SQ52201FBC
SQ52201FBC
    SILERGY(矽力杰)
    MSOP10
    具有可编程报警功能的36V高精度电流/功率监测器
SQ52201FBC 数据手册
Application Note: SQ52201 36V High-accuracy Current/Power Monitor With Programmable Alert Function General Description Features The SQ52201 is a high accuracy current shunt, bus voltage and power monitor with an I2C or SMBUScompatible interface.      The shunt voltage drop and the bus supply voltage are both sampled accurately in the device. The sampled data are processed inside the device to generate the power data with programmable calibration, averaging technique and internal multiplier. Programmable alert function provides abundant alert sources settings and makes the application system more reliable.       The SQ52201 senses current on common mode bus voltages that can vary from 0V to 36V, independent of the supply voltage. The device operates from a single 2.7V to 5.5V supply. The SQ52201 is specified over the operating temperature range between –40°C and +125°C and features up to 16 programmable addresses on the I2C-compatible interface. Applications        The SQ52201 is available in the MSOP-10 package. Ordering Information SQ52201 □(□□)□ Temperature Code Package Code Optional Spec Code Ordering Number SQ52201FBC Package type MSOP10 Senses Bus Voltages from 0 V to 36 V High-Side or Low-Side Sensing Bi-directional Current Sensing Reports Current, Voltage, and Power High Accuracy:  0.02% Gain Error (Typ) for Shunt Voltage 0.02% Gain Error (Typ) for Bus Voltage  2.5μV Offset (Typ) for Shunt Voltage  1.25mV Offset (Typ) for Bus Voltage Configurable Averaging Options Configurable Conversion Time Abundant Alert Sources Setting 16 Programmable Addresses High Speed I2C Mode Compatible Operates from 2.7V to 5.5V Power Supply Servers Telecom Equipment Computing Power Management Battery Chargers Power Supplies Test Equipment Note -- Typical Application 2.7 ~ 5.5V Power Supply 0 ~ 36V VBUS VS High-side shunt SDA LOAD IN+ SCL IN- MCU Alert A0 GND A1 Figure 1. Typical Application AN_SQ52201 Rev. 0.9 © 2021 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 1 All Rights Reserved. AN_SQ52201 Pin out (Top View) Top Mark: A1 1 10 IN+ A0 2 9 IN- Alert 3 8 VBUS SDA 4 7 GND SCL 5 6 VS (MSOP10) CXExyz, (Device code: CXE, x=year code, y=week code, z= lot number code) Pin No. 1 2 3 4 5 6 7 8 Pin Name A1 A0 Alert SDA SCL VS GND VBUS 9 IN– 10 IN+ Pin Description Address pin. Connect to GND, SCL, SDA, or VS. Address pin. Connect to GND, SCL, SDA, or VS. Multi-functional alert, open-drain output. Serial bus data line, open-drain input/output. Serial bus clock line, open-drain input. Power supply, 2.7 V to 5.5 V. Ground. Bus voltage input. Negative differential voltage input. Connect to load side of shunt resistor. Positive differential voltage input. Connect to supply side of shunt resistor. Block Diagram 2.7 ~ 5.5V Power Supply 0 ~ 36V VS VBUS High-side shunt V Current Register LOAD SDA Power Register IN+ ADC Voltage Register INLow-side shunt I SCL I2C or SMBus Compatible Interface Alert A0 A1 Alert Register GND Figure 2. Block Diagram AN_SQ52201 Rev. 0.9 © 2021 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 2 All Rights Reserved. AN_SQ52201 Absolute Maximum Ratings (Note 1) VS ----------------------------------------------------------------------------------------------------------------------- -0.3V to 6V Differential Analog input (VIN+ – VIN-) -------------------------------------------------------------------------- -40V to +40V Common Mode Analog input (VIN+ + VIN-) / 2 ------------------------------------------------------------------ -0.3V to 40V VBUS------------------------------------------------------------------------------------------------------------------ -0.3V to 40V VSDA --------------------------------------------------------------------------------------------------------------------- -0.3V to 6V VSCL ------------------------------------------------------------------------------------------------------------- -0.3V to VS+0.3V Input current into any pin ------------------------------------------------------------------------------------------------------ 5mA Open-drain digital output current-------------------------------------------------------------------------------------------- 10mA Power Dissipation, PD @ TA = 25°C--------------------------------------------------------------------------------------- 0.74W Package Thermal Resistance (Note 2) θ JA ------------------------------------------------------------------------------------------------------------- 136°C/W θ JC --------------------------------------------------------------------------------------------------------------- 25°C/W Junction Temperature Range------------------------------------------------------------------------------------------------- 150°C Storage Temperature Range ------------------------------------------------------------------------------------- -65°C to 150°C ESD Susceptibility HBM (Human Body Mode) ---------------------------------------------------------------------------------------------------- 2kV CDM ------------------------------------------------------------------------------------------------------------------------------- 1kV Recommended Operating Conditions VS --------------------------------------------------------------------------------------------------------------------------------- 3.3V Common Mode Analog input (VIN+ + VIN-) / 2 ------------------------------------------------------------------------------ 12V Operation Temperature Range----------------------------------------------------------------------------------- -40°C to 125°C AN_SQ52201 Rev. 0.9 © 2021 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 3 All Rights Reserved. AN_SQ52201 Electrical Characteristics VS = 3.3V, VIN+ = 12V, VSENSE = (VIN+ – VIN–) = 0mV and VVBUS = 12V, TA = 25°C unless otherwise specified Parameter Input Symbol Conditions Shunt Voltage Input Range Bus Voltage Input Range (Note 3) Common-Mode Rejection Shunt Offset Voltage, RTI (Note 4) Shunt Offset Voltage, RTI vs. Temperature (Note 4) Shunt Offset Voltage, RTI vs. Power Supply (Note 4) Bus Offset Voltage, RTI (Note 4) Bus Offset Voltage, RTI vs. Temperature (Note 4) Bus Offset Voltage, RTI vs. Power Supply (Note 4) Input Bias Current (IIN+, IIN) VBUS Input Impedance CMRR 0V≤VIN+≤36V +81.91 75 mV 0 36 V 140 dB –40°C≤TA≤125°C 0.02 0.1 μV/°C 2.7V≤VS≤5.5V 2.5 –40°C≤TA≤125°C μV/V ±1.25 ±7.5 mV 10 40 μV/°C PSRR 0.5 mV/V IB 7 830 μA kΩ 1 LSB Step Size Shunt Voltage Gain Error Shunt Voltage Gain Error vs. Temperature Bus Voltage Gain Error Bus Voltage Gain Error vs. Temperature Differential Nonlinearity (IN+ pin) + (IN– pin), Power-down mode 0.1 Shunt voltage Bus voltage –40°C≤TA≤125°C –40°C≤TA≤125°C tCT CT bit = 000 CT bit = 001 CT bit = 010 CT bit = 011 CT bit = 100 CT bit = 101 CT bit = 110 CT bit = 111 SMBus Smbus Timeout (Note 6) Digital Input/Output Input Capacitance AN_SQ52201 Rev. 0.9 © 2021 Silergy Corp. -81.92 μV DC Accuracy ADC Native Resolution Leakage Input Current Units ±10 VOS Input Leakage (Note 5) ADC Conversion Time Max 126 Typ ±2.5 VOS PSRR Min 0.5 μA 16 2.5 1.25 0.02 0.15 Bits μV mV % 10 50 ppm/°C 0.02 0.2 % 10 50 ppm/°C ±0.1 140 204 332 588 1.1 2.116 4.156 8.244 165 232 366 633 1.165 2.224 4.349 8.608 28 35 LSB 3 0V≤VSCL≤VS, 0V≤VSDA≤VS, 0V≤VAlert≤VS, 0V≤VA0≤VS, 0V≤VA1≤VS 0.1 μs ms ms pF 1 μA Silergy Corp. Confidential- Prepared for Customer Use Only 4 All Rights Reserved. AN_SQ52201 High Level Input Voltage Low Level Input Voltage Low Level Output Voltage, SDA, Alert Hysteresis Power Supply Operating Supply Range VIH VIL VOL IOL=3mA 0.7×VS -0.5 6 0.3×VS V V 0 0.4 V 400 2.7 Quiescent Current IQ Power-on Reset Threshold VPOR Power down (shutdown) mode mV 396 5.5 460 0.5 1 2 V μA V Note 1: Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to any Absolute Maximum Rating condition for extended periods may affect device reliability and lifetime. Note 2: θ JA is measured on silergy two layers PCB under natural convection. θ JC top is measured in accordance with JESD51-14 Note 3: While the input range is 36 V, the full-scale range of the ADC scaling is 40.96 V. Do not apply more than 36 V. Note 4: RTI = Referred-to-input. Note 5: Input leakage is positive (current flowing into the pin) for the conditions shown at the top of this table. Negative leakage currents can occur under different input conditions. Note 6: SMBus timeout in the SQ52201 resets the interface any time SCL is low for more than 28ms. AN_SQ52201 Rev. 0.9 © 2021 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 5 All Rights Reserved. AN_SQ52201 Detailed Description Bus Voltage and Current Sample The SQ52201 provides two direct measurements on the power supply bus of interest: shunt voltage and bus voltage. The shunt voltage, which indicates the current, is measured at the IN+ and IN– pins; the power supply bus voltage is measured by the VBUS pin. The differential shunt voltage is measured with respect to the IN– pin while the bus voltage is measured with respect to ground. Operation Mode The device has two operating modes for data conversion: continuous and triggered, that determine how the ADC operates following these conversions. Continuous Operating Mode: When the MODE bits of the Configuration Register (00h) are set to '111', SQ52201 is in the continuous operating mode. At first, the number of averages should be set in the Configuration Register. In each sampling sequence, the shunt voltage is sampled and converted first and followed by the bus voltage. After the shunt voltage is sampled, the current value is calculated. This current value is then used to calculate the power result. These values are subsequently stored in an accumulator, and the measurement/calculation sequence repeats until the number of averages set in the Configuration Register is reached. Following every sequence, the present set of values measured and calculated is appended to previously collected values. After all of the averaging has been completed, the final values for shunt voltage, bus voltage, current, and power are updated in the corresponding registers that can then be read. These values remain in the data output registers until they are replaced by the next fully completed conversion results. Reading the data output registers does not affect a conversion in progress. All the calculations are performed in the background and do not contribute to conversion time. The mode control in the Conversion Register (00h) also permits selecting modes to convert only the shunt voltage or the bus voltage in order to further allow the user to configure the monitoring function to fit the specific application requirements Triggered Operating Mode: When the MODE bits of the Configuration Register (00h) are set to ‘001’, ‘010’, or ‘011’, SQ52201 is in triggered mode. Writing any of the triggered convert modes into the Configuration Register triggers a single-shot conversion. This action produces a single set of measurements; thus, to trigger another singleshot conversion, the Configuration Register must be AN_SQ52201 Rev. 0.9 © 2021 Silergy Corp. written to a second time, even if the mode does not change. Power-Down Mode: In addition, the SQ52201 also has a power-down mode that reduces the quiescent current and turns off current into the device inputs, reducing the impact of supply drain when the device is not being used. Full recovery from power-down mode requires 40μs. The registers of the device can be written to and read from while the device is in power-down mode. The device remains in power-down mode until one of the active modes settings are written into the Configuration Register. Conversion Ready Flag Although the SQ52201 can be read at any time, and the data from the last conversion remain available, the Conversion Ready flag bit (Mask/Enable Register, CVRF bit) is provided to help coordinate one-shot or triggered conversions. The Conversion Ready flag (CVRF) bit is set after all conversions, averaging, and multiplication operations are complete. The Conversion Ready flag (CVRF) bit clears under these conditions: • Writing to the Configuration Register (00h) , except when configuring the MODE bits for power-down mode. • Reading the Mask/Enable Register (06h) Averaging and Conversion Time The conversion times (tCT) for both the shunt voltage and bus voltage measurements can be configured in the device. The conversion times can be selected from as fast as 140μs to as long as 8.244ms. The device could also be configured with a different conversion time setting for the shunt and bus voltage measurements. This type of approach is common in applications where the bus voltage tends to be relatively stable. This situation can allow for the time focused on the bus voltage measurement to be reduced relative to the shunt voltage measurement. There are trade-offs associated with the settings for conversion time and the averaging mode used. The averaging feature can significantly improve the measurement accuracy by effectively filtering the signal. This approach allows the device to reduce any noise in the measurement that may be caused by noise coupling into the signal. A greater number of averages enables the device to be more effective in reducing the noise component of the measurement. The conversion times selected can also have an impact on the measurement accuracy. In order to Silergy Corp. Confidential- Prepared for Customer Use Only 6 All Rights Reserved. AN_SQ52201 achieve the highest accuracy measurement possible, use a combination of the longest allowable conversion times and highest number of averages based on the timing requirements of the system. no value loaded in the Calibration Register, the power value stored is also zero. Again, these calculations are performed in the background and do not add to the overall conversion time. These current and power values are considered intermediate results (unless the averaging is set to 1) and are stored in an internal accumulation register, not the corresponding output registers. Following every measured sample, the newly-calculated values for current and power are appended to this accumulation register until all of the samples have been measured and averaged based on the number of averages set in the Configuration Register (00h). Power Calculation The Current and Power are calculated following shunt voltage and bus voltage measurements as shown in Figure 3. Current is calculated following a shunt voltage measurement based on the value set in the Calibration Register. If there is no value loaded into the Calibration Register, the current value stored is zero. Power is calculated following the bus voltage measurement based on the previous current calculation and bus voltage measurement. If there is Current Limit Detect Following Every Shunt Voltage Conversion I Bus and Power Limit Detect Following Every Bus Voltage Conversion V I V I V I V I V I V I V I V I V I V I V I V I V I V I V I P P P P P P P P P P P P P P P V P Power Average Bus Voltage Average Shunt Voltage Average Figure 3. Power Calculation Scheme In addition, the shunt and bus voltage measurements The Alert pin is an open-drain output. This pin is are also collected. After all of the samples have been asserted when the alert function selected in the measured and the corresponding current and power Mask/Enable Register exceeds the value programmed calculations have been made, the accumulated into the Alert Limit Register. Only one of these alert average for each of these parameters is then loaded to functions can be enabled and monitored at a time. If the corresponding output registers, where they can multiple alert functions are enabled, the selected then be read. function in the highest significant bit position takes priority. For example, if the Shunt Voltage OverAlert Pin Limit function and the Shunt Voltage Under-Limit The SQ52201 has a single Alert Limit Register (07h), function are both enabled, the Alert pin asserts when which allows the Alert pin to be programmed to the Shunt Voltage Register exceeds the value in the respond to a single user-defined event or to a Alert Limit Register. Conversion Ready notification if desired. The The Conversion Ready state of the device can also be Mask/Enable Register allows the user to select from monitored at the Alert pin to inform the user when one of the five available functions to monitor and/or SQ52201 has completed the previous conversion and set the Conversion Ready bit to control the response is ready to begin a new conversion. Conversion of the Alert pin. Based on the function being Ready can be monitored at the Alert pin along with monitored, the user would then enter a value into the one of the alert functions. If an alert function and the Alert Limit Register to set the corresponding Conversion Ready are both enabled to be monitored threshold value that asserts the Alert pin at the Alert pin, after the Alert pin is asserted, the The Alert pin allows one of five alert functions that Mask/Enable Register must be read following the can be monitored: alert to determine the source of the alert. By reading the Conversion Ready Flag (CVRF, bit 3), and the • Shunt Voltage Over-Limit (SOL) Alert Function Flag (AFF, bit 4) in the Mask/Enable • Shunt Voltage Under-Limit (SUL) Register, the source of the alert can be determined. If • Bus Voltage Over-Limit (BOL) the Conversion Ready feature is not desired and the CNVR bit is not set, the Alert pin only responds to an • Bus Voltage Under-Limit (BUL) exceeded alert limit based on the alert function • Power Over-Limit (POL) enabled. AN_SQ52201 Rev. 0.9 © 2021 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 7 All Rights Reserved. AN_SQ52201 Figure 3 shows when the value in the Alert Limit Register is compared to the corresponding converted value. The Shunt Voltage alert functions compare the measured shunt voltage to the Alert Limit Register following every shunt voltage conversion and assert the AFF bit and Alert pin if the limit threshold is exceeded. The Bus Voltage alert functions compare the measured bus voltage to the Alert Limit Register following every bus voltage conversion and assert the AFF bit and Alert pin if the limit threshold is exceeded. The Power Over-Limit alert function is also compared to the calculated power value following every bus voltage measurement conversion and asserts the AFF bit and Alert pin if the limit threshold is exceeded. For example, if the alert function that is enabled is Shunt Voltage Over-Limit (SOL), following every shunt voltage conversion the value in the Alert Limit Register is compared to the measured shunt voltage to determine if the measurement has exceeded the programmed limit. The AFF, bit 4 of the Mask/Enable Register, asserts high any time the measured voltage exceeds the value programmed into the Alert Limit Register. In addition to the AFF being asserted, the Alert pin is asserted based on the Alert Polarity Bit (APOL, bit 1 of the Mask/Enable Register). If the Alert Latch is enabled, the AFF and Alert pin remain asserted until either the Configuration Register (00h) is written to or the Mask/Enable Register is read. If the alert function is not used, the Alert pin can be left floating without impacting the operation of the device. Configuration for the Readouts In order to report the current and power values properly, several registers should be configured as the steps followed. Step1: select the resolution of the Current Register (04h): Current_LSB. The highest resolution for the Current Register (04h) can be obtained by using the smallest allowable Current_LSB based on the maximum expected current IMAX as shown in Equation (1). While this value yields the highest resolution, it is common to select a value for the Current_LSB to the nearest round number above this value to simplify the conversion of the Current Register (04h) and Power Register (03h) to amperes and watts respectively. Current _ LSB  IMAX 215 (1) Where Current_LSB is the resolution of the Current Register (04h); IMAX is the maximum expected current. In addition, the value of the shunt resistor is selected based on the shunt voltage measurement range and IMAX. Step2: configure the Calibration Register (05h) The Calibration Register enables the user to scale the Current Register (04h) and Power Register (03h) to the most useful value for a given application. With correct configuration of the Calibration Register (05h), the real current can read out by simply multiply the Current Register and Current_LSB. The value of the Calibration Register (05h) is named as CAL[R], which should be configured as the Equation (2) below: CAL[R ]  2048  Shunt _ LSB (2) Current _ LSB  R Shunt Where CAL[R] is the value of the Calibration Register (05h); Shunt_LSB is the resolution of the Shunt Voltage Register (01h), Shunt_LSB is 2.5uV/LSB; Current_LSB is the resolution of the Current Register (04h); RShunt is the shunt resistor. After programming the Calibration Register, the Current Register (04h) and Power Register (03h) update accordingly based on the corresponding shunt voltage and bus voltage measurements. Until the Calibration Register is programmed, the Current Register (04h) and Power Register (03h) remain at zero. Step3: readouts of the current With the sample operation of the device, the value of the Shunt Register is shown as the equation (3) Shunt[R ]  Current  R Shunt (3) Shunt _ LSB In the device, the Current Register value is calculated based on the value of the Shunt Voltage Register (01h) and the Calibration Register(05h). Current[R ]  Shunt[R ]  CAL[R ] (4) 2048 Where Current[R] is the value of the Current Register (04h); Shunt[R] is the value of the Shunt Register (01h); CAL[R] is the value of the Calibration Register (05h) Then the user can read out the real current by the equation (5) Current  Current[R ]  Current _ LSB (5) AN_SQ52201 Rev. 0.9 © 2021 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 8 All Rights Reserved. AN_SQ52201 Step5: readout of the bus voltage As the calculation equation (1)~(7), the resolution of the Power Register is fixed as 25 times of the resolution of the Current Register. The real power is read as the equation (8) The bus voltage is read by the equation (6) Bus  Bus[R]  Bus _ LSB (6) Where Bus_LSB is the resolution of the Bus Voltage Register(02h), which is a fixed 1.25mV/LSB. Step6: readout of the power The value of the Power Register (03h) is calculated based on the equation (7) Power[R ]  Current[R ]  Bus[R ] (7) 20000 Where Current[R] is the value of the Current Register (04h); Bus[R] is the value of the Bus Voltage Register (02h); Power[R] is the value of the Power Register(03h). Power  Power[R ]  Power _ LSB (8) Configuration Example The following figure shows a nominal 10A load that creates a differential voltage of 20mV across 2mΩ shunt resistor. The bus voltage for The SQ52201 is measured at the external VBUS input pin, which in this example is connected to the IN– pin to measure the voltage level delivered to the load. For this example, the VBUS pin measures less than 12 V because the voltage at the IN– pin is 11.98 V as a result of the voltage drop across the shunt resistor. 3.3V Power Supply +12V VS VBUS SDA Power Register 2mΩ SCL V Current Register 10A LOAD IN+ ADC Voltage Register IN- I I2C or SMBus Compatible Interface Alert A0 A1 Alert Register GND Figure 4. High-Side Sensing Circuit Application Example For this example, assuming a maximum expected The LSB for the Bus Voltage Register (02h) is a current of 15 A, the Current_LSB is calculated to be fixed 1.25mV/bit, which means that the 11.98V 457.7μA/bit using Equation (1). Using a value for the present at the VBUS pin results in a register value of Current_LSB of 500μA/Bit or 1mA/Bit would 2570h, or a decimal equivalent of 9584. Note that the significantly simplify the conversion from the MSB of the Bus Voltage Register (02h) is always Current Register (04h) and Power Register (03h) to zero because the VBUS pin is only able to measure amperes and watts. For this example, a value of positive voltages. 1mA/bit was chosen for the Current_LSB. Using this The Power Register (03h) is then be calculated by value for the Current_LSB does trade a small amount multiplying the decimal value of the Current Register, of resolution for having a simpler conversion process 10000, by the decimal value of the Bus Voltage on the user side. Using Equation (2) in this example Register (02h), 9584, and then dividing by 20,000, as with a Current_LSB value of 1mA/bit and a shunt defined in Equation (7). For this example, the result resistor of 2mΩ results in a Calibration Register for the Power Register (03h) is 12B8h, or a decimal value of 2560 or A00h. equivalent of 4792. Multiplying this result by the The Current Register (04h) is then calculated by multiplying the decimal value of the Shunt Voltage Register (01h) contents by the decimal value of the Calibration Register and then dividing by 2048, as shown in Equation (4). For this example, the Shunt Voltage Register contains a value of 8,000 (representing 20mV), which is multiplied by the Calibration Register value of 2560 and then divided by 2048 to yield a decimal value for the Current Register (04h) of 10000, or 2710h. Multiplying this value by 1mA/bit results in the original 10A level stated in the example. AN_SQ52201 Rev. 0.9 © 2021 Silergy Corp. power LSB (25 times Current_LSB]) results in a power calculation of (4792 × 25mW/bit), or 119.82 W. The power LSB has a fixed ratio to the Current_LSB of 25. For this example, 1mA/bit Current_LSB results in a power LSB of 25mW/bit. This ratio is internally programmed to ensure that the scaling of the power calculation is within an acceptable range. A manual calculation for the power being delivered to the load would use a bus voltage of 11.98 V multiplied by the load current of 10 A to give a result of 119.8 W. Silergy Corp. Confidential- Prepared for Customer Use Only 9 All Rights Reserved. AN_SQ52201 The following table lists the results of configuring, measuring, and calculating the values for current and power for The SQ52201. when Load = 10 A, VCM=12V, RSHUNT=2mΩ, and VVBUS=12V. Table 1. Calculating Current and Power REGISTER NAME ADDRESS CONTENTS DEC LSB VALUE Configuration Register 00h 4127h Shunt Register 01h 1F40h 8000 2.5μV 20mV Bus Voltage Register 02h 2570h 9584 1.25mV 11.98V Calibration Register 05h 0A00h 2560 Current Register 04h 2710h 10000 1mA 10A Power Register 03h 12B8h 4792 25mW 119.82W Simple Monitor Usage The device can be used without any programming if it is only necessary to read a shunt voltage drop and bus voltage with the default power-on reset configuration and continuous conversion of shunt and bus voltages. Without programming the device Calibration Register, the device is unable to provide either a valid current or power value, because these outputs are both derived using the values loaded into the Calibration Register. Basic I2C/SMBus Overview The SQ52201 offers compatibility with both I2C and SMBus interfaces. The I2C and SMBus protocols are essentially compatible with one another. The I2C interface is used throughout this data sheet as the primary example, with SMBus protocol specified only when a difference between the two systems is discussed. Two lines, SCL and SDA, connect the device to the bus. Both SCL and SDA are open-drain connections. The device that initiates a data transfer is called a master, and the devices controlled by the master are slaves. The bus must be controlled by a master device that generates the serial clock (SCL), controls the bus access, and generates START and STOP conditions. To address a specific device, the master initiates a start condition by pulling the data signal line (SDA) from a high to a low logic level while SCL is high. All slaves on the bus shift in the slave address byte on the rising edge of SCL, with the last bit indicating whether a read or write operation is intended. During the ninth clock pulse, the slave being addressed responds to the master by generating an Acknowledge and pulling SDA low. Data transfer is then initiated and eight bits of data are sent, followed by an Acknowledge bit. Register bytes are sent most significant byte first, followed by the least significant byte. During data transfer, SDA must remain stable while SCL is high. Any change in SDA while SCL is high is interpreted as a start or stop condition. After all data have been transferred, the master generates a stop condition, indicated by pulling SDA from low to high while SCL is high. The device includes a 28 ms timeout on its interface to prevent locking up the bus. The SQ52201 supports the transmission protocol for fast mode (1kHz to 400kHz) and high-speed mode (1kHz to 3.4MHz). All data bytes are transmitted most significant byte first. Serial Bus Address To communicate with SQ52201, the master must first address slave devices via a slave address byte. The slave address byte consists of seven address bits and a direction bit that indicates whether the action is to be a read or write operation. The device has two address pins, A0 and A1. The following table lists the pin logic levels for each of the 16 possible addresses. The device samples the state of pins A0 and A1 on every bus communication. Establish the pin states before any activity on the interface occurs. Table 2. Address Pins and Slave Addresses A1 GND GND GND GND AN_SQ52201 Rev. 0.9 © 2021 Silergy Corp. A0 GND VS SDA SCL SLAVE ADDRESS 1000000 1000001 1000010 1000011 Silergy Corp. Confidential- Prepared for Customer Use Only 10 All Rights Reserved. AN_SQ52201 VS VS VS VS SDA SDA SDA SDA SCL SCL SCL SCL GND VS SDA SCL GND VS SDA SCL GND VS SDA SCL 1000100 1000101 1000110 1000111 1001000 1001001 1001010 1001011 1001100 1001101 1001110 1001111 Writing Command Accessing a specific register on SQ52201 is accomplished by writing the appropriate value to the register pointer. The value for the register pointer is the first byte transferred after the slave address byte with the R/W bit low. Every write operation to the device requires a value for the register pointer. Writing to a register begins with the first byte transmitted by the master. This byte is the slave address, with the R/W bit low. The device then acknowledges receipt of a valid address. The next byte transmitted by the master is the address of the register which data is written to. This register address value updates the register pointer to the desired register. The next two bytes are written to the register addressed by the register pointer. The device acknowledges receipt of each data byte. The master may terminate data transfer by generating a start or stop condition. 1 9 9 1 1 9 1 9 SCL SDA 1 0 0 A3 A2 A1 A0 W Start by Master P7 P6 P5 P4 P3 P2 P1 P0 ACK by Slaver Frame 1 2-wire slave address byte D15 D14 D13 D12 D11 D10 D9 D8 ACK by Slaver D7 D6 D5 D4 D3 D2 D1 D0 ACK by Stop by Slaver Master ACK by Slaver Frame 2 Register pointer byte Frame 3 Data MSByte Frame 4 Data LSByte Figure 5. Timing Diagram for Write Word Format Read Command When reading from SQ52201, a new value must be written to the register pointer, as shown in Figure 6. This write is accomplished by issuing the slaver address byte with the R/W bit low, followed by the register pointer byte. No additional data are required. 1 9 9 1 SCL SDA 1 0 0 A3 A2 A1 A0 W Start by Master P7 P6 P5 P4 P3 P2 P1 P0 ACK by Stop by Slaver Master ACK by Slaver Frame 1 2-wire slave address byte Frame 2 Register pointer byte Figure 6. Typical Register Pointer Set The master then generates a start condition and sends the slave address byte with the R/W bit high to initiate the read command. The next byte is transmitted by the slave and is the most significant byte of the register indicated by the register pointer. This byte is followed by an Acknowledge from the master; then the slave transmits the least significant byte. The master acknowledges receipt of the data byte. The master may terminate data transfer by generating a Not-Acknowledge after receiving any data byte, or generating a start or stop condition. 1 9 1 9 1 9 SCL SDA Start by Master 1 0 0 A3 A2 A1 A0 R D15 D14 D13 D12 D11 D10 D9 D8 ACK by Slaver Frame 1 2-wire slave address byte D7 D6 D5 D4 D3 D2 D1 D0 NACK Stop by by Master Master ACK by Master Frame 2 Data MSByte Frame 3 Data LSByte Figure 7. Timing Diagram for Read Word Format AN_SQ52201 Rev. 0.9 © 2021 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 11 All Rights Reserved. AN_SQ52201 High-Speed I2C Mode When the bus is idle, both the SDA and SCL lines are pulled high by the pull-up resistors. The master generates a start condition followed by a valid serial byte containing high-speed (HS) master code 00001XXX. This transmission is made in fast (400kHz) or standard (100kHz) (F/S) mode at no more than 400kHz. The device does not acknowledge the HS master code, but does recognize it and switches its internal filters to support 3.4MHz operation. The master then generates a repeated start condition (a repeated start condition has the same timing as the start condition). After this repeated start condition, the protocol is the same as F/S mode, except that transmission speeds up to 3.4MHz are allowed. Instead of using a stop condition, use repeated start conditions to secure the bus in HSmode. A stop condition ends the HS-mode and switches all the internal filters of the device to support the F/S mode. tR SCL tLOW tHDDAT tHIGH tSUDAT tSUSTO tHDSTA tF SDA tSUSTA tBUF P S Sr P Figure 8. Bus Timing Diagram Table 3. Bus Timing Diagram Definitions PARAMETERS SYMBOL SCL operating frequency Bus free time between stop and start conditions Hold time after repeated START condition. After this period, the first clock is generated. Repeated start condition setup time STOP condition setup time Data hold time Data setup time SCL clock low period SCL clock high period Data fall time Clock fall time Clock rise time Clock/data rise time for SCLK≤100kHz fSCL tBUF FAST MODE MIN MAX 0.001 0.4 600 HIGH-SPEED MODE MIN MAX 0.001 3.4 160 UNITS MHz ns tHDSTA 100 100 ns tSUSTA tSUSTO tHDDAT tSUDAT tLOW tHIGH tF tF tR tR 100 100 10 100 1300 600 100 100 10 20 200 60 ns ns ns ns ns ns ns ns ns ns 900 300 300 300 1000 100 80 40 40 SMBus Alert Response The SQ52201 is designed to respond to the SMBus Alert Response address. The SMBus Alert Response provides a quick fault identification for simple slave devices. When an Alert occurs, the master can broadcast the Alert Response slave address (0001 100) with the Read/Write bit set high. Following this Alert Response, any slave device that generates an alert identifies itself by acknowledging the Alert Response and sending its address on the bus. The Alert Response can activate several different slave devices simultaneously, similar to the I2C General Call. If more than one slave attempts to respond, bus arbitration rules apply. The losing device does not generate an Acknowledge and continues to hold the Alert line low until the interrupt is cleared. The following figure shows the timing diagram for the SMBus Alert response operation. Alert 1 9 9 1 SCL SDA 0 Start by Master 0 0 1 1 0 0 R 1 ACK by Slaver Frame 1 SMBus Alert response address byte 0 0 A3 A2 A1 A0 0 NACK Stop by by Master Master Frame 2 Slave address byte Figure 9. Timing Diagram for SMBus ALERT AN_SQ52201 Rev. 0.9 © 2021 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 12 All Rights Reserved. AN_SQ52201 Register Maps SQ52201 uses a bank of registers for holding configuration settings, measurement results, minimum/maximum limits, and status information. The following table summarizes the device registers. All 16-bit device registers are two 8-bit bytes via the I2C interface. Table 4. Register Set Summary REGISTER ADDRESS (HEX) REGISTER NAME 00h Configuration Register 01h 02h Shunt Voltage Register Bus Voltage Register 03h Power Register 04h Current Register 05h Calibration Register 06h Mask/Enable Register 07h Alert Limit Register Manufacturer ID Register Die ID Register FEh FFh POWER-ON RESET (HEX) TYPE 4127h R/W 0000h 0000h R R 0000h R 0000h R 0000h R/W 0000h R/W 0000h R/W Contains unique manufacturer identification number. 190Fh R Contains unique die identification number. 0000h R FUNCTION All-register reset, shunt voltage and bus voltage ADC conversion times and averaging, operating mode. Shunt voltage measurement data. Bus voltage measurement data. Contains the value of the calculated power being delivered to the load. Contains the value of the calculated current flowing through the shunt resistor. Sets full-scale range and LSB of current and power measurements. Overall system calibration. Alert configuration and Conversion Ready flag. Contains the limit value to compare to the selected Alert function. Configuration Register (00h) (Read/Write) The Configuration Register settings control the operating modes for the device. This register controls the conversion time settings for the shunt and bus voltage measurements as well as the averaging mode used. The operating mode that controls what signals are selected to be measured is also programmed in the Configuration Register. The Configuration Register can be read from at any time without impacting or affecting the device settings or a conversion in progress. Writing to the Configuration Register halts any conversion in progress until the write sequence is completed resulting in a new conversion starting based on the new contents of the Configuration Register (00h). This halt prevents any uncertainty in the conditions used for the next completed conversion. Table 5. Configuration Register (00h) (Read/Write) Descriptions BIT NO. BIT NAME POR VALUE DESCRIPTION D15 RST 0 Reset Bit Setting this bit to '1' generates a system reset that is the same as power-on reset. Reset all registers to default values; this bit self-clears. D14 D13 D12 1 0 0 D11 AVG2 0 D10 AVG1 0 D9 AVG0 0 D8 VBUSCT2 1 D7 VBUSCT1 0 AN_SQ52201 Rev. 0.9 © 2021 Silergy Corp. Averaging Mode Determines the number of samples that are collected and averaged. The following table shows all the AVG bit settings and related number of averages for each bit setting. NUMBER OF AVG[2:0] AVERAGES 000 1 001 4 010 16 011 64 100 128 101 256 110 512 111 1024 Bus Voltage Conversion Time Sets the conversion time for the bus voltage measurement. The following table shows the VBUSCT bit options and related conversion times for each bit setting. VBUSCT[2:0] CONVERSION TIME 000 140us 001 204us 010 332us Silergy Corp. Confidential- Prepared for Customer Use Only 13 All Rights Reserved. AN_SQ52201 D6 VBUSCT0 0 D5 VSHCT2 1 D4 VSHCT1 0 D3 VSHCT0 0 D2 MODE2 1 D1 MODE1 1 D0 MODE0 1 011 588us 100 1.1ms 101 2.116ms 110 4.156ms 111 8.244ms Shunt Voltage Conversion Time Sets the conversion time for the shunt voltage measurement. The following table shows the VSHCT bit options and related conversion times for each bit setting. VSHCT[2:0] CONVERSION TIME 000 140us 001 204us 010 332us 011 588us 100 1.1ms 101 2.116ms 110 4.156ms 111 8.244ms Operating Mode Selects continuous, triggered, or power-down mode of operation. These bits default to continuous shunt and bus measurement mode. The mode settings are shown as below. MODE[2:0] MODE 000 Power-Down (or Shutdown) 001 Shunt Voltage, Triggered 010 Bus Voltage, Triggered 011 Shunt and Bus, Triggered 100 Power-Down (or Shutdown) 101 Shunt Voltage, Continuous 110 Bus Voltage, Continuous 111 Shunt and Bus, Continuous Shunt Voltage Register (01h) (Read-Only) The Shunt Voltage Register stores the current shunt voltage reading, V SHUNT. Negative numbers are represented in two's complement format. Generate the two's complement of a negative number by complementing the absolute value binary number and adding 1. An MSB = '1' denotes a negative number. If averaging is enabled, this register displays the averaged value. Full-scale range = 81.9175mV (decimal = 7FFF); LSB= 2.5μV. Table 6. Shunt Voltage Register (01h) (Read-Only) Description BIT NO. BIT NAME POR VALUE D15 D14 D13 D12 D11 D10 D9 D8 D7 D6 D5 D4 D3 D2 D1 D0 SIGN SD14 SD13 SD12 SD11 SD10 SD9 SD8 SD7 SD6 SD5 SD4 SD3 SD2 SD1 SD0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Bus Voltage Register (02h) (Read-Only) The Bus Voltage Register stores the most recent bus voltage reading, VBUS. If averaging is enabled, this register displays the averaged value. Full-scale range = 40.96V (decimal = 7FFF); LSB = 1.25mV. Table 7. Bus Voltage Register (02h) (Read-Only) Description BIT NO. BIT NAME POR VALUE D15 D14 D13 D12 D11 D10 D9 D8 D7 D6 D5 D4 D3 D2 D1 D0 - BD14 BD13 BD12 BD11 BD10 BD9 BD8 BD7 BD6 BD5 BD4 BD3 BD2 BD1 BD0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Power Register (03h) (Read-Only) If averaging is enabled, this register displays the averaged value. The Power Register LSB is internally programmed to equal 25 times the programmed value of the Current_LSB. The Power Register records power in Watts by multiplying the decimal values of the Current Register with the decimal value of the Bus Voltage Register according to Equation 4. AN_SQ52201 Rev. 0.9 © 2021 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 14 All Rights Reserved. AN_SQ52201 Table 8. Power Register (03h) (Read-Only) Description BIT NO. BIT NAME POR VALUE D15 D14 D13 D12 D11 D10 D9 D8 D7 D6 D5 D4 D3 D2 D1 D0 PD15 PD14 PD13 PD12 PD11 PD10 PD9 PD8 PD7 PD6 PD5 PD4 PD3 PD2 PD1 PD0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Current Register (04h) (Read-Only) If averaging is enabled, this register displays the averaged value. The value of the Current Register is calculated by multiplying the decimal value in the Shunt Voltage Register with the decimal value of the Calibration Register, according to Equation 3. Table 9. Current Register (04h) (Read-Only) Register Description BIT NO. BIT NAME POR VALUE D15 CSIGN D14 CD 14 D13 CD 13 D12 CD 12 D11 CD 11 D10 CD 10 D9 CD 9 D8 CD 8 D7 CD 7 D6 CD 6 D5 CD 5 D4 CD 4 D3 CD 3 D2 CD 2 D1 CD 1 D0 CD 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Calibration Register (05h) (Read/Write) This register provides the device with the value of the shunt resistor that was present to create the measured differential voltage. It also sets the resolution of the Current Register. Programming this register sets the Current_LSB and the Power_LSB. This register is also suitable for use in overall system calibration. Table 10. Calibration Register (05h) (Read/Write) Description BIT NO. BIT NAME POR VALUE D15 D14 D13 D12 D11 D10 D9 D8 D7 D6 D5 D4 D3 D2 D1 D0 - FS14 FS13 FS12 FS11 FS10 FS9 FS8 FS7 FS6 FS5 FS4 FS3 FS2 FS1 FS0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Mask/Enable Register (06h) (Read/Write) The Mask/Enable Register selects the function that is enabled to control the Alert pin as well as how that pin functions. If multiple functions are enabled, the highest significant bit position Alert Function (D15-D11) takes priority and responds to the Alert Limit Register. Table 11. Mask/Enable Register (06h) (Read/Write) BIT NO. BIT NAME POR VALUE D15 SOL 0 D14 SUL 0 D13 BOL 0 D12 BUL 0 D11 POL 0 D10 CNVR 0 D9 D8 - 0 0 AN_SQ52201 Rev. 0.9 © 2021 Silergy Corp. DESCRIPTION Shunt Voltage Over-Voltage Setting this bit high configures the Alert pin to be asserted if the shunt voltage measurement following a conversion exceeds the value programmed in the Alert Limit Register. Shunt Voltage Under-Voltage Setting this bit high configures the Alert pin to be asserted if the shunt voltage measurement following a conversion drops below the value programmed in the Alert Limit Register. Bus Voltage Over-Voltage Setting this bit high configures the Alert pin to be asserted if the bus voltage measurement following a conversion exceeds the value programmed in the Alert Limit Register. Bus Voltage Under-Voltage Setting this bit high configures the Alert pin to be asserted if the bus voltage measurement following a conversion drops below the value programmed in the Alert Limit Register. Power Over-Limit Setting this bit high configures the Alert pin to be asserted if the Power calculation made following a bus voltage measurement exceeds the value programmed in the Alert Limit Register. Conversion Ready Setting this bit high configures the Alert pin to be asserted when the Conversion Ready Flag, Bit 3, is asserted indicating that the device is ready for the next conversion. Silergy Corp. Confidential- Prepared for Customer Use Only 15 All Rights Reserved. AN_SQ52201 D7 D6 D5 - 0 0 0 D4 AFF 0 D3 CVRF 0 D2 OVF 0 D1 APOL 0 D0 LEN 0 Alert Function Flag While only one Alert Function can be monitored at the Alert pin at a time, the Conversion Ready can also be enabled to assert the Alert pin. Reading the Alert Function Flag following an alert allows the user to determine if the Alert Function was the source of the Alert. When the Alert Latch Enable bit is set to Latch mode, the Alert Function Flag bit clears only when the Mask/Enable Register is read. When the Alert Latch Enable bit is set to Transparent mode, the Alert Function Flag bit is cleared following the next conversion that does not result in an Alert condition. Conversion Ready Flag Although the device can be read at any time, and the data from the last conversion is available, the Conversion Ready Flag bit is provided to help coordinate one-shot or triggered conversions. The Conversion Ready Flag bit is set after all conversions, averaging, and multiplications are complete. Conversion Ready Flag bit clears under the following conditions: 1.) Writing to the Configuration Register (except for Power-Down selection) 2.) Reading the Mask/Enable Register Math Overflow Flag This bit is set to '1' if an arithmetic operation resulted in an overflow error. It indicates that current and power data may be invalid. Alert Polarity bit; sets the Alert pin polarity. 1 = Inverted (active-high open collector) 0 = Normal (active-low open collector) (default) Alert Latch Enable Configures the latching feature of the Alert pin and Alert Flag bits. 1 = Latch enabled 0 = Transparent (default) When the Alert Latch Enable bit is set to Transparent mode, the Alert pin and Flag bit resets to the idle states when the fault has been cleared. When the Alert Latch Enable bit is set to Latch mode, the Alert pin and Alert Flag bit remains active following a fault until the Mask/Enable Register has been read. Alert Limit Register (07h) (Read/Write) The Alert Limit Register contains the value used to compare to the register selected in the Mask/Enable Register to determine if a limit has been exceeded. Table 12. Alert Limit Register (07h) (Read/Write) Description BIT NO. BIT NAME POR VALUE D15 AUL 15 D14 AUL 14 D13 AUL 13 D12 AUL 12 D11 AUL 11 D10 AUL 10 D9 AUL 9 D8 AUL 8 D7 AUL 7 D6 AUL 6 D5 AUL 5 D4 AUL 4 D3 AUL 3 D2 AUL 2 D1 AUL 1 D0 AUL 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Manufacturer ID Register (FEh) (Read-Only) The Manufacturer ID Register stores a unique identification number for the manufacturer. Table 13. Manufacturer ID Register (FEh) (Read-Only) Description BIT NO. BIT NAME POR VALUE D15 D14 D13 D12 D11 D10 D9 D8 D7 D6 D5 D4 D3 D2 D1 D0 ID15 ID14 ID13 ID12 ID11 ID10 ID9 ID8 ID7 ID6 ID5 ID4 ID3 ID2 ID1 ID0 0 0 0 1 1 0 0 1 0 0 0 0 1 1 1 1 Die ID Register (FFh) (Read-Only) The Die ID Register stores a unique identification number and the revision ID for the die. Table 14. Die ID Register (FFh) (Read-Only) Description BIT NO. BIT NAME POR VALUE D15 DID 11 D14 DID 10 D13 DID 9 D12 DID 8 D11 DID 7 D10 DID 6 D9 DID 5 D8 DID 4 D7 DID 3 D6 DID 2 D5 DID 1 D4 DID 0 D3 RID 3 D2 RID 2 D1 RID 1 D0 RID 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 AN_SQ52201 Rev. 0.9 © 2021 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 16 All Rights Reserved. AN_SQ52201 0.10-0.25 0.40-0.80 0.18-0.28 Top view 0.25 base 4.70-5.10 2.85-3.10 MSO10 Package outline & PCB layout Side view 0.500 5.300 1.350 0.300 0.75-0.95 0.00-0.15 2.85-3.10 0.50 (TYP) Notes: Front view Recommended Pad Layout All dimension in millimeter and exclude mold flash & metal burr. AN_SQ52201 Rev. 0.9 © 2021 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 17 All Rights Reserved. AN_SQ52201 Taping & Reel Specification 1. Taping Orientation MSOP10 Feeding direction 2. Carrier Tape & Reel Specification for Packages Reel Size Package types Tape width (mm) Pocket pitch(mm) Reel size (Inch) Trailer length(mm) Leader length (mm) Qty per reel MSOP10 12 8 13" 400 400 3000 3. Others: NA AN_SQ52201 Rev. 0.9 © 2021 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 18 All Rights Reserved. AN_SQ52201 IMPORTANT NOTICE 1. Right to make changes. Silergy and its subsidiaries (hereafter Silergy) reserve the right to change any information published in this document, including but not limited to circuitry, specification and/or product design, manufacturing or descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Buyers should obtain the latest relevant information before placing orders and should verify that such information is current and complete. All semiconductor products are sold subject to Silergy’s standard terms and conditions of sale. 2. Applications. Application examples that are described herein for any of these products are for illustrative purposes only. Silergy makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Buyers are responsible for the design and operation of their applications and products using Silergy products. Silergy or its subsidiaries assume no liability for any application assistance or designs of customer products. It is customer’s sole responsibility to determine whether the Silergy product is suitable and fit for the customer’s applications and products planned. To minimize the risks associated with customer’s products and applications, customer should provide adequate design and operating safeguards. Customer represents and agrees that it has all the necessary expertise to create and implement safeguards which anticipate dangerous consequences of failures, monitor failures and their consequences, lessen the likelihood of failures that might cause harm and take appropriate remedial actions. Silergy assumes no liability related to any default, damage, costs or problem in the customer’s applications or products, or the application or use by customer’s third-party buyers. Customer will fully indemnify Silergy, its subsidiaries, and their representatives against any damages arising out of the use of any Silergy components in safety-critical applications. It is also buyers’ sole responsibility to warrant and guarantee that any intellectual property rights of a third party are not infringed upon when integrating Silergy products into any application. Silergy assumes no responsibility for any said applications or for any use of any circuitry other than circuitry entirely embodied in a Silergy product. 3. Limited warranty and liability. Information furnished by Silergy in this document is believed to be accurate and reliable. However, Silergy makes no representation or warranty, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Silergy be liable for any indirect, incidental, punitive, special or consequential damages, including but not limited to lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges, whether or not such damages are based on tort or negligence, warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Silergy’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Standard Terms and Conditions of Sale of Silergy. 4. Suitability for use. Customer acknowledges and agrees that it is solely responsible for compliance with all legal, regulatory and safety-related requirements concerning its products, and any use of Silergy components in its applications, notwithstanding any applications-related information or support that may be provided by Silergy. Silergy products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Silergy product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Silergy assumes no liability for inclusion and/or use of Silergy products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. 5. Terms and conditions of commercial sale. Silergy products are sold subject to the standard terms and conditions of commercial sale, as published at http://www.silergy.com/stdterms, unless otherwise agreed in a valid written individual agreement specifically agreed to in writing by an authorized officer of Silergy. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Silergy hereby expressly objects to and denies the application of any customer’s general terms and conditions with regard to the purchase of Silergy products by the customer. 6. No offer to sell or license. Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Silergy makes no representation or warranty that any license, either express or implied, is granted under any patent right, copyright, mask work right, or other intellectual property right. Information published by Silergy regarding third-party products or services does not constitute a license to use such products or services or a warranty or endorsement thereof. Use of such information may require a license from a third party under the patents or other intellectual property of the third party, or a license from Silergy under the patents or other intellectual property of Silergy. For more information, please visit: www.silergy.com © 2021 Silergy Corp. AN_SQ52201 Rev. 0.9 © 2021 Silergy Corp. All Rights Reserved. Silergy Corp. Confidential- Prepared for Customer Use Only 19 All Rights Reserved.
SQ52201FBC 价格&库存
很抱歉,暂时无法提供与“SQ52201FBC”相匹配的价格&库存,您可以联系我们找货
