H7533-2PR
H7533-2PR
    SIPROIN(矽朋)
    SOT89-3
    线性稳压器/LDO 35V输入 输出3.3V 200mA SOT89
H7533-2PR 数据手册
H75XX-2 200mA Current、35V Input Voltage LDO H75XX-2 General Description The H75XX-2 series is a set of three-terminal low power high voltage regulators implemented in CMOS technology. They allow input voltages as high as 35V. They are available with several fixed output voltages ranging from 3.0V to 5.0V. CMOS technology ensures low voltage drop and low quiescent current. Although designed primarily as fixed voltage regulators, these devices can be used with external components to obtain variable voltages and currents. Features ● ● ● ● ● ● Low power consumption Low temperature coefficient Low voltage drop High input voltage (up to 35V) Output voltage accuracy: tolerance ±2% TO92, SOT89 and SOT23-3 package Applications ● Battery-powered equipment ● Communication equipment ● Audio/Video equipment Shanghai Siproin Microelectronics Co. V2.0 1 H75XX-2 Order specification Part No Package Manner of Packing Devices per bag/reel H75XX-2TX TO92 Bag 1000PCS/bag H75XX-2PX SOT89 Reel 1000PCS/reel H75XX-2MX SOT23-3 Reel 3000PCS/reel Description of selection Part No Output Voltage Output Voltage Accuracy H7530-2XX 3.0V ±2% H7533-2XX 3.3V ±2% H7536-2XX 3.6V ±2% H7544-2XX 4.4V ±2% H7550-2XX 5.0V ±2% Print rules Package Marking TO92 75XX-H# SOT89 75XX-H# SOT23-3 XX-H Note:”XX” stands for output voltages. Other voltages can be specially customized. TO92 & SOT89 packages will add a “#” mark at the end of the marking. Type selection guide H75①②③④⑤ Designator Symbol ①② Integer ③ -2 Standard T Package:TO-92 P Package:SOT89 M Package:SOT23-3 R RoHS / Pb Free G Halogen Free ④ ⑤ Shanghai Siproin Microelectronics Co. Description Output Voltage(3.0~5.0V) V2.0 2 H75XX-2 Block Diagram and Pin Arrangement Diagram Pin Assignment Pin No. Pin Name 1 GND Ground connection. 2 VIN Supply Voltage Input. 3 VOUT Shanghai Siproin Microelectronics Co. Description Output. V2.0 3 H75XX-2 Functional Description The H75XX-2 series is a set of three-terminal low power high voltage regulators implemented in CMOS technology. They allow input voltages as high as 35V. They are available with several fixed output voltages ranging from 3.0V to 5.0V. Absolute Maximum Ratings Parameter Symbol Value Unit Supply Voltage Input VIN -0.3~35 V Operating Temperature Tamb -40~85 ℃ Storage Temperature Tstg -50~125 ℃ Note: These are stress ratings only. Stresses exceeding the range specified under “Absolute Maximum Ratings” may cause substantial damage to the device. Functional operation of this device at other conditions beyond those listed in the specification is not implied and prolonged exposure to extreme conditions may affect device reliability. Thermal Information Parameter Thermal Resistance (Junction to Ambient) (Assume no ambient airflow, no heat sink) Power Dissipation Symbol θ JA PD Package Max. Unit SOT23-3 500 ℃/W SOT89 200 ℃/W TO92 200 ℃/W SOT23-3 0.20 W SOT89 0.50 W TO92 0.50 W Note: P D is measured at Ta= 25℃ Shanghai Siproin Microelectronics Co. V2.0 4 H75XX-2 Electrical Characteristics H7530-2,+3.0V Output Type Parameter Symbol Test Conditions V IN Conditions Min. Typ. Max. Unit Output Voltage V OUT 8V I OUT =10mA 2.940 3.000 3.060 V Output Current I OUT 6V - - 200 - mA Load Regulation ΔV OUT 8V 1mA≤I OUT ≤ 20mA - 40 60 mV Voltage Drop(Note) V DIF - - 10 - mV ISS 8V No load - 2.0 5.0 μA VOUT VIN  VOUT - 4V≤V IN ≤35V I OUT =1mA - 0.3 - %/V Input Voltage V IN - - - - 35 V Temperature Coefficient VOUT Ta 8V - ±0.12 - mV/℃ Current Consumption Line Regulation I OUT =1mA ΔV OUT =2% I OUT =10mA 0℃
H7533-2PR 价格&库存
很抱歉,暂时无法提供与“H7533-2PR”相匹配的价格&库存,您可以联系我们找货
H7533-2PR
  • 5+0.91887
  • 50+0.72825
  • 150+0.63299
  • 1000+0.53763
  • 2000+0.48050
  • 5000+0.45188
库存:896
