Application Note: SY8745A
High Efficiency 60V, 2.0A, 500KHz
Constant Current Step-down Regulator
Features
SY8745A is a high efficiency, 12V-60V wide input
voltage range DC/DC regulator targeting at LED
applications. The device integrates the low RDS(ON)
MOSFET and internal compensation. Along with the
small SO8E package, the device achieves an extremely
small solution size for LED driver design. SY8745A
also supports PWM dimming and Analog dimming
function.
IR
IT
Low RDS(ON) for internal switches :160mΩ
Input range: 12V-60V
500kHz switching frequency
PWM/Analog dimming available
2.0A LED current output
Compact package: SO8E
RoHS Compliant and Halogen Free
±2% 100mV reference
or
K
Ordering Information
RO
N
General Description
dF
Applications
SY8745 □(□□)□
PAR Lamp
Tube Lamp
Bulb
Note
lP
Package type
SO8E
Typical Applications
R3/0.2Ω
VIN:50V~60V
Efficiency vs. Output current
97.8
VO:40V,IO=1.5A
on
fi
R4/0.2Ω
de
nti
a
Ordering Number
SY8745AFCC
rep
are
Temperature Code
Package Code
Optional Spec Code
97.6
D1
SS310
5
6
R2
10K
LX
SEN
EN
GND
yC
7
NC
VIN
8
NC
CF
GND
3
97.4
97.2
97.0
2
4
Vin=60V Vout=50V
96.8
C4
10nF
96.6
0.6
0.8
1
1.2
1.4
1.6
1.8
2
2.2
Output current(A)
Figure 1. Schematic diagram
Sil
erg
U1/SY8745A
C3
2.2uF
50V
L1/100µH
1
orp
R1
100K
.C
C2
100V
100nF
Efficiency(%)
R5/0.2Ω
C1
63V
10µF
AN_SY8745A Rev.0.9
© 2019 Silergy Corp.
Silergy Corp. Confidential- Prepared for Customer Use Only
1
All Rights Reserved.
AN_SY8745A
Pinout (top view)
1
8
NC
CF
2
7
EN
LX
3
6
SEN
GND
4
5
IN
GND
RO
N
NC
SO8E
1
CF
2
LX
3
GND
4
IN
5
SEN
6
EN
7
NC
8
dF
rep
are
lP
de
nti
a
on
fi
LX
SEN
.C
IN
Pin Description
No connection
Dimming mode selection:
VCF≥1.6V, PWM dimming mode.
VCF≤1.4V, analog dimming mode.
Inductor node. Connect an inductor from power input to
LX pin.
Ground pin
Input pin. Decouple this pin to GND pin with 1µF ceramic
cap. Also used as the positive current sense pin.
Negative Current Sense Pin.
Analog dimming mode selection:
VEN≥8.5V, add 0~1.0V signal to CF PIN, 0~1.0V analog
dimming mode.(EN connect to VIN is doable)
VEN≤6.5V, add PWM signal to EN, analog dimming with
PWM signal input.
At analog dimming mode, recommend to connect a 10nF
capacitor between CF PIN and GND.
No connection
or
K
Pin Name
NC
IR
IT
SO8E
Top Mark: BUCxyz (device code: BUC, x=year code, y=week code, z= lot number code)
orp
Current Sense
yC
PWM Dimming
processor
Resistor
Io
reference
GND
Sil
erg
EN
Driver
Control
Logic
UVLO
Dimming mode
Thermal
Shutdown
CF
Block Diagram
AN_SY8745A Rev.0.9
2
AN_SY8745A
Absolute Maximum Ratings
RO
N
LX, IN, EN, CF------ ------------------------------------------------------------------------------------------------------ -0.3V to 63V
SEN ----------------------------------------------------------------------------------------------------------------- -0.3V to VIN 0.6V
Power Dissipation, PD @ TA = 25°C SO8E, ----------------------------------------------------------------------------------- 3.3W
Package Thermal Resistance (Note 2)
θJA ------------------------------------------------------------------------------------------------ 30°C/W
θJC -------------------------------------------------------------------------------------------------------------------- 10°C/W
Junction Temperature Range ------------------------------------------------------------------------------------------ -40°C to 150°C
Lead Temperature (Soldering, 10 sec.) ----------------------------------------------------------------------------------------- 260°C
Storage Temperature Range ------------------------------------------------------------------------------------------- -65°C to 150°C
Recommended Operating Conditions
Sil
erg
yC
orp
.C
on
fi
de
nti
a
lP
rep
are
dF
or
K
IR
IT
IN------------------------------------------------------------------------------------------------------------------------------- 12V to 60V
SEN -------------------------------------------------------------------------------------------------- ------------------------- VIN 0.4V
Junction Temperature Range ------------------------------------------------------------------------------------------ -40°C to 125°C
AN_SY8745A Rev.0.9
3
AN_SY8745A
Electrical Characteristics
VIN_ON
VIN turn-off threshold
VIN_OFF
120
400
98
4.0
1.5
or
K
Dimming section:
Thermal Shutdown Temperature
TSD
Thermal Hysteresis
Hyst
7.5
160
500
100
5.0
Max
60
0.25
Unit
V
µA
mΩ
kHz
mV
mV
V
V
200
600
102
6.0
9.0
10.0
11.0
V
8.5
9.5
10.5
V
100
900
mV
mV
155
°C
°C
rep
are
VCF
dF
At Minimum ILED
At Maximum ILED
Analog dimming range on CF
Typ
RO
N
VIN turn-on threshold
Min
12
IR
IT
(VIN =24V, VOUT=12V, IOUT=100mA, TA = 25°C unless otherwise specified)
Parameter
Symbol
Test Conditions
Input Voltage Range
VIN
Shutdown Current
ISHDN
EN=0
Low Side Main FET RON
RDS(ON)
Switching Frequency
FSW
Internal Current Sense Reference
VIN-SEN
Min current sense reference
VIN-SEN_MIN
EN Rising Threshold
VENH
EN Falling Threshold
VENL
de
nti
a
lP
Note 1: Stresses beyond the “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress
ratings only. Functional operation of the device at these or any other conditions beyond those indicated in the
operational sections of the specification is not implied. Exposure to absolute maximum rating conditions for extended
periods may affect device reliability.
Note 2: θ JA is measured in the natural convection at T A = 25°C on a low effective single layer thermal conductivity
test board of JEDEC 51-3 thermal measurement standard.
Sil
erg
yC
orp
.C
on
fi
Note 3. The device is not guaranteed to function outside its operating conditions
AN_SY8745A Rev.0.9
4
AN_SY8745A
Typical Performance Characteristics
Analog dimming with PWM signal input
1.6
1.4
1.4
1.2
1.2
LED Current(A)
0.8
0.6
1.0
0.8
RO
N
1.0
0.6
0.4
0.4
0.2
0.2
0.0
0.0
0.4
0.6
0.8
1
1.2
IR
IT
LED Current(A)
0-1.0V Analog Dimming
1.6
VCF(V)
60
80
100
120
Dimming Duty(%)
PWM Dimming
or
K
1.60
1.40
dF
1.00
0.80
0.60
0.40
0.20
0.00
60
lP
rep
are
LED Current (A)
1.20
80
100
120
PWM Dimming
(VIN=60V, VO=40V,IO=1.5A,90% Duty)
0.5A/div
PWM Dimming
(VIN=60V, VO=40V,IO=1.5A,50% Duty)
Iout
IL
0.5A/div
0.5A/div
20V/div
VLX
20V/div
erg
yC
VLX
orp
.C
IL
0.5A/div
on
fi
Iout
de
nti
a
Duty (%)
Time (400µs/div)
Sil
Time (400µs/div)
AN_SY8745A Rev.0.9
5
AN_SY8745A
PWM Dimming
PWM Dimming
(VIN=60V, VO=40V,IO=1.5A,10% Duty)
(VIN=60V, VO=40V,IO=1.5A,1% Duty)
Iout
0.5A/div
IL
IL
0.5A/div
VLX
VLX
Time (400µs/div)
or
K
Time (400µs/div)
Startup
rep
are
0.5A/div
VLX
Iout
IL
lP
0.5A/div
20V/div
de
nti
a
IL
Shutdown
(VIN=60V,VO=50V,IO=1.5A)
dF
Iout
20V/div
IR
IT
20V/div
0.5A/div
0.5A/div
RO
N
Iout
Time (20ms/div)
1.0A/div
IL
1.0A/div
VLX
20V/div
Time (20ms/div)
orp
.C
Iout
0.5A/div
on
fi
Short LED
0.5A/div
VLX
Sil
erg
yC
20V/div
Time (200µs/div)
AN_SY8745A Rev.0.9
6
AN_SY8745A
Operation
The SY8745A regulator IC is quite tolerant of different
ripple current amplitude. Consequently, the final choice of
inductance can be slightly off the calculation value without
significantly impacting the performance.
SY8745A is a grounding switch buck regulator IC that
integrates the PWM control, power MOSFET on the
same die to minimize the switching transition loss and
conduction loss. With ultra low RDS(ON) power
MOSFET and proprietary PWM control, this regulator
IC can achieve the high efficiency and Along with the
also supports PWM/Analog dimming function.
RO
N
2) The saturation current rating of the inductor must be
selected to be greater than the peak inductor current
under full load conditions.
VOUT(1-VOUT/VIN,MAX)
ISAT, MIN IOUT, MAX
2 FSW L
Applications Information
IR
IT
Dimming Operation:
Dimming mode:
1: 0~1.0V analog dimming. Set VEN≥8.5V, and add
0~1.0V dimming signal to CF PIN.
2: Analog dimming with PWM signal input. Recommend
to connect a capacitor to CF PIN, and add PWM signal to
EN (VEN_HIGH≤6.5V)
3: PWM dimming. Set VCF≥1.6V, and add PWM signal
to EN PIN.
dF
or
K
Because of the high integration in the SY8745A IC, the
application circuit based on this regulator IC is rather
simple. Only input capacitor CIN, output capacitor COUT,
output inductor L and current sense resistor RSEN need
to be selected for the targeted applications
specifications.
ILED(A)
0.1(V)
R SEN ()
rep
are
Current sense resistor RSEN:
Choose RSEN to program the proper output Current:
PWM
-PWM≥8.5V
Input capacitor CIN:
Dimming mode
PWM dimming
PWM≤6.5V ≤1.4V
signal input
At PWM dimming mode, the minimum TPWM_ON time is
suggest setting bigger than 20µs.
on
fi
de
nti
a
lP
The ripple current through input capacitor is calculated
as:
ICIN_RMS IOUT D(1 - D)
A typical X7R or better grade ceramic capacitor with
suitable capacitance should be chosen to handle this
ripple current well. To minimize the potential noise
problem, place this ceramic capacitor really close to the
IN and GND pins. Care should be taken to minimize
the loop area formed by CIN, and IN/GND pins.
CF
≥1.6V
≤1.4V
yC
orp
.C
Output capacitor COUT:
The output capacitor is selected to handle the output
current ripple noise requirements. For the best
performance, it is recommended to use X7R or better
grade ceramic capacitor greater than 1µF capacitance.
Sil
erg
Output inductor L:
There are several considerations in choosing this
inductor.
1) Choose the inductance to provide the desired
ripple current. It is suggested to choose the ripple
current to be about 40% of the maximum output
current. The inductance is calculated as:
VOUT (1 VOUT /VIN,MAX )
L
FSW I OUT, MAX 40%
where Fsw is the switching frequency and I OUT,MAX is
the LED current.
AN_SY8745A Rev.0.9
Soft Start:
Add a ceramic capacitor CCF on CF to achieve soft start, the
soft start time can be adjusted by C CF.
SCP:
If VVIN-VSEN>=0.2V, PWM is disabled, When VVIN-VSEN
=0.15V, IC will recover work.
EN OFF:
IC shut down after EN OFF with 15ms.
Layout Design:
The layout design of SY8745A regulator is relatively
simple. For the best efficiency and minimum noise
problems, we should place the following components close
to the IC: CIN, L, COUT, CF and RSEN.
1) It is desirable to maximize the PCB copper area
connecting to GND pin to achieve the best thermal and
noise performance. If the board space allowed, a ground
plane is highly desirable.
2) CIN must be close to Pins IN and GND. The loop area
formed by CIN and GND must be minimized.
7
AN_SY8745A
3) The PCB copper area associated with LX pin must
be minimized to avoid the potential noise problem.
PCB Layout Suggestion
CF
NC
3
2
1
COUT
8
EN
NC
or
K
7
SEN
LED+
Top Layer
Bottom Layer
Sil
erg
yC
orp
.C
on
fi
de
nti
a
lP
rep
are
6
IN
RSEN
dF
CIN
GND
5
VIN
LED-
IR
IT
LX
4
EN
CF
GND
GND
RO
N
D1
L1
AN_SY8745A Rev.0.9
8
AN_SY8745A
dF
or
K
IR
IT
RO
N
SO8E Package Outline & PCB layout
Side view
erg
yC
orp
.C
on
fi
de
nti
a
lP
rep
are
Top view
Sil
Front view
Recommended PCB Layout
(Reference Only)
Notes: All dimension in millimeter and exclude mold flash & metal burr.
AN_SY8745A Rev.0.9
9
AN_SY8745A
Taping & Reel Specification
or
K
IR
IT
RO
N
1. Taping orientation
SO8E
Feeding direction
lP
rep
are
dF
2. Carrier Tape & Reel specification for packages
Pocket
Reel size
Trailer *
Leader *
Qty per reel
pitch(mm)
(Inch)
length(mm)
length (mm)
(pcs)
8
13"
400
400
2500
orp
Tape width
.C
on
fi
de
nti
a
Reel
Size
Package types
yC
(mm)
12
erg
SO8E
Sil
3. Others: NA
AN_SY8745A Rev.0.9
10
AN_SY8745A
Revision History
Sil
erg
yC
orp
.C
on
fi
de
nti
a
lP
rep
are
dF
or
K
IR
IT
RO
N
The revision history provided is for informational purpose only and is believed to be accurate, however, not warranted.
Please make sure that you have the latest revision.
Date
Revision
Change
September 19,2019 Revision 0.9
Initial Release
AN_SY8745A Rev.0.9
11
AN_SY8745A
IMPORTANT NOTICE
1. Right to make changes. Silergy and its subsidiaries (hereafter Silergy) reserve the right to change any information published in
this document, including but not limited to circuitry, specification and/or product design, manufacturing or descriptions, at any time
and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Buyers should
obtain the latest relevant information before placing orders and should verify that such information is current and complete. All
semiconductor products are sold subject to Silergy’s standard terms and conditions of sale.
or
K
IR
IT
RO
N
2. Applications. Application examples that are described herein for any of these products are for illustrative purposes only.
Silergy makes no representation or warranty that such applications will be suitable for the specified use without further testing or
modification. Buyers are responsible for the design and operation of their applications and products using Silergy products. Silergy
or its subsidiaries assume no liability for any application assistance or designs of customer products. It is customer’s sole
responsibility to determine whether the Silergy product is suitable and fit for the customer’s applications and products planned. To
minimize the risks associated with customer’s products and applications, customer should provide adequate design and operating
safeguards. Customer represents and agrees that it has all the necessary expertise to create and implement safeguards which
anticipate dangerous consequences of failures, monitor failures and their consequences, lessen the likelihood of failures that might
cause harm and take appropriate remedial actions. Silergy assumes no liability related to any default, damage, costs or problem in the
customer’s applications or products, or the application or use by customer’s third-party buyers. Customer will fully indemnify
Silergy, its subsidiaries, and their representatives against any damages arising out of the use of any Silergy components in safetycritical applications. It is also buyers’ sole responsibility to warrant and guarantee that any intellectual property rights of a third party
are not infringed upon when integrating Silergy products into any application. Silergy assumes no responsibility for any said
applications or for any use of any circuitry other than circuitry entirely embodied in a Silergy product.
lP
rep
are
dF
3. Limited warranty and liability. Information furnished by Silergy in this document is believed to be accurate and reliable.
However, Silergy makes no representation or warranty, expressed or implied, as to the accuracy or completeness of such information
and shall have no liability for the consequences of use of such information. In no event shall Silergy be liable for any indirect,
incidental, punitive, special or consequential damages, including but not limited to lost profits, lost savings, business interruption,
costs related to the removal or replacement of any products or rework charges, whether or not such damages are based on tort or
negligence, warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any
reason whatsoever, Silergy’ aggregate and cumulative liability towards customer for the products described herein shall be limited in
accordance with the Standard Terms and Conditions of Sale of Silergy.
on
fi
de
nti
a
4. Suitability for use. Customer acknowledges and agrees that it is solely responsible for compliance with all legal, regulatory and
safety-related requirements concerning its products, and any use of Silergy components in its applications, notwithstanding any
applications-related information or support that may be provided by Silergy. Silergy products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure
or malfunction of an Silergy product can reasonably be expected to result in personal injury, death or severe property or
environmental damage. Silergy assumes no liability for inclusion and/or use of Silergy products in such equipment or applications
and therefore such inclusion and/or use is at the customer’s own risk.
orp
.C
5. Terms and conditions of commercial sale. Silergy products are sold subject to the standard terms and conditions of
commercial sale, as published at http://www.silergy.com/stdterms, unless otherwise agreed in a valid written individual agreement
specifically agreed to in writing by an authorized officer of Silergy. In case an individual agreement is concluded only the terms and
conditions of the respective agreement shall apply. Silergy hereby expressly objects to and denies the application of any customer’s
general terms and conditions with regard to the purchase of Silergy products by the customer.
erg
yC
6. No offer to sell or license. Nothing in this document may be interpreted or construed as an offer to sell products that is open for
acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual
property rights. Silergy makes no representation or warranty that any license, either express or implied, is granted under any patent
right, copyright, mask work right, or other intellectual property right. Information published by Silergy regarding third-party
products or services does not constitute a license to use such products or services or a warranty or endorsement thereof. Use of such
information may require a license from a third party under the patents or other intellectual property of the third party, or a license
from Silergy under the patents or other intellectual property of Silergy.
Sil
For more information, please visit: www.silergy.com
AN_SY8745A Rev.0.9
Powered by TCPDF (www.tcpdf.org)
12
