SYT01S05DWC
SYT01S05DWC
    SILERGY(矽力杰)
    DFN2L_1.05X0.65MM
    ESD抑制器/TVS二极管 Vrwm=5V Vbr=6V~11V IPP=2A Ppk=30W
SYT01S05DWC 数据手册
SYT01S05DWC Ultra-Low Capacitance TVS/ESD Protection Applications   Serial ATA  PCI Express  Desktops, Servers and Notebooks IEC 61000-4-5 (Surge) 2A (8/20μs)  Cellular Phones  For 5V and below operating voltage  MDDI Ports  Package optimized for high-speed lines  USB2.0 Power and Data Line Protection  Ultra-small package (1.0mm0.6mm0.55mm)  Display Ports  Protects one data, control or power line  Digital Visual Interfaces (DVI)  Low capacitance: 0.35pF (Typical)  Low leakage current: 10nA @ VRWM (Typical)  Low clamping voltage  Each I/O pin can withstand over 1000 ESD strikes  DFN1.0*0.6-2L package for ±8kV contact discharge  Flammability Rating: UL 94V-0  Marking: Part number (S) Description  Packaging: Tape and Reel SYT01S05DWC is a low-capacitance Transient Voltage Circuit Diagram IEC 61000-4-2 (ESD) ±20kV (Air) ±20kV (Contact) typical capacitance of 0.35pF rep are lP I/O_1 de nti a discharge (ESD) protection for high-speed data interfaces. dF Mechanical Characteristics Suppressor (TVS) designed to provide electrostatic With or W Transient protection for high-speed data lines oo ko o Features only, SYT01S05DWC is designed to protect parasitic-sensitive on fi systems against over-voltage and over-current transient events. It complies with IEC 61000-4-2 (ESD), (±20kV air, ±20kV contact discharge), IEC 61000-4-5 (Surge) uses orp SYT01S05DWC .C (2A, 8/20μs), etc. ultra-small DFN1.0*0.6-2L I/O_2 yC package. Each SYT01S05DWC device can protect one high-speed data line. It offers system designers flexibility Pin Configuration erg to protect single data line where space is a premium concern. The combined features of low capacitance, Sil ultra-small size and high ESD robustness make SYT01S05DWC ideal for high-speed data port and high-frequency line (e.g., USB 2.0 & antenna line) 1 2 applications, such as cellular phones and HD visual devices. DFN1.0x0.6-2L (Top View) SYT01S05DWC Rev.0.9C © 2018 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 1 All Rights Reserved. SYT01S05DWC Absolute Maximum Rating Symbol Parameter Value Units Peak Pulse Current (8/20μs) 2 A PPK Peak Pulse Power (8/20μs) 30 Watts ESD per IEC 61000-4-2 (Air) ±20 VESD oo ko o IPP ESD per IEC 61000-4-2 (Contact) ±20 kV Operating Temperature -40/+125 C TSTG Storage Temperature -55/+150 C or W TOPT VRWM Nominal Reverse Working Voltage IR Reverse Leakage Current @ VRWM VBR Reverse Breakdown Voltage @ IT Test Current for Reverse Breakdown VC Clamping Voltage @ IPP IPP Peak Pulse Current CESD Parasitic Capacitance Reverse Voltage Small Signal Frequency .C f Test Condition orp Symbol yC VRWM VC1 VC1 Sil VBR VRWM = 5V, T = 25C Between I/O and I/O IT = 1mA Between I/O and I/O IPP = 2A, tp = 8/20μs Between I/O and I/O IPP = 16A, tp = 10/100ns Between I/O and GND tp = 10/100ns Between I/O and GND VR = 0V, f = 1MHz Between I/O and I/O erg IR RDYN1,2 CESD1 VRWM VBR VC V IR IT IPP on fi VR IT IR VC VBR VRWM de nti a IT I IPP rep are Parameter lP Symbol dF Electrical Characteristics (T = 25C) Bi-Directional TVS Minimum 6.0 Typical Maximum Units 5.0 V 0.01 1.0 μA 8.8 11 V 15 V 17 V 0.6 Ω 0.35 0.50 pF NOTES 1 Guaranteed by design and not subject to production test. 2 RDYN calculated based on IPP=8A to IPP=16A, tp = 10/100ns. SYT01S05DWC Rev.0.9C © 2018 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 2 All Rights Reserved. SYT01S05DWC Voltage Sweeping of I/O to I/O Insertion Loss S21 of I/O to I/O 2.0 0.10 0.08 0.0 Current(A) . 0.04 0.02 0.00 -0.02 -2.0 -4.0 oo ko o Insertion Loss(dB) 0.06 -6.0 -0.04 -0.06 -8.0 -0.08 -10 -8 -6 -4 -2 0 2 4 6 8 -10.0 1.00E+06 10 Voltage(V) Capacitance vs. Voltage of I/O to I/O (f = 1MHz) 1.00E+09 1.00E+10 Frequency(Hz) rep are 20.0 dF 1 18.0 0.8 16.0 0.7 14.0 12.0 lP 0.6 Clamping Voltage (V) . . 0.5 0.4 de nti a Capacitance(pF) 1.00E+08 Clamping Voltage vs. Peak Pulse Current (8/20μs) 0.9 0.3 0.2 0.1 0 0.5 1 1.5 on fi 0 2 2.5 3 0.0 0 orp 1.5 2 2.5 3 3.5 20.0 . 0.0 Clamping Voltage (V) 20.0 1 ESD Clamping of I/O to I/O (-8kV Contact per IEC 61000-4-2) Sil 40.0 0.5 Peak Pulse Current(A) erg 60.0 6.0 3.5 yC . 80.0 8.0 2.0 ESD Clamping of I/O to I/O (+8kV Contact per IEC 61000-4-2) 100.0 10.0 4.0 .C Reverse Voltage(V) Clamping Voltage (V) 1.00E+07 or W -0.10 0.0 -20.0 -40.0 -60.0 -80.0 -20.0 -100.0 -50 0 50 100 150 200 Time (ns) SYT01S05DWC Rev.0.9C © 2018 Silergy Corp. 250 300 350 400 -50 0 50 100 150 200 250 300 350 Time (ns) Silergy Corp. Confidential- Prepared for Customer Use Only 3 All Rights Reserved. 400 SYT01S05DWC Package Outline  DFN1.0*0.6-2L Package b oo ko o D PIN 1 Bar by Marking L or W E e A rep are dF PIN 1 Identification Chamfer lP A3 de nti a A1 Package Dimensions Dimensions In Millimeters on fi Symbol .C A orp A1 Minimum Maximum 0.400 0.550 0.000 0.050 Sil erg yC A3 Notes: SYT01S05DWC Rev.0.9C © 2018 Silergy Corp. 0.125 REF D 0.950 1.050 E 0.550 0.650 b 0.200 0.300 e L 0.650 BSC 0.450 0.550 All dimension in mm and exclude mold flash & metal burr. Silergy Corp. Confidential- Prepared for Customer Use Only 4 All Rights Reserved. SYT01S05DWC Tape and Reel Specification 3.9/4.1 1.4/1.6 oo ko o 7.7/8.3 1.65/1.85 0.6/0.7 or W 1.1/1.3 0.50/0.70 Pin1 Location 1.9/2.1 dF Dimensions In mm Tape width Pocket Reel size Trailer * Leader * Qty per reel (mm) pitch(mm) (Inch) length(mm) length (mm) (pcs) 8 2 7" 400 400 10000 de nti a DFN1.0*0.6-2L lP Package types rep are Feeding direction Ordering Information orp yC S .C on fi Marking Codes Part Number Working Voltage Quantity Per Reel Reel Size SYT01S05DWC 5V 10,000 7 Inch erg Pin1 Identification Sil Note: (1) “S” is part number. SYT01S05DWC Rev.0.9C © 2018 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 5 All Rights Reserved. SYT01S05DWC IMPORTANT NOTICE 1. Right to make changes. Silergy and its subsidiaries (hereafter Silergy) reserve the right to change any information published in this document, including but not limited to circuitry, specification and/or product design, manufacturing or descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Buyers should obtain the latest relevant information before placing orders and should verify that such information is current and complete. All semiconductor products are sold subject to Silergy’s standard terms and conditions of sale. rep are dF or W oo ko o 2. Applications. Application examples that are described herein for any of these products are for illustrative purposes only. Silergy makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Buyers are responsible for the design and operation of their applications and products using Silergy products. Silergy or its subsidiaries assume no liability for any application assistance or designs of customer products. It is customer’s sole responsibility to determine whether the Silergy product is suitable and fit for the customer’s applications and products planned. To minimize the risks associated with customer’s products and applications, customer should provide adequate design and operating safeguards. Customer represents and agrees that it has all the necessary expertise to create and implement safeguards which anticipate dangerous consequences of failures, monitor failures and their consequences, lessen the likelihood of failures that might cause harm and take appropriate remedial actions. Silergy assumes no liability related to any default, damage, costs or problem in the customer’s applications or products, or the application or use by customer’s third-party buyers. Customer will fully indemnify Silergy, its subsidiaries, and their representatives against any damages arising out of the use of any Silergy components in safety-critical applications. It is also buyers’ sole responsibility to warrant and guarantee that any intellectual property rights of a third party are not infringed upon when integrating Silergy products into any application. Silergy assumes no responsibility for any said applications or for any use of any circuitry other than circuitry entirely embodied in a Silergy product. de nti a lP 3. Limited warranty and liability. Information furnished by Silergy in this document is believed to be accurate and reliable. However, Silergy makes no representation or warranty, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Silergy be liable for any indirect, incidental, punitive, special or consequential damages, including but not limited to lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges, whether or not such damages are based on tort or negligence, warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Silergy’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Standard Terms and Conditions of Sale of Silergy. orp .C on fi 4. Suitability for use. Customer acknowledges and agrees that it is solely responsible for compliance with all legal, regulatory and safety-related requirements concerning its products, and any use of Silergy components in its applications, notwithstanding any applications-related information or support that may be provided by Silergy. Silergy products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Silergy product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Silergy assumes no liability for inclusion and/or use of Silergy products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. erg yC 5. Terms and conditions of commercial sale. Silergy products are sold subject to the standard terms and conditions of commercial sale, as published at http://www.silergy.com/stdterms, unless otherwise agreed in a valid written individual agreement specifically agreed to in writing by an authorized officer of Silergy. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Silergy hereby expressly objects to and denies the application of any customer’s general terms and conditions with regard to the purchase of Silergy products by the customer. Sil 6. No offer to sell or license. Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Silergy makes no representation or warranty that any license, either express or implied, is granted under any patent right, copyright, mask work right, or other intellectual property right. Information published by Silergy regarding third-party products or services does not constitute a license to use such products or services or a warranty or endorsement thereof. Use of such information may require a license from a third party under the patents or other intellectual property of the third party, or a license from Silergy under the patents or other intellectual property of Silergy. For more information, please visit: www.silergy.com © 2018 Silergy Corp. SYT01S05DWC Rev.0.9C © 2018 Silergy Corp. Powered by TCPDF (www.tcpdf.org) All Rights Reserved. Silergy Corp. Confidential- Prepared for Customer Use Only 6 All Rights Reserved.
SYT01S05DWC 价格&库存
很抱歉,暂时无法提供与“SYT01S05DWC”相匹配的价格&库存,您可以联系我们找货
