SY56805A1QEC
SY56805A1QEC
    SILERGY(矽力杰)
    QFN32_5X5MM
    SY56805A1是一种组合式以太网供电设备(PD)接口和初级侧转换器,专门针对隔离转换器设计进行了优化。
SY56805A1QEC 数据手册
Application Note: SY56805A1 PoE Power Device General Description Features The SY56805A1 is a combined Power over Ethernet (PoE) powered device (PD) interface and primary side converter optimized specifically for isolated converter designs. The PoE interface supports the IEEE 802.3af standard as a 13W Type 1 powered device. • • • • • • • • • • SY56805A1 features a detection signature pin which can also be used to disable the internal hotswap MOSFET. This allows the PoE function to be turned off during powered operation. Classification can be programmed to any of the defined Type 1 PD with a single resistor. D1 CIN VDD COUT1 VCC CLS DRAIN VSS VOUT RVC1 DVC1 RZCS1 ZCS APD RZCS2 SOURCE RCS1 CS RCS2 RTN CVC RCLS yC Sil D2 RAPD2 Adapter RO N .C orp T1 DA RAPD1 dF de nti a Note ---- DEN erg From Ethernet Pairs 4-5,7-8 C1 Z1 RDEN From Ethernet Pairs 1-2,3-6 Typical Applications IEEE 802.3af Compliant Devices Video and VoIP Telephones RFID Readers Multiband Access Points Security Cameras on fi Package type QFN5*5-32L • • • • • lP SY56805 □(□□)□ Ordering Number SY56805A1QEC Applications rep are Ordering Information Temperature Code Package Code Optional Spec Code IR IT or K To achieve higher efficiency and better EMI performance, SY56805A1 drives Flyback converters in the Quasi-Resonant mode and adaptive PWM/PFM control. The flyback converter integrate a 150V, 0.14Ω MOSFET. Power Up to 13W(input) PDs Supports the IEEE 802.3af Standard Primary Side Control QR-mode Operation for High Efficiency PWM/PFM Control for Higher Average Efficiency Adapter ORing Support 100 V, 0.45Ω Hotswap MOSFET Integrate 150V, 0.14Ω MOSFET for Converter RoHS Compliant and Halogen Free Compact Package: QFN5*5-32L Figure 1. Schematic Diagram AN_SY56805A1 Rev.0.9B © 2022 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only All Rights Reserved. 1 AN_SY56805A1 NC NC 26 25 1 24 RTN NC 2 23 RTN VSS 3 22 RTN 21 NC 20 VCC VSS Drain 4 Exposed Pad 5 CLS 6 19 APD 7 18 NC 8 14 15 16 SOURCE SOURCE NC NC dF 13 SOURCE 12 SOURCE CS rep are 11 10 NC SOURCE 9 17 NC ZCS or K DEN IR IT VDD RO N NC NC 29 NC NC 30 27 NC 31 28 NC 32 Pinout (top view) (QFN5*5-32L) Top Mark: EBFxyz (device code: EBF, x=year code, y=week code, z= lot number code) Pin VDD 1 VSS 3,4 DEN 5 CLS 6 Connect a resistor from CLS to VSS to program classification current. 2.5 V is applied to the program resistor during classification to set class current. APD 7 Pull APD above 1.5 V disables the internal hotswap switch. This forces power to come from an external VDD-RTN adapter. Connect APD to RTN when not used. SOURCE 11,12,13,14 SOURCE 15 de nti a Description Connect to the positive PoE input power rail. VDD powers the PoE interface circuits. Bypass with a 0.1 μF capacitor and protect with a TVS. erg yC orp .C on fi Connect to the negative power rail derived from the PoE source. Connect a 24.9 kΩ resistor from DEN to VDD to provide the PoE detection signature. Pulling this pin to VSS during powered operation causes the internal hotswap MOSFET to turn off. 18 Source of the internal power MOSFET. Internal connected to the source of the internal power MOSFET, this pin can be floating. Current sense pin. ZCS Sil CS lP Name 19 Inductor current zero-crossing detection pin. This pin receives the auxiliary winding voltage by a resistor divider and detects the inductor current zero crossing point. VCC 20 DC/DC converter bias voltage. RTN 22,23,24 Drain Exposed Pad NC others RTN is the output of the PoE hotswap MOSFET. Drain of the internal power MOSFET. Not connected. AN_SY56805A1 Rev.0.9B © 2022 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only All Rights Reserved. 2 AN_SY56805A1 Absolute Maximum Ratings (1) RO N Input voltage range [DEN, VDD, RTN (2)] to VSS --------------------------------------------------------------------- -0.3-100V Input voltage range [VDD, VCC] to RTN ------------------------------------------------------------------------------- -0.3-100V Input voltage range CLS (3) to VSS--------------------------------------------------------------------------------------- -0.3- 5.5V Input voltage range [ZCS, CS, APD] to RTN -------------------------------------------------------------------------- -0.3- 5.5V Package Thermal Resistance (4) QFN5*5-32L, θJA ----------------------------------------------------------------------------------------------- 25.13°C/W QFN5*5-32L, θJC ----------------------------------------------------------------------------------------------- 16.85°C/W Junction Temperature Range ------------------------------------------------------------------------------------ ---- -45°C to 150°C Lead Temperature (Soldering, 10 sec.) --------------------------------------------------------------------------------------- 260°C Storage Temperature Range ---------------------------------------------------------------------------------------- -65°C to 150°C IR IT Recommended Operating Conditions or K Input voltage range [RTN, VDD] to VSS------------------------------------------------------------------------------------ 0- 72V Input voltage range VDD to RTN -------------------------------------------------------------------------------------------- 0- 72V Input voltage range VCC to RTN --------------------------------------------------------------------------------------------- 0- 18V Junction Temperature Range ---------------------------------------------------------------------------------------- -40°C to 125°C dF Notes: (1): Stresses beyond the “Absolute Maximum Ratings” may cause perm anent damage to the device. These rep are are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Sil erg yC orp .C on fi de nti a lP (2): IRTN=0 for VRTN>80V. (3): Do not apply voltage to this pin. (4): JESD 51-2,-5,-7,-8,-14 standard. AN_SY56805A1 Rev.0.9B © 2022 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only All Rights Reserved. 3 AN_SY56805A1 Block Diagram VCC VDD Control VO Estimator ZCS_FB RO N ZCS Valley_DET enb ZCS_OVP VCC_OVP IR IT Valley Detect ZCS_OVP COMP gm Protection IPK_SEN CS Drain Flimit_SET COMP Behavior (Frequency_ set、 Ipk_set) IPK_SET rep are Soft start dF Valley_DET or K ZCS_REF PWM generator PWM SOURCE IPK_Sense de nti a lP IPK_Sense Detection VSS DEN Classification Logic& Regulator CLS Control logic & Inrush and current limit APD Sil erg yC orp .C on fi VDD VSS AN_SY56805A1 Rev.0.9B © 2022 Silergy Corp. Current sense RTN Silergy Corp. Confidential- Prepared for Customer Use Only All Rights Reserved. 4 AN_SY56805A1 Electrical Characteristics (Unless otherwise noted: CVCC=0.1 μF, RDEN=24.9 kΩ, RCLS open, VVDD-VVSS = 48 V, 9 V ≤ VCC≤ 18 V. Typical specifications are at 25°C.) DC-DC Controller Section IVCC VDD=48V, VCC=0V VZCS_OVP Blanking Time for OFF Time TOFF_MIN CS Maximum Threshold Voltage VLIMIT dF ZCS OVP Threshold Max OFF Time TOFF_MAX Maximum Switching Frequency FMAX INTEGRATED MOSFET VBV RDSON VGS=12V,IDS=0.1A VAPD_EN .C VAPD rising VAPD_H Hysteresis orp yC APD Threshold Voltage APD Leakage Current VGS=0V,IDS=250µA on fi Breakdown Voltage Static Drain-Source OnResistance APD de nti a TON_MAX lP SWITCHING Max ON Time Unit 9.45 200 9 2.5 7 22 280 350 V V V V µA 0.5 1 2 mA 1.18 1.2 1.22 V 1.35 1.45 1.55 V 0.53 0.64 0.75 µs 0.92 1.06 1.2 V 6.5 Typ RO N VCC falling rep are VZCS_REF Max 8.55 ZCS Voltage Reference Min IR IT Startup Current Source Conditions or K VSS=RTN, all voltages referred to RTN. Parameter Symbol VCC VCC Turn-on Threshold VVCC_ON VCC UVLO Hysteresis VVCC_HYS VCC SCP Threshold VVCC_SCP VCC OVP Voltage VVCC_OVP Quiescent Current IQ 7.5 12 µs 400 550 700 µs 160 200 280 kHz 150 V Ω 0.14 1.4 1.5 1.6 V 0.3 VAPD=5.5V V 1 μA erg THERMAL SHUTDOWN Thermal Shutdown Temperature 150 °C 20 °C Sil Hysteresis TJ rising AN_SY56805A1 Rev.0.9B © 2022 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only All Rights Reserved. 5 AN_SY56805A1 PD Interface Section All voltages referred to VSS unless otherwise noted Symbol DEN Detection Current Detection Bias Current VPD_DIS ICLS Classification Regulator Lower Threshold Classification Regulator Upper Threshold HOTSWAP MOSFET On Resistance VCL_ON VCL_H VCU_OFF VCU_H or K Classification Current dF CLS lP Current Limit de nti a Inrush Limit Leakage Current Min Typ 7 10 μA 3 4 0.1 5 5 V μA 2 10 18 28 40 11 2 22 0.6 13 3 23 1 mA mA mA mA mA V V V V 0.45 0.6 Ω 9 1 21 0.3 580 50 60 Thermal Shutdown Temperature mA 40 μA 36 V Hysteresis 4.3 V TJ rising 150 °C 20 °C Sil erg yC 35 80 VUVLO_H orp Hysteresis 34 mA VDD rising on fi THERMAL SHUTDOWN μA μA VUVLO_R .C UVLO Threshold Unit 4.5 VVDD=VRTN=100V, DEN=VSS UVLO Max 60 400 IR IT VDEN=VVDD=57V,measure IDEN VDD= RTN=VSUPPLY positive RCLS=1270Ω RCLS=243Ω RCLS=137Ω RCLS=90.9Ω RCLS=63.4Ω Regulator turns on, VDD rising Hysteresis Regulator turns off, VDD rising Hysteresis rep are Hotswap Disable Threshold DEN Leakage Current CLASSIFICATION Conditions VVDD= RTN=VSUPPLY positive VVDD=1.6V VVDD=10V VVDD=10V,float DEN, measure ISUPPLY RO N Parameter DETECTION AN_SY56805A1 Rev.0.9B © 2022 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only All Rights Reserved. 6 AN_SY56805A1 Typical Performance Characteristics (Test condition: input voltage: 37-57Vdc; output spec: 12Vdc/1A; Ambient temperature: 25±5 ℃; Ambient humidity:65±25%.) Startup Shutdown (VIN=37V(DC)@Full Load) (VIN=37V(DC)@Full Load) 20V/div VBUS 20V/div VOUT 12V/div VOUT 12V/div ISEN 1V/div ISEN 1V/div IR IT IOUT 1A/div dF Time (10ms/div) Startup VOUT 12V/div ISEN 1V/div 1A/div Shutdown VBUS VOUT 12V/div ISEN 1V/div IOUT Time (10ms/div) orp Steady Steady ISEN 1V/div IOUT erg 12V/div Sil VOUT yC (VIN=37V(DC)@Full Load) 50V/div 1A/div Time (4µs/div) AN_SY56805A1 Rev.0.9B © 2022 Silergy Corp. 1A/div .C Time (10ms/div) Time (10ms/div) (VIN=57V(DC)@Full Load) 20V/div on fi IOUT lP 20V/div de nti a VBUS rep are (VIN=57V(DC)@Full Load) VDrain 1A/div or K IOUT RO N VBUS (VIN=57V(DC)@Full Load) VDrain 50V/div VOUT 12V/div ISEN 1V/div IOUT 1A/div Time (4µs/div) Silergy Corp. Confidential- Prepared for Customer Use Only All Rights Reserved. 7 AN_SY56805A1 Short Circuit Protection Short Circuit Protection (VIN=37V(DC)@Full Load) (VIN=57V(DC)@Full Load) 50V/div VDrain 50V/div VOUT 12V/div VOUT 12V/div ISEN 1V/div ISEN 1V/div IR IT IOUT 1A/div IOUT Line Regulation dF 37V 48V 57V 12.03 VIN=37V VIN=48V VIN=57V 11.97 11.90 0% 25% 50% 75% 100% Output Current Rate(%) Sil erg yC orp .C on fi Input Voltage (V) Output Voltage (V) 11.97 12.10 rep are I=0A I=0.25A I=0.5A I=0.75A I=1A lP 12.03 de nti a Output Voltage (V) Load Regulation 12.16 12.10 11.90 1A/div Time (1s/div) or K Time (1s/div) 12.16 RO N VDrain AN_SY56805A1 Rev.0.9B © 2022 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only All Rights Reserved. 8 AN_SY56805A1 voltage across hotswap switch is sufficiently low, indicating the switcher supply capacitor is almost completely charged. Once the inrush current falls and the RTN drops to nearly zero, the PD current limit switches to the operational level. Operation Principles Protocol Section Detection In order to identify a device as a valid PD, the Power Sourcing Equipment (PSE) senses the Ethernet connection by applying two voltages in a range of 2.8 V to 10 V on the Ethernet cable and measuring the corresponding currents. An equivalent resistance is calculated using the ΔV/ΔI. During this phase, the PD must present a resistance between 23.75 kΩ and 26.25 kΩ. The value of the detection resistance has to be selected also taking into account the typical drop in voltage of the diode bridges. The typical value that can be used in most case is 24.9 kΩ. Adapter Power Input IR IT RO N In some applications, it is desirable to power the PD from an auxiliary power source such as a wall adapter. The SY56805A1 supports forced operation from either of the power sources. Figure 1 illustrates the recommended connection of the adapter power to PD. The hot-swap switch is disabled while the adapter is used to pull APD high (up to 1.5V), blocking the PoE source from powering the output. RDEN de nti a on fi Power at PD(W) Class current (mA) Resistor 0 0.44~12.95 0~4 1270 1 0.44~3.84 9~12 243 2 3.84~6.49 137 3 erg 17~20 6.49~12.95 26~30 90.9 4 - 36~44 63.4 yC orp Class Sil .C Table 1. Class Resistor Selection Inrush and Operational Current Limit VDD DEN RCLS CLS VSS RTN APD Adapter RAPD1 rep are dF From PSE lP In the classification mode, the PSE will classify the PD for one of five power levels or classes. This allows the PSE to efficiently manage power distribution. The five different classes is shown in Table 1, it determine the class the PD must advertise. An external resistor (RCLS) connected from CLS to VSS sets the classification current. The PSE may disconnect a PD if it draws more than its stated Class power. During hardware Classification, the PSE presents a fixed voltage between 15.5 V and 20.5 V to the PD, which in turn draws a fixed current set by RCLS. PD current is measured by the PSE to determine which of the five available classes is advertised (see Table 1). The SY56805A1 disables classification while the input voltage is above 22V to avoid excessive power dissipation. If the PD thermal limit is trigger or when APD or DEN is active, the CLS reference voltage will be turned off . or K Classification RAPD2 Fig.1 Adapter Power Input DC-DC Controller Operation Start-up Operation After DC supply is powered on, the rectified BUS voltage ramps up. The capacitor across VCC and RTN pins, CVCC, is charged up by the BUS voltage through internal start up circuit. Once VVCC rises up to VVCC_ON, the internal blocks starts the operation. VVCC will subsequently be pulled down by the power consumption of the circuitry until the auxiliary winding of Flyback transformer can supply sufficient energy. To avoid triggering VVCC_SCP threshold during start-up, the VCC bypass capacitor should be large enough to maintain VVCC above VVCC_SCP(7V typical). The startup procedure is divided into two sections, as shown in Fig.2: tSTC is the CVCC charged up section, and tSTO is the output voltage built-up section. The start up time tST composes of tSTC and tSTO, and usually tSTO is much smaller than tSTC. Once the classification is successfully completed, the PSE will rise its voltage, when the input voltage is above UVLO turn on threshold(35V), the hotswap switch is turned on, and the input capacitor is charged with a low current (inrush current) limit until the AN_SY56805A1 Rev.0.9B © 2022 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only All Rights Reserved. 9 AN_SY56805A1 N AUX (1) NS NAUX is the turns of auxiliary winding; NS is the turns of secondary winding; VD_F is the forward voltage of the power diode. VAUX = (VOUT + VD _ F )  Fig.2 Start up Quasi-Resonant Operation IR IT RO N At the current zero-crossing point, VD_F is nearly zero, so VOUT is proportional with VAUX exactly. The voltage of this point is sampled by the IC as the feedback of output voltage. The resistor divider is designed by VZCS _ REF R ZCSD N =  AUX (2) VOUT R ZCSU + R ZCSD NS Where VZCS_REF is the internal voltage reference. QR mode operation provides low turn-on switching losses for Flyback converter. VNAUX IPP dF IPRI or K VG rep are Valley VDS ISP ISEC IOUT tDIS de nti a Fig.3 QR mode operation lP tS .C on fi The voltage across drain and source of the primary MOSFET is reflected by the auxiliary winding of the Flyback transformer. ZCS pin detects the voltage across the auxiliary winding by a resistor divider. When the voltage across drain and source of the primary MOSFET is at voltage valley, the MOSFET would be turned on. Output Voltage Control yC orp In order to achieve primary side constant voltage control, the output voltage is detected by the auxiliary winding voltage. RAUX CVCC Sil RZCSD erg NAUX RZCSU VCC SY56805A1 ZCS Fig.4 ZCS pin connection As shown in Fig.5, during OFF time, the voltage across the auxiliary winding is AN_SY56805A1 Rev.0.9B © 2022 Silergy Corp. VAUX VOUT  t1 tS t2 N AUX NS t3 Fig.5 Auxiliary winding voltage waveforms Fault Protection Modes ZCS Pin Short Protection The SY56805A1 has a protection against faults caused by a shorted ZCS pin. During start-up, the voltage on the ZCS pin is monitored. In normal situations, the voltage on the ZCS pin reaches the sense protection trigger level. When the ZCS voltage does not reach this level, the ZCS pin is shorted and the protection is activated. The IC stops switching and discharge the VCC voltage. Once VVCC is below VVCC_OFF, the IC will shut down and be charged again by VDD. CS pin Short Protection The SY56805A1 has a protection against the faults caused by shorting CS pin to RTN. During start-up, the voltage on the CS pin is monitored. If the VCS does not Silergy Corp. Confidential- Prepared for Customer Use Only All Rights Reserved. 10 AN_SY56805A1 exceed 150mV after 2.5µS, the protection will be triggered, the IC stops switching and discharge the VCC voltage. Once VVCC decreases below VVCC_OFF, the IC will shut down and the VCC will be charged again by VDD. Power Device Design MOSFET and DIODE When the operation condition is with maximum input voltage and full load, the voltage stress of MOSFET and secondary power diode is maximized; Output Over Voltage Protection When the ZCS pin signal exceeds 1.45V, reflecting an output over-voltage condition, SY56805A1 will stop switching and discharge the VCC voltage. Once VVCC is below VVCC_OFF, the IC will shut down and the VCC will be charged again by VDD. VD_R_MAX = IR IT or K When the operation condition is with minimum input voltage and full load, the current stress of MOSFET and power diode is maximized. I MOS_PK_MAX =IP_PK_MAX (5) dF yC orp .C on fi de nti a lP The SCP will be triggered when the VCC is falling below VVCC-SCP (7V typical) and the voltage of internal comp is up to 2V. When the IC starts up with heavy load, or the output current is getting heavier and heavier during normal operation, or output is shorted to ground, the VCC voltage will decrease and internal COMP will be high, Once VVCC is below VVCC_SCP, IC will shut down immediately, VCC will be charged again by VDD. To avoid thermal rising risk, a digital counter is adopted. When VCC has reached VVCC_ON, the counter will plus 1. When the counter has reached number 8, SCP flag signal will be reset. Meanwhile, IC will try to start up again. In order to guarantee SCP function is not affected by voltage spike of auxiliary winding, a filter resistor RAUX is needed. erg +VOUT (4) rep are Short Circuit Protection (SCP) I MOS_RMS_MAX =I P_RMS_MAX (6) I D_PK_MAX =N PS  I P_PK_MAX (7) I D_AVG =I OUT (8) Where IP_PK_MAX and IP_RMS_MAX are maximum primary peak current and RMS current, which will be introduced later. Transformer (NPS and LM) NPS is limited by the electrical stress of the power MOSFET: VMOS_(BR)DS  90%-VDC_MAX -ΔVS (9) NPS  VOUT +VD_F Where VMOS_(BR)DS is the breakdown voltage of the power MOSFET. VCC CVCC SY56805A1 In Quasi-Resonant mode, each switching period cycle tS consists of three parts: current rising time t1, current falling time t2 and quasi-resonant time t3 shown in Fig.8. Sil NAUX N PS Where VDC_MAX is maximum input DC voltage; NPS is the turns ratio of the Flyback transformer; V OUT is the rated output voltage; VD_F is the forward voltage of secondary power diode; ΔVS is the overshoot voltage clamped by RCD snubber during OFF time. VCC Over Voltage Protection When the VCC voltage exceeds VVCC_OVP threshold, SY56805A1 will stop switching and discharge the VCC voltage. Once VVCC is below VVCC_OFF, the SY56805A1 will shut down and the VCC will be charged again by VDD. RAUX VDC_MAX RO N VMOS_DS_MAX =VDC_MAX +N PS  (VOUT +VD_F )+ΔVS (3) Fig. 6 Filter resistor RAUX AN_SY56805A1 Rev.0.9B © 2022 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only All Rights Reserved. 11 AN_SY56805A1 VG t1 = t2 = IPP IPRI L M  I P _ PK _ MAX tS = ISEC (14) 1 (15) fS _ MIN current IR IT VDS or K t3 t2 tS (f) Compute secondary maximum peak current IS_PK_MAX and RMS current IS_RMS_MAX for the transformer fabrication. IS_PK_MAX =N PS  I P_PK_MAX (17) dF t1 Fig.7 switching waveforms (b) Preset minimum frequency fS_MIN on fi de nti a lP Once the minimum frequency fS_MIN is set, the inductance of the transformer could be induced. The design flow is shown as below: (a)Select NPS VMOS_(BR)DS  90%-VDC_MAX -ΔVS (10) NPS  VOUT +VD_F IS _ RMS _ MAX = rep are When the operation condition is with minimum input DC RMS voltage and full load, the switching frequency is minimum frequency, the maximum peak current through MOSFET and the transformer happens. orp .C (c) Compute inductor LM and maximum primary peak current IP_PK_MAX yC 2POUT 2POUT 2POUT + +  CDrain  fS_ MIN  VDC _ MIN  NPS  (VOUT + VD _ F )  2POUT  I 2P _ PK _ MAX  fS _ MIN (11) (12) erg LM = N PS  (VOUT + VD _ F ) (e) Compute primary maximum RMS IP_RMS_MAX for the transformer fabrication. t 3 IP _ RMS _ MAX = IP _ PK _ MAX  1 (16) 3 tS IOUT IP _ PK _ MAX = LM  I P _ PK _ MAX RO N ISP (13) VBUS Transformer Design (NP,NS,NAUX) The design of the transformer is similar with ordinary Flyback transformer. the parameters below are necessary: Necessary parameters Turns ratio Inductance Primary maximum current Primary maximum RMS current Secondary maximum RMS current Sil (d) Compute current rising time t1 and current falling time t2 The design rules are as followed: (a) Select the magnetic core style, identify the effective area Ae. (b) Preset the maximum magnetic flux ΔB ΔB=0.22~0.26T NP = L M  I P_PK_MAX ΔB  A e (19) (d) Compute secondary turn NS NS = © 2022 Silergy Corp. NPS LM IP_PK_MAX IP_RMS_MAX IS_RMS_MAX (c) Compute primary turn NP Where CDrain is the parasitic capacitance at drain of MOSFET; η is the efficiency; POUT is rated full load power. AN_SY56805A1 Rev.0.9B t 3 N PS  I P _ PK _ MAX  2 (18) 3 tS NP (20) N PS Silergy Corp. Confidential- Prepared for Customer Use Only All Rights Reserved. 12 AN_SY56805A1 Table2. Class Resistor Selection (e) compute auxiliary turn NAUX Where VVCC is the working voltage of VCC pin (10V~15V is recommended). (f) Select an appropriate wire diameter With IP_RMS_MAX and IS_RMS_MAX, select appropriate wire to make sure the current density ranges from 4A/mm2 to 10A/mm2. 1270 1 0.44 3.84 243 2 3.84 6.49 137 3 6.49 12.95 90.9 IR IT or K dF lP de nti a on fi (23) PRCD The CRCD is related with the voltage ripple of the snubber ΔVC_RCD: N  (VOUT +VD_F )+ΔVS (24) CRCD = PS R RCD  fS  ΔVC_RCD .C orp yC erg The standard specifies a detection signature resistance, RDEN between 23.7 kΩ and 26.3 kΩ. Connect a 24.9kΩ resistor from DEN to VDD to provide the PoE detection signature. VDD to VSS ESD Protection Voltage transients caused by surge or other special applications can occur, a TVS (D1, see in Fig.8) must limit this voltage to be within the absolute maximum ratings. The TVS such as SMBJ58A can be used. A TVS with negative resistance characteristic is not recommended. A Schottky diode (D2 on the Fig.8) such as PT3L100F-A is required between VSS and RTN for application design. RDEN 24.9k VDD DEN C1 D1 A resistor from CLS to VSS programs the classification current per the IEEE standard. The PD power ranges and corresponding resistor values are listed in following table. The power assigned should correspond to the maximum average power drawn by the PD during operation. SY56805A1 supports class 0-3 power levels. Sil DEN Resistor Selection CLS RCLS From Ethernet 4-5,7-8 (NPS  (VOUT +VD_F )+ΔVS ) 2 (22) R APD1 + R APD2  (VAPDEN - VAPDH) R APD2 From Ethernet 1-2,3-6 LK  POUT (22) LM rep are  The RRCD is related with the power loss, CLS Resistor Selection 12.95 VAPDTR_OFF = Where NPS is the turns ratio of the flyback transformer; VOUT is the output voltage; VD_F is the forward voltage of the power diode; ΔVS is the overshoot voltage clamped by RCD snubber; LK is the leakage inductor; LM is the inductance of the Flyback transformer; POUT is the output power. R RCD = 0.44 R APD1 = R APD2  (VAPDTR_ON - VAPDEN)/VAPDEN The power loss of the snubber PRCD is evaluated first ΔVS 0 APD forces power to come from an external adapter connected from VDD to RTN by opening the hotswap switch. Select the APD divider resistors per Equation (22) where VADPTR_ON is the desired adapter voltage that enables the APD function as adapter voltage rises. RCD Snubber for MOSFET N PS  (VOUT +VD_F )+ΔVS Resistor APD Resistor Selection (g) If the winding area of the core and bobbin is not enough, reselect the core style, go to (a) and redesign the transformer until the ideal transformer is achieved. PRCD = Power at PD Minmum Maximum (W) (W) Class RO N V N AUX =N S  VCC (21) VOUT SY56805A1 VSS APD D2 RTN Fig.8 VDD to VSS ESD protection AN_SY56805A1 Rev.0.9B © 2022 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only All Rights Reserved. 13 AN_SY56805A1 Input Bypass Capacitor Selection 3 The standard specifies an input bypass capacitor of 0.05 μF to 0.12 μF. Typically a 0.1 μF, 100V ceramic capacitor between VDD and VSS(C1 on the Fig.8) is used while the input power source is only PSE (C2 not connnect). 1 5 4 2 7 Ground ①: ground of BUS capacitor. Ground ②: ground of bias supply capacitor. Ground ③: ground node of auxiliary winding. Ground ④: ground node of divider resistor. Ground ⑤: primary ground node of Y capacitor. Ground ⑥: ground node of current sample resistor. Ground ⑦: ground of IC GND. IR IT RO N If the external adapter is also used to power the device, one capacitor C1 between VDD and VSS, and one capacitor C2 between RTN and VSS is both recommended to be connected. The typical value of C1 and C2 is both recommended to be 0.047uF/100V. Layout rep are dF or K (d) bias supply trace should be connected to the bias supply capacitor first instead of GND pin. The bias supply capacitor should be put beside the IC. (e) Loop of ‘Source pin – current sample resistor – GND pin’ should be kept as small as possible. (f) The resistor divider connected to ZCS pin is recommended to be put beside the IC. de nti a lP (a) To achieve better EMI performance and reduce line frequency ripples, the output of the bridge rectifier should be connected to the BUS line capacitor first, then to the switching circuit. (b) The circuit loop of all switching circuit should be kept small: primary power loop, secondary loop and auxiliary power loop. (c) The connection of primary ground is recommended as: 6 Design Notice on fi Sil erg yC orp 4. 5. At no load secondary side diode freewheeling time should be more than TOFF_MIN. VCC voltage prefer to larger than 10V for all conditions. At heavy load, the peak-to-peak voltage at the ZCS pin should be less than approximately 100mV after. TOFF_MIN time. This can be guaranteed by decreasing the leakage inductance and using proper RCD snubber. RZCSU is the upper resistor of the divider. Normally, its value is recommended between 30kΩ~91kΩ. In order to ensure the loop stability, the output capacitor should be selected properly. On the other hand, switching frequency ripple should also be considered. If the switching frequency ripple is too large, increase the capacitance of Cout properly or use low ESR capacitor. .C 1. 2. 3. AN_SY56805A1 Rev.0.9B © 2022 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only All Rights Reserved. 14 AN_SY56805A1 Design Example A design example of typical application is shown below step by step. Design Specification VDC IOUT 37V~57V 1A VOUT η 12V 82% IR IT #2. Transformer design (NPS, LM) 37V 50V 12W VDC_MAX VMOS-(BR)DS V D_ F CDrain 60pF fS_MIN 150kHz rep are (a)Compute turns ratio NPS first 57V 150V 1V dF Conditions VDC_MIN ΔVS POUT(max) or K Refer to Power Device Design N PS  RO N #1. Identify design specification VMOS_(BR)DS  90%-VDC_MAX -ΔVS VOUT +VD,F lP 150V  0.9-57V-50V 12V+1V =2.15 de nti a = NPS is set to on fi N PS =2 .C (b)fS,MIN is preset orp fS_MIN =150kHz Sil erg yC (c) Compute inductor LM and maximum primary peak current IP,PK,MAX 2POUT I P _ PK _M AX =   N PS VO   VDC _ MIN   N PS VO + VDC _ MIN   2  12W = 2*12V 0.82  (37V  ) 2*12V + 37V = 2.01A 2POUT LM = 2  I P _ PK _ MAX  fS _ MIN 2  12W 0.82  (2.01A)2  150KHz = 48.78H = AN_SY56805A1 Rev.0.9B © 2022 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only All Rights Reserved. 15 AN_SY56805A1 Set: LM=48µH (d) Compute current rising time t1 and current falling time t2 t2 = LM  I P _ PK _ MAX VDC_ MIN = 48H  2.01A = 2.607s 37V LM  I P _ PK _ MAX N PS  (VOUT + VD _ F ) = 48H  2.01A = 3.711s 2  (12V + 1V) RO N t1 = IR IT t 3 =π  LM  CDrain =π  48H  60pF=0.168s or K t S = t1 + t 2 + t 3 = 2.607s + 3.711s + 0.168s = 6.486s (e) Compute primary maximum RMS current IP-RMS-MAX for the transformer fabrication. dF t 3 3 2.607s IP _ PK _ MAX  1 =  2.01A  = 0.736A 3 tS 3 6.486s rep are IP _ RMS _ MAX = (f) Compute secondary maximum peak current I S-PK-MAX and RMS current IS-RMS-MAX for the transformer fabrication. IS_PK_MAX =N PS  I P_PK_MAX = 2  2.01A = 4.02A lP t 3 3 3.711s IP _ PK _ MAX  2 = 2   2.01A  = 1.756A 3 tS 3 6.486s de nti a IS _ RMS _ MAX = N PS  #3. Select secondary power diode .C NPS V D_ F 2 1V orp Known conditions at this step VDC_MAX 57V VOUT 12V on fi Refer to Power Device Design VD_R_MAX = VDC_MAX N PS +VOUT Sil erg 57V +12V 2 =40.5V = yC Compute the voltage and the current stress of secondary power diode I D_PK_MAX =N PS  I P_PK_MAX =2  2.01A=4.02A I D_AVG =1A #4. Set current sense resistor to achieve ideal output current AN_SY56805A1 Rev.0.9B © 2022 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only All Rights Reserved. 16 AN_SY56805A1 Known conditions at this step NPS 2 VLIMIT 1V IOUT,LIM 1.3A The current sense resistor is VLIMIT I P _ PK _M AX RO N RS = 1V 2.01A =0.498Ω IR IT = Set Rs or K Rs=0.5 dF #5. Set ZCS pin Refer to VOUT Parameters Designed RZCSU rep are First identify RZCSU need for line regulation. lP 56kΩ Conditions VOUT RZCSU NAUX de nti a Then compute RZCSD 12V 56kΩ 9 VZCS_REF NS 1.2V 9 on fi R ZCSU 56K = = 6.8K VOUT NAUX 12V  9 − 1) -1 ( (1.2V+0.1) 9 (VZCS_REF +0.1V)NS .C R ZCSD = orp Set RZCSD (Note: In consideration of the propagation delay of internal circuit, a 0.1V is added to VZCS_REF for compensation.) yC R ZCSD =6.8kΩ erg #6. Set DEN pin Connect a 24.9kΩ resistor from DEN to VDD Sil #7. Set CLS pin Connect a 1.27kΩ resistor from CLS to VSS #9. Final result AN_SY56805A1 Rev.0.9B © 2022 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only All Rights Reserved. 17 AN_SY56805A1 C4 1nF/250V C3 1μF/100V VDD DEN VCC D1 SMBJ58A T1 50µH/EP13 CLS DRAIN R9 D5 PT5V100B 20 C5 C7 0.1µF/25V 10µF/25V R3 10 RCLS 1.27k From Ethernet 4-5,7-8 R2 10 D2 BAV21W RDEN 24.9k C1 68nF/100V R1 20k ZCS D4 BAV21W C6 10µF/25V C8 10μF/25V R4 56k VSS R5 6.8k SOURCE APD D3 PT3L100F-A C10 220μF/16V R7 1 R8 1 - Vout + or K R6 100 IR IT RTN C11 470pF/100V R10 1k CS RAPD 0 C9 10μF/25V RO N From Ethernet 1-2,3-6 C2 22μF/63V Sil erg yC orp .C on fi de nti a lP rep are dF Fig.9 Design example VIN=37V-57V, PoE application, Vout=12V@1A AN_SY56805A1 Rev.0.9B © 2022 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only All Rights Reserved. 18 AN_SY56805A1 or K IR IT RO N QFN5x5-32L Package outline & PCB Layout Bottom View PCB layout (Recommended) All dimension in millimeter and exclude mold flash & metal burr. Sil Notes: erg yC Side View orp .C on fi de nti a lP rep are dF Top View AN_SY56805A1 Rev.0.9B © 2022 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only All Rights Reserved. 19 AN_SY56805A1 Taping & Reel Specification Feeding direction or K IR IT RO N 1. Taping orientation de nti a lP rep are dF 2. Carrier Tape & Reel specification for packages Reel size (Inch) Trailer length(mm) Leader length (mm) Qty per reel 12 8 13" 400 400 5000 yC Pocket pitch(mm) Sil QFN5×5 Tape width (mm) erg Package types orp .C on fi Reel Size 3. Others: NA AN_SY56805A1 Rev.0.9B © 2022 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only All Rights Reserved. 20 AN_SY56805A1 Revision History The revision history provided is for informational purpose only and is believed to be accurate, however, not warranted. Please make sure that you have the latest revision. Date Revision Change Revision 0.9B Update the VVCC_SCP Threshold April 15, 2021 Revision 0.9A Update the Package outline & PCB Layout information October 23, 2020 Revision 0.9 Initial Release Sil erg yC orp .C on fi de nti a lP rep are dF or K IR IT RO N April 2, 2022 AN_SY56805A1 Rev.0.9B © 2022 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only All Rights Reserved. 21 AN_SY56805A1 IMPORTANT NOTICE 1. Right to make changes. Silergy and its subsidiaries (hereafter Silergy) reserve the right to change any information published in this document, including but not limited to circuitry, specification and/or product design, manufacturing or descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Buyers should obtain the latest relevant information before placing orders and should verify that such information is current and complete. All semiconductor products are sold subject to Silergy’s standard terms and conditions of sale. or K IR IT RO N 2. Applications. Application examples that are described herein for any of these products are for illustrative purposes only. Silergy makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Buyers are responsible for the design and operation of their applications and products using Silergy products. Silergy or its subsidiaries assume no liability for any application assistance or designs of customer products. It is customer’s sole responsibility to determine whether the Silergy product is suitable and fit for the customer’s applications and products planned. To minimize the risks associated with customer’s products and applications, customer should provide adequate design and operating safeguards. Customer represents and agrees that it has all the necessary expertise to create and implement safeguards which anticipate dangerous consequences of failures, monitor failures and their consequences, lessen the likelihood of failures that might cause harm and take appropriate remedial actions. Silergy assumes no liability related to any default, damage, costs or problem in the customer’s applications or products, or the application or use by customer’s third-party buyers. Customer will fully indemnify Silergy, its subsidiaries, and their representatives against any damages arising out of the use of any Silergy components in safetycritical applications. It is also buyers’ sole responsibility to warrant and guarantee that any intellectual property rights of a third party are not infringed upon when integrating Silergy products into any application. Silergy assumes no responsibility for any said applications or for any use of any circuitry other than circuitry entirely embodied in a Silergy product. lP rep are dF 3. Limited warranty and liability. Information furnished by Silergy in this document is believed to be accurate and reliable. However, Silergy makes no representation or warranty, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Silergy be liable for any indirect, incidental, punitive, special or consequential damages, including but not limited to lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges, whether or not such damages are based on tort or negligence, warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Silergy’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Standard Terms and Conditions of Sale of Silergy. on fi de nti a 4. Suitability for use. Customer acknowledges and agrees that it is solely responsible for compliance with all legal, regulatory and safety-related requirements concerning its products, and any use of Silergy components in its applications, notwithstanding any applications-related information or support that may be provided by Silergy. Silergy products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Silergy product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Silergy assumes no liability for inclusion and/or use of Silergy products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. orp .C 5. Terms and conditions of commercial sale. Silergy products are sold subject to the standard terms and conditions of commercial sale, as published at http://www.silergy.com/stdterms, unless otherwise agreed in a valid written individual agreement specifically agreed to in writing by an authorized officer of Silergy. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Silergy hereby expressly objects to and denies the application of any customer’s general terms and conditions with regard to the purchase of Silergy products by the customer. erg yC 6. No offer to sell or license. Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Silergy makes no representation or warranty that any license, either express or implied, is granted under any patent right, copyright, mask work right, or other intellectual property right. Information published by Silergy regarding third-party products or services does not constitute a license to use such products or services or a warranty or endorsement thereof. Use of such information may require a license from a third party under the patents or other intellectual property of the third party, or a license from Silergy under the patents or other intellectual property of Silergy. Sil For more information, please visit: www.silergy.com © 2022 Silergy Corp. AN_SY56805A1 Rev.0.9B © 2022 Silergy Corp. Powered by TCPDF (www.tcpdf.org) All Rights Reserved. Silergy Corp. Confidential- Prepared for Customer Use Only All Rights Reserved. 22
SY56805A1QEC 价格&库存
很抱歉,暂时无法提供与“SY56805A1QEC”相匹配的价格&库存,您可以联系我们找货
