SY6282LACC
SY6282LACC
    SILERGY(矽力杰)
    TSOT-23-5
    6V,2.5A低损耗配电开关
SY6282LACC 数据手册
Application Note: SY6282L 6V, 2.5A Low Loss Power Distribution Switch General Description Features        SY6282 □(□□)□ Temperature Code Package Code Optional Spec Code Applications      Note USB 3G Datacard USB Dongle MiniPCI Accessories USB Charger Public Place Multi-USB Charger dF Package type TSOT23-5 rep are Ordering Number SY6282LACC or W Ordering Information oo ko o Input Voltage: 2.4V to 6V 2.5A Load Current Capability Programmable Current limit Over Temperature Protection Reverse Blocking (No Body Diode) OUT Can be Forced Higher Than IN at Shutdown Compact TSOT23-5 Package Minimizes the Board Space  RoHS Compliant and Halogen Free SY6282L is ultra-low RDS(ON) switch with programmable current limit to protect the power source from over current and short circuit conditions. It incorporates over temperature protection and reverse blocking function. 5 de nti a VIN lP Typical Application IN OUT VOUT 1 SY6282L CIN 10µF .C ISET GND RSET 6.8kΩ 2 Figure1. Schematic Diagram Sil erg yC orp COUT 10µF 3 EN on fi 4 AN_SY6282L Rev. 0.9A © 2018 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 1 All Rights Reserved. AN_SY6282L OUT 1 GND 2 ISET 3 5 IN 4 EN (TSOT23-5) oo ko o Pinout (top view) Pin number 1 2 ISET 3 EN IN 4 5 Pin Description Output pin, decoupled with a 10µF capacitor to GND. Ground pin. Current limit programming pin. Connect a resistor R SET from this pin to ground to program the current limit: ILIM (A)=6800/RSET (Ω) ON/OFF control. Pull high to enable IC. Do not leave it floating. Input pin, decoupled with a 10µF capacitor to GND. lP rep are dF Pin Name OUT GND or W Top mark: Vmxyz for SY6282LACC (Device code: Vm, x=year code, y=week code, z= lot number code) Current Sense Current Limit yC Driver OUT ISET GND Thermal Sense Sil erg EN orp UVLO .C IN on fi de nti a Block Diagram Figure2. Block Diagram AN_SY6282L Rev. 0.9A © 2018 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 2 All Rights Reserved. AN_SY6282L Absolute Maximum Ratings (Note 1) oo ko o IN, OUT, EN, ISET ---------------------------------------------------------------------------------------------------- -0.3V to 7V Power Dissipation, PD @ TA = 25°C TSOT23-5 -------------------------------------------------------------------------- 1.46W Package Thermal Resistance (Note 2) θ JA --------------------------------------------------------------------------------------------------------------- 68.5°C/W θ JC ----------------------------------------------------------------------------------------- ---------------------- 10.9°C/W Junction Temperature Range ------------------------------------------------------------------------------------- -40°C to 150°C Lead Temperature (Soldering, 10 sec.) ------------------------------------------------------------------------------------ 260°C Storage Temperature Range ------------------------------------------------------------------------------------- -65°C to 150°C Recommended Operating Conditions (Note 3) rep are dF or W IN------------------------------------------------------------------------------------------------------------------------ 2.4V to 6V OUT, ISET--------------------------------------------------------------------------------------------------------------- 0V to 6V EN ---------------------------------------------------------------------------------------------------------------------------- 0V to IN Junction Temperature Range ------------------------------------------------------------------------------------- -40°C to 125°C Ambient Temperature Range -------------------------------------------------------------------------------------- -40°C to 85°C Electrical Characteristics yC orp .C on fi de nti a lP (VIN = 5V, COUT=10µF, TA = 25°C, unless otherwise specified.) Parameter Symbol Test Conditions Input Voltage Range VIN Shutdown Input Current ISHDN Open load, IC disabled Quiescent Supply Current IQ Open load, IC enabled FET RON RDS(ON) EN Rising Threshold VEN(H) EN Falling Threshold VEN(L) EN Leakage Current IEN VEN=5.0V IN UVLO Threshold VIN_UVLO IN UVLO Hysteresis VIN_HYS Over Current Limit ILIM RSET=6.8kΩ Programmable current limit range IRANGE Turn-on Time tON RL=10Ω, COUT=1µF Turn-off Time tOFF RL=10Ω, COUT=1µF Thermal Shutdown Temperature tSD Thermal Shutdown Hysteresis tSD_HYS Min 2.4 Typ 0.2 38 80 Max 6 1 2 0.8 1 2.3 0.75 0.4 0.1 1 130 20 150 20 1.25 2.5 Unit V µA µA mΩ V V µA V V A A µs µs ℃ ℃ Sil erg Note 1: Stresses beyond the “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Note 2: θ JA is measured in the natural convection at T A = 25°C on a Silergy test board. Pin 2 of TSOT23-5 package is the case position for θ JC measurement. Note 3: The device is not guaranteed to function outside its operating conditions. AN_SY6282L Rev. 0.9A © 2018 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 3 All Rights Reserved. AN_SY6282L Typical Performance Characteristics RDS(ON) vs. Load Current Input Quiescent Current vs. Input Voltage 120 VIN=3.3V 0 VIN=5V 110 34 100 32 90 30 28 26 24 80 oo ko o RDS(ON) (mΩ) 70 60 50 40 30 20 22 or W Input Quiescent Current (μA) 36 10 20 2.5 3 3.5 4 4.5 5 0 5.5 0 0.5 2 2.5 3 dF RLIM vs. ILIM rep are RDS(ON) vs. Input Voltage 120 4.0 110 3.5 100 3.0 90 70 de nti a 60 50 40 20 0 3 3.5 4 4.5 1.0 0.5 0 2 5.5 4 6 8 Rise Time (μs) 2 18 20 5.5 6 120 Sil 3 16 140 erg 4 14 160 yC 5 12 Rise Time vs. VIN Output Voltage vs. Output Current 6 10 RLIM (kΩ) orp Input Voltage (V) 5 2.0 .C 2.5 2.5 1.5 on fi 10 ILIM (A) lP 80 30 Output Voltage (V) 1.5 Load Current (A) Input Voltage (V) RDS(ON) (mΩ) 1 100 80 60 40 RLIM = 6.8k(ILIM = 1A) 1 20 0 0 0 0.2 0.4 0.6 0.8 Output Current (A) AN_SY6282L Rev. 0.9A © 2018 Silergy Corp. 1 1.2 1.4 2 2.5 3 3.5 4 4.5 5 VIN (V) Silergy Corp. Confidential- Prepared for Customer Use Only 4 All Rights Reserved. AN_SY6282L VIN 1V/div VOUT 1V/div IO 1A/div (VIN=3.3V, IO=2.5A) IO 1A/div rep are (VIN=3.3V, IO=0.5A) VIN 2V/div VOUT 2V/div lP 0.2A/div IO 0.2A/div Time (2ms/div) Sil erg yC orp .C Time(2ms/div) on fi IO 1V/div de nti a 2V/div 1V/div Shutdown from VIN (VIN=3.3V, IO=0.5A) VOUT VIN VOUT Time (2μs/div) Startup from VIN 2V/div 2V/div dF Time (40μs/div) VIN EN oo ko o 2V/div Shutdown from Enable (VIN=3.3V, IO=2.5A) or W EN Startup from Enable AN_SY6282L Rev. 0.9A © 2018 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 5 All Rights Reserved. AN_SY6282L Current Limiting Setting Applications Information Current limit is programmable to protect the power source from over current and short circuit conditions. Connect a resistor RSET from ISET pin to GND to program the current limit: SY6282L is a current limited P-channel MOSFET power switch with over current and over temperature protections. There is no body diode across the drain and the source of the MOSFET. It prevents the current flow from the output to the input after the chip is disabled. oo ko o ILIM (A) = 6800 / RSET (Ω) The minimum current limit is 0.4A. Current limit beyond 2.5A is not recommended. Over Current Protection When the over current condition is detected, the switch is regulated to achieve constant output current. If the over current condition lasts for a long time, and results in a junction temperature over 150°C, the switch will be shutdown. Once the junction temperature drops to 130°C, the part will restart. Maximum Input Voltage Consideration: or W For any application, input voltage for SY6282L should not be allowed to exceed the maximum recommended value (6V). Below is a typical application circuit for SY6282L. The front stage is a non-synchronous Boost stage and the input power supply can be a battery or an adapter. rep are Some adapters may have poor output voltage tolerance, or may have large output voltage overshoot if the adapter is hot plug in directly. The voltage overshoot higher than VIN (6V) will significantly reduce the reliability of SY6282L and may even lead to IC EOS failure. de nti a lP In order to prevent the input voltage from dropping during hot-plug condition, a 10µF ceramic capacitor from VIN to GND is strongly recommended. However, higher capacitance could help reduce the voltage drop. Furthermore, an output short will cause ringing on the input without the input capacitor. It could destroy the internal circuitry when the input transient voltage exceeds the absolute maximum supply voltage even for a short duration. dF Supply Filter Capacitor IN orp CIN .C Battery or Adapter Input D on fi L Long wire 5 CIN:10µF 4 FB yC GND VIN erg Sil OUT 1 COUT:10µF SY6282L EN VOUT 3 ISET GND Non-synchronous Boost IC AN_SY6282L Rev. 0.9A © 2018 Silergy Corp. IN 2 Figure3. USB Host Application Silergy Corp. Confidential- Prepared for Customer Use Only 6 All Rights Reserved. AN_SY6282L PCB Layout Guide 2) Keep all power traces as short and wide as possible and use at least 2 ounce copper for all power traces. Locate the output capacitors as close to the connectors as possible to lower the impedance (mainly inductance) between the port and the capacitor and improve transient performance. 4) Place a ground plane under all circuitry to lower both resistance and inductance and improve DC and transient performance. Input and output capacitors should be placed close to the IC and connected to the ground plane to reduce noise coupling. 5) Locate the ceramic bypass capacitors as close as possible to the IN pin and OUT pin of SY6282L. oo ko o 1) 3) or W To achieve a better performance, the following guidelines must be strictly followed: COUT CIN OUT OUT GND GND GND IN EN EN REN GND on fi RSET de nti a OCB ISET GND IN IN lP OUT rep are dF GND Sil erg yC orp .C Figure4. PCB Layout Suggestion AN_SY6282L Rev. 0.9A © 2018 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 7 All Rights Reserved. AN_SY6282L TSOT23-5 Package outline & PCB Layout Design 0.55 1.50 - 1.70 oo ko o dF 0.80 or W 2.70 - 3.00 2.40 2.80 - 3.10 0.95 TYP 0.30 - 0.50 0.01 - 0.1 1.00 (max) 0.25 REF de nti a lP 0.1 - 0.20 rep are Recommended Pad Layout 0.95 TYP 1.90 TYP orp .C on fi 0.3 - 0.6 Sil erg yC Notes: All dimensions are in millimeters. All dimensions don’t include mold flash & metal burr. AN_SY6282L Rev. 0.9A © 2018 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 8 All Rights Reserved. AN_SY6282L Taping & Reel Specification 1. Taping orientation TSOT23-5 3.9/4.1 dF rep are Feeding direction or W 7.7/8.3 oo ko o 1.45/1.55 erg .C yC orp Reel Size on fi de nti a lP 2. Carrier Tape & Reel specification for packages Tape width (mm) Pocket pitch(mm) Reel size (Inch) Trailer length(mm) Leader length (mm) Qty per reel 8 4 7" 280 160 3000 Sil Package type TSOT23-5 3. Others: NA AN_SY6282L Rev. 0.9A © 2018 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 9 All Rights Reserved. AN_SY6282L IMPORTANT NOTICE 1. Right to make changes. Silergy and its subsidiaries (hereafter Silergy) reserve the right to change any information published in this document, including but not limited to circuitry, specification and/or product design, manufacturing or descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Buyers should obtain the latest relevant information before placing orders and should verify that such information is current and complete. All semiconductor products are sold subject to Silergy’s standard terms and conditions of sale. dF or W oo ko o 2. Applications. Application examples that are described herein for any of these products are for illustrative purposes only. Silergy makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Buyers are responsible for the design and operation of their applications and products using Silergy products. Silergy or its subsidiaries assume no liability for any application assistance or designs of customer products. It is customer’s sole responsibility to determine whether the Silergy product is suitable and fit for the customer’s applications and products planned. To minimize the risks associated with customer’s products and applications, customer should provide adequate design and operating safeguards. Customer represents and agrees that it has all the necessary expertise to create and implement safeguards which anticipate dangerous consequences of failures, monitor failures and their consequences, lessen the likelihood of failures that might cause harm and take appropriate remedial actions. Silergy assumes no liability related to any default, damage, costs or problem in the customer’s applications or products, or the application or use by customer’s third-party buyers. Customer will fully indemnify Silergy, its subsidiaries, and their representatives against any damages arising out of the use of any Silergy components in safety-critical applications. It is also buyers’ sole responsibility to warrant and guarantee that any intellectual property rights of a third party are not infringed upon when integrating Silergy products into any application. Silergy assumes no responsibility for any said applications or for any use of any circuitry other than circuitry entirely embodied in a Silergy product. de nti a lP rep are 3. Limited warranty and liability. Information furnished by Silergy in this document is believed to be accurate and reliable. However, Silergy makes no representation or warranty, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Silergy be liable for any indirect, incidental, punitive, special or consequential damages, including but not limited to lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges, whether or not such damages are based on tort or negligence, warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Silergy’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Standard Terms and Conditions of Sale of Silergy. on fi 4. Suitability for use. Customer acknowledges and agrees that it is solely responsible for compliance with all legal, regulatory and safety-related requirements concerning its products, and any use of Silergy components in its applications, notwithstanding any applications-related information or support that may be provided by Silergy. Silergy products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Silergy product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Silergy assumes no liability for inclusion and/or use of Silergy products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. orp .C 5. Terms and conditions of commercial sale. Silergy products are sold subject to the standard terms and conditions of commercial sale, as published at http://www.silergy.com/stdterms, unless otherwise agreed in a valid written individual agreement specifically agreed to in writing by an authorized officer of Silergy. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Silergy hereby expressly objects to and denies the application of any customer’s general terms and conditions with regard to the purchase of Silergy products by the customer. Sil erg yC 6. No offer to sell or license. Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Silergy makes no representation or warranty that any license, either express or implied, is granted under any patent right, copyright, mask work right, or other intellectual property right. Information published by Silergy regarding third-party products or services does not constitute a license to use such products or services or a warranty or endorsement thereof. Use of such information may require a license from a third party under the patents or other intellectual property of the third party, or a license from Silergy under the patents or other intellectual property of Silergy. For more information, please visit: www.silergy.com © 2018 Silergy Corp. AN_SY6282L Rev. 0.9A © 2018 Silergy Corp. Powered by TCPDF (www.tcpdf.org) All Rights Reserved. Silergy Corp. Confidential- Prepared for Customer Use Only 10 All Rights Reserved.
SY6282LACC 价格&库存
很抱歉,暂时无法提供与“SY6282LACC”相匹配的价格&库存,您可以联系我们找货
