GBU25005-GBU2510
25A Single-Phase GLass Passivated Bridge Rectifiers
Recifiter Reverse Voltage 50V to 1000V
GBU
Features
●Glass passivated junction
●The plastic material used carries Underwriters Laboratory
flammability recognition 94V-0
●Suge overload ratings to 300amperes peak
●Ideal for printed circuit board application
●High temperature soldering guaranteed 265℃/10
Mechanical Data
Case:Molded plastic
Terminals:Platde leads solderable per MIL-STD-750,
Method 2026
Polarity:Polarity symbols molded or Marked on body
Mounting Position:Any
Weight:0.138ounce,3.9 grams(approx)
Dimensions in inches and (milimeters)
Maximum Ratings & Thermal Characteristics
Rating at 25℃ ambient temperature unless otherwise specified,Resistive or inductive load,60HZ.
For Capacitive load derate current by 20%
Parameter
Maximum repetitive peak reverse voltage
Maximum RMS bridge input voltage
Maximum DC blocking voltage
Maximum average forward rectified
output current at TA=40℃
Peak forward surge current single sine-wave
superimposed on rated load (JEDEC Method)
Maximum Forward Voltage at 5.0A DC
Maximum DC reverse current at ratde TA=25℃
DC blocking voltage per element TA=125℃
Typical thermal resistance per element(1)
Mounting torque(Suggests 045~0.65)
Typical thermal resistance per element(2)
Operating junction and stroage temperature
range
Symbol
GBU
25005
GBU
2501
GBU
2502
GBU
2504
GBU
2506
GBU
2508
GBU
2510
unit
VRRM
VRMS
VDC
50
35
50
100
70
100
200
140
200
400
280
400
25.0
4.2
600
420
600
800
560
800
1000
700
1000
V
V
V
IF(AV)
A
IFSM
300
A
VF
1.1
5
500
2.2
Rating Torque:0.8(Suggests 045~0.65)
70.0
V
℃/w
N.m
PF
-55to+150
IR
ReJA
Tor
Cj
TJ,
TSTG
UA
Notes:(1)Device mounted on 100mm*100mm*1.6mm Cu plate heatsink.
(2)Measured at 1.0MHz and applied reverse voltage of 4.0 volts.
ht t p : //
Revision:20170701-P1
www.lgesem i .c o m
mail:lge@lgesemi.com
GBU25005-GBU2510
Rating and Characteristic Curves(TA=25℃ Uniless otherwise noted)
FIG.2-MAXIMUM NON-REPETITIVE SUNRGE CURRENT
FIG.1-DERATING CURVE FOR
OUTPUT RECTIFIED CURRENT
350
10
5
GBU25
300
Peak Forward Surge
Current Amperes
BRIDGE OUTPUT
FULL WAVE RECTIFIED CURRENT
AVERAGE AMPERES
25
PULSE WIDTH 8.3ms
SINGLE HALF-SINEWAVE
(JEDEC METHOD)
250
200
150
100
SINGLE PHASE HALF WAVE 60Hz
RESISTIVE OR INDUCTIVE LOAD
50
50
2
150
5
1
2
50
NUMBER OF CYCLES AT 60Hz
100
AMBIENT TEMPERATURE ,°C
FIG.4-TYPICAL FORWARD CHARACTERISTICS
FIG.3-TYPICAL REVERSE
CHARACTERISTICS
100
INSTANTANEOUS FORWARD CURRENT,
INSTANTANCEOUS REVERSE CURRENT,
(u A)
100
100
10
1.0
TJ=25°C
0.1
0.01
TJ = 25°C
1.0
PULSE WIDTH
0.1
60
80
100 120
140
PERCENT OF RATED PEAK REVERSE VOLTAGE,(%)
ht t p : //
10
0.4
0.6
0.8
1.0
1.2
1.4
1.6 1.8
INSTANTANEOUS FORWARD VOLTAGE, VOLTS
www.lgesem i .c o m
很抱歉,暂时无法提供与“GBU2510”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.99160
- 10+2.36520
- 30+2.09520
- 250+1.69560
- 500+1.54440
- 1000+1.44720
