SB5200
SB5200
    ST(先科)
    DO-201AD
    肖特基二极管 Vrrm=200V If=5A Cj=120pF
SB5200 数据手册
SB5200-HAF Surface Mount Schottky Barrier Rectifier Reverse Voltage - 200 V Forward Current - 5 A Features • Plastic package has Underwriters Laboratory Flammability Classification 94V-0 • Guard ring for overvoltage protection • Low power loss, high efficiency • High current capability, low forward voltage drop • For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications • Halogen and Antimony Free(HAF), RoHS compliant Mechanical Data • Case: Molded plastic body, JEDEC DO-201AD. • Terminals: Axial leads, solderable per MIL-STD-750, method 2026 • Polarity: Color band denotes cathode end. • Mounting Position: Any Maximum Ratings and Electrical Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20%. Symbols Value Unit Marking SB5200HF - Maximum Repetitive Peak Reverse Voltage VRRM 200 V Maximum RMS Voltage VRMS 140 V Maximum DC Blocking Voltage VDC 200 V Maximum Average Forward Rectified Current IF(AV) 5 A Peak Forward Surge Current 8.3 ms Half Sine-wave Superimposed on Rated Load (JEDEC method) IFSM 120 A VF 0.85 V IR 0.1 1 mA Cj 120 pF Typical Thermal Resistance 2) RθJA 10 ℃/W 2) RθJC 2 ℃/W Tj - 55 to + 150 ℃ Tstg - 55 to + 150 ℃ Parameter Maximum Instantaneous Forward Voltage at 5 A Maximum DC Reverse Current at Rated DC Blocking Voltage Ta = 25℃ Ta = 100℃ Typical Junction Capacitance 1) Typical Thermal Resistance Operating Junction Temperature Range Storage Temperature Range 1) Measured at 1MHz and applied reverse voltage of 4 V D.C. 2) Thermal Resistance from Junction to lead vertical P.C.B, mounted with 0.375”(9.5mm) lead length 1/2 ® Dated: 02/12/2020 TL Rev : 03 SB5200-HAF 2/2 ® Dated: 02/12/2020 TL Rev : 03
SB5200 价格&库存
很抱歉,暂时无法提供与“SB5200”相匹配的价格&库存,您可以联系我们找货
