1N4448WT-HAF
Silicon Epitaxial Planar Switching Diode
PINNING
Fast Switching Diode
DESCRIPTION
PIN
1
Cathode
2
Anode
Features
• Halogen and Antimony Free(HAF), RoHS compliant
2
1
A
Top View
Marking Code: "A"
Simplified outline SOD-523 and symbol
Absolute Maximum Ratings (Ta = 25 OC)
Parameter
Symbol
Value
Unit
Peak Reverse Voltage
VRM
100
V
Reverse Voltage
VR
80
V
IF(AV)
125
mA
IFM
250
mA
IFSM
0.5
1
4
A
Power Dissipation
Pd
150
mW
Junction Temperature
Tj
150
O
C
Tstg
- 65 to + 150
O
C
Symbol
Max.
Unit
RθJA
833
/W
Average Rectified Forward Current
Forward Continuous Current
Non-repetitive Peak Forward Surge Current
at t = 1 s
at t = 1 ms
at t = 1 μs
Storage Temperature Range
Thermal Characteristics
Parameter
Thermal Resistance from Junction to Ambient 1)
1)
Device mounted on FR-4 substrate PC board, 2oz copper, with minimum recommended pad layout.
1/4
Dated:23/12/2021 Rev:02
1N4448WT-HAF
Characteristics at Ta = 25 OC
Parameter
Reverse Breakdown Voltage
at IR = 100 µA
Forward Voltage
at IF = 5 mA
at IF = 10 mA
at IF = 100 mA
at IF = 150 mA
Symbol
Min.
Max.
Unit
V(BR)R
80
V
VF
0.62
0.72
0.855
1
1.25
V
100
25
50
30
nA
nA
µA
µA
Reverse Leakage Current
at VR = 80 V
at VR = 20 V
at VR = 75 V, TJ = 150 OC
at VR = 25 V, TJ = 150 OC
IR
Capacitance
at VR = 0.5 V, f = 1 MHz
Ctot
4
pF
trr
4
ns
Reverse Recovery Time
at IF = 10 mA, Irr = 0.1 X IR , VR = 6 V, RL = 100 Ω
2/4
1N4448WT-HAF
Electrical Characteristics Curves
Fig 2. Capacitance characteristics
Cj,Junction Capacitance(pF)
Fig 1. Power Derating Curve
VR, Reverse Voltage (V)
Fig 4. Forward Characteristics
IF, Forward Current (mA)
Fig 3. Reverse Characteristics
VF, Forward Voltage (V)
3/4
1N4448WT-HAF
PACKAGE OUTLINE
Plastic surface mounted package
SOD-523
ALL ROUND
C
A
HE
D
bp
E
A
UNIT
A
bp
C
D
E
HE
V
mm
0.70
0.60
0.4
0.3
0.135
0.100
1.25
1.15
0.85
0.75
1.7
1.5
0.1
5
O
Recommended Soldering Footprint
1.7
0.6
0.8
Packing information
Pitch
Reel Size
Package
Tape Width
(mm)
mm
inch
mm
inch
SOD-523
8
4 ± 0.1
0.157 ± 0.004
178
7
Per Reel Packing Quantity
4,000
Marking information
" • "= HAF (Halogen and Antimony Free(HAF)
.A
" A " = Part No.
" III " = Cathode line
Font type: Arial
4/4
很抱歉,暂时无法提供与“1N4448WT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.15196
- 500+0.12539
- 1500+0.11060
- 4000+0.10174
- 24000+0.09407
- 48000+0.08986
