BAT46WS
BAT46WS
    ST(先科)
    SC-76
    肖特基二极管 Vrrm=100V If=200mA Pd=230mW
BAT46WS 数据手册
BAT46WS-HAF Small Signal Schottky Barrier Diode PINNING DESCRIPTION PIN Features • Low forward voltage drop • Surface mount device • Halogen and Antimony Free(HAF), RoHS compliant 1 Cathode 2 Anode 2 1 SO Description • High voltage schottky rectifier suited for SLIC protection during the card insertion operation Top View Marking Code: "SO" Simplified outline SC-76 and symbol Absolute Maximum Ratings (Ta = 25℃) Parameter Symbol Value Unit Repetitive Peak Reverse Voltage VRRM 100 V Average Forward Rectified Current IF(AV) 200 mA Non-Repetitive Peak Forward Surge Current (tp ˂ 10 ms) IFSM 750 mA Power Dissipation Ptot 230 mW RthJA 550 ℃/W Operating Junction Temperature Range TJ 150 ℃ Storage Temperature Range Tstg - 65 to + 150 ℃ Thermal Resistance Junction Ambient Characteristics at Ta = 25℃ Parameter Reverse Breakdown Voltage at IR = 100 µA Forward Voltage at IF = 0.1 mA at IF = 10 mA at IF = 250 mA Reverse Current at VR = 1.5 V at VR = 10 V at VR = 50 V at VR = 75 V at VR = 1.5 V, Tj = 75℃ at VR = 10 V, Tj = 75℃ at VR = 50 V, Tj = 75℃ at VR = 75 V, Tj = 75℃ Symbol Min. Typ. Max. Unit VBR 100 - - V - - 0.25 0.45 1 - 2.5 4 6 7 0.5 0.8 2 5 - - 10 6 - VF IR Total Capacitance at VR = 0 V, f = 1 MHz at VR = 1 V, f = 1 MHz CT 1/3 V µA pF ® Dated: 14/07/2021 Rev: 03 BAT46WS-HAF Electrical characteristics curves Fig 1. Reverse Characteristics Curve Reverse Current (µA) Forward Current (mA) Fig 2. Forward Characteristics Curve Reverse Voltage (V) Forward Voltage (V) Junction Capacitance (pF) Fig 3. Junction Capacitance Reverse Voltage (V) 2/3 ® Dated: 14/07/2021 Rev: 03 BAT46WS-HAF PACKAGE OUTLINE Plastic surface mounted package; 2 leads SC-76 A c HE A D E bp UNIT A bp C D E HE mm 1.10 0.80 0.40 0.25 0.15 0.10 1.80 1.60 1.35 1.15 2.80 2.30 Recommended Soldering Footprint Packing information Package SC-76 Tape Width (mm) 8 Pitch Reel Size Per Reel Packing Quantity mm inch mm inch 4 ± 0.1 0.157 ± 0.004 178 7 3,000 Marking information " III " = Cathode line " • " = HAF (Halogen and Antimony Free) " SO " = Part No. Font type: Arial . SO 3/3 ® Dated: 14/07/2021 Rev: 03
BAT46WS 价格&库存
很抱歉,暂时无法提供与“BAT46WS”相匹配的价格&库存,您可以联系我们找货
