SY6018QEC
SY6018QEC
    SILERGY(矽力杰)
    QFN32_5X5MM
    模拟D类音频IC 5.6V~26V QFN32_5X5MM
SY6018QEC 数据手册
Application Notes: AN_SY6018 Analog Class-D Audio IC Features • • • The SY6018 advanced oscillator/PLL circuit employs a multiple switching frequency option to avoid AM/AF interferences; this is achieved together with an option of Master and Slave synchronization, making it possible to synchronize multiple devices. • • • • • de nti a lP The SY6018 is fully protected against faults including short circuit, over temperature, DC error, under voltage and over voltage. The short circuit, over temperature and DC error protection includes an auto-recovery feature. The under voltage and over voltage protection with hysteresis can be self-cleared. rep are • Ordering Information on fi SY6018 □(□□)□ orp Package type QFN5×5-32 Note • • Applications • • • • • • • Flat Panel Display TVs DLP® TVs CRT TVs Powered Speakers Music Instruments Boom Box Consumer Audio Applications Sil erg yC Ordering Number SY6018QEC .C Temperature Code Package Code Optional Spec Code RO N • IR IT • 2×30W into 8Ω BTL Loads @ 10% THD+N from a 24V Supply 60W into a 4Ω PBTL Load @ 10% THD+N from a 24V Supply Wide Voltage Range: 5.6V to 26V Filter-free Operation Differential and Single-ended Inputs Internal Feedback Control with High PSRR High Efficiency Class-D Operation Eliminates Need for Heat Sinks AM/AF Avoidance Master and Slave Synchronization Four Fixed-gain Controlled: 20dB, 26dB, 32dB and 36dB Selectable BD Mode and 1SPW Mode Modulation Integrated Protection Circuits Including Over Voltage, Under Voltage, Over Temperature, DC Error, and Short Circuit Comprehensive Click and Pop Suppression Space-saving Surface Mount 32Pin QFN 5mm×5mm Package or K • The SY6018 is a Class-D audio power amplifier with analog input and high-power efficiency for driving bridge-tied stereo speakers with up to 2×30W/8Ω or a bridge-tied mono speaker with up to 60W/4Ω. The efficiency of the SY6018 eliminates the need for an external heat sink when playing music. dF General Description AN_SY6018 Rev.0.9D © 2021 Silergy Corp. Silergy Corp. Confidential-prepared for Customer Use Only 1 All Rights Reserved. AN_ SY6018 Typical Applications SY6018 AVDD PVDD AGND LINP Left Channel Negative LINN Right Channel Positive RINP Right Channel Negative RINN GREG PGND BSPL OUTPL OUTNL VREF Shutdown Control Fault Dectect Gain & Master/Slave Selection Mute Control BSNL MODSEL SDZ BSPR or K BD/1SPW Selection FAULTZ OUTPR GAIN/SLV dF MUTE OUTNR AM2 AM1 AM0 Synchronizing to Class-D Devices BSNR SYNC rep are AM/FM Avoidance Control RO N Left Channel Positive 5.6V to 26V IR IT 5.6V to 26V GREG lP (a) Stereo Class-D Amplifier with BTL Output AVDD PVDD AGND PGND LINP BSPL LINN OUTPL on fi 5.6V to 26V de nti a SY6018 RINP Left Channel Negative RINN orp .C Left Channel Positive GREG yC BD/1SPW Selection Shutdown Control erg Fault Dectect Gain & Master/Slave Selection Sil Mute Control AM/FM Avoidance Control Synchronizing to Class-D Devices 5.6V to 26V OUTNL VREF BSNL MODSEL SDZ FAULTZ BSPR OUTPR GAIN/SLV MUTE AM2 AM1 AM0 OUTNR BSNR GREG SYNC (b) Mono Class-D Amplifier with PBTL Output Fig.1 Typical Application Circuit AN_SY6018 Rev.0.9D © 2021 Silergy Corp. Silergy Corp. Confidential-prepared for Customer Use Only 2 All Rights Reserved. AN_ SY6018 OUTPR 29 28 27 26 25 VREF 1 24 PGND GREG 2 23 OUTNR GAIN/SLV 3 22 BSNR AGND 4 LINN 5 20 MODSEL 21 PGND IR IT THERMAL PAD RO N BSPR 30 PVDD FAULTZ 31 SDZ RINP 32 PVDD RINN Pinout (top view) 6 19 BSNL 7 18 OUTNL AM2 8 17 PGND 13 14 15 16 PVDD BSPL OUTPL rep are (QFN5×5-32) dF 12 PVDD AM0 AM1 11 AVDD 10 SYNC 9 or K LINP MUTE Sil erg yC orp .C on fi de nti a lP Top Mark: BHLxyz (device code: BHL, x=year code, y=week code, z= lot number code) Pin Name Pin Number Description VREF 1 Internal reference pin. Connect to GREG directly. GREG Gate drive supply. Nominal voltage is 3.4V. 2 Gain & Master/Slave mode selection depending on voltage divider from GREG GAIN/SLV 3 to GND. AGND Analog Ground. 4 LINN 5 Negative audio input for left channel. Biased at 1.7V. LINP 6 Positive audio input for left channel. Biased at 1.7V. Mute pin (high=mute, low=unmute), TTL logic levels with compliance to MUTE 7 AVDD. AM2 8 AM/AF avoidance frequency selection. AM1 9 AM/AF avoidance frequency selection. AM0 10 AM/AF avoidance frequency selection. Clock input/output for synchronizing other Class-D devices. Determined by SYNC 11 GAIN/SLV pin. AVDD 12 Analog power supply. Not internally connected to PVDD. PVDD 13 Power supply. PVDD 14 Power supply. BSPL 15 Bootstrap for left positive channel output. OUTPL 16 Positive left channel output. PGND 17 Power Ground. OUTNL 18 Negative left channel output. BSNL 19 Bootstrap for left negative channel output. Mode selection (low=BD, high=1SPW), TTL logic levels with compliance to MODSEL 20 AVDD. PGND 21 Power Ground. BSNR 22 Bootstrap for right negative channel output. OUTNR 23 Negative right channel output. PGND 24 Power Ground. OUTPR 25 Positive left channel output. AN_SY6018 Rev.0.9D © 2021 Silergy Corp. Silergy Corp. Confidential-prepared for Customer Use Only 3 All Rights Reserved. AN_ SY6018 26 27 28 SDZ 29 FAULTZ 30 RINP RINN Thermal Pad 31 32 33 Bootstrap for right positive channel output. Power supply. Power supply. Shutdown pin (low = enter shutdown, high = exit shutdown). TTL logic levels with compliance to AVDD. Open drain output used to display general fault, including SCP, OTP, DCP fault status (low=fault, high=normal). Positive audio input for right channel. Biased at 1.7V. Negative audio input for right channel. Biased at 1.7V. Connect to GND for best system performance. RO N BSPR PVDD PVDD or K IR IT Block Diagram GREG GREG OUTPR RINP RINN INPUT CIRCUIT Differential Modulation and Compensation OUTNR ANTICLICK & POP lP VREF SYNC GAIN/SLV AM DCP de nti a VREF BSPR PVDD PBTL dF LDO rep are AVDD GREG PVDD DRIVER OUTPR PGND PWM LOGIC PVDD DRIVER PVDD GREG OUTNR BSNR RAMP on fi UVLO/OVLO FAULT & CONTROL orp .C FAULTZ BSPL GREG PVDD SCP PVDD PBTL OTP DRIVER PGND OUTPL LINP yC LINN INPUT CIRCUIT PWM LOGIC PVDD OUTNL PBTL DRIVER PVDD GREG Sil AGND Differential Modulation and Compensation erg INPUT SENSE OUTPL OUTNL BSNL Fig.2 Block Diagram AN_SY6018 Rev.0.9D © 2021 Silergy Corp. Silergy Corp. Confidential-prepared for Customer Use Only 4 All Rights Reserved. AN_ SY6018 Absolute Maximum Ratings (Note 1) RO N AVDD, PVDD (Note 2) -------------------------------------------------------------------------------------------- -0.3V to 30V RIN, LIN ----------------------------------------------------------------------------------------------------------- -- -0.3V to 3.6V MODSEL, SDZ, MUTE, AM2, AM1, AM0 ------------------------------------------------------ -0.3V to (AVDD +0.3)V VREF, GAIN/SLV, SYNC ---------------------------------------------------------------------------- -0.3V to (GREG+0.3)V Minimum Load Resistance Output Configuration ------------------------------------------------------------------------- 3.2Ω Junction Temperature Range ---------------------------------------------------------------------------------- -40°C to 150°C Storage Temperature Range ------------------------------------------------------------------------------------- -40°C to 125°C Package Thermal Resistance IR IT θ JA (Note 3) ------------------------------------------------------------------------------------------------------ 22°C/W θ JC ------------------------------------------------------------------------------------------------------------------ 8°C/W Recommended Operating Conditions dF or K Supply Voltage Range ------------------------------------------------------------------------------------------------ 5.6V to 26V Junction Temperature Range ----------------------------------------------------------------------------- -40°C to 125°C Ambient Temperature Range ------------------------------------------------------------------------------- -40°C to 85°C Electrical Characteristics Min 18.5 100 de nti a Unit 26 V mA μA 122 V 1.75 V 0.75 on fi .C orp Max 2.05 4 V 1 V 0.22 V 0.1 μA 6 8 μA 105 130 mΩ -0.1 yC erg Sil AN_SY6018 Rev.0.9D © 2021 Silergy Corp. Typ 5.6 lP rep are (TA =25°C, VDD=19V, RL=8Ω, Gain=26dB, unless otherwise specified.) Parameter Symbol Test Conditions DC Characteristics AVDD, PVDD VDD SDZ=1, no load or filter (Note 4) Quiescent Supply Current IQ SDZ=0, no load or filter SDZ, SYNC, MUTE, AM2, AM1, AM0 High-level Input Voltage VIH MODSEL (Note 4) SDZ, SYNC, MUTE, AM2, AM1, AM0 Low-level Input Voltage VIL MODSEL (Note 4) FAULTZ, RPULL-UP=100kΩ, Low-level Output Voltage VOL (Note 4) PVDD=26V MODESEL, MUTE, AM2, AM1, AM0, VI= 2V High-level Input Current IIH SDZ, VI= 2V Drain-Source On-State RDS(ON) Resistance R1=Open, R2=5.6kΩ, no load (Note 4) R1=100kΩ, R2=20kΩ, no load Gain (Master) G R1=100kΩ, R2=39kΩ, no load (Note 4) R1=75kΩ, R2=47kΩ, no load (Note 4) 20 25.5 26 32 26.5 dB 36 Silergy Corp. Confidential-prepared for Customer Use Only 5 All Rights Reserved. AN_ SY6018 tON tOFF Output Offset Voltage |VOS| Gate Drive Supply GREG Oscillator Frequency fOSC dF rep are AC Characteristics (Note 4) Vn 20Hz to 22kHz, A-weighted filter, Gain=20dB Max output at THD+N
SY6018QEC 价格&库存
很抱歉,暂时无法提供与“SY6018QEC”相匹配的价格&库存,您可以联系我们找货
