Application Note: SY8891E
High Efficiency, 1.5MHz,
5.5V/1A Synchronous Step Down Regulator
Features
SY8891E is in a space saving, low profile SOT563
package.
Ordering Information
SY8891 □(□□)□
Temperature Code
Package Code
Optional Spec Code
dF
Note
USB Dongle
Media Player
Smart Phone
Set Top Box
rep
are
Package type
SOT563
Applications
de
nti
a
lP
Ordering Number
SY8891EARC
RO
N
2.5V to 5.5V Input Voltage Range.
Low RDS(ON) for Internal Switches (top/bottom)
170mΩ /100mΩ
High Switching Frequency 1.5MHz Minimizes
the External Components
Internal Soft-start Limits the Inrush Current
100% Dropout Operation
Forced PWM Operation
Power Good Indicator
Hic-cup for Short Circuit Protection
Output Auto Discharge Function
RoHS Compliant and Halogen Free
Compact Package: SOT563
IR
IT
SY8891E is a high efficiency 1.5MHz synchronous
step down DC/DC regulator, capable of delivering up
to 1A output current. It can operate over a wide input
voltage range from 2.5V to 5.5V and integrate main
switch and synchronous switch with very low RDS (ON)
to minimize the conduction loss.
or
K
General Description
Typical Application
RH
100k
.C
RPG
100k
PG
FB
yC
erg
Inductor and COUT Selection Table
Sil
L
[µH]
1.5
2.2
1.5
2.2
2.2
1.2
1.8
3.3
4.7
COUT [µF]
10
Figure1. Schematic Diagram
AN_SY8891E Rev. 0.9B
© 2020 Silergy Corp.
Efficiency vs. Output Current
(IOUT=0~1A, L=2.2μH/0420CDMCCDS-2R2MC)
100
COUT
Cff
22pF 10μF/6.3V
90
80
RL
49.9k
GND
VOUT
[V]
VOUT:1.8V
Efficiency (%)
EN
ON/ OFF
orp
CIN
10μF/6.3V
LX
VIN
on
fi
L1:2.2µH
VIN: 2.5-5.5V
22
70
60
50
40
VIN=3.3V,VOUT=1.8V
30
VIN=4.2V,VOUT=1.8V
VIN=5.0V,VOUT=1.8V
0.001
0.01
0.1
Output Current (A)
Figure2. Efficiency vs. Output Current
Silergy Corp. Confidential- Prepared for Customer Use Only
1
All Rights Reserved.
1
SY8891E
PG
EN
LX
6
5
4
1
2
3
FB
GND
VIN
RO
N
Pin out (Top View)
IR
IT
Top Mark: E2 xyz (device code: E2, x=year code, y=week code, z= lot number code)
Pin Description
Pin Number
FB
1
GND
2
VIN
3
LX
EN
4
5
PG
6
Pin Description
Output feedback pin. Connect this pin to the center point of the output resistor
divider (as shown in Figure 1) to program the output voltage:
VOUT=0.6×(1+RH/RL).
Ground pin.
Input pin. Decouple this pin to GND pin with at least a 10µF ceramic
capacitor.
Inductor pin. Connect this pin to the switching node of inductor.
Enable control. Pull high to turn on. Do not leave it floating.
Power good indicator. Power good indicator (open drain output). Low if the
output < 90% or the output >120% of regulation voltage; High otherwise.
Connect a pull-up resistor to the input.
de
nti
a
lP
rep
are
dF
or
K
Pin Name
Input
UVLO
IN
Current
Sense
orp
.C
Internal
Power
on
fi
Function Block
EN
LX
yC
1.2V
0.6V
Sil
erg
FB
OVP
120%VREF
Control
Logic
Soft
Start
GND
Thermal
Detect
PG
Figure3. Block Diagram
2
SY8891E
Absolute Maximum Ratings (Note 1)
RO
N
Supply Input Voltage----------------------------------------------------------------------------------------------- -0.3V to 6.0V
FB, EN, PG Voltage----------------------------------------------------------------------------------------- -0.3V to VIN + 0.6V
LX Voltage----------------------------------------------------------------------------------------- -0.3V (*1) to 6.0V (*2) (*3)
Power Dissipation, PD @ TA = 25°C --------------------------------------------------------------------------------------- 0.95W
Package Thermal Resistance (Note 2)
θ JA --------------------------------------------------------------------------------------------------------------- 105°C/W
θ JC ---------------------------------------------------------------------------------------------------------------- 30°C/W
dF
Recommended Operating Conditions (Note 4)
or
K
IR
IT
Junction Temperature Range ------------------------------------------------------------------------------------- -40°C to 150°C
Lead Temperature (Soldering, 10 sec.) --------------------------------------------------------------------------------- 260°C
Storage Temperature Range ----------------------------------------------------------------------------------- -65°C to 150°C
(*1)
LX Voltage Tested Down to -3V
很抱歉,暂时无法提供与“SY8891EARC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.01200
- 100+0.67540
- 1250+0.56210
- 2500+0.49720
- 5000+0.45210
