SS10100
SS10100
    ST(先科)
    SMC(DO-214AB)
    肖特基二极管 Vrrm=100V If=10A Vf=850mV
SS10100 数据手册
SS10100-HAF Surface Mount Schottky Barrier Rectifier Reverse Voltage - 100 V Forward Current - 10 A PINNING PIN Features • Metal silicon junction, majority carrier conduction • For surface mounted applications • Low power loss, high efficiency • High forward surge current capability • For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications • Halogen and Antimony Free(HAF), RoHS compliant 1 DESCRIPTION Cathode 2 Anode 1 2 Top view Plastic Package : SMC(DO-214AB) Mechanical Data • Case: SMC(DO-214AB) • Terminals: Solderable per MIL-STD-750, Method 2026 Absolute Maximum Ratings and Characteristics Ratings at 25°Ϲ ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20%. Symbols Value Units Marking .S1010 - Maximum Repetitive Peak Reverse Voltage VRRM 100 V Maximum RMS Voltage VRMS 70 V Maximum DC Blocking Voltage VDC 100 V Maximum Average Forward Rectified Current IF(AV) 10 A Peak Forward Surge Current, 8.3 ms Single Half Sine Wave Superimposed on Rated Load (JEDEC Method) IFSM 175 A Maximum Forward Voltage at 10 A VF 0.85 V IR 0.05 10 mA RθJA 47 ℃/W Tj - 55 to + 150 ℃ Tstg - 55 to + 150 ℃ Parameter Maximum DC Reverse Current at Rated DC Blocking Voltage Typical Thermal Resistance Tj = 25℃ Tj = 100℃ 1) Operating Junction Temperature Range Storage Temperature Range 1) Thermal resistance from junction to ambient , PCB mounted. 1/3 ® Dated:17/08/2021 JD SZ Rev : 01 SS10100-HAF Electrical Characteristic Curves 2/3 ® Dated:17/08/2021 JD SZ Rev : 01 SS10100-HAF Package Outline Dimensions in inches (millimeters) SMC(DO-214AB) Marking information " S1010 " = Part No. " III " = Cathode line " • " = HAF (Halogen and Antimony Free) Font type: Arial . S1010 3/3 ® Dated:17/08/2021 JD SZ Rev : 01
SS10100 价格&库存
很抱歉,暂时无法提供与“SS10100”相匹配的价格&库存,您可以联系我们找货
