutdown
Temperature
Thermal Shutdown Hysteresis
VOUT
很抱歉,暂时无法提供与“SY7072ABC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.79300
- 100+1.43000
- 750+1.27600
- 1500+1.21000
- 3000+1.14400
- 国内价格
- 1+2.80800
- 10+2.21400
- 30+1.95480
- 100+1.63080
- 500+1.49040
- 1000+1.40400
