SD103AWT
SD103AWT
    ST(先科)
    SOD-523(SC-79)
    肖特基二极管 Vrrm=40V Vr=40V If=350mA Pd=200mW
SD103AWT 数据手册
SD103AWT-HAF Surface Mount Schottky Barrier Diode PINNING DESCRIPTION PIN Features • Low forward voltage • Halogen and Antimony Free(HAF), RoHS compliant 1 Cathode 2 Anode 2 1 SJ Top View Marking Code : SJ Simplified outline SOD-523 and symbol Absolute Maximum Ratings (Ta = 25℃) Parameter Symbol Value Unit VRRM 40 V VR 40 V Average Forward Rectified Current IF(AV) 350 mA Non-Repetitive Peak Forward Surge Current at t = 1 s IFSM 2 A Power Dissipation Ptot 200 mW Tj, Tstg - 65 to + 125 ℃ Peak Repetitive Reverse Voltage Reverse Voltage Operating and Storage Temperature Range Characteristics at Ta = 25℃ Parameter Reverse Breakdown Voltage at IR = 10 µA Reverse Leakage Current at VR = 30 V Forward Voltage at IF = 20 mA at IF = 200 mA Total Capacitance at VR = 0 V, f = 1 MHz Reverse Recovery Time at IF = IR = 200 mA, Irr = 0.1 IR, RL = 100 Ω 1/3 Symbol Min. Typ. Max. Unit V(BR)R 40 - - V IR - - 5 µA VF - - 0.37 0.6 V CT - 50 - pF trr - 10 - ns ® Dated: 27/10/2020 Rev : 01 SD103AWT-HAF Electrical Characteristics Curves Fig 1. Power Derating Curve Fig 2. Forward Characteristics Fig 3. Typical Capacitance vs. Reverse Voltage Fig 4. Reverse Current vs. Reverse Voltage 2/3 ® Dated: 27/10/2020 Rev : 01 SD103AWT-HAF PACKAGE OUTLINE Plastic surface mounted package; 2 leads SOD-523 ALL ROUND C A ∠ HE D bp E A UNIT A bp C D E HE V mm 0.70 0.60 0.4 0.3 0.135 0.100 1.25 1.15 0.85 0.75 1.7 1.5 0.1 ∠ 5 O Recommended Soldering Footprint 1.7 0.6 0.8 Packing information Package SOD-523 Pitch Tape Width Reel Size (mm) mm inch mm inch 8 4 ± 0.1 0.157 ± 0.004 178 7 Per Reel Packing Quantity 4,000 Marking information " • "= HAF (Halogen and Antimony Free(HAF) " SJ " = Part No. " III " = Cathode line Font type: Arial • SJ 3/3 ® Dated: 27/10/2020 Rev : 01
SD103AWT 价格&库存
很抱歉,暂时无法提供与“SD103AWT”相匹配的价格&库存,您可以联系我们找货
