MUR460G
MUR460G
    ST(先科)
    DO-201AD
    整流二极管 Vrrm=600V IF=4A Trr=50ns Cj=36pF
MUR460G 数据手册
MUR460G-HAF Fast Recovery Rectifier Reverse Voltage – 600 V Forward Current – 4 A Features • Glass passivated die construction • Super fast recovery time for high efficiency • Low forward voltage drop and high current capability • Halogen and Antimony Free(HAF), RoHS compliant Mechanical Data • Case: Molded plastic, DO-201AD • Terminals: Solder plater terminal, solderable per MIL-STD-202, method 208 guaranteed • Polarity: Cathode Band • Mounting position: Any Absolute Maximum Ratings and Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20%. Symbols Units Value Parameter Maximum Recurrent Peak Reverse Voltage VRRM 600 V Maximum Working Peak Reverse Voltage VRWM 600 V VR 600 V VR(RMS) 424 V Maximum Average Forward Rectified Current at Ta = 55℃ IF(AV) 4 A Peak Forward Surge Current, 8.3 ms Single Half-sine-wave Superimposed on rated load (JEDEC method) Maximum Forward Voltage at IF = 3 A, Tj = 25℃ at IF = 4 A, Tj = 25℃ at IF = 3 A, Tj = 150℃ Ta = 25°Ϲ Maximum Reverse Current at Rated DC Blocking Voltage Ta = 150°Ϲ IFSM 70 A 1.25 1.28 1.05 10 250 V Maximum DC Blocking Voltage Maximum RMS Reverse Voltage VF IR µA Maximum Reverse Recovery Time 1) trr 50 ns Typical Junction Capacitance 2) CJ 36 pF RθJA 28 ℃/W TJ, TStg -65 to +175 ℃ Typical Thermal Resistance 3) Operating Junction and Storage Temperature Range 1) Measured with IF = 0.5 A, IR = 1.0 A, Irr = 0.25 A. 2) Measured at 1.0 MHz and applied reverse voltage of 4 V DC. 3) Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length,P.C.B. mounted. 1/3 ® Dated : 21/09/2022 SS&H Rev:02 MUR460G-HAF Electrical Characteristics Curves % 2/3 ® Dated : 21/09/2022 SS&H Rev:02 MUR460G-HAF Marking information " HF " = HAF (Halogen and Antimony Free) " MUR460G " = Part No. Font type: Arial MUR460GHF 3/3 ® Dated : 21/09/2022 SS&H Rev:02
MUR460G 价格&库存
很抱歉,暂时无法提供与“MUR460G”相匹配的价格&库存,您可以联系我们找货
