Application Note: SY6974B
3A, Single Cell Li-Ion DC/DC Switching Charger with
I2C Control, USB Detection and OTG
JEITA Compliant, Power Path Management
General Description
The SY6974B is a fully-integrated switching battery
charger with system power path management devices
for single cell Li-ion and Li-polymer battery in a
wide range of tablet and other portable devices. Its
low impedance power path optimizes switching
conversion efficiency, reduces battery charging time
and extends battery life during the discharging mode.
The I2C serial interface with charging and system
settings makes the device a truly flexible solution.
The device supports a wide range of input sources,
including standard USB host port, USB charging
port and non-standard DC adapter. The SY6974B
takes the result from the internal USB port
identification circuit thru DP/DM compliant with
BC1.2. Meanwhile, the SY6974B meets USB Onthe-Go operation power rating specification by
supplying 5.15V (programmable) on BUS with
current limit up to 1.2A (programmable).
The power path management regulates the system
voltage slightly above battery voltage but does not
drop below 3.5V minimum system voltage
(programmable). With this feature, the switching
converter will keep working to support the system
load even when the battery is completely depleted or
removed. When the input current limit or voltage
limit is reached, the power path management will
reduce the charging current to zero firstly. If the
system load continues to increase, the power path
will discharge the battery to provide the power
required by system. This supplement mode operation
prevents overloading the input source.
AN_SY6974B Rev.0.9
© 2020 Silergy Corp.
The device initiates and completes a charging cycle
without software control. It automatically detects the
battery voltage and charges the battery in five phases:
battery short, preconditioning, constant current and
constant voltage and top-off charging (optional). At
the end of the charging cycle, the charger
automatically will terminate when the charge current
is below a preset limit in the constant voltage phase.
When the full battery falls below the recharge
threshold, the charger will automatically start another
charging cycle. The SY6974B can be compliant with
JEITA spec for the 4.2V Li-ion battery.
The device provides various safety features for
battery charging and system operation, including
negative thermistor monitoring, charging safety timer
and over-voltage / over-current protections. The
thermal regulation will reduce charge current when
the
junction
temperature
exceeds
110°C
(programmable).
The STAT output reports the charging status and any
fault conditions. The INT immediately will notify the
host when a fault occurs.
The SY6974B are available in QFN4x4-24 package.
Ordering Information
SY6974 □(□□)□
Temperature Code
Package Code
Optional Spec Code
Ordering Number
SY6974BQCC
Package type
Note
QFN4x4-24
Silergy Corp. Confidential- Prepared for Customer Use Only
-1All Rights Reserved.
AN_SY6974B
Features
High Efficiency 3A 1.5MHz Buck Mode
Charger
– Support 3.9V-13.5V Input Voltage Range
– Programmable IDPM/VDPM to Support the
USB and Adapter
– 3.856V-4.624V Adjustable Charge Voltage
– Support Narrow VDC Power Path
Management
– JEITA Compliance
– ±0.5% Charge Voltage Regulation
– Charge Status Outputs for LED or Host
Processor
Maximum 1.2A 1.5MHz Boost OTG Current
– 4.85V-5.3V Adjustable OTG Output
Voltage
– Selectable OTG Output Current Limit
– ±1.5% Output Regulation in Boost Mode
– Soft-Start up to 500µF Capacitive Load
– Constant Current (CC) Limit
Full BATFET Control to Support Shipping
Mode, Wake up, and System Reset
Safety
– Battery Temperature Sensing for Charge and
Boost Mode
– Battery Charging Safety Timer
– Thermal Regulation and Thermal Shutdown
– Input/System over-Voltage Protection
– MOSFET over-Current Protection
Low Battery Leakage Current and Support
Shipping Mode
4mm x 4mm QFN-24 Package
Applications
Smart Phone
Tablet PC
Power Bank
Portable Internet Devices
Typical Application
3.9V-13.5V
USB
VBUS SY6974B
1µF
PMID
10µF
VAC
PGND
DM
DP
1µH
SYSTEM
LX
47nF
10µF
10µF
BST
SYS
STAT
SYS
VBIAS
BAT
10µF
Battery
SCL
Host
SDA
/INT
REGN
4.7µF
/CE
5.23k
/QON
NTC
Power Pad
10k
(103-AT)
30.1k
Figure 1. Schematic Diagram
AN_SY6974B Rev.0.9
-2All Rights Reserved.
AN_SY6974B
BUS
PMID
REGN
BST
LX
LX
Pinout
24
23
22
21
17
PGND
DM
3
16
SYS
STAT
4
15
SYS
SCL
5
14
BAT
SDA
6
13
BAT
7
8
9
10
11
12
/QON
2
NTC
DP
NC
PGND
/CE
18
NC
1
/INT
VAC
(QFN4x4-24)
Top Mark: DDNxyz(device code: DDN, x=year code, y=week code, z= lot number code)
Pin Name
Pin No
Pin Description
VAC
DP
1
2
DM
3
STAT
4
SCL
SDA
5
6
/INT
7
NC
8, 10
/CE
9
NTC
11
/QON
12
BAT
13,14
Charge input voltage sense. This pin must be connected close to BUS pin.
USB identification port. USB detection strategy is compliant with BC1.2. SDP, CDP,
DCP and adapter port can be identified according to the detection results thru DP/DM
pins.
Open drain charge status output to indicate various charger operation. Connect to the pull
up rail via 10kΩ resistor. Low indicates charge in progress. High indicates charge
complete or charge disabled. When any charge fault condition occurs, STAT pin will
blink at 1Hz.
The STAT pin function can be disabled when STAT_DIS bit is set.
I2C Interface clock. Connect SCL to the logic rail through a 10kΩ resistor.
I2C Interface data. Connect SDA to the logic rail through a 10kΩ resistor.
Open-drain interrupt output. Connect the /INT to a logic rail via 10kΩ resistor. The /INT
pin sends active low, 256μs pulse to host to report charger device status and fault.
No connect.
Active low charge enable pin. Battery charging will be enabled when REG01[4]=1 and
/CE pin =Low. /CE pin must be pulled high or low.
Connect a resistor divider from REGN to NTC to GND to achieve battery thermal
protection. Charge will suspend when NTC pin is out of range.
Recommend 103AT-2 thermistor.
BATFET enable control in shipping mode and BATFET reset function.
When BATFET is in shipping mode, logic high to low transition on this pin with
minimum of TQON_LOW low level will turn on BATFET to exit shipping mode. This pin is
internally pulled up to default high logic.
When BUS is not plugged in and BATFET_DIS=0, a logic low of TQON_RST will reset
SYS (system power) by turning BATFET off for TBATFET_RST and then re-enable
BATFET.
Battery connection point to the positive terminal of the battery pack. The internal
BATFET is connected between BAT and SYS. Connect a 10μF closely to the BAT pin
AN_SY6974B Rev.0.9
-3All Rights Reserved.
AN_SY6974B
SYS
15,16
PGND
17,18
LX
BST
19,20
21
REGN
22
PMID
23
BUS
24
Exposed
pad
AN_SY6974B Rev.0.9
System connection point. The internal BATFET is connected between BAT and SYS.
When the battery falls below the minimum system voltages, switch mode converter will
keep SYS above the minimum system voltage.
Power ground connection node. Internally, PGND is connected to the source of the nchannel LSFET. On PCB layout, connect directly to ground connection of input and
output capacitors of the charger.
Switching node pin. Connect to external inductor.
HSFET driver positive supply. Connect a 47nF bootstrap capacitor from LX to BST.
LSFET driver positive supply. Connect a 4.7μF ceramic capacitor from REGN to analog
GND. The capacitor should be placed close to the IC. REGN also serves as bias rail of
NTC pin.
Connected to the drain of the reverse blocking MOSFET and the drain of HSFET. Put at
least 10μF on PMID to PGND, and place it as close as possible to IC.
Charger power input pin. Place a 1μF ceramic capacitor from BUS to PGND and place it
Exposed pad beneath the IC for heat dissipation. Always solder exposed pad to the board,
and have vias on the Power Pad plane star-connecting to PGND and ground plane for
high current power converter.
-4All Rights Reserved.
AN_SY6974B
Absolute Maximum Ratings (Note 1)
BUS, VAC, PMID, LX -------------------------------------------------------------------------------------- -0.3V to +18V
BAT, SYS, REGN, DP, DM, STAT, SCL, SDA, /INT, /CE, NTC, /QON, BST-LX ---------------- -0.3V to +6V
Package Thermal Resistance (Notes 2)
θ JA ------------------------------------------------------------------------------------------------------------------ 27.5°C/W
θ JC (top) -------------------------------------------------------------------------------------------------------------- 18°C/W
θ JB ---------------------------------------------------------------------------------------------------------------------- 8°C/W
JT------------------------------------------------------------------------------------------------------------------ 0.35°C/W
Junction Temperature Range ----------------------------------------------------------------------------- -40°C to +150°C
Operating Temperature Range --------------------------------------------------------------------------- -40°C to +150°C
Storage Temperature -------------------------------------------------------------------------------------- -65°C to +150°C
Lead Temperature (Soldering, 10s) -------------------------------------------------------------------------------- +300°C
ESD Susceptibility
HBM (Human Body Mode) --------------------------------------------------------------------------------------------- 2kV
CDM (Charged Device Mode) ---------------------------------------------------------------------------------------- 200V
Recommended Operating Conditions (Note 3)
BUS, VAC, PMID, LX ----------------------------------------------------------------------------------------- 0V to +16V
BAT, SYS, REGN, DP, DM, STAT, SCL, SDA, /INT, /CE, NTC, /QON, BST-LX ----------------- 0V to +5.5V
Junction Temperature Range ------------------------------------------------------------------------------ -40°C to 125°C
Ambient Temperature Range ------------------------------------------------------------------------------- -40°C to 85°C
AN_SY6974B Rev.0.9
-5All Rights Reserved.
AN_SY6974B
Block Diagram
BUS
VUVLO
VAC
Drive
VSLEEP
LDO
VDPM
VOVP
PMID
Q1
REGN
BST
IDPM
EN_HIZ
TJ
TREG
Loop
Selection
VSYS
Q2
PWM
Generator
LX
LX
VSYSMIN
Protection
VCV
Q3
VBAT
ICC
PGND
PGND
ICHG
DP
NTC
Comparators
USB
Detection
NTC
DM
SYS
SYS
Q4
Control
Q4
BAT
BAT
DAC
Charge & Discharge Control
/QON
I2C
Interface
/INT
STAT
SCL SDA
/CE
Figure 2. Block Diagram
AN_SY6974B Rev.0.9
-6All Rights Reserved.
AN_SY6974B
Electrical Characteristics
(VBUS_UVLOZVBAT,
converter not switching
VBUS> VBUS_UVLOZ, VBUS>VBAT,
converter switching, VBAT=3.8V,
ISYS=0A
VBAT=4.2V, Boost mode,
IBUS=0A, converter switching
3
mA
3.5
mA
BUS/BAT Power up
BUS Operating Range
VBUS_OP
3.9
I2C
VSLEEP
VSLEEPZ
VACOV
VACOV_RC
VBUS falling, REG06[7:6]=00
5.5
5.7
5.9
V
VACOV
VBUS rising, REG06[7:6]=11
13.8
14.1
14.4
V
VACOV_RC
VBUS falling, REG06[7:6]=11
13.5
13.8
14.1
V
Battery for Active I2C, no BUS
VBAT_UVLOZ
Battery Depletion Threshold
Battery Depletion Recovery
Threshold
Bad Adapter Detection Threshold
Bad Adapter Detection Hysteresis
Bad Adapter Detection Current
Source
Bad Source Detection Duration
VBAT_DPL
VBAT rising value to active I2C
VBAT falling
VBAT falling
2.15
2.1
1.8
2.3
2.3
2.0
2.5
V
V
V
VBAT_DPLZ
VBAT rising
2.3
2.55
2.7
V
VBUSMIN
VBUSMIN_HYST
VBUS falling
VBUS rising
3.6
3.7
100
3.8
V
mV
VBUS_UVLOZ
25
170
5.7
V
V
V
mV
mV
V
Sleep Mode Falling Threshold
Sleep Mode Rising Threshold
BUS over-Voltage Rising Threshold
BUS over-Voltage Recovery
Threshold
Threshold
no
3.3
2.9
65
250
5.9
13.5
3.5
3.25
120
300
6.1
Rising value to active
Falling value
VBUS falling, VBUS-VBAT
VBUS rising, VBUS-VBAT
VBUS rising, REG06[7:6]=00
BUS for Active IC and
Battery
I2C,
IBADSRC
30
mA
tBADSRC
30
ms
System Regulation Voltage
VSYS_MAX
VSYS_MIN
AN_SY6974B Rev.0.9
ISYS = 0A, VBAT>VSYSMIN,
BATFET off, VBAT up to 4.35V,
VSYS=VBAT+50mV
ISYS=0A, VBAT780mA
ITERM =60mA, ICHG_REG ≤780mA
ITERM = 180mA, ICHG_REG >
780mA
VBAT falling
VBAT rising
VBAT
