Application Note: SY8032I
High Efficiency, 1.5MHz, 2A
Synchronous Step Down Regulator
Features
The low output voltage ripple, the small external
inductor and the capacitor sizes are achieved at
1.5MHz switching frequency.
dF
Ordering Information
2.7V to 5.5V Input Voltage Range
50μA Low Quiescent Current
Low RDS(ON) for Internal Switches (Top/Bottom)
130mΩ /85mΩ
High Switching Frequency 1.5MHz Minimizes
the External Components
Internal Soft-start Limits the Inrush Current
100% Dropout Operation
Reliable Short Circuit Protection
Power Good Indicator
RoHS Compliant and Halogen Free
Compact Package: SOT23-6
谷
The SY8032I is a high efficiency, 1.5MHz
synchronous step down DC/DC regulator capable of
delivering up to 2A output current. It can operate over
a wide input voltage range from 2.7V to 5.5V and
integrate main switch and synchronous switch with
very low RDS(ON) to minimize the conduction loss.
or
午
General Description
SY8032 □(□□)□
Temperature Code
Package Code
Optional Spec Code
rep
are
Package type
SOT23-6
Note
LX
IN
RPG
100k
.C
RH
100k
PG
FB
EN
RL
49.9k
erg
Figure1. Schematic Diagram
4.7
Sil
1.2/ 1.8
/3.3
L [µH]
0.47
1.0
2.2
COUT [µF]
10
22
2×22
Note: ‘☆’ means recommended for most applications.
AN_SY8032I Rev. 0.9
© 2018 Silergy Corp.
95
90
85
80
VIN=3.3V, VOUT=1.8V
VIN=4.2V, VOUT=1.8V
VIN=5.0V, VOUT=1.8V
75
Inductor and COUT Selection Table
VOUT [V]
100
COUT
10μF/10V
yC
GND
CFF
22pF
orp
CIN
10μF/6.3V
Efficiency vs. Output Current
VOUT:1.8V
Efficiency (%)
L:1.0µH
on
fi
Typical Applications
VIN: 2.7-5.5V
Set Top Box
USB Dongle
Media Player
Smart Phone
de
nti
a
lP
Ordering Number
SY8032IABC
Applications
70
0.001
0.01
0.1
1
10
Output Current (A)
Figure2. Efficiency vs. Output Current
Silergy Corp. Confidential- Prepared for Customer Use Only
1
All Rights Reserved.
AN_SY8032I
Pinout (Top View)
EN 1
6
FB
GND 2
5
PG
3
4
IN
LX
(SOT23-6)
Pin Name
Pin Number
EN
1
Enable control. Pull high to turn on. Do not leave it floating.
GND
2
Ground pin.
LX
3
Inductor pin. Connect this pin to the switching node of the inductor.
IN
4
Input pin. Decouple this pin to the GND pin with at least a 10µF ceramic capacitor.
PG
5
FB
6
rep
are
dF
or
午
Pin Description
谷
Top Mark: fMxyz (device code: fM, x=year code, y=week code, z= lot number code)
lP
Power good indicator (open-drain output). Low if the output < 90% of the regulation
voltage; High otherwise. Connect a pull-up resistor to the input.
Output feedback pin. Connect this pin to the center point of the output resistor divider
(as shown in Figure 1) to program the output voltage: V OUT=0.6×(1+RH/RL).
on
fi
Input
UVLO
IN
Current
Sense
orp
.C
Internal
Power
de
nti
a
Block Diagram
EN
LX
yC
1.2V
Control
Logic
0.6V
GND
Sil
erg
FB
Soft
Start
Thermal
Detect
PG
Figure3. Block Diagram
AN_SY8032I Rev. 0.9
2
AN_SY8032I
Absolute Maximum Ratings (Note 1)
Supply Input Voltage ---------------------------------------------------------------------------------------------- -0.3V to 6.0V
PG, FB, EN Voltage------------------------------------------------------------------------------------------- -0.3V to VIN+0.6V
LX Voltage------------------------------------------------------------------------------------------------------- -0.3V(*1) to 6.0V(*2)
Power Dissipation, P D @ T A = 25°C -------------------------------------------------------------------------------0.83W
Package Thermal Resistance (Note 2)
θ
θ
JA
-------------------------------------------------------------------------------------------- ----------120°C/W
dF
Recommended Operating Conditions (Note 3)
or
午
谷
JC ----------------------------------------------------------------------------------------------- --------------20°
C/W
Junction Temperature Range ------------------------------------------------------------------------------------- -40oC to 150°C
Lead Temperature (Soldering, 10 sec.) ------------------------------------------------------------------------------------ 260°C
Storage Temperature Range -------------------------------------------------------------------------------------- -65°C to 150°C
(*1)
LX Voltage Tested Down to -3V
很抱歉,暂时无法提供与“SY8032IABC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.88220
- 200+0.60940
- 1500+0.55330
- 3000+0.51700
- 国内价格
- 1+10.99510
- 10+8.13340
- 100+6.97150
- 1000+5.80960
