SY98110VVC
SY98110VVC
    SILERGY(矽力杰)
    QFN52_7X8MM
    4.5~16V输入,15A输出,降压DC/DC转换器
SY98110VVC 数据手册
Application Note: SY98110 4.5-16V Input, 15A Output, Step Down DC/DC Converter Features   The SY98110 adopts the instant PWM architecture to achieve fast transient responses for high step down applications. The device is also equipped with cycle-bycycle current limit, hiccup over current protection and thermal shutdown protection. yC erg Sil VOUT VIN + Ce Telecom and Networking Systems Servers High power access points Storage systems Cellular base stations .C orp VIN:4.5-16V      Note -- on fi Package Type QFN7×8-52 Applications de nti a Temperature Code Package Code Optional Spec Code lP SY98110 □(□□)□ Typical Applications RO N rep are    Ordering Information Ordering Number SY98110VVC    IR IT  Wide Input Voltage Range: 4.5V to 16V. Capable of 15A Constant Output Current High Output Voltage Accuracy Over Temperature Range Instant PWM Architecture to Achieve Fast Transient Response Pseudo 600kHz, 800kHz and 1000kHz Switching Frequency Selection Reliable Protection Mode:  Auto-recovery Mode for UVP, UVLO, OTP and OVP  Hic-cup Mode for OCP and SCP Start-up with Pre-biased Voltage Adjustable Input Voltage UVLO by EN Pin Adjustable Soft-start Time Limits the Inrush Current Remote Sensing at Point of Load Side Power Good Indicator Compact Package: QFN7×8-52 or K    The SY98110 operates over a wide input voltage range from 4.5V to 16V which is suitable for 12V input voltage application. And it is capable of delivering 15A output current over a wide ambient temperature range. The efficiency is pretty high because it integrates high quality main switch, synchronous switch and inductor inside to minimize the conduction loss. It provides accurate regulation for a variety of loads over all operation temperature range. dF General Description VOUT CIN Cff RH To EN Control EN FB SS SENSEPG COUT Load RL CSS RPG MODE VCC RMODE CVCC GND AGND RGND Figure 1. Schematic Diagram AN_SY98110 Rev.0.9 © 2020 Silergy Corp. Silergy Corp. Confidential-Prepared for Customer Use Only 1 All Rights Reserved. SY98110 27 AGND 28 PG 30 EN 29 AGND 31 FB 32 SENSE- 33 SS 35 NC 34 MODE 37 AGND 36 AGND 39 VOUT 38 VOUT Pinout (top view) VOUT 39 VOUT 40 VOUT 41 VOUT VOUT 42 43 24 VIN 23 VIN VOUT 44 22 VIN VOUT 45 21 VIN 27 AGND IR IT 25 AGND RO N 26 AGND EP1 AGND 20 VIN GND 46 GND 47 19 VIN GND 48 or K EP2 GND 18 VIN 17 GND GND 49 16 GND GND 50 GND 51 dF 15 GND 14 GND GND 1 13 GND 12 GND 13 GND 11 GND 10 GND 9 GND 8 GND 7 GND 6 GND 5 GND 4 VCC 3 NC 2 AGND 1 GND rep are GND 52 33 MODE 34 VOUT 38-45 AN_SY98110 Rev.0.9 © 2020 Silergy Corp. Silergy Corp. Confidential-Prepared for Customer Use Only 2 All Rights Reserved. 3, 35 VCC 4 VIN 18-24 PG 28 EN 30 SENSE- yC erg 31 Sil FB .C NC on fi SS Pin Description Ground pins. Analog ground pins. Only connect pin2 to GND. Refer to layout suggestion for details. Do not connect these pins to AGND, to another pin, or to any other voltage. These pins are connected to internal circuitry. Each pin must be soldered to an isolated pad. Internal 3.3V LDO output. Power supply for internal analog circuits and driving circuit. Decouple this pin to GND with at least a 1μF ceramic capacitor. Input pin. Decouple this pin to the GND pin with at least a 30μF ceramic capacitor. Power good Indicator. Open drain output when the output voltage is within 90% to 120% of regulation point. Enable control. Pull this pin high to turn on the IC. Can be used for setting the on and off threshold (adjust UVLO) with two additional resistors. Do not leave this pin floating. Output feedback pin. Connect this pin (as shown in Figure 1) to program the output voltage. Negative output voltage sensing pin. It can be connected to the load negative terminal to compensate power line voltage drop. If this function is not needed, connect this pin to the closest GND pin. Soft-start programming pin. Connect a capacitor from this pin to ground to program the soft-start time. Leave this pin open for default 1.3ms soft-start. Operation mode selection pin. Program this pin the select FCCM or PFM mode, and the switching frequency. Output pin. Decouple this pin to GND pin with at least 6×22μF ceramic capacitors. AGND Pin Number 1, 5-17, 46-52 2, 25-27, 29, 36-37 orp Pin Name GND de nti a lP (QFN7×8-52) Top Mark: DCRxyz (device code: DCR, x=year code, y=week code, z= lot number code) 32 SY98110 IN VCC Input UVLO VCC UVLO 3.3V LDO Current Sense VCC RO N Bcotstrap Charge EN MODE CBS OVP Current Sense VCC dF UVP FB rep are DIFF SENSE- GND Discharge SoftStart AGND lP SS Vout L or K PWM Control & Protection Logic OTP IR IT PG de nti a Figure2. Block Diagram Absolute Maximum Ratings (Note 1) on fi Supply Input Voltage------------------------------------------------------------------------------------------------- -0.3V to 18V FB, SENSE-, AGND, VCC, PG Voltage-------------------------------------------------------------------------- -0.3V to 4V All Other Pins ------------------------------------------------------------------------------------------------- -0.3V to VIN+0.3V Power Dissipation, PD @ TA = 25°C --------------------------------------------------------------------------------------- 7.6W Package Thermal Resistance (Note 2) .C θ JA ------------------------------------------------------------- -------------------------------------------------13.1°C/W yC orp Lead Temperature (Soldering, 10 sec.) ------------------------------------------------------------------------------------ 260°C Storage Temperature Range -------------------------------------------------------------------------------------- -65°C to 150°C Operation Internal Temperature Range ------------------------------------------------------------------------- -40°C to 150°C Recommended Operating Conditions (Note 3) Sil erg Supply Input Voltage -------------------------------------------------------------------------------------------------- 4.5V to 16V Output Voltage --------------------------------------------------------------------------------------------------- 0.6V to 6.5V Output Current Range--------------------------------------------------------------------------------------------0A to 15A Operating Junction Temp.(T J) ----------------------------------------------------------------------------- -40℃ to +125℃ AN_SY98110 Rev.0.9 © 2020 Silergy Corp. Silergy Corp. Confidential-Prepared for Customer Use Only 3 All Rights Reserved. SY98110 Electrical Characteristics Sil erg yC orp .C on fi de nti a lP rep are dF or K IR IT RO N (VIN = 12V, VOUT =3.3V, IOUT = 15A, COUT = 6×22µF, RMODE=30kΩ, TA = 25°C, FB divider resistor accuracy = 0.5%, unless otherwise specified) Parameter Symbol Test Conditions Min Typ Max Unit Input Specifications Input Voltage Range VIN 4.5 16 V Input UVLO Threshold (rising) VUVLO EN=VIN 4.2 V Input UVLO Threshold VHYS 200 mV Hysteresis IIN, NULL Input Current with No Load VIN=12V, IO=0A 36 60 80 mA IIN, FULL Input Current with Full Load VIN=12V, IO=15A 4.4 4.6 5.5 A ISD Shutdown Current VIN=12V, EN=0 2.5 μA Output Specifications ∆VLNR Line Regulation VIN=5-16V, TA=25°C, IO=15A -1.5 1 % VIN=12V, TA=-40°C to 85°C, Temperature Regulation ∆T -1 2 % IO=7.5A ILIMT Output Current Limit Protection Mode: Hiccup 16 20 24 A From 10% to 90% of output setRise Time tRISE Point, CSS open, start up from 0.6 1 1.4 ms EN VOVP VOUT OVP 110 120 130 %Vo,setpoint VUVP VOUT UVP 45 50 55 %Vo,setpoint tUVP,DLY VOUT UVP Delay Time 20 µs General Specifications RMODE=0Ω,IOUT=0A,FCCM, 480 600 720 kHz VOUT=1V, TJ=25°C RMODE=30.1kΩ,IOUT=0A,FCCM, Switching Frequency fSW 640 800 960 kHz VOUT=1V, TJ=25°C RMODE=60.4kΩ,IOUT=0A,FCCM, 800 1000 1200 kHz VOUT=1V, TJ=25°C Thermal Shutdown TSD OTP Mode: auto recovery 160 °C Temperature Thermal Shutdown Hysteresis THYS 30 °C Min ON Time (Note 4) tON,MIN IOUT=3A 60 ns Min OFF Time (Note 4) tOFF,MIN IOUT=3A 180 ns Control and Indicator Signals EN Input Voltage High VEN,H VIN=12V, IO=0A 1.1 1.2 1.5 V EN Input Voltage Low VEN,L VIN=12V, IO=0A 0.9 1 1.3 V VEN,HYS EN Hysteresis 0.2 V VFB falling, PG high to low 77 80 84 %VREF VFB rising, PG low to high 89.5 92.5 96.5 %VREF Power Good Threshold VPG VFB rising, PG high to low 110 120 130 %VREF VFB falling, PG low to high 102 105 108 %VREF Power Good Asserts Delay tPG 0.8 ms (Note 4) Power Good Sink Current IPG,SINK VPG=0.4V 10 mA Capability IPG, LKG Power Good Leakage Current VPG=3.3V 3 5 μA VCC VCC Voltage IVCC=0mA 3.18 3.3 3.42 V VREF -40°C 0.4V), or thermal shutdown, so that the output voltage can be discharged in a minimal time, even when the load current is zero. The discharge FET in parallel with the low-side synchronous rectifier turns on after the low-side synchronous rectifier turns off when shut down logic is triggered. When operating in FCCM light load mode, if the output voltage remains higher than the OVP level, the lower-side MOSFETS keeps on until the reverse current limit (~-13A) is triggered to discharge the output voltage. lP It is not recommended to connect EN and VIN directly. A 10kΩ resistor should be used if EN is pulled high by VIN. RO N Enable Control The EN input is a high-voltage capable input with logic-compatible threshold. The comparator design scheme makes the EN rising threshold accurate comparatively. When EN voltage rises to ~0.8V, VCC works so that the EN comparator has source supply. When EN is driven above 1.23V normal device operation will be enabled, and the switching node pulse appear. When EN voltage falls lower than EN rising threshold for one hysteresis, the switching node pulse is inhibited. When EN voltage is driven < 0.4V the VCC will be shut down, reducing input current to < 5μA (Normal temperature). Over Temperature Protection (OTP) The module includes OTP circuitry to prevent overheating due to excessive power dissipation. This will shut down the device when the die temperature exceeds 160°C. Once the die temperature cools down by approximately 30°C, the device will resume normal operation. For continuous operation, provide adequate cooling so that the die temperature does not exceed the OTP threshold. Pre-bias Startup If the output is pre-biased to a certain voltage before start-up, the device disables the switching of both the high-side power switch and the low-side synchronous rectifier until the voltage on the internal soft start SS pin voltage exceeds the sensed output voltage at the FB node. Before the switching node pulse occurs, the switching node voltage is sampled to internal ontime generator circuit to generate the first on-time, so that the first on-time will match the current pre-bias output voltage. Silergy Corp. Confidential-Prepared for Customer Use Only 11 All Rights Reserved. SY98110 Capacitance 6×22μF Vendor murata 2) CIN must be close to the VIN and GND pins. The loop area formed by CIN and GND must be minimized. IR IT COUT Layout Design For the minimum noise consideration, following components should be close to the IC: CIN and COUT. 1) It is desirable to maximize the PCB copper area connecting to the GND pin to achieve the best thermal and noise performance. If the board space allowed, a ground plane is highly desirable. RO N Output Capacitor COUT The output capacitor is selected to reduce the output ripple noise. Both steady state ripple and transient requirements must be taken into consideration when selecting this capacitor. For the best performance, it is recommended to use an X7R or better grade ceramic capacitor with 16V rating and greater than 132μF capacitance. Place this ceramic capacitor really close to the OUT and GND pins to minimize the loop area formed by COUT, and the OUT/GND pins. 3) It’s recommended to connect AGND and GND at a single point, close to the corresponding capacitors. Please refer to the detail in the following layout demonstration. PN GRM31CC71C226ME11L dF or K If the output capacitance is larger than 800μF (ceramic) or other type of capacitor (polymer , tantalum…) is used, please contact Silergy supporting team to get more assessment. VIN + CIN3 CIN2 CIN4 R3 To EN Control EN FB SS SENSEPG C3 COUT1 COUT2 COUT3 COUT4 COUT5 COUT6 Load lP CIN1 VOUT rep are VOUT VIN:4.5-16V C2 de nti a R4 R1 MODE R2 C1 AGND on fi GND VCC Sil erg yC orp .C R5 Figure3. PCB Layout Suggestion AN_SY98110 Rev.0.9 © 2020 Silergy Corp. Silergy Corp. Confidential-Prepared for Customer Use Only 12 All Rights Reserved. SY98110 R4 RO N Murata Murata Murata Murata Murata Murata Murata Murata Murata Murata GRM1885C1H472JA01D Murata fsw:600kHz VOUT=0.6V VOUT=1.2V VOUT=1.8V VOUT=3.3V VOUT=5V Sil erg yC orp .C on fi de nti a lP R5 GGM31CC71E106KA03# GGM31CC71E106KA03# GGM31CC71E106KA03# GRM31CC71C226ME11L GRM31CC71C226ME11L GRM31CC71C226ME11L GRM31CC71C226ME11L GRM31CC71C226ME11L GRM31CC71C226ME11L GGM188R71C105MA64# Note IR IT CIN2 CIN3 CIN4 COUT1 COUT2 COUT3 COUT4 COUT5 COUT6 C1 C2 C3 R1 R2 R3 Manufacturer or K CIN1 Part Number dF Description 100µF/25V Electrolytic Capacitor 10µF,25V,X7R,1206 10µF,25V,X7R,1206 10µF,25V,X7R,1206 22µF, 16V, X7S, 1206 22µF, 16V, X7S, 1206 22µF, 16V, X7S, 1206 22µF, 16V, X7S, 1206 22µF, 16V, X7S, 1206 22µF, 16V, X7S, 1206 1µF, 6.3V, 0603 NA 4.7nF, 50V, C0G, 0603 100kΩ, 0603 0Ω, 0603 2kΩ, 0603 5MΩ, 0603 2kΩ, 0603 1kΩ, 0603 0.442kΩ, 0603 0.274kΩ, 0603 0Ω, 0603 rep are Reference Designator AN_SY98110 Rev.0.9 © 2020 Silergy Corp. Silergy Corp. Confidential-Prepared for Customer Use Only 13 All Rights Reserved. SY98110 rep are dF or K IR IT RO N QFN7×8-52 Package Outline Drawing Bottom View erg yC orp .C on fi de nti a lP Top View Sil Front View Recommended PCB layout (Reference only) Notes: 1, All dimension in millimeter and exclude mold flash & metal burr; 2, center line refers chip body center AN_SY98110 Rev.0.9 © 2020 Silergy Corp. Silergy Corp. Confidential-Prepared for Customer Use Only 14 All Rights Reserved. SY98110 Taping & Reel Specification 1. Taping Orientation Feeding Direction rep are dF or K IR IT RO N QFN8.0×7.0 on fi de nti a lP 2. Carrier Tape & Reel specification for packages Sil erg yC orp .C Reel Size Package types Tape width (mm) Pocket pitch(mm) QFN8.0×7.0 16 12 AN_SY98110 Rev.0.9 © 2020 Silergy Corp. Reel size Trailer * (Inch) length(mm) 13" 600 Leader * length (mm) Qty per reel (pcs) 600 800 Silergy Corp. Confidential-Prepared for Customer Use Only 15 All Rights Reserved. SY98110 IMPORTANT NOTICE RO N 1. Right to make changes. Silergy and its subsidiaries (hereafter Silergy) reserve the right to change any information published in this document, including but not limited to circuitry, specification and/or product design, manufacturing or descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Buyers should obtain the latest relevant information before placing orders and should verify that such information is current and complete. All semiconductor products are sold subject to Silergy’s standard terms and conditions of sale. rep are dF or K IR IT 2. Applications. Application examples that are described herein for any of these products are for illustrative purposes only. Silergy makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Buyers are responsible for the design and operation of their applications and products using Silergy products. Silergy or its subsidiaries assume no liability for any application assistance or designs of customer products. It is customer’s sole responsibility to determine whether the Silergy product is suitable and fit for the customer’s applications and products planned. To minimize the risks associated with customer’s products and applications, customer should provide adequate design and operating safeguards. Customer represents and agrees that it has all the necessary expertise to create and implement safeguards which anticipate dangerous consequences of failures, monitor failures and their consequences, lessen the likelihood of failures that might cause harm and take appropriate remedial actions. Silergy assumes no liability related to any default, damage, costs or problem in the customer’s applications or products, or the application or use by customer’s third-party buyers. Customer will fully indemnify Silergy, its subsidiaries, and their representatives against any damages arising out of the use of any Silergy components in safety-critical applications. It is also buyers’ sole responsibility to warrant and guarantee that any intellectual property rights of a third party are not infringed upon when integrating Silergy products into any application. Silergy assumes no responsibility for any said applications or for any use of any circuitry other than circuitry entirely embodied in a Silergy product. de nti a lP 3. Limited warranty and liability. Information furnished by Silergy in this document is believed to be accurate and reliable. However, Silergy makes no representation or warranty, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Silergy be liable for any indirect, incidental, punitive, special or consequential damages, including but not limited to lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges, whether or not such damages are based on tort or negligence, warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Silergy’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Standard Terms and Conditions of Sale of Silergy. orp .C on fi 4. Suitability for use. Customer acknowledges and agrees that it is solely responsible for compliance with all legal, regulatory and safety-related requirements concerning its products, and any use of Silergy components in its applications, notwithstanding any applications-related information or support that may be provided by Silergy. Silergy products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Silergy product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Silergy assumes no liability for inclusion and/or use of Silergy products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. erg yC 5. Terms and conditions of commercial sale. Silergy products are sold subject to the standard terms and conditions of commercial sale, as published at http://www.silergy.com/stdterms, unless otherwise agreed in a valid written individual agreement specifically agreed to in writing by an authorized officer of Silergy. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Silergy hereby expressly objects to and denies the application of any customer’s general terms and conditions with regard to the purchase of Silergy products by the customer. Sil 6. No offer to sell or license. Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Silergy makes no representation or warranty that any license, either express or implied, is granted under any patent right, copyright, mask work right, or other intellectual property right. Information published by Silergy regarding third-party products or services does not constitute a license to use such products or services or a warranty or endorsement thereof. Use of such information may require a license from a third party under the patents or other intellectual property of the third party, or a license from Silergy under the patents or other intellectual property of Silergy. For more information, please visit: www.silergy.com © 2020 Silergy Corp. AN_SY98110 Rev.0.9 © 2020 Silergy Corp. Powered by TCPDF (www.tcpdf.org) All Rights Reserved. Silergy Corp. Confidential-Prepared for Customer Use Only 16 All Rights Reserved.
SY98110VVC 价格&库存
很抱歉,暂时无法提供与“SY98110VVC”相匹配的价格&库存,您可以联系我们找货
