BAS16
BAS16
    ST(先科)
    SOT-23-3
    开关二极管(小信号)Vr=80V If=215mA Pd=350mW Trr=4ns
BAS16 数据手册
BAS16-HAF Silicon Epitaxial Planar Switching Diode Features • Small package 3 • Low forward voltage • Fast reverse recovery time • Small total capacitance • Halogen and Antimony Free(HAF), RoHS compliant 1 2 1. Anode 2. NC 3. Cathode TO-236 Plastic Package Applications • Ultra high speed switching application Absolute Maximum Ratings (Ta = 25 OC) Parameter Symbol Value Unit VRRM 100 V Continuous Reverse Voltage VR 80 V Continuous Forward Current IF 215 mA IFRM 500 mA IFSM 4 1 0.5 A Ptot 350 mW Tj 150 O C Tstg - 55 to + 150 O C Symbol Max. Unit RθJA 357 /W Repetitive Peak Reverse Voltage Repetitive Peak Forward Current Non-Repetitive Peak Forward Surge Current t = 1 µs t = 1 ms t=1s Power Dissipation Junction Temperature Storage Temperature Range Thermal Characteristics Parameter Thermal Resistance from Junction to Ambient 1) 1) Device mounted on FR-4 PCB with minimum recommended pad layout. ® 1/4 Dated: 18/11/2021 Rev: 04 BAS16-HAF Characteristics at Ta = 25 OC Parameter Symbol Min. Max. Unit Forward Voltage at IF = 1 mA at IF = 10 mA at IF = 50 mA at IF = 150 mA VF VF VF VF - 715 855 1 1.25 mV mV V V Reverse Current at VR = 25 V at VR = 80V at VR = 25 V, TJ = 150 OC at VR = 80 V, TJ = 150 OC IR IR IR IR - 30 0.5 30 50 nA µA µA µA V(BR)R 75 - V Cd - 2 pF trr - 4 ns Reverse Breakdown Voltage at IR = 100 µA Diode Capacitance at VR = 0 V, f = 1 MHz Reverse Recovery Time at IF = 10 mA, Irr = 0.1 x IR, VR = 6 V, RL = 100 Ω ® 2/4 Dated: 18/11/2021 Rev: 04 BAS16-HAF Electrical Characteristics Curves Fig 1. Power Derating Curve Fig 2. Capacitance Characteristics Fig 3. Reverse Characteristics Fig 4. Forward Characteristics IF, Forward Current (mA) TJ=150 TJ=125 TJ=100 TJ=75 TJ=25 TJ=-40 TJ=0 VF, Forward Voltage (V) ® 3/4 Dated: 18/11/2021 Rev: 04 BAS16-HAF Package Outline (Dimensions in mm) Unit mm A 1.20 0.89 A1 0.100 0.013 B 1.40 1.20 C 0.19 0.08 TO-236 D 3.04 2.80 E 2.6 2.2 F 1.02 0.89 G 2.04 1.78 L 0.51 0.37 L1 0.2 MIN Recommended Soldering Footprint 2.0 1.0 0.8 1.0 0.8 1.9 Packing information Pitch Reel Size Package Tape Width (mm) mm inch mm inch TO-236 8 4 ± 0.1 0.157 ± 0.004 178 7 Per Reel Packing Quantity 3,000 Marking information " 5D " = Part No. " • " = HAF (Halogen and Antimony Free) "YM" = Date Code Marking "Y" = Year • "M" = Month 5D Font type: Arial ® 4/4 Dated: 18/11/2021 Rev: 04
BAS16 价格&库存
很抱歉,暂时无法提供与“BAS16”相匹配的价格&库存,您可以联系我们找货
BAS16
  • 20+0.14580
  • 200+0.11319
  • 600+0.09515
  • 3000+0.08608
库存:2790
